=========================== USB Port2 =========================== Connection Status : 0x01 (Device is connected) Port Chain : 2-2 Properties : 0x01 IsUserConnectable : yes PortIsDebugCapable : no PortHasMultiCompanions : no PortConnectorIsTypeC : no ConnectionIndex : 0x02 (Port 2) CompanionIndex : 0 CompanionHubSymLnk : USB#ROOT_HUB30#5&2dabee3f&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} CompanionPortNumber : 0x06 (Port 6) -> CompanionPortChain : 2-6 ========================== Summary ========================= Vendor ID : 0x2341 (Arduino SA) Product ID : 0x0042 USB Version : 1.1 Port maximum Speed : High-Speed (Companion Port 2-6 is doing the SuperSpeed) Device maximum Speed : Full-Speed Device Connection Speed : Full-Speed Self powered : yes Demanded Current : 100 mA Used Endpoints : 4 ======================== USB Device ======================== +++++++++++++++++ Device Information ++++++++++++++++++ Friendly Name : Arduino Mega 2560 (COM3) Device Description : Arduino Mega 2560 Device ID : USB\VID_2341&PID_0042\95032303937351E03221 Hardware IDs : USB\VID_2341&PID_0042&REV_0001 USB\VID_2341&PID_0042 Driver KeyName : {4d36e978-e325-11ce-bfc1-08002be10318}\0000 (GUID_DEVCLASS_PORTS) Driver : \SystemRoot\System32\drivers\usbser.sys (Version: 10.0.19041.3636 Date: 2023-11-15 Company: Microsoft Corporation) Driver Inf : C:\Windows\inf\oem135.inf Legacy BusType : PNPBus Class : Ports Class GUID : {4d36e978-e325-11ce-bfc1-08002be10318} (GUID_DEVCLASS_PORTS) Service : usbser Enumerator : USB Location Info : Port_#0002.Hub_#0004 Address : 2 Location IDs : PCIROOT(0)#PCI(0801)#PCI(0004)#USBROOT(0)#USB(2), ACPI(_SB_)#ACPI(PCI0)#ACPI(GP17)#ACPI(XHC1)#ACPI(RHUB)#ACPI(HS02) Container ID : {65ce48a4-330b-5ec5-a638-2ce24682aa8d} Manufacturer Info : Arduino LLC (www.arduino.cc) Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK) Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER) Problem Code : 0 Power State : D0 (supported: D0, D3, wake from D0) COM-Port : COM3 (\Device\USBSER000) ---------------- Connection Information --------------- Connection Index : 0x02 (Port 2) Connection Status : 0x01 (DeviceConnected) Current Config Value : 0x01 (Configuration 1) Device Address : 0x03 (3) Is Hub : 0x00 (no) Device Bus Speed : 0x01 (Full-Speed) Number of open Pipes : 0x03 (3 pipes to data endpoints) Pipe[0] : EndpointID=2 Direction=IN ScheduleOffset=0 Type=Interrupt wMaxPacketSize=0x8 bInterval=255 -> 196 Bits/ms = 24500 Bytes/s Pipe[1] : EndpointID=4 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=0x40 bInterval=1 Pipe[2] : EndpointID=3 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=0x40 bInterval=1 Data (HexDump) : 02 00 00 00 12 01 10 01 02 00 00 08 41 23 42 00 ............A#B. 01 00 01 02 DC 01 01 01 00 03 00 03 00 00 00 01 ................ 00 00 00 07 05 82 03 08 00 FF 00 00 00 00 07 05 ................ 04 02 40 00 01 00 00 00 00 07 05 83 02 40 00 01 ..@..........@.. 00 00 00 00 .... --------------- Connection Information V2 ------------- Connection Index : 0x02 (2) Length : 0x10 (16 bytes) SupportedUsbProtocols : 0x03 Usb110 : 1 (yes, port supports USB 1.1) Usb200 : 1 (yes, port supports USB 2.0) Usb300 : 0 (no, port not supports USB 3.0) -> but Companion Port 2-6 does ReservedMBZ : 0x00 Flags : 0x00 DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher) DevIsSsCapOrHigher : 0 (Device is not SuperSpeed capable or higher) DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher) DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher) ReservedMBZ : 0x00 Data (HexDump) : 02 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00 ................ ---------------------- Device Descriptor ---------------------- bLength : 0x12 (18 bytes) bDescriptorType : 0x01 (Device Descriptor) bcdUSB : 0x110 (USB Version 1.1) bDeviceClass : 0x02 (Communications and CDC Control) bDeviceSubClass : 0x00 bDeviceProtocol : 0x00 (No class specific protocol required) bMaxPacketSize0 : 0x08 (8 bytes) idVendor : 0x2341 (Arduino SA) idProduct : 0x0042 bcdDevice : 0x0001 iManufacturer : 0x01 (String Descriptor 1) Language 0x0409 : "Arduino (www.arduino.cc)" iProduct : 0x02 (String Descriptor 2) *!*ERROR String descriptor not found iSerialNumber : 0xDC (String Descriptor 220) Language 0x0409 : "95032303937351E03221" bNumConfigurations : 0x01 (1 Configuration) Data (HexDump) : 12 01 10 01 02 00 00 08 41 23 42 00 01 00 01 02 ........A#B..... DC 01 .. ------------------ Configuration Descriptor ------------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x02 (Configuration Descriptor) wTotalLength : 0x003E (62 bytes) bNumInterfaces : 0x02 (2 Interfaces) bConfigurationValue : 0x01 (Configuration 1) iConfiguration : 0x00 (No String Descriptor) bmAttributes : 0xC0 D7: Reserved, set 1 : 0x01 D6: Self Powered : 0x01 (yes) D5: Remote Wakeup : 0x00 (no) D4..0: Reserved, set 0 : 0x00 MaxPower : 0x32 (100 mA) Data (HexDump) : 09 02 3E 00 02 01 00 C0 32 09 04 00 00 01 02 02 ..>.....2....... 01 00 05 24 00 01 10 04 24 02 06 05 24 06 00 01 ...$....$...$... 07 05 82 03 08 00 FF 09 04 01 00 02 0A 00 00 00 ................ 07 05 04 02 40 00 01 07 05 83 02 40 00 01 ....@......@.. ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x00 (Interface 0) bAlternateSetting : 0x00 bNumEndpoints : 0x01 (1 Endpoint) bInterfaceClass : 0x02 (Communications and CDC Control) bInterfaceSubClass : 0x02 (Abstract Control Model) bInterfaceProtocol : 0x01 (AT Commands defined by ITU-T V.250 etc) iInterface : 0x00 (No String Descriptor) Data (HexDump) : 09 04 00 00 01 02 02 01 00 ......... -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x00 (Header Functional Descriptor) bcdCDC : 0x1001 (CDC Version 10.01) Data (HexDump) : 05 24 00 01 10 .$... -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x04 (4 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x02 (Abstract Control Management Functional Descriptor) bmCapabilities : 0x06 D7..4 : 0x00 (Reserved) D3 : 0x00 (not supports the notification Network_Connection) D2 : 0x01 (supports the request Send_Break) D1 : 0x01 (supports the request combination of Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State) D0 : 0x00 (not supports the request combination of Set_Comm_Feature, Clear_Comm_Feature, and Get_Comm_Feature) Data (HexDump) : 04 24 02 06 .$.. -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x06 (Union Functional Descriptor) bControlInterface : 0x00 bSubordinateInterface[0] : 0x01 Data (HexDump) : 05 24 06 00 01 .$... ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x82 (Direction=IN EndpointID=2) bmAttributes : 0x03 (TransferType=Interrupt) wMaxPacketSize : 0x0008 (8 bytes) bInterval : 0xFF (255 ms) Data (HexDump) : 07 05 82 03 08 00 FF ....... ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x01 (Interface 1) bAlternateSetting : 0x00 bNumEndpoints : 0x02 (2 Endpoints) bInterfaceClass : 0x0A (CDC-Data) bInterfaceSubClass : 0x00 bInterfaceProtocol : 0x00 iInterface : 0x00 (No String Descriptor) Data (HexDump) : 09 04 01 00 02 0A 00 00 00 ......... ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x04 (Direction=OUT EndpointID=4) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x0040 (64 bytes) bInterval : 0x01 (ignored) Data (HexDump) : 07 05 04 02 40 00 01 ....@.. ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x83 (Direction=IN EndpointID=3) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x0040 (64 bytes) bInterval : 0x01 (ignored) Data (HexDump) : 07 05 83 02 40 00 01 ....@.. -------------------- String Descriptors ------------------- ------ String Descriptor 0 ------ bLength : 0x04 (4 bytes) bDescriptorType : 0x03 (String Descriptor) Language ID[0] : 0x0409 (English - United States) Data (HexDump) : 04 03 09 04 .... ------ String Descriptor 1 ------ bLength : 0x32 (50 bytes) bDescriptorType : 0x03 (String Descriptor) Language 0x0409 : "Arduino (www.arduino.cc)" Data (HexDump) : 32 03 41 00 72 00 64 00 75 00 69 00 6E 00 6F 00 2.A.r.d.u.i.n.o. 20 00 28 00 77 00 77 00 77 00 2E 00 61 00 72 00 .(.w.w.w...a.r. 64 00 75 00 69 00 6E 00 6F 00 2E 00 63 00 63 00 d.u.i.n.o...c.c. 29 00 ). ----- String Descriptor 0xDC ----- bLength : 0x2A (42 bytes) bDescriptorType : 0x03 (String Descriptor) Language 0x0409 : "95032303937351E03221" Data (HexDump) : 2A 03 39 00 35 00 30 00 33 00 32 00 33 00 30 00 *.9.5.0.3.2.3.0. 33 00 39 00 33 00 37 00 33 00 35 00 31 00 45 00 3.9.3.7.3.5.1.E. 30 00 33 00 32 00 32 00 31 00 0.3.2.2.1.
