.include "m32def.inc" ;ein ATMEGA32 steckt im Sockel .def temp1 = r21 ;Register mit dem Daten oder Befehlsbyte .def temp3 = r20 ;Hilfsregister von dem subtrahiert wird .CSEG .org 0 rjmp RESET ;****************************************************************************** ; data tables ;****************************************************************************** ; force table to begin at 256 byte boundary .org 0x100 sine: ; 256 step sinewave table .DB 64,65,67,68,70,72,73,75 .DB 76,78,79,81,82,84,85,87 .DB 88,90,91,92,94,95,97,98 .DB 99,100,102,103,104,105,107,108 .DB 109,110,111,112,113,114,115,116 .DB 117,118,118,119,120,121,121,122 .DB 123,123,124,124,125,125,126,126 .DB 126,127,127,127,127,127,127,127 .DB 128,127,127,127,127,127,127,127 .DB 126,126,126,125,125,124,124,123 .DB 123,122,121,121,120,119,118,118 .DB 117,116,115,114,113,112,111,110 .DB 109,108,107,105,104,103,102,100 .DB 99,98,97,95,94,92,91,90 .DB 88,87,85,84,82,81,79,78 .DB 76,75,73,72,70,68,67,65 .DB 64,62,61,59,58,56,54,53 .DB 51,50,48,47,45,44,42,41 .DB 39,38,36,35,34,32,31,30 .DB 28,27,26,25,23,22,21,20 .DB 19,18,17,15,14,13,13,12 .DB 11,10,9,8,8,7,6,5 .DB 5,4,4,3,3,2,2,2 .DB 1,1,1,0,0,0,0,0 .DB 0,0,0,0,0,0,1,1 .DB 1,2,2,2,3,3,4,4 .DB 5,5,6,7,8,8,9,10 .DB 11,12,13,13,14,15,17,18 .DB 19,20,21,22,23,25,26,27 .DB 28,30,31,32,34,35,36,38 .DB 39,41,42,44,45,47,48,50 .DB 51,53,54,56,58,59,61,62 ; ; ; ; Output frequency (using 24 bit accumulator) : ; ; f = deltaPhase * fClock/2^24 ; ; fClock is in this case the CPU clock divided by the ; number of cycles to output the data ( 9 cycles ) ; ; f = r24/r25/r26 * (11059200/9)/16777216 ; ; f = r24/r25/r26 * 0.073242188 ; ; fMax (theoretical) = 0.5 * fClock ; ;*** Initialisierung Stack reset: ldi temp1,HIGH(RAMEND) out SPH,temp1 ldi temp1,LOW(RAMEND) ;Stack ans Speicherende legen out SPL,temp1 ldi temp1,0xFF ;PortC Ausgabe out DDRC,temp1 ldi temp1,0xFF ;PortC Ausgabe out DDRA,temp1 sbi PORTA,6 rcall pause250ms rcall pause250ms rcall pause250ms rcall pause250ms cbi PORTA,6 ; set sinewave output as default ldi r31,HIGH(sine*2); setup Z pointer hi ldi r30,LOW(sine*2) ; setup Z pointer lo ; clear accumulator ldi r29,0x00 ; clear accumulator ldi r28,0x00 ; clear accumulator ; setup adder registers ldi r24,0x55 ; setup adder value ldi r25,0x35 ; to 1 kHz ldi r26,0x00 ; main loop ; ; r28,r29,r30 is the phase accumulator ; r24,r25,r26 is the adder value determining frequency ; ; add value to accumulator ; load byte from current table in ROM ; output byte to port ; repeat ; LOOPX: add r28,r24 ; 1 adc r29,r25 ; 1 adc r30,r26 ; 1 lpm ; 3 out PORTC,r0 ; 1 ;cbi PORTC,7 ; 2 rjmp LOOPX ; 2 => 11 cycles ;********************* ;*** 250ms - Pause *** ;********************* pause250ms: push r16 push r17 push r18 ldi r18, 107 pause250000us0: ldi r17, 178 pause250000us1: ldi r16, 69 pause250000us2: subi r16, 1 brne pause250000us2 subi r17, 1 brne pause250000us1 subi r18, 1 brne pause250000us0 pop r18 pop r17 pop r16 ret
