Dim Kalman_dt as Single Dim Kalman_gyro_sensor as Single Dim Kalman_adxl_sensor as Single Dim Neigungswinkel as Integer Dim Buf_Ad_gyro as Integer Dim Buf_Ad_adxl as Integer Dim Ad_gyro as Integer Dim Ad_adxl as Integer Sub main() 'Init init_Gyro1DKalman(0.0001, 0.0003, 0.3) 'Kalman Filter Kalman_dt = 0.0157 'time passed in s since last call 'Auszug.. etc.. 'Kanal setzen Gyro_zero = ADC_Read() 'Kanal setzen Adxl_zero = ADC_Read() 'main loop Do While True 'Endlosschleife 'Auszug.. etc.. 'Kanal setzen Ad_gyro = ADC_Read() 'Kanal setzen Ad_adxl = ADC_Read() Buf_Ad_gyro = Ad_gyro - Gyro_zero Buf_Ad_adxl = Ad_adxl - Adxl_zero Kalman_gyro_sensor = Buf_Ad_gyro * 1.4634135 ' /1025*3.0V/0.002 Kalman_adxl_sensor = Buf_ad_adxl * 1.5139 ' /1025*3.0V/0.0019333 0,348V for 180° = 1,9333mV per ° Neigungswinkel = Kalman_Filter_Auswertung(Kalman_gyro_sensor, Kalman_adxl_sensor, Kalman_dt) End While End Sub '############################################################################# '######################## Kalman Filter - Datei ############################## 'struct Gyro1DKalman '* These variables represent our state matrix x Dim Gyro1DKalman_x_angle As Single Dim Gyro1DKalman_x_bias As Single '* Our error covariance matrix Dim Gyro1DKalman_P_00 As Single Dim Gyro1DKalman_P_01 As Single Dim Gyro1DKalman_P_10 As Single Dim Gyro1DKaalman_P_11 As Single '* Q is a 2x2 matrix of the covariance. Because we '* assuma the gyro and accelero noise to be independend '* of eachother, the covariances on the / diagonal are 0. '* '* Covariance Q, the process noise, from the assumption '* x = F x + B u + w '* with w having a normal distribution with covariance Q. '* (covariance = E[ (X - E[X])*(X - E[X])' ] '* We assume is linair with dt Dim Gyro1DKalman_Q_angle As Single Dim Gyro1DKalman_Q_gyro As Single '* Covariance R, our observation noise (from the accelerometer) '* Also assumed to be linair with dt Dim Gyro1DKalman_R_angle As Single 'End Structure '####################################################################### '*********************************************************************** '* * '* This file contains the code for the kalman filter that uses the * '* sensor data as inputs. * '* * '*********************************************************************** '* * '* Author: Tom Pycke * '* Filename: ars.c * '* Date: 17/10/2007 * '* File Version: 1.00 * '* * '*********************************************************************** '* * '* Comments: * '* To help others to understand the kalman filter, I used one of * '* the most accessible sources with information on it: * '* http://en.wikipedia.org/wiki/Kalman_filter * '* The code is split into 2 parts: a Predict function and an * '* Update function, just as the wikipedia page does. * '* The model I used in the kalman filter is the following: * '* Our gyroscope measures the turnrate in degrees per second. This * '* is the derivative of the angle, called dotAngle. The bias is the * '* output of our gyro when the rotationrate is 0 degrees per second * '* (not rotating). Because of drift it changes over time. * '* So mathematically we just integrate the gyro (dt is timespan * '* since last integration): * '* angle = angle + (dotAngle - bias) * dt * '* When we include the bias in our model, the kalman filter will * '* try to estimate the bias, thanks to our last input: the measured * '* angle. This is just an estimate and comes from the accelerometer. * '* So the state used in our filter had 2 dimensions: [ angle, bias ] * '* Jump to the functions to read more about the actual * '* implementation. * '* * '*********************************************************************** Sub init_Gyro1DKalman( ByVal Q_angle As Single, ByVal Q_gyro As Single, ByVal R_angle As Single) Gyro1DKalman_Q_angle = Q_angle Gyro1DKalman_Q_gyro = Q_gyro Gyro1DKalman_R_angle = R_angle End Sub '* The predict function. Updates 2 variables: '* our model-state x and the 2x2 matrix P '* '* x = [ angle, bias ]' '* '* = F x + B u '* '* = [ 1 -dt, 0 1 ] [ angle, bias ] + [ dt, 0 ] [ dotAngle 0 ] '* '* => angle = angle + dt (dotAngle - bias) '* bias = bias '* '* '* P = F P transpose(F) + Q '* '* = [ 1 -dt, 0 1 ] * P * [ 1 0, -dt 1 ] + Q '* '* P(0,0) = P(0,0) - dt * ( P(1,0) + P(0,1) ) + dt˛ * P(1,1) + Q(0,0) '* P(0,1) = P(0,1) - dt * P(1,1) + Q(0,1) '* P(1,0) = P(1,0) - dt * P(1,1) + Q(1,0) '* P(1,1) = P(1,1) + Q(1,1) '* Sub ars_predict( ByVal dotAngle As Single, ByVal dt As Single) Gyro1DKalman_x_angle = Gyro1DKalman_x_angle + (dt * (dotAngle - Gyro1DKalman_x_bias)) Gyro1DKalman_P_00 = Gyro1DKalman_P_00 + (-dt * (Gyro1DKalman_P_10 + Gyro1DKalman_P_01) + Gyro1DKalman_Q_angle * dt) Gyro1DKalman_P_01 = Gyro1DKalman_P_01 + (-dt * Gyro1DKalman_P_11) Gyro1DKalman_P_10 = Gyro1DKalman_P_10 + (-dt * Gyro1DKalman_P_11) Gyro1DKalman_P_11 = Gyro1DKalman_P_11 + (+Gyro1DKalman_Q_gyro * dt) End Sub '* The update function updates our model using '* the information from a 2nd measurement. '* Input angle_m is the angle measured by the accelerometer. '* '* y = z - H x '* '* S = H P transpose(H) + R '* = [ 1 0 ] P [ 1, 0 ] + R '* = P(0,0) + R '* '* K = P transpose(H) S^-1 '* = [ P(0,0), P(1,0) ] / S '* '* x = x + K y '* '* P = (I - K H) P '* '* = ( [ 1 0, [ K(0), '* 0 1 ] - K(1) ] * [ 1 0 ] ) P '* '* = [ P(0,0)-P(0,0)*K(0) P(0,1)-P(0,1)*K(0), '* P(1,0)-P(0,0)*K(1) P(1,1)-P(0,1)*K(1) ] '* ' Gyro1DKalman *Gyro1DKalman Sub ars_update( ByVal angle_m As Single) As Single Dim y As Single Dim S As Single Dim K_0 As Single Dim K_1 As Single y = angle_m - Gyro1DKalman_x_angle S = Gyro1DKalman_P_00 + Gyro1DKalman_R_angle K_0 = Gyro1DKalman_P_00 / S K_1 = Gyro1DKalman_P_10 / S Gyro1DKalman_x_angle = Gyro1DKalman_x_angle + (K_0 * y) Gyro1DKalman_x_bias = Gyro1DKalman_x_bias + (K_1 * y) Gyro1DKalman_P_00 = Gyro1DKalman_P_00 - (K_0 * Gyro1DKalman_P_00) Gyro1DKalman_P_01 = Gyro1DKalman_P_01 - (K_0 * Gyro1DKalman_P_01) Gyro1DKalman_P_10 = Gyro1DKalman_P_10 - (K_1 * Gyro1DKalman_P_00) Gyro1DKalman_P_11 = Gyro1DKalman_P_11 - (K_1 * Gyro1DKalman_P_01) Return Gyro1DKalman_x_angle End Sub Sub Kalman_Filter_Auswertung(gyro As Single, adxl As Single, dt As Single) As Single '----------------Kalman Filter---------------------------------- 'ars_predict(Kalman_gyro_sensor, Kalman_dt) 'Kalman predict 'Neigungswinkel_Filter = ars_update(Kalman_adxl_sensor) '--------------------------------------------------------------- Dim Wert As Single ars_predict(gyro, dt) 'Kalman predict Wert = ars_update(adxl) Return Wert End Sub
