Bus 007 Device 007: ID 21a4:ac40 Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x21a4 idProduct 0xac40 bcdDevice 3.00 iManufacturer 1 Licensed by Nintendo of America iProduct 2 EA SPORTS Active(tm) (c) 2010 Electronic Arts Inc. iSerial 3 00974041 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 34 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 3 Human Interface Device bInterfaceSubClass 0 No Subclass bInterfaceProtocol 0 None iInterface 0 HID Device Descriptor: bLength 9 bDescriptorType 33 bcdHID 1.11 bCountryCode 0 Not supported bNumDescriptors 1 bDescriptorType 34 Report wDescriptorLength 100 Report Descriptor: (length is 100) Item(Global): Usage Page, data= [ 0x01 ] 1 Generic Desktop Controls Item(Local ): Usage, data= [ 0xff ] 255 (null) Item(Main ): Collection, data= [ 0x01 ] 1 Application Item(Global): Usage Page, data= [ 0x00 0xff ] 65280 (null) Item(Global): Logical Minimum, data= [ 0x00 ] 0 Item(Global): Logical Maximum, data= [ 0xff 0x00 ] 255 Item(Global): Physical Minimum, data= [ 0x00 ] 0 Item(Global): Physical Maximum, data= [ 0xff 0x00 ] 255 Item(Local ): Usage, data= [ 0x20 ] 32 (null) Item(Local ): Usage, data= [ 0x21 ] 33 (null) Item(Local ): Usage, data= [ 0x22 ] 34 (null) Item(Local ): Usage, data= [ 0x23 ] 35 (null) Item(Local ): Usage, data= [ 0x24 ] 36 (null) Item(Local ): Usage, data= [ 0x25 ] 37 (null) Item(Local ): Usage, data= [ 0x26 ] 38 (null) Item(Local ): Usage, data= [ 0x27 ] 39 (null) Item(Local ): Usage, data= [ 0x28 ] 40 (null) Item(Local ): Usage, data= [ 0x29 ] 41 (null) Item(Local ): Usage, data= [ 0x2a ] 42 (null) Item(Local ): Usage, data= [ 0x2b ] 43 (null) Item(Local ): Usage, data= [ 0x2c ] 44 (null) Item(Local ): Usage, data= [ 0x2d ] 45 (null) Item(Local ): Usage, data= [ 0x2e ] 46 (null) Item(Local ): Usage, data= [ 0x2f ] 47 (null) Item(Local ): Usage, data= [ 0x30 ] 48 (null) Item(Local ): Usage, data= [ 0x31 ] 49 (null) Item(Local ): Usage, data= [ 0x32 ] 50 (null) Item(Local ): Usage, data= [ 0x33 ] 51 (null) Item(Local ): Usage, data= [ 0x34 ] 52 (null) Item(Local ): Usage, data= [ 0x35 ] 53 (null) Item(Local ): Usage, data= [ 0x36 ] 54 (null) Item(Local ): Usage, data= [ 0x37 ] 55 (null) Item(Local ): Usage, data= [ 0x38 ] 56 (null) Item(Local ): Usage, data= [ 0x39 ] 57 (null) Item(Local ): Usage, data= [ 0x3a ] 58 (null) Item(Local ): Usage, data= [ 0x3b ] 59 (null) Item(Local ): Usage, data= [ 0x3c ] 60 (null) Item(Local ): Usage, data= [ 0x3d ] 61 (null) Item(Local ): Usage, data= [ 0x3e ] 62 (null) Item(Global): Report Size, data= [ 0x08 ] 8 Item(Global): Report Count, data= [ 0x1f ] 31 Item(Main ): Input, data= [ 0x02 ] 2 Data Variable Absolute No_Wrap Linear Preferred_State No_Null_Position Non_Volatile Bitfield Item(Global): Report Count, data= [ 0x02 ] 2 Item(Local ): Usage, data= [ 0x21 0x40 ] 16417 (null) Item(Main ): Feature, data= [ 0x02 ] 2 Data Variable Absolute No_Wrap Linear Preferred_State No_Null_Position Non_Volatile Bitfield Item(Local ): Usage, data= [ 0x21 0x41 ] 16673 (null) Item(Main ): Output, data= [ 0x02 ] 2 Data Variable Absolute No_Wrap Linear Preferred_State No_Null_Position Non_Volatile Bitfield Item(Main ): End Collection, data=none Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0010 1x 16 bytes bInterval 16 Device Status: 0x0000 (Bus Powered)
