Release 13.2 - xst O.61xd (nt) Copyright (c) 1995-2011 Xilinx, Inc. All rights reserved. --> Parameter TMPDIR set to xst/projnav.tmp Total REAL time to Xst completion: 2.00 secs Total CPU time to Xst completion: 1.28 secs --> Parameter xsthdpdir set to xst Total REAL time to Xst completion: 2.00 secs Total CPU time to Xst completion: 1.28 secs --> Reading design: microblaze_own_IP_III_top.prj TABLE OF CONTENTS 1) Synthesis Options Summary 2) HDL Compilation 3) Design Hierarchy Analysis 4) HDL Analysis 5) HDL Synthesis 5.1) HDL Synthesis Report 6) Advanced HDL Synthesis 6.1) Advanced HDL Synthesis Report 7) Low Level Synthesis 8) Partition Report 9) Final Report 9.1) Device utilization summary 9.2) Partition Resource Summary 9.3) TIMING REPORT ========================================================================= * Synthesis Options Summary * ========================================================================= ---- Source Parameters Input File Name : "microblaze_own_IP_III_top.prj" Input Format : mixed Ignore Synthesis Constraint File : NO ---- Target Parameters Output File Name : "microblaze_own_IP_III_top" Output Format : NGC Target Device : xc3s500e-4-fg320 ---- Source Options Top Module Name : microblaze_own_IP_III_top Automatic FSM Extraction : YES FSM Encoding Algorithm : Auto Safe Implementation : No FSM Style : LUT RAM Extraction : Yes RAM Style : Auto ROM Extraction : Yes Mux Style : Auto Decoder Extraction : YES Priority Encoder Extraction : Yes Shift Register Extraction : YES Logical Shifter Extraction : YES XOR Collapsing : YES ROM Style : Auto Mux Extraction : Yes Resource Sharing : YES Asynchronous To Synchronous : NO Multiplier Style : Auto Automatic Register Balancing : No ---- Target Options Add IO Buffers : YES Global Maximum Fanout : 500 Add Generic Clock Buffer(BUFG) : 24 Register Duplication : YES Slice Packing : YES Optimize Instantiated Primitives : NO Use Clock Enable : Yes Use Synchronous Set : Yes Use Synchronous Reset : Yes Pack IO Registers into IOBs : Auto Equivalent register Removal : YES ---- General Options Optimization Goal : Speed Optimization Effort : 1 Keep Hierarchy : No Netlist Hierarchy : As_Optimized RTL Output : Yes Global Optimization : AllClockNets Read Cores : YES Write Timing Constraints : NO Cross Clock Analysis : NO Hierarchy Separator : / Bus Delimiter : <> Case Specifier : Maintain Slice Utilization Ratio : 100 BRAM Utilization Ratio : 100 Verilog 2001 : YES Auto BRAM Packing : NO Slice Utilization Ratio Delta : 5 ========================================================================= ========================================================================= * HDL Compilation * ========================================================================= Compiling vhdl file "D:/Projekte/uBlaze/microblaze_own_IP_III/microblaze_own_IP_III/hdl/microblaze_own_IP_III.vhd" in Library work. Entity compiled. Entity (Architecture ) compiled. Compiling vhdl file "D:/Projekte/uBlaze/microblaze_own_IP_III/microblaze_own_IP_III/microblaze_own_IP_III_top.vhd" in Library work. Entity compiled. Entity (Architecture ) compiled. ========================================================================= * Design Hierarchy Analysis * ========================================================================= Analyzing hierarchy for entity in library (architecture ). ========================================================================= * HDL Analysis * ========================================================================= Analyzing Entity in library (Architecture ). Entity analyzed. Unit generated. ========================================================================= * HDL Synthesis * ========================================================================= Performing bidirectional port resolution... Synthesizing Unit . Related source file is "D:/Projekte/uBlaze/microblaze_own_IP_III/microblaze_own_IP_III/microblaze_own_IP_III_top.vhd". Unit synthesized. ========================================================================= HDL Synthesis Report Found no macro ========================================================================= ========================================================================= * Advanced HDL Synthesis * ========================================================================= Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Reading core . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . Loading core for timing and area information for instance . ========================================================================= Advanced HDL Synthesis Report Found no macro ========================================================================= ========================================================================= * Low Level Synthesis * ========================================================================= Optimizing unit ... Mapping all equations... Building and optimizing final netlist ... Found area constraint ratio of 100 (+ 5) on block microblaze_own_IP_III_top, actual ratio is 59. INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 8 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 3 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 3 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 13 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 13 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 9 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 2 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 10 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 11 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 2 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 5 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 8 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 3 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 3 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 13 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 13 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 9 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 2 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 10 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 11 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 2 FFs/Latches : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following FF/Latch : INFO:Xst:2260 - The FF/Latch in Unit is equivalent to the following 5 FFs/Latches : Final Macro Processing ... ========================================================================= Final Register Report Found no macro ========================================================================= ========================================================================= * Partition Report * ========================================================================= Partition Implementation Status ------------------------------- No Partitions were found in this design. ------------------------------- ========================================================================= * Final Report * ========================================================================= Final Results RTL Top Level Output File Name : microblaze_own_IP_III_top.ngr Top Level Output File Name : microblaze_own_IP_III_top Output Format : NGC Optimization Goal : Speed Keep Hierarchy : No Design Statistics # IOs : 63 Cell Usage : # BELS : 4235 # BUF : 4 # GND : 16 # INV : 100 # LUT1 : 104 # LUT2 : 368 # LUT2_D : 14 # LUT2_L : 13 # LUT3 : 935 # LUT3_D : 56 # LUT3_L : 19 # LUT4 : 1545 # LUT4_D : 31 # LUT4_L : 52 # MULT_AND : 34 # MUXCY : 249 # MUXCY_L : 136 # MUXF5 : 317 # MUXF6 : 6 # MUXF7 : 2 # MUXF8 : 1 # VCC : 10 # XORCY : 223 # FlipFlops/Latches : 3641 # FD : 669 # FD_1 : 10 # FDC : 20 # FDC_1 : 5 # FDCE : 46 # FDE : 300 # FDE_1 : 8 # FDP : 13 # FDR : 1496 # FDR_1 : 17 # FDRE : 742 # FDRE_1 : 1 # FDRS : 71 # FDRS_1 : 2 # FDRSE : 51 # FDS : 94 # FDS_1 : 4 # FDSE : 71 # ODDR2 : 21 # RAMS : 173 # RAM16X1D : 160 # RAMB16_S18_S36 : 4 # RAMB16_S36 : 1 # RAMB16_S4_S4 : 8 # Shift Registers : 149 # SRL16 : 26 # SRL16E : 115 # SRLC16E : 8 # Clock Buffers : 7 # BUFG : 7 # IO Buffers : 80 # IBUF : 27 # IBUFG : 1 # IOBUF : 2 # OBUF : 33 # OBUFDS : 1 # OBUFT : 16 # DCMs : 2 # DCM_SP : 2 # MULTs : 3 # MULT18X18SIO : 3 # Others : 1 # BSCAN_SPARTAN3 : 1 ========================================================================= Device utilization summary: --------------------------- Selected Device : 3s500efg320-4 Number of Slices: 2755 out of 4656 59% Number of Slice Flip Flops: 3641 out of 9312 39% Number of 4 input LUTs: 3706 out of 9312 39% Number used as logic: 3237 Number used as Shift registers: 149 Number used as RAMs: 320 Number of IOs: 63 Number of bonded IOBs: 63 out of 232 27% Number of BRAMs: 13 out of 20 65% Number of MULT18X18SIOs: 3 out of 20 15% Number of GCLKs: 7 out of 24 29% Number of DCMs: 2 out of 4 50% --------------------------- Partition Resource Summary: --------------------------- No Partitions were found in this design. --------------------------- ========================================================================= TIMING REPORT NOTE: THESE TIMING NUMBERS ARE ONLY A SYNTHESIS ESTIMATE. FOR ACCURATE TIMING INFORMATION PLEASE REFER TO THE TRACE REPORT GENERATED AFTER PLACE-and-ROUTE. Clock Information: ------------------ ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-----------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ Clock Signal | Clock buffer(FF name) | Load | ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-----------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ fpga_0_clk_1_sys_clk_pin | clock_generator_0/DCM1_INST/Using_Virtex.DCM_INST:CLK0 | 2541 | microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i | BUFG | 208 | microblaze_own_IP_III_i/mdm_0/bscan_update1 | BUFG | 42 | fpga_0_clk_1_sys_clk_pin | clock_generator_0/DCM1_INST/Using_Virtex.DCM_INST:CLK2X+clock_generator_0/DCM0_INST/Using_Virtex.DCM_INST:CLK0 | 900 | fpga_0_clk_1_sys_clk_pin | clock_generator_0/DCM1_INST/Using_Virtex.DCM_INST:CLK2X+clock_generator_0/DCM0_INST/Using_Virtex.DCM_INST:CLK90 | 244 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<0>(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_dqs[0]..u_dqs_delay_col1/gen_delay.one:O)| NONE(*)(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/delay_ff) | 13 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<0>(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_dqs[0]..u_dqs_delay_col0/gen_delay.one:O)| NONE(*)(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/delay_ff_1)| 13 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<1>(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_dqs[1]..u_dqs_delay_col1/gen_delay.one:O)| NONE(*)(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/delay_ff) | 13 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<1>(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_dqs[1]..u_dqs_delay_col0/gen_delay.one:O)| NONE(*)(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/delay_ff_1)| 13 | ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-----------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ (*) These 4 clock signal(s) are generated by combinatorial logic, and XST is not able to identify which are the primary clock signals. Please use the CLOCK_SIGNAL constraint to specify the clock signal(s) generated by combinatorial logic. INFO:Xst:2169 - HDL ADVISOR - Some clock signals were not automatically buffered by XST with BUFG/BUFR resources. Please use the buffer_type constraint in order to insert these buffers to the clock signals to help prevent skew problems. Asynchronous Control Signals Information: ---------------------------------------- ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ Control Signal | Buffer(FF name) | Load | ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/Config_Reg_Acst_inv(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/Config_Reg_Acst_inv1_INV_0:O) | NONE(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/Config_Reg_0) | 23 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/rd_addr_rst_reg(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/rd_addr_rst_reg:Q) | NONE(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_rd_addr[0].fifo0_rd_addr_inst/gen_addr[0].u_addr_bit)| 16 | microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/infrastructure/sys_rst_reg(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/infrastructure/sys_rst_reg:Q) | NONE(microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_0_wr_addr/gen_addr[0].u_addr_bit) | 16 | microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/SEL_inv(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/SEL_inv1_INV_0:O) | NONE(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/PORT_Selector_0) | 12 | fpga_0_rst_1_sys_rst_pin | IBUF | 4 | microblaze_own_IP_III_i/clock_generator_0/clock_generator_0/DCM0_INST/reset(microblaze_own_IP_III_i/clock_generator_0/clock_generator_0/DCM0_INST/reset1_INV_0:O) | NONE(microblaze_own_IP_III_i/clock_generator_0/clock_generator_0/DCM0_INST/rst_delay_0) | 4 | microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Command_Reg_Rst(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Command_Reg_Rst:Q) | NONE(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/command_reg_0) | 2 | microblaze_own_IP_III_i/mdm_0/bscan_update1(microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:UPDATE) | BUFG(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/running_clock) | 1 | microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/data_cmd_inv(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/data_cmd_inv1_INV_0:O) | NONE(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/execute) | 1 | microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/local_sel_n3(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/Insert_Delays[4].LUT_Delay:O) | NONE(microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/FDC_I) | 1 | microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/continue_from_brk(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/continue_from_brk:Q)| NONE(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/continue_from_brk_TClk) | 1 | microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/force_stop_cmd(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/force_stop_cmd1:O) | NONE(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/force_stop_TClk) | 1 | microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/normal_stop_cmd(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/normal_stop_cmd1:O) | NONE(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/normal_stop_TClk) | 1 | microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/start_single_step(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/start_single_step:Q)| NONE(microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/single_Step_TClk) | 1 | ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+------------------------------------------------------------------------------------------------------------------------------------------------------------------------+-------+ Timing Summary: --------------- Speed Grade: -4 Minimum period: 15.926ns (Maximum Frequency: 62.790MHz) Minimum input arrival time before clock: 4.704ns Maximum output required time after clock: 12.163ns Maximum combinational path delay: No path found Timing Detail: -------------- All values displayed in nanoseconds (ns) ========================================================================= Timing constraint: Default period analysis for Clock 'fpga_0_clk_1_sys_clk_pin' Clock period: 14.471ns (frequency: 69.105MHz) Total number of paths / destination ports: 157984 / 9295 ------------------------------------------------------------------------- Delay: 7.235ns (Levels of Logic = 4) Source: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_state_r_FSM_FFd2 (FF) Destination: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_0 (FF) Source Clock: fpga_0_clk_1_sys_clk_pin rising 2.0X Destination Clock: fpga_0_clk_1_sys_clk_pin rising 2.0X Data Path: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_state_r_FSM_FFd2 to microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_0 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDRS:C->Q 16 0.591 1.069 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_state_r_FSM_FFd2 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_state_r_FSM_FFd2) LUT4_D:I2->LO 1 0.704 0.135 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_state_r_FSM_Out51 (N361) LUT4:I2->O 26 0.704 1.264 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_and0001 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_and0001) LUT4:I3->O 15 0.704 1.052 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_or0000 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_or0000) LUT3:I2->O 14 0.704 0.000 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_mux0000<3>11 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_mux0000<3>1) FDRS:D 0.308 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/phy_init/init_cnt_r_0 ---------------------------------------- Total 7.235ns (3.715ns logic, 3.520ns route) (51.3% logic, 48.7% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i' Clock period: 12.228ns (frequency: 81.780MHz) Total number of paths / destination ports: 311 / 251 ------------------------------------------------------------------------- Delay: 6.114ns (Levels of Logic = 5) Source: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/SYNC_FDRE (FF) Destination: microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_7 (FF) Source Clock: microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i falling Destination Clock: microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i rising Data Path: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/SYNC_FDRE to microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_7 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDRE_1:C->Q 1 0.591 0.499 JTAG_CONTROL_I/SYNC_FDRE (JTAG_CONTROL_I/sync) LUT3:I1->O 1 0.704 0.424 JTAG_CONTROL_I/shifting_Data_SW0 (N34) LUT4:I3->O 9 0.704 0.820 JTAG_CONTROL_I/shifting_Data (Dbg_Shift_7) end scope: 'mdm_0/MDM_Core_I1' end scope: 'mdm_0' begin scope: 'microblaze_0' INV:I->O 8 0.704 0.757 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Shift_inv1_INV_0 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Shift_inv) FDR:R 0.911 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_0 ---------------------------------------- Total 6.114ns (3.614ns logic, 2.500ns route) (59.1% logic, 40.9% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/mdm_0/bscan_update1' Clock period: 15.926ns (frequency: 62.790MHz) Total number of paths / destination ports: 329 / 50 ------------------------------------------------------------------------- Delay: 7.963ns (Levels of Logic = 6) Source: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/FDC_I (FF) Destination: microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/control_reg_0 (FF) Source Clock: microblaze_own_IP_III_i/mdm_0/bscan_update1 falling Destination Clock: microblaze_own_IP_III_i/mdm_0/bscan_update1 rising Data Path: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/FDC_I to microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/control_reg_0 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDC_1:C->Q 14 0.591 1.175 JTAG_CONTROL_I/FDC_I (JTAG_CONTROL_I/data_cmd) LUT2:I0->O 2 0.704 0.622 JTAG_CONTROL_I/Dbg_Reg_En_I<2>1 (Dbg_Reg_En_0<2>) end scope: 'mdm_0/MDM_Core_I1' end scope: 'mdm_0' begin scope: 'microblaze_0' LUT4:I0->O 4 0.704 0.762 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Command_Reg_En_cmp_eq000011 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/N6) LUT3:I0->O 2 0.704 0.622 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Control_Reg_En_cmp_eq000011 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/N25) LUT3:I0->O 9 0.704 0.820 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Control_Reg_En_cmp_eq00001 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Control_Reg_En) FDCE:CE 0.555 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/force_stop_TClk ---------------------------------------- Total 7.963ns (3.962ns logic, 4.001ns route) (49.8% logic, 50.2% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<1>' Clock period: 6.620ns (frequency: 151.057MHz) Total number of paths / destination ports: 39 / 28 ------------------------------------------------------------------------- Delay: 3.310ns (Levels of Logic = 1) Source: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/delay_ff_1 (FF) Destination: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_1_wr_addr/gen_addr[3].u_addr_bit (FF) Source Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<1> rising Destination Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<1> falling Data Path: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/delay_ff_1 to microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_1_wr_addr/gen_addr[3].u_addr_bit Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDR:C->Q 1 0.591 0.499 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/delay_ff_1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/din_delay) LUT2:I1->O 12 0.704 0.961 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_1_wr_en/dout1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/fifo_1_wr_en<1>) FDCE:CE 0.555 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_1_wr_addr/gen_addr[0].u_addr_bit ---------------------------------------- Total 3.310ns (1.850ns logic, 1.460ns route) (55.9% logic, 44.1% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<1>' Clock period: 6.842ns (frequency: 146.156MHz) Total number of paths / destination ports: 43 / 32 ------------------------------------------------------------------------- Delay: 3.421ns (Levels of Logic = 1) Source: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/delay_ff (FF) Destination: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_0_wr_addr/gen_addr[3].u_addr_bit (FF) Source Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<1> falling Destination Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<1> rising Data Path: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/delay_ff to microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_0_wr_addr/gen_addr[3].u_addr_bit Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDR:C->Q 3 0.591 0.610 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/delay_ff (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/din_delay) LUT2:I1->O 12 0.704 0.961 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[1].u_fifo_0_wr_en/dout1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/fifo_0_wr_en<1>) FDCE:CE 0.555 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[1].u_fifo_0_wr_addr/gen_addr[0].u_addr_bit ---------------------------------------- Total 3.421ns (1.850ns logic, 1.571ns route) (54.1% logic, 45.9% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<0>' Clock period: 6.620ns (frequency: 151.057MHz) Total number of paths / destination ports: 39 / 28 ------------------------------------------------------------------------- Delay: 3.310ns (Levels of Logic = 1) Source: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/delay_ff_1 (FF) Destination: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_1_wr_addr/gen_addr[3].u_addr_bit (FF) Source Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<0> rising Destination Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col1<0> falling Data Path: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/delay_ff_1 to microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_1_wr_addr/gen_addr[3].u_addr_bit Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDR:C->Q 1 0.591 0.499 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/delay_ff_1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/din_delay) LUT2:I1->O 12 0.704 0.961 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_1_wr_en/dout1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/fifo_1_wr_en<0>) FDCE:CE 0.555 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_1_wr_addr/gen_addr[0].u_addr_bit ---------------------------------------- Total 3.310ns (1.850ns logic, 1.460ns route) (55.9% logic, 44.1% route) ========================================================================= Timing constraint: Default period analysis for Clock 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<0>' Clock period: 6.842ns (frequency: 146.156MHz) Total number of paths / destination ports: 43 / 32 ------------------------------------------------------------------------- Delay: 3.421ns (Levels of Logic = 1) Source: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/delay_ff (FF) Destination: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_0_wr_addr/gen_addr[3].u_addr_bit (FF) Source Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<0> falling Destination Clock: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/dqs_delayed_col0<0> rising Data Path: microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/delay_ff to microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_0_wr_addr/gen_addr[3].u_addr_bit Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDR:C->Q 3 0.591 0.610 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/delay_ff (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/din_delay) LUT2:I1->O 12 0.704 0.961 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read_controller/gen_wr[0].u_fifo_0_wr_en/dout1 (DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/fifo_0_wr_en<0>) FDCE:CE 0.555 DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_phy_if_0/data_path/data_read/gen_wr_addr[0].u_fifo_0_wr_addr/gen_addr[0].u_addr_bit ---------------------------------------- Total 3.421ns (1.850ns logic, 1.571ns route) (54.1% logic, 45.9% route) ========================================================================= Timing constraint: Default OFFSET IN BEFORE for Clock 'microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i' Total number of paths / destination ports: 122 / 98 ------------------------------------------------------------------------- Offset: 4.704ns (Levels of Logic = 4) Source: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:SHIFT (PAD) Destination: microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_7 (FF) Destination Clock: microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i rising Data Path: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:SHIFT to microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_7 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ BSCAN_SPARTAN3:SHIFT 5 0.000 0.000 mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I (bscan_shift) begin scope: 'mdm_0/MDM_Core_I1' LUT4:I0->O 9 0.704 0.820 JTAG_CONTROL_I/shifting_Data (Dbg_Shift_7) end scope: 'mdm_0/MDM_Core_I1' end scope: 'mdm_0' begin scope: 'microblaze_0' INV:I->O 8 0.704 0.757 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Shift_inv1_INV_0 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Shift_inv) FDR:R 0.911 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/shift_count_0 ---------------------------------------- Total 4.704ns (3.127ns logic, 1.577ns route) (66.5% logic, 33.5% route) ========================================================================= Timing constraint: Default OFFSET IN BEFORE for Clock 'fpga_0_clk_1_sys_clk_pin' Total number of paths / destination ports: 10 / 10 ------------------------------------------------------------------------- Offset: 2.762ns (Levels of Logic = 2) Source: fpga_0_rst_1_sys_rst_pin (PAD) Destination: microblaze_own_IP_III_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/exr_d1 (FF) Destination Clock: fpga_0_clk_1_sys_clk_pin rising Data Path: fpga_0_rst_1_sys_rst_pin to microblaze_own_IP_III_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/exr_d1 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ IBUF:I->O 5 1.218 0.633 fpga_0_rst_1_sys_rst_pin_IBUF (fpga_0_rst_1_sys_rst_pin_IBUF) begin scope: 'microblaze_own_IP_III_i' begin scope: 'proc_sys_reset_0' FDS:S 0.911 proc_sys_reset_0/EXT_LPF/exr_d1 ---------------------------------------- Total 2.762ns (2.129ns logic, 0.633ns route) (77.1% logic, 22.9% route) ========================================================================= Timing constraint: Default OFFSET IN BEFORE for Clock 'microblaze_own_IP_III_i/mdm_0/bscan_update1' Total number of paths / destination ports: 20 / 20 ------------------------------------------------------------------------- Offset: 4.085ns (Levels of Logic = 3) Source: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:SEL2 (PAD) Destination: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/command_0 (FF) Destination Clock: microblaze_own_IP_III_i/mdm_0/bscan_update1 falling Data Path: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:SEL2 to microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/command_0 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ BSCAN_SPARTAN3:SEL2 2 0.000 0.000 mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I (mdm_0/sel) begin scope: 'mdm_0/MDM_Core_I1' LUT3:I0->O 7 0.704 0.743 Ext_JTAG_SEL11 (N2) LUT3:I2->O 8 0.704 0.757 Old_MDM_SEL1 (Old_MDM_SEL) FDE_1:CE 0.555 JTAG_CONTROL_I/command_7 ---------------------------------------- Total 4.085ns (2.585ns logic, 1.500ns route) (63.3% logic, 36.7% route) ========================================================================= Timing constraint: Default OFFSET OUT AFTER for Clock 'fpga_0_clk_1_sys_clk_pin' Total number of paths / destination ports: 1496 / 48 ------------------------------------------------------------------------- Offset: 12.163ns (Levels of Logic = 9) Source: microblaze_own_IP_III_i/pwm_lights_0/pwm_lights_0/USER_LOGIC_I/count_24 (FF) Destination: pwm_lights_0_LEDs_pin<0> (PAD) Source Clock: fpga_0_clk_1_sys_clk_pin rising Data Path: microblaze_own_IP_III_i/pwm_lights_0/pwm_lights_0/USER_LOGIC_I/count_24 to pwm_lights_0_LEDs_pin<0> Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FD:C->Q 14 0.591 1.175 pwm_lights_0/USER_LOGIC_I/count_24 (pwm_lights_0/USER_LOGIC_I/count<24>) LUT2:I0->O 2 0.704 0.451 pwm_lights_0/USER_LOGIC_I/PWM_value<6>54 (pwm_lights_0/USER_LOGIC_I/PWM_value<6>54) LUT4:I3->O 1 0.704 0.424 pwm_lights_0/USER_LOGIC_I/PWM_value<6>94_SW0 (N16) LUT4:I3->O 1 0.704 0.595 pwm_lights_0/USER_LOGIC_I/PWM_value<6>94 (pwm_lights_0/USER_LOGIC_I/PWM_value<6>) LUT2:I0->O 1 0.704 0.000 pwm_lights_0/USER_LOGIC_I/Mcompar_LEDs_cmp_ge0000_lut<6> (pwm_lights_0/USER_LOGIC_I/Mcompar_LEDs_cmp_ge0000_lut<6>) MUXCY:S->O 1 0.464 0.000 pwm_lights_0/USER_LOGIC_I/Mcompar_LEDs_cmp_ge0000_cy<6> (pwm_lights_0/USER_LOGIC_I/Mcompar_LEDs_cmp_ge0000_cy<6>) MUXCY:CI->O 1 0.459 0.455 pwm_lights_0/USER_LOGIC_I/Mcompar_LEDs_cmp_ge0000_cy<7> (pwm_lights_0/USER_LOGIC_I/LEDs_cmp_ge0000) LUT3:I2->O 8 0.704 0.757 pwm_lights_0/USER_LOGIC_I/LEDs<1>1 (LEDs<7>) end scope: 'pwm_lights_0' end scope: 'microblaze_own_IP_III_i' OBUF:I->O 3.272 pwm_lights_0_LEDs_pin_0_OBUF (pwm_lights_0_LEDs_pin<0>) ---------------------------------------- Total 12.163ns (8.306ns logic, 3.857ns route) (68.3% logic, 31.7% route) ========================================================================= Timing constraint: Default OFFSET OUT AFTER for Clock 'microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i' Total number of paths / destination ports: 126 / 1 ------------------------------------------------------------------------- Offset: 11.543ns (Levels of Logic = 10) Source: microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Use_SRL16.The_Cache_Addresses[3].SRL16E_Cache_I (FF) Destination: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:TDO2 (PAD) Source Clock: microblaze_own_IP_III_i/mdm_0/mdm_0/drck_i rising Data Path: microblaze_own_IP_III_i/microblaze_0/microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Use_SRL16.The_Cache_Addresses[3].SRL16E_Cache_I to microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:TDO2 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ SRL16E:CLK->Q 1 3.706 0.499 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/Use_SRL16.The_Cache_Addresses[3].SRL16E_Cache_I (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/tdo_config_word1<4>) LUT3:I1->O 1 0.704 0.455 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO23 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO23) LUT4:I2->O 1 0.704 0.000 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO73_F (N323) MUXF5:I0->O 1 0.321 0.499 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO73 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO73) LUT4:I1->O 1 0.704 0.000 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW01 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW0) MUXF5:I1->O 1 0.321 0.424 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW0_f5 (N247) LUT4:I3->O 1 0.704 0.499 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324 (DBG_TDO) end scope: 'microblaze_0' begin scope: 'mdm_0' begin scope: 'mdm_0/MDM_Core_I1' LUT4:I1->O 1 0.704 0.595 TDO_i81 (TDO_i81) LUT4:I0->O 0 0.704 0.000 TDO_i217 (TDO) end scope: 'mdm_0/MDM_Core_I1' BSCAN_SPARTAN3:TDO2 0.000 mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I ---------------------------------------- Total 11.543ns (8.572ns logic, 2.971ns route) (74.3% logic, 25.7% route) ========================================================================= Timing constraint: Default OFFSET OUT AFTER for Clock 'microblaze_own_IP_III_i/mdm_0/bscan_update1' Total number of paths / destination ports: 56 / 1 ------------------------------------------------------------------------- Offset: 9.076ns (Levels of Logic = 11) Source: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/FDC_I (FF) Destination: microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:TDO2 (PAD) Source Clock: microblaze_own_IP_III_i/mdm_0/bscan_update1 falling Data Path: microblaze_own_IP_III_i/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/FDC_I to microblaze_own_IP_III_i/mdm_0/mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I:TDO2 Gate Net Cell:in->out fanout Delay Delay Logical Name (Net Name) ---------------------------------------- ------------ FDC_1:C->Q 14 0.591 1.175 JTAG_CONTROL_I/FDC_I (JTAG_CONTROL_I/data_cmd) LUT2:I0->O 8 0.704 0.792 JTAG_CONTROL_I/Dbg_Reg_En_I<7>1 (Dbg_Reg_En_0<7>) end scope: 'mdm_0/MDM_Core_I1' end scope: 'mdm_0' begin scope: 'microblaze_0' LUT4:I2->O 1 0.704 0.455 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO264 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO264) LUT4:I2->O 1 0.704 0.000 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW01 (microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW0) MUXF5:I1->O 1 0.321 0.424 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324_SW0_f5 (N247) LUT4:I3->O 1 0.704 0.499 microblaze_0/MicroBlaze_Core_I/Area.Implement_Debug_Logic.Master_Core.Debug_Area/TDO324 (DBG_TDO) end scope: 'microblaze_0' begin scope: 'mdm_0' begin scope: 'mdm_0/MDM_Core_I1' LUT4:I1->O 1 0.704 0.595 TDO_i81 (TDO_i81) LUT4:I0->O 0 0.704 0.000 TDO_i217 (TDO) end scope: 'mdm_0/MDM_Core_I1' BSCAN_SPARTAN3:TDO2 0.000 mdm_0/Use_Spartan3.BSCAN_SPARTAN3_I ---------------------------------------- Total 9.076ns (5.136ns logic, 3.940ns route) (56.6% logic, 43.4% route) ========================================================================= Total REAL time to Xst completion: 31.00 secs Total CPU time to Xst completion: 30.19 secs --> Total memory usage is 213908 kilobytes Number of errors : 0 ( 0 filtered) Number of warnings : 0 ( 0 filtered) Number of infos : 37 ( 0 filtered)
