Release 13.2 ngdbuild O.61xd (nt) Copyright (c) 1995-2011 Xilinx, Inc. All rights reserved. Command Line: C:\Programme\Xilinx\13.2\ISE_DS\ISE\bin\nt\unwrapped\ngdbuild.exe -intstyle ise -dd _ngo -nt timestamp -i -bm edkBmmFile.bmm -p xc3s500e-fg320-4 microblaze_own_IP_III_top.ngc microblaze_own_IP_III_top.ngd Reading NGO file "D:/Projekte/uBlaze/microblaze_own_IP_III/microblaze_own_IP_ III_top.ngc" ... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/microblaze_own_IP_ III.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/microblaze_0_wrapp er.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/mb_plb_wrapper.ngc "... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/ilmb_wrapper.ngc". .. Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/dlmb_wrapper.ngc". .. Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/dlmb_cntlr_wrapper .ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/ilmb_cntlr_wrapper .ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/lmb_bram_wrapper.n gc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/rs232_dce_wrapper. ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/dip_switches_4bit_ wrapper.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/buttons_4bit_wrapp er.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/ddr_sdram_wrapper. ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/clock_generator_0_ wrapper.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/mdm_0_wrapper.ngc" ... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/proc_sys_reset_0_w rapper.ngc"... Loading design module "D:\Projekte\uBlaze\microblaze_own_IP_III/pwm_lights_0_wrapp er.ngc"... Applying constraints in "D:\Projekte\uBlaze\microblaze_own_IP_III/microblaze_own_IP_ III.ncf" to module "microblaze_own_IP_III_i"... Checking Constraint Associations... Gathering constraint information from source properties... Done. Resolving constraint associations... Checking Constraint Associations... INFO:ConstraintSystem:178 - TNM 'sys_clk_pin', used in period specification 'TS_sys_clk_pin', was traced into DCM_SP instance clock_generator_0/DCM1_INST/Using_Virtex.DCM_INST. The following new TNM groups and period specifications were generated at the DCM_SP output(s): CLK0: INFO:ConstraintSystem:178 - TNM 'sys_clk_pin', used in period specification 'TS_sys_clk_pin', was traced into DCM_SP instance clock_generator_0/DCM1_INST/Using_Virtex.DCM_INST. The following new TNM groups and period specifications were generated at the DCM_SP output(s): CLK2X: INFO:ConstraintSystem:178 - TNM 'microblaze_own_IP_III_i_clock_generator_0_clock_generator_0_SIG_DCM1_CLK2X', used in period specification 'TS_microblaze_own_IP_III_i_clock_generator_0_clock_generator_0_SIG_DCM1_CLK2 X', was traced into DCM_SP instance clock_generator_0/DCM0_INST/Using_Virtex.DCM_INST. The following new TNM groups and period specifications were generated at the DCM_SP output(s): CLK0: INFO:ConstraintSystem:178 - TNM 'microblaze_own_IP_III_i_clock_generator_0_clock_generator_0_SIG_DCM1_CLK2X', used in period specification 'TS_microblaze_own_IP_III_i_clock_generator_0_clock_generator_0_SIG_DCM1_CLK2 X', was traced into DCM_SP instance clock_generator_0/DCM0_INST/Using_Virtex.DCM_INST. The following new TNM groups and period specifications were generated at the DCM_SP output(s): CLK90: Done... Processing BMM file "edkBmmFile.bmm" ... INFO:NgdBuild:1222 - Setting CLKIN_PERIOD attribute associated with DCM instance clock_generator_0/DCM0_INST/Using_Virtex.DCM_INST to 10.000000 ns based on the period specification (). Checking expanded design ... WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[30].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[29].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[28].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[27].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[26].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[25].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[24].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[23].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[22].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[21].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[20].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[19].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[18].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[17].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[16].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[15].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[14].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[13].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[12].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[11].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[10].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[9].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[8].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[7].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[6].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[5].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[4].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[3].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[2].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[1].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/gen_tap2[0].u' has unconnected output pin WARNING:NgdBuild:443 - SFF primitive 'microblaze_own_IP_III_i/DDR_SDRAM/DDR_SDRAM/mpmc_core_0/gen_s3_ddr_phy.mpmc_ phy_if_0/infrastructure/cal_top/tap_dly/u31' has unconnected output pin WARNING:NgdBuild:452 - logical net 'N23' has no driver WARNING:NgdBuild:452 - logical net 'N24' has no driver WARNING:NgdBuild:452 - logical net 'N25' has no driver WARNING:NgdBuild:452 - logical net 'N26' has no driver WARNING:NgdBuild:452 - logical net 'N27' has no driver WARNING:NgdBuild:452 - logical net 'N28' has no driver WARNING:NgdBuild:452 - logical net 'N29' has no driver WARNING:NgdBuild:452 - logical net 'N30' has no driver WARNING:NgdBuild:452 - logical net 'N31' has no driver WARNING:NgdBuild:452 - logical net 'N32' has no driver WARNING:NgdBuild:452 - logical net 'N33' has no driver WARNING:NgdBuild:452 - logical net 'N34' has no driver WARNING:NgdBuild:452 - logical net 'N35' has no driver WARNING:NgdBuild:452 - logical net 'N36' has no driver WARNING:NgdBuild:452 - logical net 'N37' has no driver WARNING:NgdBuild:452 - logical net 'N38' has no driver WARNING:NgdBuild:452 - logical net 'N39' has no driver WARNING:NgdBuild:452 - logical net 'N40' has no driver WARNING:NgdBuild:452 - logical net 'N41' has no driver WARNING:NgdBuild:478 - clock net microblaze_own_IP_III_i/mdm_0/bscan_drck1 with clock driver microblaze_own_IP_III_i/mdm_0/mdm_0/BUFG_DRCK1 drives no clock pins Partition Implementation Status ------------------------------- No Partitions were found in this design. ------------------------------- NGDBUILD Design Results Summary: Number of errors: 0 Number of warnings: 52 Total memory usage is 132884 kilobytes Writing NGD file "microblaze_own_IP_III_top.ngd" ... Total REAL time to NGDBUILD completion: 44 sec Total CPU time to NGDBUILD completion: 44 sec Writing NGDBUILD log file "microblaze_own_IP_III_top.bld"...
