$regfile "m48def.dat" $crystal = 10000000 $baud = 9600 Config Portb = Output Dim A As Integer 'Winkel Alpha Dim B As Integer 'Sin- Wert von Alpha Dim C As Integer 'Ein- Zeit der PWM (indirekte Spannung) Dim D As Integer 'Winkel Dim E As Integer Dim W As Byte 'PWM- Timer ==================================================================== Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Up , Prescale = 256 Enable Timer1 'Interrupttimer ================================================================ Config Timer2 = Timer , Prescale = 1 On Timer2 Tim2isr Enable Interrupts Enable Timer2 '=============================================================================== Start Timer2 A = 0 B = 0 C = 1 D = 235 / 100 sbi portb,3 cbi portb,4 Pwm1a = C Start Timer2 Do W = Timer2 If W > 2 Then sbi portb,5 End If Loop Tim2isr: 'interruptroutine für timer0 A = A + D 'B = Sin(a) 'B = Round(b) 'B = Rad2deg(b) If A => 179 Then A = 0 Toggle Pinb.3 Toggle Pinb.4 Else End If C = B * 254 'Ein-Zeit = sinAlpha * Radius Pwm1a = C Return End 'end program
