Using built-in specs. COLLECT_GCC=D:\WINAVR\BIN\AVR-GCC.EXE COLLECT_LTO_WRAPPER=d:/winavr/bin/../libexec/gcc/avr/4.7.0/lto-wrapper.exe Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 (experimental) (GCC) COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/winavr/bin/../libexec/gcc/avr/4.7.0/cc1.exe -E -quiet -v -imultilib avr4 -iprefix d:\winavr\bin\../lib/gcc/avr/4.7.0/ main.c -mmcu=atmega8 -flto -fpch-preprocess -o main.i ignoring nonexistent directory "d:\winavr\bin\../lib/gcc/avr/4.7.0/../../../../avr/sys-include" ignoring duplicate directory "d:/winavr/lib/gcc/../../lib/gcc/avr/4.7.0/include" ignoring duplicate directory "d:/winavr/lib/gcc/../../lib/gcc/avr/4.7.0/include-fixed" ignoring nonexistent directory "d:/winavr/lib/gcc/../../lib/gcc/avr/4.7.0/../../../../avr/sys-include" ignoring duplicate directory "d:/winavr/lib/gcc/../../lib/gcc/avr/4.7.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: d:\winavr\bin\../lib/gcc/avr/4.7.0/include d:\winavr\bin\../lib/gcc/avr/4.7.0/include-fixed d:\winavr\bin\../lib/gcc/avr/4.7.0/../../../../avr/include End of search list. COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/winavr/bin/../libexec/gcc/avr/4.7.0/cc1.exe -fpreprocessed main.i -quiet -dumpbase main.c -mmcu=atmega8 -auxbase main -version -flto -o main.s GNU C (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU C (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 Compiler executable checksum: e54f48a37bae19349487e8c9d60cf558 COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/as.exe -mmcu=atmega8 -o main.o main.s COMPILER_PATH=d:/winavr/bin/../libexec/gcc/avr/4.7.0/;d:/winavr/bin/../libexec/gcc/;d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ LIBRARY_PATH=d:/winavr/bin/../lib/gcc/avr/4.7.0/avr4/;d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/;d:/winavr/bin/../lib/gcc/avr/4.7.0/;d:/winavr/bin/../lib/gcc/;d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/winavr/bin/../libexec/gcc/avr/4.7.0/collect2.exe -plugin d:/winavr/bin/../libexec/gcc/avr/4.7.0/liblto_plugin-0.dll -plugin-opt=d:/winavr/bin/../libexec/gcc/avr/4.7.0/lto-wrapper.exe -plugin-opt=-fresolution=main.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -flto -m avr4 d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/crtm8.o -Ld:/winavr/bin/../lib/gcc/avr/4.7.0/avr4 -Ld:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4 -Ld:/winavr/bin/../lib/gcc/avr/4.7.0 -Ld:/winavr/bin/../lib/gcc -Ld:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib main.o -lgcc -lc -lgcc d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ld.exe: could not read lto-wrapper output D:\WINAVR\BIN\AVR-GCC.EXE @f:\temp\ccGXI6QI.args Using built-in specs. COLLECT_GCC=D:\WINAVR\BIN\AVR-GCC.EXE Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 (experimental) (GCC) COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=f:\temp\cc3kAI3r.ltrans.out' '-fwpa' '-fresolution=main.res' d:/winavr/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpbase main.o -mmcu=atmega8 -mmcu=atmega8 -auxbase main -version -fltrans-output-list=f:\temp\cc3kAI3r.ltrans.out -fwpa -fresolution=main.res @f:\temp\ccjfxI3r GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 lto1.exe: internal compiler error: invalid resolution in the resolution file Please submit a full bug report, with preprocessed source if appropriate. See for instructions. collect2.exe: error: ld returned 1 exit status d:/winavr/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ld.exe: could not read lto-wrapper output D:\WINAVR\BIN\AVR-GCC.EXE @f:\temp\ccGXI6QI.args Using built-in specs. COLLECT_GCC=D:\WINAVR\BIN\AVR-GCC.EXE Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 (experimental) (GCC) COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=f:\temp\cc3kAI3r.ltrans.out' '-fwpa' '-fresolution=main.res' d:/winavr/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpbase main.o -mmcu=atmega8 -mmcu=atmega8 -auxbase main -version -fltrans-output-list=f:\temp\cc3kAI3r.ltrans.out -fwpa -fresolution=main.res @f:\temp\ccjfxI3r GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 lto1.exe: internal compiler error: invalid resolution in the resolution file Please submit a full bug report, with preprocessed source if appropriate. See for instructions.
