Using built-in specs. COLLECT_GCC=avr-gcc COLLECT_LTO_WRAPPER=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/lto-wrapper.exe Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 - by SRMeister (GCC) COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/cc1.exe -E -quiet -v -imultilib avr4 -iprefix d:\programme\atmel\avr-toolchain-4.7.0-2012-02-19\bin\../lib/gcc/avr/4.7.0/ main.c -mmcu=atmega8 -flto -fpch-preprocess -o main.i ignoring nonexistent directory "d:\programme\atmel\avr-toolchain-4.7.0-2012-02-19\bin\../lib/gcc/avr/4.7.0/../../../../avr/sys-include" ignoring duplicate directory "d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../lib/gcc/avr/4.7.0/include" ignoring duplicate directory "d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../lib/gcc/avr/4.7.0/include-fixed" ignoring nonexistent directory "d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../lib/gcc/avr/4.7.0/../../../../avr/sys-include" ignoring duplicate directory "d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../lib/gcc/avr/4.7.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: d:\programme\atmel\avr-toolchain-4.7.0-2012-02-19\bin\../lib/gcc/avr/4.7.0/include d:\programme\atmel\avr-toolchain-4.7.0-2012-02-19\bin\../lib/gcc/avr/4.7.0/include-fixed d:\programme\atmel\avr-toolchain-4.7.0-2012-02-19\bin\../lib/gcc/avr/4.7.0/../../../../avr/include End of search list. COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/cc1.exe -fpreprocessed main.i -quiet -dumpbase main.c -mmcu=atmega8 -auxbase main -version -flto -o main.s GNU C (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU C (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 Compiler executable checksum: e54f48a37bae19349487e8c9d60cf558 COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/as.exe -mmcu=atmega8 -o main.o main.s COMPILER_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ LIBRARY_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-mmcu=atmega8' '-flto' '-v' '-save-temps' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/collect2.exe -plugin d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/liblto_plugin-0.dll -plugin-opt=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/lto-wrapper.exe -plugin-opt=-fresolution=main.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -flto -m avr4 d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/crtm8.o -Ld:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/avr4 -Ld:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4 -Ld:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0 -Ld:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc -Ld:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib main.o -lgcc -lc -lgcc avr-gcc @C:\DOKUME~1\krapao\LOKALE~1\Temp\ccOFOX5k.args Using built-in specs. COLLECT_GCC=avr-gcc Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 - by SRMeister (GCC) COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out' '-fwpa' '-fresolution=main.res' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpbase main.o -mmcu=atmega8 -mmcu=atmega8 -auxbase main -version -fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out -fwpa -fresolution=main.res @C:\DOKUME~1\krapao\LOKALE~1\Temp\ccrg0f5h GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 COMPILER_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ LIBRARY_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out' '-fwpa' '-fresolution=main.res' [Leaving LTRANS C:\DOKUME~1\krapao\LOKALE~1\Temp\ccOFOX5k.args] [Leaving LTRANS C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out] avr-gcc @C:\DOKUME~1\krapao\LOKALE~1\Temp\ccj0zC0q.args Using built-in specs. COLLECT_GCC=avr-gcc Target: avr Configured with: ../gcc-trunk/configure --with-gmp=/usr/local --prefix=/usr/local/avr --target=avr --enable-languages=c,c++ --with-dwarf2 --disable-shared --disable-libada --disable-libssp --disable-nls Thread model: single gcc version 4.7.0 20120217 - by SRMeister (GCC) COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out' '-fltrans' '-o' 'C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.ltrans.o' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/avr/4.7.0/lto1.exe -quiet -dumpbase ccZpZ3Cf.ltrans0.o -mmcu=atmega8 -mmcu=atmega8 -auxbase-strip C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.ltrans.o -version -fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out -fltrans @C:\DOKUME~1\krapao\LOKALE~1\Temp\ccW9vnbe -o ccZpZ3Cf.ltrans0.s GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 GNU GIMPLE (GCC) version 4.7.0 20120217 (experimental) (avr) compiled by GNU C version 4.6.2, GMP version 5.0.4, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=30 --param ggc-min-heapsize=4096 COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out' '-fltrans' '-o' 'C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.ltrans.o' d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/as.exe -mmcu=atmega8 -mmcu=atmega8 -o C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.ltrans.o ccZpZ3Cf.ltrans0.s COMPILER_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/lib/gcc/../../libexec/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../libexec/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/bin/ LIBRARY_PATH=d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/avr4/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/;d:/programme/atmel/avr-toolchain-4.7.0-2012-02-19/bin/../lib/gcc/avr/4.7.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-mmcu=atmega8' '-mmcu=atmega8' '-v' '-save-temps' '-fltrans-output-list=C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans.out' '-fltrans' '-o' 'C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.ltrans.o' [Leaving LTRANS C:\DOKUME~1\krapao\LOKALE~1\Temp\ccj0zC0q.args] [Leaving LTRANS C:\DOKUME~1\krapao\LOKALE~1\Temp\ccZpZ3Cf.ltrans0.o]
