Howto make BootICE (Compatible to A**** AVR JTAG*ICE)
- ATmega163 (or Atmega16, need bootloader fix!!)
- 7.3728 Crystal
- Standard UART Serial Driver (MAX232, etc)
- VREF (pin 29) to VCC
- ADC2 (pin35) to VCC
- PD3 pull-down resistor 4k7
- Connect some ATmega to your ICE
- TDO - PB6(pin12) to target TDO
- TDI - PB5(pin1) to target TDI
- TMS - PB1(pin41) to target TMS
- TCK - PB7(pin3) to target TCK
- PB3(pin43) to LED (other side of LED to VCC) this is "JTAG Activity"
- Program with bootice.rom see source
bootice.bas (AVR
Basic) use PonyProg (notice bootloader is
for m163 only)
- Set Fuses: BOOTSZ, BOOTRST all programmed, Clock all non-programmed see
PonyProg screenshot
- Connect your ATmega to COM port
- Start AVRStudio 4
- Launch AVRPROG
- Select "Program Files\Atmel\AVR Tools\JTAGICE\Upgrade.ebn" as Flash file
- Program Flash, close AVRPROG
- Program Fuses using PonyProg so that BOOTRST is not programmed see
PonyProg screenshot
- In AVRStudio 4, Tools-JTAGICE you should see following screenshot
- Congratulations you have AVRStudio connected to JTAGICE!
- Go ahead and use your own JTAGICE !
This works folks! I made a mistake at the start having TDO at wrong pin but
thanks to hints from friendly internet users who sent me a link to old version
of JTAGICE datasheet this was fixed.
m16 Bootloader (seems to work, but readback fails) bas und rom
additional info about JTAG OCD and
AVR JTAG Flash Programming
