Version 4 SHEET 1 1560 680 WIRE -112 -32 -112 -48 WIRE -16 -32 -16 -48 WIRE 144 0 112 0 WIRE 224 0 208 0 WIRE 416 0 224 0 WIRE -112 80 -112 48 WIRE -16 80 -16 48 WIRE 320 112 320 80 WIRE 224 128 224 0 WIRE 288 128 224 128 WIRE 416 144 416 0 WIRE 416 144 352 144 WIRE 480 144 416 144 WIRE -96 160 -176 160 WIRE 0 160 -16 160 WIRE 16 160 0 160 WIRE 112 160 112 0 WIRE 112 160 96 160 WIRE 128 160 112 160 WIRE 224 160 208 160 WIRE 288 160 224 160 WIRE -176 192 -176 160 WIRE 0 208 0 160 WIRE 224 208 224 160 WIRE 320 208 320 176 WIRE -176 320 -176 272 WIRE 0 320 0 272 WIRE 0 320 -176 320 WIRE 224 320 224 272 WIRE 224 320 0 320 WIRE 480 320 224 320 WIRE 224 368 224 320 FLAG 320 80 +V FLAG 320 208 -V FLAG 480 144 +Vout IOPIN 480 144 Out FLAG 480 320 -Vout IOPIN 480 320 Out FLAG -16 -48 +V FLAG -16 80 0 FLAG -112 -48 -V FLAG -112 80 0 FLAG 224 368 0 SYMBOL Opamps\\LT1007 320 80 R0 SYMATTR InstName U1 SYMBOL res 224 144 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R3 SYMATTR Value {R3} SYMBOL res 112 144 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R2 SYMATTR Value {R2} SYMBOL res 0 144 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R1 SYMATTR Value {R1} SYMBOL cap -16 208 R0 SYMATTR InstName C1 SYMATTR Value {C1} SYMBOL cap 208 208 R0 SYMATTR InstName C3 SYMATTR Value {C3} SYMBOL cap 208 -16 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C2 SYMATTR Value {C2} SYMBOL voltage -176 176 R0 WINDOW 123 24 132 Left 2 WINDOW 39 0 0 Left 2 WINDOW 3 -318 48 Left 2 SYMATTR Value2 AC 1 SYMATTR InstName V1 SYMATTR Value SINE(0 0.1 1k 0 0 0 1k) SYMBOL voltage -16 -48 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V2 SYMATTR Value +15 SYMBOL voltage -112 -48 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V3 SYMATTR Value -15 TEXT 264 -56 Left 2 !.tran 0.1 TEXT -272 -304 Left 2 ;Sallen-Key-Filter wurden 1955 am Massachusetss Institut of Technology von\nR.P.Sallen und E.L.Key entwickelt.Mit Sallen-Key-Filtern können sowohl Tiefpass-, \nHochpass- als auch Bandpassfilter realisiert werden. Bandsperren können nicht \nrealisiert werden. Sallen-Key-Filter weisen eine Ordnung von 2 auf, d.h. der Betrag\nder Amplitude ändert sich mit 12dB pro Oktave. Neben der geringen Anzahl von \nBauelementen weisen Sallen-Key-Filter eine relativ hohe Toleranz gegenüber\nBauteiltolereanzen auf. Sie werden dort eingesetzt wo geringe Gütefaktoren akzep-\ntierbar sind. TEXT -296 416 Left 2 ;.params R1=270 R2=430 R3=820 C1=0.47u C2=0.47u C3=0.047u;Butterworth Tiefpassfilter mit fc = 1.6 kHz TEXT 264 -96 Left 2 ;Linear Technology, Application Note 67 TEXT -296 456 Left 2 ;.params R1=360 R2=3.3k R3=3.3k C1=0.47u C2=0.1u C3=0.022u;Butterworth Tiefpassfilter mit fc = 1 kHz TEXT -296 496 Left 2 !.params R1=360 R2=7.5k R3=180 C1=0.022u C2=0.047u C3=0.001u;Butterworth Tiefpassfilter mit fc = 20 kHz TEXT 616 -32 Left 2 ;Der Sallen-Key Tiefpassfilter wird instabil bei:\nA=1+(1+R2/R3*C3/C2)\nBei dieser Verstärkung schwingt er mit:\nf=1/(2*Pi*Sqr(R2*R3*C2*C3)
