Functions
FAT directory functions
[FAT support]
Functions for managing directories. More...
Functions
struct fat_dir_struct * fat_open_dir (struct fat_fs_struct *fs, const struct fat_dir_entry_struct *dir_entry)
 Opens a directory.
void fat_close_dir (struct fat_dir_struct *dd)
 Closes a directory descriptor.
uint8_t fat_read_dir (struct fat_dir_struct *dd, struct fat_dir_entry_struct *dir_entry)
 Reads the next directory entry contained within a parent directory.
uint8_t fat_reset_dir (struct fat_dir_struct *dd)
 Resets a directory handle.
uint8_t fat_create_dir (struct fat_dir_struct *parent, const char *dir, struct fat_dir_entry_struct *dir_entry)
 Creates a directory.
uint8_t fat_delete_dir (struct fat_fs_struct *fs, struct fat_dir_entry_struct *dir_entry)
 Deletes a directory.
uint8_t fat_move_dir (struct fat_fs_struct *fs, struct fat_dir_entry_struct *dir_entry, struct fat_dir_struct *parent_new, const char *dir_new)
 Moves or renames a directory.
Detailed Description
Function Documentation
void fat_close_dir ( struct fat_dir_struct *  dd  )
This function destroys a directory descriptor which was previously obtained by calling fat_open_dir(). When this function returns, the given descriptor will be invalid.
Parameters:
[in] dd The directory descriptor to close.
See also:
fat_open_dir
uint8_t fat_create_dir ( struct fat_dir_struct *  parent,
const char *  dir,
struct fat_dir_entry_struct dir_entry
Creates a directory and obtains its directory entry. If the directory to create already exists, its directory entry will be returned within the dir_entry parameter.
Note:
The notes which apply to fat_create_file() also apply to this function.
Parameters:
[in] parent The handle of the parent directory of the new directory.
[in] dir The name of the directory to create.
[out] dir_entry The directory entry to fill for the new directory.
Returns:
0 on failure, 1 on success.
See also:
fat_delete_dir
uint8_t fat_delete_dir ( struct fat_fs_struct *  fs,
This is just a synonym for fat_delete_file(). If a directory is deleted without first deleting its subdirectories and files, disk space occupied by these files will get wasted as there is no chance to release it and mark it as free.
Parameters:
[in] fs The filesystem on which to operate.
[in] dir_entry The directory entry of the directory to delete.
Returns:
See also:
fat_create_dir
uint8_t fat_move_dir ( struct fat_fs_struct *  fs,
struct fat_dir_entry_struct dir_entry,
struct fat_dir_struct *  parent_new,
const char *  dir_new
This is just a synonym for fat_move_file().
Parameters:
[in,out] dir_entry The directory entry of the directory to move.
[in] parent_new The handle of the new parent directory.
[in] dir_new The directory's new name.
Returns:
See also:
fat_create_dir, fat_delete_dir, fat_move_file
struct fat_dir_struct* fat_open_dir ( struct fat_fs_struct *  fs,
const struct fat_dir_entry_struct dir_entry
) [read]
Opens a directory.
Parameters:
[in] fs The filesystem on which the directory to open resides.
[in] dir_entry The directory entry which stands for the directory to open.
Returns:
An opaque directory descriptor on success, 0 on failure.
See also:
fat_close_dir
uint8_t fat_read_dir ( struct fat_dir_struct *  dd,
Parameters:
[in] dd The descriptor of the parent directory from which to read the entry.
[out] dir_entry Pointer to a buffer into which to write the directory entry information.
Returns:
See also:
fat_reset_dir
uint8_t fat_reset_dir ( struct fat_dir_struct *  dd  )
Resets the directory handle such that reading restarts with the first directory entry.
Parameters:
[in] dd The directory handle to reset.
Returns:
See also:
fat_read_dir
