Execution times: Clear display 1.64ms; home cursor 40 us to 1.64ms depending on how far display is scrolled; all others 40us, except read busy flag which is complete in a single enable cycle (or two cycles in 4-bit mode), and character generator ram reads and writes which should be separated by 120us delays. These execution times mean that after an operation, the CPU must do Busy Flag checks until the BF (bit 7) is 0, or, when the connection to the module from the CPU is write-only, wait more than the execution time before the next operation. These times are usually strict, LCDs used in a write-only configuration should provide the specified delays. Some speed improvement might be realized by utilizing busy flag reads instead of delays.
WRITE:
______ _____________________________ ___________ RS ______X_________valid_RS_level______X__________ | | | | |<--tAS-->| tAH-->| |<-- ______| | | |____________ R/W ______\_________|___R/W_low____|____/_____________ | | |<----PWEH---->| | | |<-------------|-------TcycE----->| |______________| |_________ E ________________/ \__________________/ tR-->||<-- -->||<--tF || |<--tDSW-->|| | -->| |<--tWH __________________|_______________|________________ D0-D7 __________________X__valid_data___X____________
READ:
______ _____________________________ ___________ RS ______X_________valid_RS_level______X__________ | | | | |<--tAS-->| tAH-->| |<-- ______|_________|__ _ ____|____|____________ R/W ______/ | R/W high | \_____________ | | |<----PWEH---->| | | |<-------------|-------TcycE----->| |______________| |_________ E ________________/ \__________________/ tR-->||<-- -->||<--tF | || tDDr-->| |<-- || | -->| |<--tRH ___________________|_______________|________________ data ___________________X__valid_data___X____________
Generally, there are no max time requirements on the user except Enable rise and fall times. An LCD module can be driven with just toggle switches for data, RS, and R/W, and a debounced pushbutton on the enable line.
Character generator RAM appears to reside at locations 64-127 and display RAM seems to be at locations 128-255. This is an artifact of the control scheme. They are actually separate noncontiguous blocks of RAM.
The display has 64 bytes of CG RAM, which supports 8 user-definable characters, each defined as a 5X8 character in an 8X8 block. The 5X8 region is right-justified. Note that in 5X10 matrix mode, only 4 user-defined characters are supported, using 11 bytes each.
CG Address CG Data ========== =============== D7-----------D0 x+0 x x x 1 1 1 1 1 ***** x+1 x x x 1 0 0 0 0 * x+2 x x x 1 0 0 0 1 * * x+3 x x x 1 1 1 1 1 = ***** x+4 x x x 1 0 0 0 1 * * x+5 x x x 1 0 0 0 0 * x+6 x x x 1 0 0 0 0 * x+7 x x x 0 0 0 0 0 (cursor line)
Where "x" is the base address for the character: CG0=0, CG1=8, CG2=16, CG3=24, CG4=32, CG5=40, CG6=48, CG7=56.
As you can see in the above figure, each byte of CG data represents 1 row of pixels in the character, with D0 being the rightmost pixel, and D4 being the leftmost (the upper 3 bits are not displayed). The first address for a character is the topmost row, while the 7th is the bottom. (The 8th is ORed with the cursor underbar). A '1' in any pixel position becomes a dark pixel on the display.
CG RAM occupies a separate address space from the data display (DD) RAM. One must set the (first) CG address before writing any CG data. Each write automatically increments/decrements the CG address pointer to the next location. Remember to set the display back to DD addressing mode before trying to write characters to be displayed.
As an example, we'll define character #3 to be the above symbol by first reading the DD address, writing the CG address to the start of the character's RAM, writing the successive rows of pixel data, then restoring the addressing mode back to DD addressing (which requires the DD address we saved at the beginning.
RS R/W D7----D0 == === ======== 0 1 (baaaaaaa) Read current DD address 0 0 01011000 Set CG RAM address to char #3 (3x8=24=11000b) 1 0 00011111 Write top row of pixels 1 0 00010000 : 1 0 00010001 : 1 0 00011111 : 1 0 00010001 : 1 0 00010000 : 1 0 00010000 Write bottom row of pixels 1 0 00000000 Write cursor row (descender) 0 0 1aaaaaaa Restore DD mode (& address)
Note: There should be a 120 uSec delay between successive reads or writes.
(Section 3.5.1 by Doug Girling)
See a clever example of using custom characters to create doubleheight characters in Ian Harries' tutorial at http://www.doc.ic.ac.uk/~ih/doc/lcd/double.html
In the list below, "line 1" is the topmost line, and "line n" is the bottommost line. On each line, the leftmost character has the lowest address, and addresses increase to the right. Also, DD RAM addresses are shown without the 80h mode bit set. Add 80h to the character address (set bit 7) to make the Display Data RAM Address Set command.
"Line 1" (left) addresses are 00h to 07h (0 to 7) "Line 2" (right) addresses are 40h to 47h (64 to 71)
As you write characters to the module, the cursor will automatically increment until you get to the 9th character--you have to move the cursor to address 40h before writing the 9th character on the 1x16 module.
|00|01|02|03|04|05|06|07|40|41|42|43|44|45|46|47|
Rarely, 16x1 modules are formatted as one line, 00h to 0Fh.
Line 1 addresses are 00h to 0Fh (0 to 15) Line 2 addresses are 40h to 4Fh (64 to 79)
|00|01|02|03|04|05|06|07|08|09|0A|0B|0C|0D|0E|0F| |40|41|42|43|44|45|46|47|48|49|4A|4B|4C|4D|4E|4F|
Line 1 addresses are 00h to 13h (0 to 19)
|00|01|02|03|04|05|06|07|08|09|0A|0B|0C|0D|0E|0F|10|11|12|13|
Line 1 addresses are 00h to 13h (0 to 19) Line 2 addresses are 40h to 53h (64 to 83)
|00|01|02|03|04|05|06|07|08|09|0A|0B|0C|0D|0E|0F|10|11|12|13| |40|41|42|43|44|45|46|47|48|49|4A|4B|4C|4D|4E|4F|50|51|52|53|
Line 1 addresses are 00h to 13h (0 to 19) Line 2 addresses are 40h to 53h (64 to 83) Line 3 addresses are 14h to 27h (20 to 39) Line 4 addresses are 54h to 67h (84 to 103)
|00|01|02|03|04|05|06|07|08|09|0A|0B|0C|0D|0E|0F|10|11|12|13| |40|41|42|43|44|45|46|47|48|49|4A|4B|4C|4D|4E|4F|50|51|52|53| |14|15|16|17|18|19|1A|1B|1C|1D|1E|1F|20|21|22|23|24|25|26|27| |54|55|56|57|58|59|5A|5B|5C|5D|5E|5F|60|61|62|63|64|65|66|67|
Line 1 addresses are 00h to 27h (0 to 39) Line 2 addresses are 40h to 67h (64 to 103)
[table omitted, similar to above]
The full 80 bytes of display RAM exist no matter how many characters appear on the display. These extra bytes can be typed on when display window scrolling is enabled, or they can be used to store other information--external data RAM for the CPU, if you like. No RAM exists in the 28h-3Fh and 68h-7Fh blocks.
Modules with Hitachi controllers will properly self-initialize if Vcc rises from 0 to 4.5v in a period between .1mS and 10mS. I suppose an RC circuit would be needed to keep powerup rise time as slow as .1ms, so the manual initialization will be required in most applications. If you do use auto-initialization, it will come up in this mode: 8-bit interface, 1/8 duty cycle (1 line mode), 5x7 font, cursor increment right, no shift. On most displays, you want to switch to 1/16 duty cycle (2 line mode) because for all but the 20x1, there are two logical lines as the controller sees it. If you have a 5x11-size character dot matrix module, you'll want to switch to the 5x10 font as well (the 11th line is the cursor). See the Instruction Set section for details on the commands.
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 1 1 x x x x x=don't care Set 8-bit mode (attention!)
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 1 1 x x x x Set 8-bit mode (attention!)
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 1 1 1 F x x 8-bit operation 1/16 duty cycle F=font, 1 for 5x11 dot matrix 0 for 5x8 dot matrix
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 1 0 0 0 Display off, cursor off, blink off
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 1 1 C B Display on, C=1 for cursor on B=1 for blinking cursor
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 0 0 0 0 0 0 0 1 I S Set entry mode I=1 for cursor move to the right I=0 for cursor move to the left, S=1 for shift display, S=0 for no shift
