| \/ | __ _ _ ____ _____| | | | |\/| |/ _` | '__\ \ / / _ \ | | | | | | (_| | | \ V / __/ | | |_| |_|\__,_|_| \_/ \___|_|_| _ _ ____ _ | | | | | __ ) ___ ___ | |_ | | | |___| _ \ / _ \ / _ \| __| | |_| |___| |_) | (_) | (_) | |_ \___/ |____/ \___/ \___/ \__| ** MARVELL BOARD: SHEEVA PLUG LE U-Boot 1.1.4 (Jul 14 2009 - 06:46:57) Marvell version: 3.4.16 U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006CF120 Soc: MV88F6281 Rev 3 (DDR2) CPU running @ 1200Mhz L2 running @ 400Mhz SysClock = 400Mhz , TClock = 200Mhz DRAM CAS Latency = 5 tRP = 5 tRAS = 18 tRCD=6 DRAM CS[0] base 0x00000000 size 256MB DRAM CS[1] base 0x10000000 size 256MB DRAM Total size 512MB 16bit width Flash: 0 kB Addresses 8M - 0M are saved for the U-Boot usage. Mem malloc Initialization (8M - 7M): Done NAND:512 MB CPU : Marvell Feroceon (Rev 1) Streaming disabled Write allocate disabled USB 0: host mode PEX 0: interface detected no Link. Net: egiga0 [PRIME], egiga1 Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x100000, size 0x400000 Reading data from 0x4ff800 -- 100% complete. 4194304 bytes read: OK ## Booting image at 00800000 ... Image Name: Linux-2.6.22.18 Created: 2009-03-19 9:18:16 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2106696 Bytes = 2 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK OK Starting kernel ... Uncompressing Linux.................................................................... Linux version 2.6.22.18 (dhaval@devbox) (gcc version 4.2.1) #1 Thu Mar 19 14:46:22 IST9 CPU: ARM926EJ-S [56251311] revision 1 (ARMv5TE), cr=00053177 Machine: Feroceon-KW Using UBoot passing parameters structure Memory policy: ECC disabled, Data cache writeback CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets Built 1 zonelists. Total pages: 130048 Kernel command line: console=ttyS0,115200 mtdparts=nand_mtd:0x400000@0x100000(uImage),e PID hash table entries: 2048 (order: 11, 8192 bytes) Console: colour dummy device 80x30 Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 256MB 256MB 0MB 0MB = 512MB total Memory: 515456KB available (3864K code, 257K data, 104K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 CPU Interface ------------- SDRAM_CS0 ....base 00000000, size 256MB SDRAM_CS1 ....base 10000000, size 256MB SDRAM_CS2 ....disable SDRAM_CS3 ....disable PEX0_MEM ....base e8000000, size 128MB PEX0_IO ....base f2000000, size 1MB INTER_REGS ....base f1000000, size 1MB NFLASH_CS ....base fa000000, size 2MB SPI_CS ....base f4000000, size 16MB BOOT_ROM_CS ....no such DEV_BOOTCS ....no such CRYPT_ENG ....base f0000000, size 2MB Marvell Development Board (LSP Version KW_LSP_4.2.7_patch2)-- SHEEVA PLUG Soc: MV88E Detected Tclk 200000000 and SysClk 400000000 MV Buttons Device Load Marvell USB EHCI Host controller #0: c08b8600 PEX0 interface detected no Link. PCI: bus0: Fast back to back transfers enabled SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 Time: kw_clocksource clocksource has been installed. IP route cache hash table entries: 16384 (order: 4, 65536 bytes) TCP established hash table entries: 65536 (order: 7, 524288 bytes) TCP bind hash table entries: 65536 (order: 6, 262144 bytes) TCP: Hash tables configured (established 65536 bind 65536) TCP reno registered RTC registered Use the XOR engines (acceleration) for enhancing the following functions: o RAID 5 Xor calculation o kernel memcpy o kenrel memzero Number of XOR engines to use: 4 cesadev_init(c000c894) mvCesaInit: sessions=640, queue=64, pSram=f0000000 Warning: TS unit is powered off. MV Buttons Driver Load NTFS driver 2.1.28 [Flags: R/O]. JFFS2 version 2.2. (NAND) ?Â?© 2001-2006 Red Hat, Inc. io scheduler noop registered io scheduler anticipatory registered (default) Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A serial8250.0: ttyS1 at MMIO 0xf1012100 (irq = 34) is a 16550A Loading Marvell Ethernet Driver: o Cached descriptors in DRAM o DRAM SW cache-coherency o Single RX Queue support - ETH_DEF_RXQ=0 o Single TX Queue support - ETH_DEF_TXQ=0 o TCP segmentation offload enabled o Receive checksum offload enabled o Transmit checksum offload enabled o Network Fast Processing (Routing) supported o Driver ERROR statistics enabled o Driver INFO statistics enabled o Proc tool API enabled o Rx descripors: q0=128 o Tx descripors: q0=532 o Loading network interface(s): o eth0, ifindex = 1, GbE port = 0 o eth1, ifindex = 2, GbE port = 1 mvFpRuleDb (dfd00000): 16384 entries, 65536 bytes Intel(R) PRO/1000 Network Driver - version 7.3.20-k2-NAPI Copyright (c) 1999-2006 Intel Corporation. e100: Intel(R) PRO/100 Network Driver, 3.5.17-k4-NAPI e100: Copyright(c) 1999-2006 Intel Corporation Integrated Sata device found scsi0 : Marvell SCSI to SATA adapter scsi1 : Marvell SCSI to SATA adapter NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $ NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit) Scanning device for bad blocks 2 cmdlinepart partitions found on MTD device nand_mtd Using command line partition definition Creating 2 MTD partitions on "nand_mtd": 0x00100000-0x00500000 : "uImage" 0x00500000-0x20000000 : "rootfs" ehci_marvell ehci_marvell.70059: Marvell Orion EHCI ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1 ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100 ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected USB Universal Host Controller Interface driver v3.0 usbcore: registered new interface driver usblp drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice i2c /dev entries driver Linux telephony interface: v1.00 Marvell Telephony Driver: mvBoardVoiceAssembleModeGet: TDM not supported(boardId=0x9) assembly=-1,irq=-1 mp_check_config: Error, invalid voice assembley mode md: linear personality registered for level -1 md: raid0 personality registered for level 0 md: raid1 personality registered for level 1 raid6: int32x1 97 MB/s raid6: int32x2 114 MB/s raid6: int32x4 122 MB/s raid6: int32x8 110 MB/s raid6: using algorithm int32x4 (122 MB/s) md: raid6 personality registered for level 6 md: raid5 personality registered for level 5 md: raid4 personality registered for level 4 raid5: measuring checksumming speed arm4regs : 1084.000 MB/sec 8regs : 754.800 MB/sec 32regs : 899.600 MB/sec raid5: using function: arm4regs (1084.000 MB/sec) device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: dm-devel@redhat.com dm_crypt using the OCF package. sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mvsdmmc: irq =28 start f1090000 mvsdmmc: no IRQ detect usbcore: registered new interface driver usbhid drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.14 (Thu May 31 09:03:25 2007 UTC). mvCLAudioCodecRegGet: Error while reading register! mvCLAudioCodecInit: Error - Invalid Cirrus Logic chip/rev ID! Error - Cannot initialize audio decoder.at address =0xff<6>ALSA device list: #0: Marvell mv88fx_snd ALSA driver TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 eth0: link down eth0: started IP-Config: Complete: device=eth0, addr=10.4.50.4, mask=255.255.255.0, gw=10.4.50.5, host=DB88FXX81, domain=, nis-domain=(none), bootserver=10.4.50.5, rootserver=10.4.50.5, rootpath= md: Autodetecting RAID arrays. md: autorun ... md: ... autorun DONE. eth0: link up, full duplex, speed 1 Gbps Empty flash at 0x1999cc4c ends at 0x1999d000 Empty flash at 0x19dbc20c ends at 0x19dbc800 VFS: Mounted root (jffs2 filesystem). Freeing init memory: 104K [ OK ]ting preliminary keymap... * Setting the system clock [ OK ]rting basic networking... [ OK ]rting kernel event manager... [ OK ]ding hardware drivers... * Setting the system clock [ OK ]ding kernel modules... * Loading manual drivers... [ OK ]ting kernel variables (/etc/sysctl.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-console-messages.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-network-security.conf)... * Setting kernel variables (/etc/sysctl.d/10-process-security.conf)... error: y [fail] [ OK ]ting kernel variables (/etc/sysctl.d/10-tcp-timestamps-workaround.conf)... [ OK ]ivating swap... FATAL: Could not load /lib/modules/2.6.22.18/modules.dep: No such file or directory FATAL: Could not load /lib/modules/2.6.22.18/modules.dep: No such file or directory [ OK ]rting early crypto disks... FATAL: Could not load /lib/modules/2.6.22.18/modules.dep: No such file or directory FATAL: Could not load /lib/modules/2.6.22.18/modules.dep: No such file or directory [ OK ]rting remaining crypto disks... * Checking file systems... fsck 1.41.3 (12-Oct-2008) [ OK ] [ OK ]nting local filesystems... [ OK ]ivating swapfile swap... [ OK ]figuring network interfaces... [ OK ]ting up console font and keymap... * Starting system log daemon... Ubuntu jaunty (development branch) debian ttyS0 [ OK ] login: [ OK ] * Starting kernel log daemon... [ OK ] * Starting OpenBSD Secure Shell server sshd [ OK ] * Starting periodic command scheduler crond fat: exports duplicate symbol fat_add_entries (owned by kernel) insmod: error inserting '/boot/fat.ko': -1 Invalid module format
