Register usage: ; ; R3: Holds value used to toggle D4 in PORT D ; R16: Temporary use ; R17: Port B contents to turn on Antenna 1 ; R18: Port B contents to turn on Antenna 2 ; R19: Port B contents to turn on Antenna 3 ; R20: Port B contents to turn on Antenna 4 ; R21: Bit image for PORT D ; R24-R28: General counters ; .equ portd=$12 .equ ddrd=$11 .equ pind=$10 .equ portb=$18 .equ ddrb=$17 .equ pinb=$16 .equ divcount=50 ;number of clock pulse transitions for each antenna switch time .org 0 ;code always begins at address 0 rjmp start .org 4 ;jump over IVT ;*************** main *************** start: rcall initports ;initialize ports rcall delay ;wait about 200 mS for things to settle ; ; Revision 1.1 -- Check PD0, which is now pulled up by the internal resistor. ; If (PD0==1) use the normal clock speed. Otherwise, drop the clock by 12%. ; in r16,pind bst r16,0 ;Check on PD0 brtc slow_code ;If (PD0==0) then run the slow code rjmp normal_code ;Otherwise run the normal code ;********************************************************************** ; ; SLOW_CODE ; ; This is the entry point for the slower (by 12%) code. ; ;********************************************************************** ; ; Static register setups ; slow_code: ldi r16,0b00010000 ; value to toggle D4 in port D mov r3,r16 ldi r17,0b10101001 ; turn on Antenna 1 value ldi r18,0b10100110 ; turn on Antenna 2 value ldi r19,0b10011010 ; turn on Antenna 3 value ldi r20,0b01101010 ; turn on Antenna 4 value ldi r21,0 ; all pins on port D initially LOW ldi r24,divcount ; prime for 1st execution of ANT1 logic ; ; ANTENNA1 portion of cycle ; mainloop: out portb,r17 ;turn on antenna1 loop1: eor r21,r3 ;toggle 100 kHz clock signal nop out portd,r21 ;update I/O port pins ldi r25,divcount ;setup for LOOP2 dec r24 breq ant2 rjmp loop1 ; ; ANTENNA2 portion of cycle ; ant2: out portb,r18 ;turn on antenna2 loop2: eor r21,r3 ;toggle 100 kHz clock signal nop out portd,r21 ;update I/O port pins ldi r26,divcount ;setup for LOOP3 dec r25 breq ant3 rjmp loop2 ; ; ANTENNA3 portion of cycle ; ant3: out portb,r19 ;turn on antenna3 loop3: eor r21,r3 ;toggle 100 kHz clock signal nop out portd,r21 ;update I/O port pins ldi r27,divcount ;setup for LOOP4 dec r26 breq ant4 rjmp loop3 ; ; ANTENNA4 portion of cycle ; ant4: out portb,r20 ;turn on antenna4 ; ; R28 setup in LOOP3 ; loop4: eor r21,r3 ;toggle 100 kHz clock signal nop out portd,r21 ;update I/O port pins ldi r24,divcount ;setup for LOOP1 dec r27 breq mainloop rjmp loop4 ;********************************************************************** ; ; NORMAL_CODE ; ; This is the entry point for the normal speed code. It is identical to ; the code from the original version. ; ;********************************************************************** normal_code: ; ; Static register setups ; ldi r16,0b00010000 ; value to toggle D4 in port D mov r3,r16 ldi r17,0b10101001 ; turn on Antenna 1 value ldi r18,0b10100110 ; turn on Antenna 2 value ldi r19,0b10011010 ; turn on Antenna 3 value ldi r20,0b01101010 ; turn on Antenna 4 value ldi r21,0 ; all pins on port D initially LOW ldi r24,divcount ; prime for 1st execution of ANT1 logic ; ; ANTENNA1 portion of cycle ; nmainloop: out portb,r17 ;turn on antenna1 nloop1: eor r21,r3 ;toggle 100 kHz clock signal out portd,r21 ;update I/O port pins ldi r25,divcount ;setup for LOOP2 dec r24 breq nant2 rjmp nloop1 ; ; ANTENNA2 portion of cycle ; nant2: out portb,r18 ;turn on antenna2 nloop2: eor r21,r3 ;toggle 100 kHz clock signal out portd,r21 ;update I/O port pins ldi r26,divcount ;setup for LOOP3 dec r25 breq nant3 rjmp nloop2 ; ; ANTENNA3 portion of cycle ; nant3: out portb,r19 ;turn on antenna3 nloop3: eor r21,r3 ;toggle 100 kHz clock signal out portd,r21 ;update I/O port pins ldi r27,divcount ;setup for LOOP4 dec r26 breq nant4 rjmp nloop3 ; ; ANTENNA4 portion of cycle ; nant4: out portb,r20 ;turn on antenna4 ; ; R28 setup in LOOP3 ; nloop4: eor r21,r3 ;toggle 100 kHz clock signal out portd,r21 ;update I/O port pins ldi r24,divcount ;setup for LOOP1 dec r27 breq nmainloop rjmp nloop4 ;******************************************************* ; ;Delay: Wait for approximately 200 mS (depends on 1 MHz CPU2 clock) ; ;Destroys R17, R18 ; ;******************************************************* delay: clr r17 clr r18 dl1: dec r17 brne dl1 dec r18 brne dl1 ret ;******************************************************* ; ;Delay50: Wait for approximately 50 mS (depends on 1 MHz CPU2 clock) ; ;Destroys R17, R18 ; ;******************************************************* delay50: clr r17 ldi r18,$40 rjmp dl1 ;******************************************************* ; ;Delay25: Wait for approximately 12 mS (depends on 1 MHz CPU2 clock) ; ;Destroys R17, R18 ; ;******************************************************* delay25: clr r17 ldi r18,$10 rjmp dl1 ; ;******************** initports ****************** ; ;Set port D as all outputs, except for PD0 -- an input with ; a pull-up resistor. ; ;Set port B as all outputs. ;; ;R16 is destroyed. ; ;************************************************* ; initports: ser r16 ;ff->R16 out ddrb,r16 ;make port B all outputs ldi r16,$fe out ddrd,r16 ;make port D all outputs ;except for PD0 ldi r16,$01 out portd,r16 ;turn on the pull-up resistor on PD0 ret
