Open On-Chip Debugger 0.4.0 (2010-11-23-14:20) Licensed under GNU GPL v2 For bug reports, read http://openocd.berlios.de/doc/doxygen/bugs.html Warn : Interface already configured, ignoring srst_only srst_pulls_trst srst_gates_jtag srst_open_drain 1000 kHz Info : max TCK change to: 30000 kHz Info : clock speed 1000 kHz Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3) Info : Embedded ICE version 1 Info : sam7x256.cpu: hardware has 2 breakpoint/watchpoint units Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3) Warn : srst pulls trst - can not reset into halted mode. Issuing halt after reset. target state: halted target halted in ARM state due to debug-request, current mode: Supervisor cpsr: 0x20000093 pc: 0x0000008c Warn : NOTE! DCC downloads have not been enabled, defaulting to slow memory writes. Type 'help dcc'. Warn : NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'. at91sam7 gpnvm dcc downloads are enabled background polling: on TAP: sam7x256.cpu (enabled) target state: halted target halted in ARM state due to debug-request, current mode: Supervisor cpsr: 0x20000093 pc: 0x0000008c flash 'at91sam7' found at 0x00100000 auto erase enabled auto unlock enabled wrote 16384 bytes from file at91sam7x_getting_started_flash.bin in 4.020006s (3.980 kb/s) Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3) Warn : NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'. shutdown command invoked
