Marvell>> printenv baudrate=115200 loads_echo=0 rootpath=/mnt/ARM_FS/ CASset=min MALLOC_len=1 ethprime=egiga0 bootargs_end=:::DB88FXX81:eth0:none image_name=uImage ethmtu=1500 mvPhoneConfig=mv_phone_config=dev0:fxs,dev1:fxs mvNetConfig=mv_net_config=(00:11:88:0f:62:81,0:1:2:3),mtu=1500 usb0Mode=host yuk_ethaddr=00:00:00:EE:51:81 nandEcc=1bit netretry=no rcvrip=169.254.100.100 loadaddr=0x02000000 autoload=no ethact=egiga0 ethaddr=00:50:43:01:96:CF run_diag=no arcNumber=2097 bootargs_root=root=/dev/sda1 rootdelay=15 filesize=30eef8 fileaddr=2000000 netmask=255.255.255.0 ipaddr=192.168.178.26 serverip=192.168.178.20 console_1=console=ttyS0,115200 console_orig=console=ttyS0,115200 mtdparts=nand_mtd:0xc0000@0(uboot)ro,0x1ff00000@0x100000(root) bootargs_orig=console=ttyS0,115200 mtdparts=nand_mtd:0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs) rw root=/dev/mtdblock1 rw ip=10.4.50.4:10.4.50.5:10.4.50.5:255.255.255.0:DB88FXX81:eth0:none bootcmd_tftp=tftpboot 0x02000000 sheeva-3.5.7-uImage; tftpboot 0x08000000 initrd; bootm 0x02000000 0x08000000 bootcmd_orig=nand read.e 0x800000 0x100000 0x400000; bootm 0x800000 standalone=fsload 0x2000000 $(image_name);setenv bootargs $(console_orig) root=/dev/mtdblock0 rw ip=$(ipaddr):$(serverip)$(bootargs_end) $(mvPhoneConfig); bootm 0x2000000; bootcmd_tftp_1=tftpboot 0x02000000 sheeva-3.5.7-uImage; bootm 0x02000000 bootcmd_usb=usb start; fatload usb 0:1 0x02000000 sheeva-3.5.7-uImage; bootm 0x02000000 bootargs_1=console=ttyS0,115200 mtdparts=orion_nand:0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs) rw root=/dev/mtdblock1 rw ip=10.4.50.4:10.4.50.5:10.4.50.5:255.255.255.0:DB88FXX81:eth0:none stdin=serial stdout=serial stderr=serial console=console=ttyS0,115200 mtdparts=nand_mtd:0xc0000@0(uboot)ro,0x1ff00000@0x100000(root) mainlineLinux=yes enaMonExt=no enaCpuStream=no enaWrAllo=no pexMode=RC disL2Cache=no setL2CacheWT=yes disL2Prefetch=yes enaICPref=yes enaDCPref=yes sata_dma_mode=yes netbsd_en=no vxworks_en=no bootdelay=3 disaMvPnp=no enaAutoRecovery=yes bootcmd_2=setenv bootargs $(bootargs_1); run bootcmd_tftp_1 bootcmd_1=setenv bootargs $(bootargs_orig); run bootcmd_orig bootcmd_3=setenv bootargs $(console_1); run bootcmd_tftp bootcmd=setenv bootargs $(console_1); run bootcmd_tftp Environment size: 2244/131068 bytes Marvell>> saveenv Saving Environment to NAND... Erasing Nand...Writing to Nand... done Marvell>> reset __ __ _ _ | \/ | __ _ _ ____ _____| | | | |\/| |/ _` | '__\ \ / / _ \ | | | | | | (_| | | \ V / __/ | | |_| |_|\__,_|_| \_/ \___|_|_| _ _ ____ _ | | | | | __ ) ___ ___ | |_ | | | |___| _ \ / _ \ / _ \| __| | |_| |___| |_) | (_) | (_) | |_ \___/ |____/ \___/ \___/ \__| ** MARVELL BOARD: SHEEVA PLUG LE U-Boot 1.1.4 (Jul 14 2009 - 06:46:57) Marvell version: 3.4.16 U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006CF120 Soc: MV88F6281 Rev 3 (DDR2) CPU running @ 1200Mhz L2 running @ 400Mhz SysClock = 400Mhz , TClock = 200Mhz DRAM CAS Latency = 5 tRP = 5 tRAS = 18 tRCD=6 DRAM CS[0] base 0x00000000 size 256MB DRAM CS[1] base 0x10000000 size 256MB DRAM Total size 512MB 16bit width Flash: 0 kB Addresses 8M - 0M are saved for the U-Boot usage. Mem malloc Initialization (8M - 7M): Done NAND:512 MB CPU : Marvell Feroceon (Rev 1) Streaming disabled Write allocate disabled USB 0: host mode PEX 0: interface detected no Link. Net: egiga0 [PRIME], egiga1 Hit any key to stop autoboot: 0 Using egiga0 device TFTP from server 192.168.178.20; our IP address is 192.168.178.26 Filename 'sheeva-3.5.7-uImage'. Load address: 0x2000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ########################################## done Bytes transferred = 3206904 (30eef8 hex) Using egiga0 device TFTP from server 192.168.178.20; our IP address is 192.168.178.26 Filename 'initrd'. Load address: 0x8000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# # done Bytes transferred = 3331626 (32d62a hex) ## Booting image at 02000000 ... Image Name: Linux-3.5.7 Created: 2012-10-14 2:14:11 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3206840 Bytes = 3.1 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK OK ## Loading Ramdisk Image at 08000000 ... Image Name: initrd.ext2.gz Created: 2009-08-19 14:24:20 UTC Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3331562 Bytes = 3.2 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 Initializing cgroup subsys cpu Linux version 3.5.7 (kelly@bbb.internal) (gcc version 4.7.3 20121001 (prerelease) (Linaro GCC 4.7-2012.10) ) #2 PREEMPT Sat Oct 13 20:14:07 MDT 2012 CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: Marvell SheevaPlug Reference Board Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: console=ttyS0,115200 PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 509672k/509672k available, 14616k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc05dd77c (5974 kB) .init : 0xc05de000 - 0xc060a22c ( 177 kB) .data : 0xc060c000 - 0xc064ec50 ( 268 kB) .bss : 0xc064ec74 - 0xc06a9994 ( 364 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:114 sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 21474ms Console: colour dummy device 80x30 Calibrating delay loop... 1191.11 BogoMIPS (lpj=5955584) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 Initializing cgroup subsys cpuacct Initializing cgroup subsys devices Initializing cgroup subsys freezer Initializing cgroup subsys blkio CPU: Testing write buffer coherency: ok Setting up static identity map for 0x46bf80 - 0x46bfbc devtmpfs: initialized NET: Registered protocol family 16 Kirkwood: MV88F6281-A1, TCLK=200000000. Feroceon L2: Enabling L2 Feroceon L2: Cache support initialised. bio: create slab at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource orion_clocksource FS-Cache: Loaded NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (no cpio magic); looks like an initrd Freeing initrd memory: 3252K NFS: Registering the id_resolver key type Key type id_resolver registered Key type id_legacy registered FS-Cache: Netfs 'nfs' registered for caching jffs2: version 2.2. (NAND) ?© 2001-2006 Red Hat, Inc. JFS: nTxBlock = 4007, nTxLock = 32057 msgmni has been set to 1001 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mv_xor_shared mv_xor_shared.0: Marvell shared XOR driver mv_xor_shared mv_xor_shared.1: Marvell shared XOR driver mv_xor mv_xor.0: Marvell XOR: ( xor cpy ) mv_xor mv_xor.1: Marvell XOR: ( xor fill cpy ) mv_xor mv_xor.2: Marvell XOR: ( xor cpy ) mv_xor mv_xor.3: Marvell XOR: ( xor fill cpy ) Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A console [ttyS0] enabled brd: module loaded loop: module loaded NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit), page size: 2048, OOB size: 64 Scanning device for bad blocks Creating 3 MTD partitions on "orion_nand": 0x000000000000-0x000000100000 : "u-boot" 0x000000100000-0x000000500000 : "uImage" 0x000000500000-0x000020000000 : "root" mv643xx_eth: MV-643xx 10/100/1000 ethernet driver version 1.4 mv643xx_eth smi: probed mv643xx_eth_port mv643xx_eth_port.0: eth0: port 0 with MAC address 00:50:43:01:96:cf ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver orion-ehci orion-ehci.0: Marvell Orion EHCI orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1 orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000 orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-cypress usbcore: registered new interface driver ums-datafab usbcore: registered new interface driver ums-freecom usbcore: registered new interface driver ums-jumpshot usbcore: registered new interface driver ums-sddr09 usbcore: registered new interface driver ums-sddr55 mousedev: PS/2 mouse device common for all mice rtc-mv rtc-mv: rtc core: registered rtc-mv as rtc0 i2c /dev entries driver cpuidle: using governor ladder cpuidle: using governor menu sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: mvsdio driver initialized, lacking card detect (fall back to polling) sdhci-pltfm: SDHCI platform and OF driver helper usbcore: registered new interface driver usbhid usbhid: USB HID core driver zram: num_devices not specified. Using default: 1 zram: Creating 1 devices ... TCP: cubic registered NET: Registered protocol family 10 NET: Registered protocol family 17 lib80211: common routines for IEEE802.11 drivers Key type dns_resolver registered registered taskstats version 1 rtc-mv rtc-mv: setting system clock to 2012-06-19 02:23:35 UTC (1340072615) RAMDISK: gzip image found at block 0 EXT2-fs (ram0): warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem) on device 1:0. ***************************************************************** sheevaplug installer version 1.0 **** PRESS ENTER TO STOP THE COUNT DOWN **** Will flash tarball from USB disk to SD card /dev/mmcblkp0 **** This will wipe out EVERYTHING on the attached SD card **** Will wait 10 seconds before the flash. ****** ERROR - must specify in Kernel bootargs the install_type ****** nand- burn plug internal NAND flash ****** mmc- burn connect Memory Card (SD/SDHC) Please press Enter to activate this console. #
