Marvell>> printenv baudrate=115200 loads_echo=0 rootpath=/mnt/ARM_FS/ CASset=min MALLOC_len=1 ethprime=egiga0 bootargs_end=:::DB88FXX81:eth0:none image_name=uImage ethmtu=1500 mvPhoneConfig=mv_phone_config=dev0:fxs,dev1:fxs mvNetConfig=mv_net_config=(00:11:88:0f:62:81,0:1:2:3),mtu=1500 usb0Mode=host yuk_ethaddr=00:00:00:EE:51:81 nandEcc=1bit netretry=no rcvrip=169.254.100.100 loadaddr=0x02000000 autoload=no ethact=egiga0 ethaddr=00:50:43:01:96:CF run_diag=no arcNumber=2097 bootargs_root=root=/dev/sda1 rootdelay=15 filesize=30eef8 fileaddr=2000000 netmask=255.255.255.0 ipaddr=192.168.178.26 serverip=192.168.178.20 console_1=console=ttyS0,115200 console_orig=console=ttyS0,115200 mtdparts=nand_mtd:0xc0000@0(uboot)ro,0x1ff00000@0x100000(root) bootargs_orig=console=ttyS0,115200 mtdparts=nand_mtd:0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs) rw root=/dev/mtdblock1 rw ip=10.4.50.4:10.4.50.5:10.4.50.5:255.255.255.0:DB88FXX81:eth0:none bootcmd_orig=nand read.e 0x800000 0x100000 0x400000; bootm 0x800000 standalone=fsload 0x2000000 $(image_name);setenv bootargs $(console_orig) root=/dev/mtdblock0 rw ip=$(ipaddr):$(serverip)$(bootargs_end) $(mvPhoneConfig); bootm 0x2000000; bootcmd_tftp_1=tftpboot 0x02000000 sheeva-3.5.7-uImage; bootm 0x02000000 bootcmd_usb=usb start; fatload usb 0:1 0x02000000 sheeva-3.5.7-uImage; bootm 0x02000000 bootcmd_1=setenv bootargs $(bootargs_orig); run bootcmd_orig bootcmd_tftp_2=tftpboot 0x02000000 sheeva-3.5.7-uImage; tftpboot 0x08000000 initrd; bootm 0x02000000 0x08000000 bootcmd_2=setenv bootargs $(console_1); run bootcmd_tftp_2 bootargs_1=console=ttyS0,115200 mtdparts=orion_nand:0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs) root=/dev/mtdblock1 rw rootfstype=jffs2 ip=10.4.50.4:10.4.50.5:10.4.50.5:255.255.255.0:DB88FXX81:eth0:none bootcmd_3=setenv bootargs $(bootargs_1); run bootcmd_tftp_1 bootcmd_test=setenv bootargs $(bootargs_test); run bootcmd_tftp_1 bootcmd=setenv bootargs $(bootargs_test); run bootcmd_tftp_1 console=console=ttyS0,115200 mtdparts=nand_mtd:0xc0000@0(uboot)ro,0x1ff00000@0x100000(root) bootargs_test=console=ttyS0,115200 mtdparts=orion_nand::0xc0000@0(uboot)ro,0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs)rw root=/dev/mtdblock2 rw rootfstype=jffs2 stdin=serial stdout=serial stderr=serial mainlineLinux=yes enaMonExt=no enaCpuStream=no enaWrAllo=no pexMode=RC disL2Cache=no setL2CacheWT=yes disL2Prefetch=yes enaICPref=yes enaDCPref=yes sata_dma_mode=yes netbsd_en=no vxworks_en=no bootdelay=3 disaMvPnp=no enaAutoRecovery=yes Environment size: 2505/131068 bytes Marvell>> boot Using egiga0 device TFTP from server 192.168.178.20; our IP address is 192.168.178.26 Filename 'sheeva-3.5.7-uImage'. Load address: 0x2000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ########################################## done Bytes transferred = 3206904 (30eef8 hex) ## Booting image at 02000000 ... Image Name: Linux-3.5.7 Created: 2012-10-14 2:14:11 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3206840 Bytes = 3.1 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 Initializing cgroup subsys cpu Linux version 3.5.7 (kelly@bbb.internal) (gcc version 4.7.3 20121001 (prerelease) (Linaro GCC 4.7-2012.10) ) #2 PREEMPT Sat Oct 13 20:14:07 MDT 2012 CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: Marvell SheevaPlug Reference Board Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: console=ttyS0,115200 mtdparts=orion_nand::0xc0000@0(uboot)ro,0x400000@0x100000(uImage),0x1fb00000@0x500000(rootfs)rw root=/dev/mtdblock2 rw rootfstype=jffs2 PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 512928k/512928k available, 11360k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc05dd77c (5974 kB) .init : 0xc05de000 - 0xc060a22c ( 177 kB) .data : 0xc060c000 - 0xc064ec50 ( 268 kB) .bss : 0xc064ec74 - 0xc06a9994 ( 364 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:114 sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 21474ms Console: colour dummy device 80x30 Calibrating delay loop... 1191.11 BogoMIPS (lpj=5955584) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 Initializing cgroup subsys cpuacct Initializing cgroup subsys devices Initializing cgroup subsys freezer Initializing cgroup subsys blkio CPU: Testing write buffer coherency: ok Setting up static identity map for 0x46bf80 - 0x46bfbc devtmpfs: initialized NET: Registered protocol family 16 Kirkwood: MV88F6281-A1, TCLK=200000000. Feroceon L2: Enabling L2 Feroceon L2: Cache support initialised. bio: create slab at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource orion_clocksource FS-Cache: Loaded NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NFS: Registering the id_resolver key type Key type id_resolver registered Key type id_legacy registered FS-Cache: Netfs 'nfs' registered for caching jffs2: version 2.2. (NAND) ?© 2001-2006 Red Hat, Inc. JFS: nTxBlock = 4007, nTxLock = 32058 msgmni has been set to 1001 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mv_xor_shared mv_xor_shared.0: Marvell shared XOR driver mv_xor_shared mv_xor_shared.1: Marvell shared XOR driver mv_xor mv_xor.0: Marvell XOR: ( xor cpy ) mv_xor mv_xor.1: Marvell XOR: ( xor fill cpy ) mv_xor mv_xor.2: Marvell XOR: ( xor cpy ) mv_xor mv_xor.3: Marvell XOR: ( xor fill cpy ) Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A console [ttyS0] enabled brd: module loaded loop: module loaded NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit), page size: 2048, OOB size: 64 Scanning device for bad blocks mtd: partition size too small (0) Creating 3 MTD partitions on "orion_nand": 0x000000000000-0x000000100000 : "u-boot" 0x000000100000-0x000000500000 : "uImage" 0x000000500000-0x000020000000 : "root" mv643xx_eth: MV-643xx 10/100/1000 ethernet driver version 1.4 mv643xx_eth smi: probed mv643xx_eth_port mv643xx_eth_port.0: eth0: port 0 with MAC address 00:50:43:01:96:cf ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver orion-ehci orion-ehci.0: Marvell Orion EHCI orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1 orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000 orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-cypress usbcore: registered new interface driver ums-datafab usbcore: registered new interface driver ums-freecom usbcore: registered new interface driver ums-jumpshot usbcore: registered new interface driver ums-sddr09 usbcore: registered new interface driver ums-sddr55 mousedev: PS/2 mouse device common for all mice rtc-mv rtc-mv: rtc core: registered rtc-mv as rtc0 i2c /dev entries driver cpuidle: using governor ladder cpuidle: using governor menu sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: mvsdio driver initialized, lacking card detect (fall back to polling) sdhci-pltfm: SDHCI platform and OF driver helper usbcore: registered new interface driver usbhid usbhid: USB HID core driver zram: num_devices not specified. Using default: 1 zram: Creating 1 devices ... TCP: cubic registered NET: Registered protocol family 10 NET: Registered protocol family 17 lib80211: common routines for IEEE802.11 drivers Key type dns_resolver registered registered taskstats version 1 rtc-mv rtc-mv: setting system clock to 2012-06-20 23:19:57 UTC (1340234397) jffs2: Empty flash at 0x10097c80 ends at 0x10098000 jffs2: Empty flash at 0x1013c3e4 ends at 0x1013c800 jffs2: Empty flash at 0x1999cc4c ends at 0x1999d000 jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found. VFS: Mounted root (jffs2 filesystem) on device 31:2. devtmpfs: mounted Freeing init memory: 176K [ OK ]ting preliminary keymap... * Setting the system clock [ OK ]rting basic networking... * Starting kernel event manager... udevd (715): /proc/715/oom_adj is deprecated, please use /proc/715/oom_score_adj instead. udev: starting version 136 [ OK ] * Loading hardware drivers... end_request: I/O error, dev mtdblock0, sector 0 Buffer I/O error on device mtdblock0, logical block 0 uncorrectable error : uncorrectable error : end_request: I/O error, dev mtdblock0, sector 8 Buffer I/O error on device mtdblock0, logical block 1 uncorrectable error : uncorrectable error : end_request: I/O error, dev mtdblock0, sector 16 Buffer I/O error on device mtdblock0, logical block 2 uncorrectable error : end_request: I/O error, dev mtdblock0, sector 24 Buffer I/O error on device mtdblock0, logical block 3 end_request: I/O error, dev mtdblock0, sector 0 Buffer I/O error on device mtdblock0, logical block 0 IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ OK ] * Setting the system clock [ OK ]ding kernel modules... * Loading manual drivers... [ OK ]ting kernel variables (/etc/sysctl.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-console-messages.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-network-security.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-process-security.conf)... [ OK ]ting kernel variables (/etc/sysctl.d/10-tcp-timestamps-workaround.conf)... [ OK ]ivating swap... FATAL: Could not load /lib/modules/3.5.7/modules.dep: No such file or directory FATAL: Could not load /lib/modules/3.5.7/modules.dep: No such file or directory [ OK ]rting early crypto disks... FATAL: Could not load /lib/modules/3.5.7/modules.dep: No such file or directory FATAL: Could not load /lib/modules/3.5.7/modules.dep: No such file or directory [ OK ]rting remaining crypto disks... * Checking file systems... fsck 1.41.3 (12-Oct-2008) [ OK ] [ OK ]nting local filesystems... [ OK ]ivating swapfile swap... mv: preserving permissions for `/var/log/udev': Permission denied [ OK ]figuring network interfaces... [ OK ]ting up console font and keymap... * Starting system log daemon... Ubuntu jaunty (development branch) debian ttyS0 [ OK ] login: * Starting kernel log daemon... Killed [fail] [ OK ] * Starting OpenBSD Secure Shell server sshd [ OK ] * Starting periodic command scheduler crond fat: version magic '2.6.22.18 mod_unload ARMv5 ' should be '3.5.7 preempt mod_unload ARMv5 ' insmod: error inserting '/boot/fat.ko': -1 Invalid module format Ubuntu jaunty (development branch) debian ttyS0 debian login: root Password: Last login: Wed Jun 20 23:19:16 UTC 2012 on ttyS0 Linux debian 3.5.7 #2 PREEMPT Sat Oct 13 20:14:07 MDT 2012 armv5tel The programs included with the Ubuntu system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. To access official Ubuntu documentation, please visit: http://help.ubuntu.com/ root@debian:~# cd .. root@debian:/# ls -al total 0 drwxr-xr-x 21 root root 0 Jan 1 1970 . drwxr-xr-x 21 root root 0 Jan 1 1970 .. drwxr-xr-x 2 root root 0 Nov 14 2008 bin drwxr-xr-x 2 root root 0 Jan 25 2009 boot drwxr-xr-x 10 root root 3720 Jun 20 23:21 dev drwxr-xr-x 56 root root 0 Jun 20 23:20 etc drwxr-xr-x 2 root root 0 Dec 23 2008 home drwxr-xr-x 11 root root 0 Jan 12 2009 lib drwxr-xr-x 2 root root 0 Jan 19 2009 media drwxr-xr-x 2 root root 0 Jan 26 2009 mnt drwxr-xr-x 2 root root 0 Jan 19 2009 opt dr-xr-xr-x 57 root root 0 Jan 1 1970 proc drwxr-xr-x 4 root root 0 Jun 7 2010 root drwxr-xr-x 2 root root 0 Mar 18 2009 sbin drwxr-xr-x 2 root root 0 Nov 13 2008 selinux drwxr-xr-x 2 root root 0 Jan 19 2009 srv dr-xr-xr-x 11 root root 0 Jun 20 23:20 sys drwxr-xr-x 5 root root 0 Jan 26 2009 tmp drwxr-xr-x 15 root root 0 Nov 13 2008 usr drwxr-xr-x 13 root root 0 Dec 23 2008 var root@debian:/#
