library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_logic_unsigned.all; use IEEE.STD_logic_arith.all; entity usb_control is generic(buswidth : natural := 8); Port (usb_clk : in STD_LOGIC; TXE : in STD_LOGIC; RXF : in STD_LOGIC; data_TX : in STD_LOGIC_VECTOR(buswidth-1 downto 0); rdempty : in std_logic; rdreq : out STD_LOGIC; WR : out STD_LOGIC; OE : out STD_LOGIC; RD : out STD_LOGIC; SIWU : out STD_LOGIC; usb_data : inout std_logic_vector(buswidth-1 downto 0)); end usb_control; architecture Behavioral of usb_control is signal ft2232_wait : integer range 0 to 1 := 0; signal bus_oe_mode : integer range 0 to 3 := 0; signal state_tx : std_logic; signal state_rx : std_logic; signal tx : std_logic; signal rx : std_logic; signal data_rx : std_logic_vector(buswidth-1 downto 0) := x"00"; begin SIWU <= '1'; --If not used tie this pin to Vcc tx <= '1' when TXE = '0' and ft2232_wait = 1 and rdempty = '0' else '0'; rx <= '1' when RXF = '0' else '0'; state_tx<= '1' when tx_ = '1' else '0'; state_rx <= '1' when bus_oe_mode > 1 and rx = '1' and tx = '0' else '0'; rdreq <= '1' when state_tx = '1' else '0'; WR <= '0' when state_tx = '1' else '1'; RD <= '0' when state_rx = '1' else '1'; OE <= '0' when bus_oe_mode > 0 else '1'; usb_data <= data_tx when state_tx = '1' else (others => 'Z'); data_rx <= usb_data when bus_oe_mode > 0 and RXF = '0'; process begin wait until rising_edge(usb_clk); if (tx = '0' or rx = '1') then bus_oe_mode <= 0; if (TXE = '0') then ft2232_wait <= ft2232_wait + 1; else ft2232_wait <= 0; end if; elsif (rx = '1') then ft2232_wait <= 0; if (bus_oe_mode < 3) then bus_oe_mode <= bus_oe_mode + 1; end if; end if; end process; end Behavioral;
