.include "ATxmega128A1def.inc" .def tempreg=r16 .def counterreg=r17 .def outputreg=r22 .equ DIR_PORTA_MASK=0xA8 .equ DIR_PORTB_MASK=0x02 .equ KEY_INTERRUPT_MASK=0x04 .org 0x0 rjmp RESET .org PORTB_INT0_vect rjmp ISR .org INT_VECTORS_SIZE RESET: ; init section ; init counter variable ser outputreg ; initialize 32Mhz clock call SET_CLOCK_32MHZ call INIT_INTR ; init PORTs ; init PORTA (LEDs) ldi tempreg,DIR_PORTA_MASK sts PORTA_DIR,tempreg ; init PORTB ldi tempreg,DIR_PORTB_MASK sts PORTB_DIR,tempreg ; set pull up resitors for PORTB ; because there're the keys we need ; additionally we have to set the right ; input/sense configuration ; we want to sense every falling edge ldi tempreg,PORT_OPC_PULLUP_gc | PORT_ISC_FALLING_gc sts PORTB_PIN0CTRL,tempreg sts PORTB_PIN2CTRL,tempreg ; init LEDs ; we do not want them be lit from the beginning ser tempreg sts PORTA_OUT,tempreg sts PORTB_OUT,tempreg ; global interrupt flag sei MAIN: call READKEYS rjmp MAIN READKEYS: ; check if keys are pressed lds tempreg,PORTB_IN ; is SW1 pressed? sbrs tempreg,2 call SW1_PROC sbrs tempreg,0 call SW2_PROC ret INIT_EVSYS: ; to be implemented... ret INIT_INTR: ; activate port interrupt ldi tempreg,PORT_INT0LVL_LO_gc sts PORTB_INTCTRL,tempreg ; select pin2 ldi tempreg,KEY_INTERRUPT_MASK sts PORTB_INT0MASK,tempreg ; set PMIC ldi tempreg,PMIC_LOLVLEN_bm sts PMIC_CTRL,tempreg ret SW1_PROC: ; wait ... call DELAY_100MS ; set LEDs ; modifying register "output" to set LEDs sbrc counterreg,0 cbr outputreg,0x08 sbrc counterreg,1 cbr outputreg,0x20 sbrc counterreg,2 cbr outputreg,0x80 sbrc counterreg,3 cbr outputreg,0x02 sts PORTA_OUT,outputreg sts PORTB_OUT,outputreg call DELAY_1S call CLEAR ret SW2_PROC: ; wait ... call DELAY_100MS ; init -> Z-Pointer ldi ZL, low(TCC0_CNT<<1) ldi ZH, high(TCC0_CNT<<1) lpm tempreg,Z sbrc tempreg,0 cbr outputreg,0x08 sbrc tempreg,1 cbr outputreg,0x20 sbrc tempreg,2 cbr outputreg,0x80 sbrc tempreg,3 cbr outputreg,0x02 sts PORTA_OUT,outputreg sts PORTB_OUT,outputreg call DELAY_1S call CLEAR ret CLEAR: ; clr LEDs after 1s and ; jump back to MAIN ; new operation is possible ; reset counter clr counterreg ldi tempreg,0x00 sts TCC0_CNT,tempreg sts TCC0_CNT+1,tempreg ser outputreg sts PORTA_OUT,outputreg sts PORTB_OUT,outputreg ret SET_CLOCK_32MHZ: ; configure XOSC ; configure with 2 -9 MHz and 1KCLK ldi tempreg,OSC_FRQRANGE_2TO9_gc | OSC_XOSCSEL_XTAL_1KCLK_gc sts OSC_XOSCCTRL,tempreg ; configure PLL ; PLL with factor 4 (constant PLLFAC2 writes factor 4) ; set source fpr PLL -> external oscillator ldi tempreg,OSC_PLLSRC_XOSC_gc | OSC_PLLFAC2_bm sts OSC_PLLCTRL,tempreg ; enable PLL and XTAL ldi tempreg,OSC_PLLEN_bm | OSC_XOSCEN_bm | OSC_RC2MEN_bp sts OSC_CTRL,tempreg STATUSLOOP: ; PLL must be ready ; checking PLLEN bit lds tempreg,OSC_STATUS ; loading state sbrs tempreg,OSC_PLLRDY_bp rjmp STATUSLOOP ; disable change protection ldi tempreg,CCP_IOREG_gc sts CPU_CCP,tempreg ; release protection for 4 cycles ldi tempreg,CLK_SCLKSEL_PLL_gc sts CLK_CTRL,tempreg ret DELAY_100MS: ldi r18,0x30 DELAY_100MS_1: ldi r19,0xFF DELAY_100MS_2: ldi r20,0xFF DELAY_100MS_3: dec r20 brne DELAY_100MS_3 dec r19 brne DELAY_100MS_2 dec r18 brne DELAY_100MS_1 ret DELAY_1S: ldi r21,0x0A DELAY_1S_1: call DELAY_100MS dec r21 brne DELAY_1S_1 ret ISR: push tempreg lds tempreg,CPU_SREG push tempreg ; counterreg will be only incremented ; when counterreg is below 16 ldi tempreg,0x0F cpse tempreg,counterreg inc counterreg pop tempreg sts CPU_SREG,tempreg pop tempreg reti
