I [27/Jan/2013:19:06:42 +0000] Saving job.cache... I [27/Jan/2013:19:06:42 +0000] Listening to 0.0.0.0:631 (IPv4) I [27/Jan/2013:19:06:42 +0000] Listening to [v1.::]:631 (IPv6) I [27/Jan/2013:19:06:42 +0000] Listening to /var/run/cups/cups.sock (Domain) I [27/Jan/2013:19:06:42 +0000] Remote access is enabled. D [27/Jan/2013:19:06:42 +0000] Added auto ServerAlias raspberrypi I [27/Jan/2013:19:06:42 +0000] Loaded configuration file "/etc/cups/cupsd.conf" I [27/Jan/2013:19:06:42 +0000] Using default TempDir of /var/spool/cups/tmp... I [27/Jan/2013:19:06:43 +0000] Configured for up to 100 clients. I [27/Jan/2013:19:06:43 +0000] Allowing up to 100 client connections per host. I [27/Jan/2013:19:06:43 +0000] Using policy "default" as the default. I [27/Jan/2013:19:06:43 +0000] Full reload is required. I [27/Jan/2013:19:06:43 +0000] Loaded MIME database from "/usr/share/cups/mime" and "/etc/cups": 38 types, 55 filters... D [27/Jan/2013:19:06:43 +0000] Loading printer GEBE-TINI... D [27/Jan/2013:19:06:43 +0000] load_ppd: Loading /var/cache/cups/GEBE-TINI.data... D [27/Jan/2013:19:06:43 +0000] Calling DeleteDevice(cups-GEBE-TINI) D [27/Jan/2013:19:06:43 +0000] failed to DeleteDevice: org.freedesktop.DBus.Error.InvalidArgs:Type of message, `(s)', does not match expected type `(o)' D [27/Jan/2013:19:06:43 +0000] Using profile id of GEBE-TINI-Gray.. D [27/Jan/2013:19:06:43 +0000] Calling CreateProfile(GEBE-TINI-Gray..,temp) D [27/Jan/2013:19:06:43 +0000] created profile /org/freedesktop/ColorManager/profiles/GEBE_TINI_Gray__ I [27/Jan/2013:19:06:43 +0000] Registering ICC color profiles for "GEBE-TINI" D [27/Jan/2013:19:06:43 +0000] Calling CreateDevice(cups-GEBE-TINI,temp) D [27/Jan/2013:19:06:43 +0000] created device /org/freedesktop/ColorManager/devices/cups_GEBE_TINI D [27/Jan/2013:19:06:43 +0000] Calling /org/freedesktop/ColorManager/devices/cups_GEBE_TINI:AddProfile(/org/freedesktop/ColorManager/profiles/GEBE_TINI_Gray__) [soft] D [27/Jan/2013:19:06:43 +0000] cupsdRegisterPrinter(p=0x41e21e28(GEBE-TINI)) I [27/Jan/2013:19:06:43 +0000] Loading job cache file "/var/cache/cups/job.cache"... D [27/Jan/2013:19:06:43 +0000] [Job 6] Loading from cache... I [27/Jan/2013:19:06:43 +0000] Full reload complete. D [27/Jan/2013:19:06:43 +0000] cupsdCleanFiles(path="/var/spool/cups/tmp", pattern="(null)") I [27/Jan/2013:19:06:43 +0000] Cleaning out old files in "/var/spool/cups/tmp"... D [27/Jan/2013:19:06:43 +0000] cupsdCleanFiles(path="/var/cache/cups", pattern="*.ipp") I [27/Jan/2013:19:06:43 +0000] Cleaning out old files in "/var/cache/cups"... I [27/Jan/2013:19:06:43 +0000] Listening to 0.0.0.0:631 on fd 9... E [27/Jan/2013:19:06:43 +0000] Unable to open listen socket for address [v1.::]:631 - Address family not supported by protocol. I [27/Jan/2013:19:06:43 +0000] Listening to /var/run/cups/cups.sock:631 on fd 10... I [27/Jan/2013:19:06:43 +0000] Resuming new connection processing... D [27/Jan/2013:19:06:43 +0000] Avahi client started D [27/Jan/2013:19:06:43 +0000] cupsdRegisterPrinter(p=0x41e21e28(GEBE-TINI)) D [27/Jan/2013:19:06:43 +0000] cupsdSetBusyState: newbusy="Not busy", busy="Not busy" D [27/Jan/2013:19:06:43 +0000] Discarding unused server-started event... D [27/Jan/2013:19:06:44 +0000] Report: clients=0 D [27/Jan/2013:19:06:44 +0000] Report: jobs=1 D [27/Jan/2013:19:06:44 +0000] Report: jobs-active=0 D [27/Jan/2013:19:06:44 +0000] Report: printers=1 D [27/Jan/2013:19:06:44 +0000] Report: printers-implicit=0 D [27/Jan/2013:19:06:44 +0000] Report: stringpool-string-count=498 D [27/Jan/2013:19:06:44 +0000] Report: stringpool-alloc-bytes=7768 D [27/Jan/2013:19:06:44 +0000] Report: stringpool-total-bytes=9472 D [27/Jan/2013:19:07:18 +0000] cupsdAcceptClient: 15 from localhost (Domain) D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 POST / HTTP/1.1 D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients", busy="Not busy" D [27/Jan/2013:19:07:18 +0000] cupsdAuthorize: No authentication data provided. D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 1.1 CUPS-Get-Default 1 D [27/Jan/2013:19:07:18 +0000] CUPS-Get-Default D [27/Jan/2013:19:07:18 +0000] Returning IPP successful-ok for CUPS-Get-Default (no URI) from localhost D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Not busy", busy="Active clients" D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 POST /printers/GEBE-TINI HTTP/1.1 D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients", busy="Not busy" D [27/Jan/2013:19:07:18 +0000] cupsdAuthorize: No authentication data provided. D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 1.1 Create-Job 1 D [27/Jan/2013:19:07:18 +0000] Create-Job ipp://localhost:631/printers/GEBE-TINI D [27/Jan/2013:19:07:18 +0000] cupsdMarkDirty(----J-) D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients" D [27/Jan/2013:19:07:18 +0000] add_job: requesting-user-name="pi" I [27/Jan/2013:19:07:18 +0000] [Job 7] Adding start banner page "none". D [27/Jan/2013:19:07:18 +0000] Discarding unused job-created event... I [27/Jan/2013:19:07:18 +0000] [Job 7] Queued on "GEBE-TINI" by "pi". D [27/Jan/2013:19:07:18 +0000] Returning IPP successful-ok for Create-Job (ipp://localhost:631/printers/GEBE-TINI) from localhost D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files" D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 POST /printers/GEBE-TINI HTTP/1.1 D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Dirty files" D [27/Jan/2013:19:07:18 +0000] cupsdAuthorize: No authentication data provided. D [27/Jan/2013:19:07:18 +0000] cupsdReadClient: 15 1.1 Send-Document 1 D [27/Jan/2013:19:07:18 +0000] Send-Document ipp://localhost:631/printers/GEBE-TINI D [27/Jan/2013:19:07:18 +0000] cupsdIsAuthorized: requesting-user-name="pi" D [27/Jan/2013:19:07:18 +0000] [Job 7] Auto-typing file... D [27/Jan/2013:19:07:18 +0000] [Job 7] Request file type is text/plain. D [27/Jan/2013:19:07:18 +0000] cupsdMarkDirty(----J-) D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files" I [27/Jan/2013:19:07:18 +0000] [Job 7] File of type text/plain queued by "pi". I [27/Jan/2013:19:07:18 +0000] [Job 7] Adding end banner page "none". D [27/Jan/2013:19:07:18 +0000] cupsdMarkDirty(----J-) D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files" D [27/Jan/2013:19:07:18 +0000] cupsdMarkDirty(----J-) D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files" D [27/Jan/2013:19:07:18 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files" D [27/Jan/2013:19:07:18 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:18 +0000] [Job 7] job-sheets=none,none D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[0]="GEBE-TINI" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[1]="7" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[2]="pi" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[3]="test.txt" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[4]="1" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[5]="finishings=3 number-up=1 job-uuid=urn:uuid:e504a192-e527-3759-4f72-bfbe7e067bec job-originating-host-name=localhost time-at-creation=1359313638 time-at-processing=1359313638" D [27/Jan/2013:19:07:18 +0000] [Job 7] argv[6]="/var/spool/cups/d00007-001" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[0]="CUPS_CACHEDIR=/var/cache/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[1]="CUPS_DATADIR=/usr/share/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[4]="CUPS_REQUESTROOT=/var/spool/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[5]="CUPS_SERVERBIN=/usr/lib/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[6]="CUPS_SERVERROOT=/etc/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[7]="CUPS_STATEDIR=/var/run/cups" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[8]="HOME=/var/spool/cups/tmp" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[10]="SERVER_ADMIN=root@raspberrypi" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[11]="SOFTWARE=CUPS/1.5.3" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[12]="TMPDIR=/var/spool/cups/tmp" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[13]="TZ=Etc/UTC" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[14]="USER=root" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[16]="CUPS_ENCRYPTION=IfRequested" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[17]="IPP_PORT=631" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[18]="CHARSET=utf-8" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[19]="LANG=de_DE.UTF-8" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[20]="PPD=/etc/cups/ppd/GEBE-TINI.ppd" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[21]="RIP_MAX_CACHE=128m" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[22]="CONTENT_TYPE=text/plain" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[23]="DEVICE_URI=usb://GeBE/GEBE-TINI" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[24]="PRINTER_INFO=Bondrucker" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[25]="PRINTER_LOCATION=Raspberry" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[26]="PRINTER=GEBE-TINI" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[27]="PRINTER_STATE_REASONS=none" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[28]="CUPS_FILETYPE=document" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[29]="FINAL_CONTENT_TYPE=printer/GEBE-TINI" D [27/Jan/2013:19:07:18 +0000] [Job 7] envp[30]="AUTH_I****" I [27/Jan/2013:19:07:18 +0000] [Job 7] Started filter /usr/lib/cups/filter/texttopdf (PID 3712) I [27/Jan/2013:19:07:18 +0000] [Job 7] Started filter /usr/lib/cups/filter/pdftopdf (PID 3713) I [27/Jan/2013:19:07:18 +0000] [Job 7] Started filter /usr/lib/cups/filter/gstoraster (PID 3714) I [27/Jan/2013:19:07:18 +0000] [Job 7] Started filter /usr/lib/cups/filter/rastertopclx (PID 3715) I [27/Jan/2013:19:07:18 +0000] [Job 7] Started backend /usr/lib/cups/backend/usb (PID 3716) D [27/Jan/2013:19:07:19 +0000] Discarding unused job-state-changed event... D [27/Jan/2013:19:07:19 +0000] Returning IPP successful-ok for Send-Document (ipp://localhost:631/printers/GEBE-TINI) from localhost D [27/Jan/2013:19:07:19 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Active clients and dirty files" D [27/Jan/2013:19:07:19 +0000] cupsdReadClient: 15 WAITING Closing on EOF D [27/Jan/2013:19:07:19 +0000] cupsdCloseClient: 15 D [27/Jan/2013:19:07:19 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:19 +0000] [Job 7] Page = 232x513; 0,0 to 232,513 D [27/Jan/2013:19:07:19 +0000] [Job 7] Printing on printer with URI: usb://GeBE/GEBE-TINI D [27/Jan/2013:19:07:19 +0000] [Job 7] libusb_get_device_list=6 D [27/Jan/2013:19:07:19 +0000] [Job 7] STATE: +connecting-to-device D [27/Jan/2013:19:07:19 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:19 +0000] [Job 7] STATE: -connecting-to-device D [27/Jan/2013:19:07:19 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:19 +0000] [Job 7] Device protocol: 2 I [27/Jan/2013:19:07:19 +0000] [Job 7] Sending data to printer. D [27/Jan/2013:19:07:19 +0000] [Job 7] Set job-printer-state-message to "Sending data to printer.", current level=INFO D [27/Jan/2013:19:07:19 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:19 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:19 +0000] PID 3712 (/usr/lib/cups/filter/texttopdf) exited with no errors. D [27/Jan/2013:19:07:19 +0000] [Job 7] PPD uses qualifier 'Gray..203dpi' D [27/Jan/2013:19:07:19 +0000] PID 3713 (/usr/lib/cups/filter/pdftopdf) exited with no errors. D [27/Jan/2013:19:07:19 +0000] [Job 7] Calling FindDeviceById(GEBE-TINI) D [27/Jan/2013:19:07:19 +0000] [Job 7] Failed to send: org.freedesktop.ColorManager.Failed:device id 'GEBE-TINI' does not exists D [27/Jan/2013:19:07:19 +0000] [Job 7] Failed to get profile filename! I [27/Jan/2013:19:07:19 +0000] [Job 7] no profiles specified in PPD D [27/Jan/2013:19:07:19 +0000] [Job 7] Set job-printer-state-message to "no profiles specified in PPD", current level=INFO D [27/Jan/2013:19:07:19 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:19 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:19 +0000] [Job 7] Ghostscript command line: /usr/bin/gs -dQUIET -dPARANOIDSAFER -dNOPAUSE -dBATCH -dNOINTERPOLATE -sDEVICE=cups -sstdout=%stderr -sOutputFile=%stdout -r203x203 -dDEVICEWIDTHPOINTS=232 -dDEVICEHEIGHTPOINTS=513 -dcupsBitsPerColor=1 -dcupsColorOrder=0 -dcupsColorSpace=3 -dcupsCompression=3 -scupsPageSizeName=82x181mm -I/usr/share/cups/fonts -c -f -_ D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[0]="CUPS_CACHEDIR=/var/cache/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[1]="CUPS_DATADIR=/usr/share/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[4]="CUPS_REQUESTROOT=/var/spool/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[5]="CUPS_SERVERBIN=/usr/lib/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[6]="CUPS_SERVERROOT=/etc/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[7]="CUPS_STATEDIR=/var/run/cups" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[8]="HOME=/var/spool/cups/tmp" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[10]="SERVER_ADMIN=root@raspberrypi" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[11]="SOFTWARE=CUPS/1.5.3" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[12]="TMPDIR=/var/spool/cups/tmp" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[13]="TZ=Etc/UTC" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[14]="USER=root" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[16]="CUPS_ENCRYPTION=IfRequested" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[17]="IPP_PORT=631" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[18]="CHARSET=utf-8" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[19]="LANG=de_DE.UTF-8" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[20]="PPD=/etc/cups/ppd/GEBE-TINI.ppd" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[21]="RIP_MAX_CACHE=128m" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[22]="CONTENT_TYPE=text/plain" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[23]="DEVICE_URI=usb://GeBE/GEBE-TINI" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[24]="PRINTER_INFO=Bondrucker" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[25]="PRINTER_LOCATION=Raspberry" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[26]="PRINTER=GEBE-TINI" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[27]="PRINTER_STATE_REASONS=none" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[28]="CUPS_FILETYPE=document" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[29]="FINAL_CONTENT_TYPE=printer/GEBE-TINI" D [27/Jan/2013:19:07:19 +0000] [Job 7] envp[30]="AUTH_INFO_REQUIRED=none" I [27/Jan/2013:19:07:20 +0000] [Job 7] Start rendering... D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Start rendering...", current level=INFO D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused printer-state-changed event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Processing page 1... D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Processing page 1...", current level=INFO D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:20 +0000] [Job 7] PAGE: 1 1 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Starting page 1. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Starting page 1.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] StartPage... D [27/Jan/2013:19:07:20 +0000] [Job 7] MediaClass = "" D [27/Jan/2013:19:07:20 +0000] [Job 7] MediaColor = "" D [27/Jan/2013:19:07:20 +0000] [Job 7] MediaType = "" D [27/Jan/2013:19:07:20 +0000] [Job 7] OutputType = "" D [27/Jan/2013:19:07:20 +0000] [Job 7] AdvanceDistance = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] AdvanceMedia = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] Collate = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] CutMedia = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] Duplex = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] HWResolution = [ 203 203 ] D [27/Jan/2013:19:07:20 +0000] [Job 7] ImagingBoundingBox = [ 0 0 232 513 ] D [27/Jan/2013:19:07:20 +0000] [Job 7] InsertSheet = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] Jog = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] LeadingEdge = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] Margins = [ 0 0 ] D [27/Jan/2013:19:07:20 +0000] [Job 7] ManualFeed = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] MediaPosition = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] MediaWeight = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] MirrorPrint = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] NegativePrint = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] NumCopies = 1 D [27/Jan/2013:19:07:20 +0000] [Job 7] Orientation = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] OutputFaceUp = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] PageSize = [ 232 513 ] D [27/Jan/2013:19:07:20 +0000] [Job 7] Separations = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] TraySwitch = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] Tumble = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsWidth = 655 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsHeight = 1447 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsMediaType = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsBitsPerColor = 1 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsBitsPerPixel = 1 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsBytesPerLine = 82 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsColorOrder = 0 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsColorSpace = 3 D [27/Jan/2013:19:07:20 +0000] [Job 7] cupsCompression = 3 D [27/Jan/2013:19:07:20 +0000] [Job 7] PrinterPlanes = 1 D [27/Jan/2013:19:07:20 +0000] [Job 7] BlankValue=0 I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 0% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 0% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=0 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused printer-state-changed event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 8% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 8% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=8 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 17% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 17% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=17 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 26% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 26% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=26 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 35% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 35% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=35 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 44% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 44% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=44 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 53% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 53% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=53 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Processing page 2... D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Processing page 2...", current level=INFO I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 61% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 61% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=61 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 70% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 70% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=70 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 79% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 79% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=79 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 88% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 88% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=88 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Printing page 1, 97% complete. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Printing page 1, 97% complete.", current level=INFO D [27/Jan/2013:19:07:20 +0000] [Job 7] ATTR: job-media-progress=97 D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Finished page 1. D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Finished page 1.", current level=INFO D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused printer-state-changed event... I [27/Jan/2013:19:07:20 +0000] [Job 7] Rendering completed D [27/Jan/2013:19:07:20 +0000] [Job 7] Set job-printer-state-message to "Rendering completed", current level=INFO D [27/Jan/2013:19:07:20 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:20 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:20 +0000] [Job 7] Read 1348 bytes of print data... D [27/Jan/2013:19:07:20 +0000] PID 3715 (/usr/lib/cups/filter/rastertopclx) exited with no errors. D [27/Jan/2013:19:07:20 +0000] PID 3714 (/usr/lib/cups/filter/gstoraster) exited with no errors. D [27/Jan/2013:19:07:30 +0000] [Job 7] Read 1 bytes of back-channel data... D [27/Jan/2013:19:07:40 +0000] [Job 7] Got USB pipe stalled during write. E [27/Jan/2013:19:07:40 +0000] [Job 7] Unable to send data to printer. D [27/Jan/2013:19:07:40 +0000] [Job 7] Set job-printer-state-message to "Unable to send data to printer.", current level=ERROR D [27/Jan/2013:19:07:40 +0000] [Job 7] libusb write operation returned fffffff7. D [27/Jan/2013:19:07:40 +0000] [Job 7] Sent 0 bytes... D [27/Jan/2013:19:07:40 +0000] [Job 7] Waiting for read thread to exit... D [27/Jan/2013:19:07:40 +0000] Discarding unused job-progress event... D [27/Jan/2013:19:07:40 +0000] Discarding unused printer-state-changed event... D [27/Jan/2013:19:07:40 +0000] PID 3716 (/usr/lib/cups/backend/usb) stopped with status 1. I [27/Jan/2013:19:07:40 +0000] [Job 7] Backend returned status 1 (failed) D [27/Jan/2013:19:07:40 +0000] Discarding unused job-state-changed event... I [27/Jan/2013:19:07:40 +0000] [Job 7] Printer stopped due to backend errors; please consult the error_log file for details. D [27/Jan/2013:19:07:40 +0000] cupsdMarkDirty(----J-) D [27/Jan/2013:19:07:40 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:40 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:41 +0000] Discarding unused printer-stopped event... D [27/Jan/2013:19:07:41 +0000] cupsdMarkDirty(P-----) D [27/Jan/2013:19:07:41 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:41 +0000] cupsdRegisterPrinter(p=0x41e21e28(GEBE-TINI)) D [27/Jan/2013:19:07:41 +0000] cupsdMarkDirty(P-----) D [27/Jan/2013:19:07:41 +0000] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:44 +0000] Report: clients=0 D [27/Jan/2013:19:07:44 +0000] Report: jobs=2 D [27/Jan/2013:19:07:44 +0000] Report: jobs-active=1 D [27/Jan/2013:19:07:44 +0000] Report: printers=1 D [27/Jan/2013:19:07:44 +0000] Report: printers-implicit=0 D [27/Jan/2013:19:07:44 +0000] Report: stringpool-string-count=540 D [27/Jan/2013:19:07:44 +0000] Report: stringpool-alloc-bytes=8616 D [27/Jan/2013:19:07:44 +0000] Report: stringpool-total-bytes=10304 D [27/Jan/2013:19:07:47 +0000] cupsdAcceptClient: 15 from localhost (Domain) D [27/Jan/2013:19:07:47 +0000] cupsdReadClient: 15 POST / HTTP/1.1 D [27/Jan/2013:19:07:47 +0000] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Printing jobs and dirty files" D [27/Jan/2013:19:07:47 +0000] cupsdAuthorize: No authentication data provided. D [27/Jan/2013:19:07:47 +0000] cupsdReadClient: 15 1.1 CUPS-Get-Printers 1 D [27/Jan/2013:19:07:47 +0000] CUPS-Get-Printers D [27/Jan/2013:19:07:47 +0000] Returning IPP successful-ok for CUPS-Get-Printers (no URI) from localhost D [27/Jan/2013:19:07:47 +0000] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files" I [27/Jan/2013:19:07:48 +0000] Saving printers.conf... I [27/Jan/2013:19:07:48 +0000] Saving job.cache... D [27/Jan/2013:19:07:48 +0000] cupsdSetBusyState: newbusy="Not busy", busy="Dirty files" D [27/Jan/2013:19:08:54 +0000] Report: clients=1 D [27/Jan/2013:19:08:54 +0000] Report: jobs=2 D [27/Jan/2013:19:08:54 +0000] Report: jobs-active=1 D [27/Jan/2013:19:08:54 +0000] Report: printers=1 D [27/Jan/2013:19:08:54 +0000] Report: printers-implicit=0 D [27/Jan/2013:19:08:54 +0000] Report: stringpool-string-count=540 D [27/Jan/2013:19:08:54 +0000] Report: stringpool-alloc-bytes=8616 D [27/Jan/2013:19:08:54 +0000] Report: stringpool-total-bytes=10304 D [27/Jan/2013:19:10:00 +0000] Report: clients=1 D [27/Jan/2013:19:10:00 +0000] Report: jobs=2 D [27/Jan/2013:19:10:00 +0000] Report: jobs-active=1 D [27/Jan/2013:19:10:00 +0000] Report: printers=1 D [27/Jan/2013:19:10:00 +0000] Report: printers-implicit=0 D [27/Jan/2013:19:10:00 +0000] Report: stringpool-string-count=540 D [27/Jan/2013:19:10:00 +0000] Report: stringpool-alloc-bytes=8616 D [27/Jan/2013:19:10:00 +0000] Report: stringpool-total-bytes=10304 D [27/Jan/2013:19:11:06 +0000] Report: clients=1 D [27/Jan/2013:19:11:06 +0000] Report: jobs=2 D [27/Jan/2013:19:11:06 +0000] Report: jobs-active=1 D [27/Jan/2013:19:11:06 +0000] Report: printers=1 D [27/Jan/2013:19:11:06 +0000] Report: printers-implicit=0 D [27/Jan/2013:19:11:06 +0000] Report: stringpool-string-count=540 D [27/Jan/2013:19:11:06 +0000] Report: stringpool-alloc-bytes=8616 D [27/Jan/2013:19:11:06 +0000] Report: stringpool-total-bytes=10304
