/********************************************************************* * * Hardware specific definitions * ********************************************************************* * FileName: HardwareProfile.h * Dependencies: None * Processor: PIC18, PIC24F, PIC24H, dsPIC30F, dsPIC33F, PIC32 * Compiler: Microchip C32 v1.05 or higher * Microchip C30 v3.12 or higher * Microchip C18 v3.30 or higher * HI-TECH PICC-18 PRO 9.63PL2 or higher * Company: Microchip Technology, Inc. * * Software License Agreement * * Copyright (C) 2002-2009 Microchip Technology Inc. All rights * reserved. * * Microchip licenses to you the right to use, modify, copy, and * distribute: * (i) the Software when embedded on a Microchip microcontroller or * digital signal controller product ("Device") which is * integrated into Licensee's product; or * (ii) ONLY the Software driver source files ENC28J60.c, ENC28J60.h, * ENCX24J600.c and ENCX24J600.h ported to a non-Microchip device * used in conjunction with a Microchip ethernet controller for * the sole purpose of interfacing with the ethernet controller. * * You should refer to the license agreement accompanying this * Software for additional information regarding your rights and * obligations. * * THE SOFTWARE AND DOCUMENTATION ARE PROVIDED "AS IS" WITHOUT * WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT * LIMITATION, ANY WARRANTY OF MERCHANTABILITY, FITNESS FOR A * PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT SHALL * MICROCHIP BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR * CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF * PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS * BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE * THEREOF), ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER * SIMILAR COSTS, WHETHER ASSERTED ON THE BASIS OF CONTRACT, TORT * (INCLUDING NEGLIGENCE), BREACH OF WARRANTY, OR OTHERWISE. * * * Author Date Comment *~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ * Howard Schlunder 10/03/06 Original, copied from Compiler.h * Ken Hesky 07/01/08 Added ZG2100-specific features ********************************************************************/ #ifndef __HARDWARE_PROFILE_H #define __HARDWARE_PROFILE_H #include "GenericTypeDefs.h" #include "Compiler.h" // Choose which hardware profile to compile for here. See // the hardware profiles below for meaning of various options. //#define PICDEMNET2 //#define PIC18_EXPLORER //#define HPC_EXPLORER //#define PIC24FJ64GA004_PIM // Explorer 16, but with the PIC24FJ64GA004 PIM module, which has significantly differnt pin mappings //#define EXPLORER_16 // PIC24FJ128GA010, PIC24HJ256GP610, dsPIC33FJ256GP710 PIMs //#define DSPICDEM11 //#define OLIMEX_MAXI // based on PIC18F97J60 //#define OLIMEX_WEB //#define OLIMEX_MINI // based on PIC18F25J10 #define OLIMEX_P67J60 // based on PIC18F67J60 //#define YOUR_BOARD #if defined(OLIMEX_MAXI) || defined(OLIMEX_WEB) || defined(OLIMEX_MINI) || \ defined(OLIMEX_MICRO) || defined(OLIMEX_P67J60) #define OLIMEX_HW #endif // If no hardware profiles are defined, assume that we are using // a Microchip demo board and try to auto-select the correct profile // based on processor selected in MPLAB #if !defined(PICDEMNET2) && !defined(PIC18_EXPLORER) && !defined(HPC_EXPLORER) && !defined(EXPLORER_16) && !defined(PIC24FJ64GA004_PIM) && !defined(DSPICDEM11) && !defined(PICDEMNET2) && !defined(INTERNET_RADIO) && !defined(OLIMEX_MAXI) && !defined(OLIMEX_WEB) && !defined(OLIMEX_MINI) && !defined(OLIMEX_MICRO) && !defined(OLIMEX_P67J60) && !defined(YOUR_BOARD) && !defined(__PIC24FJ128GA006__) #if defined(__18F97J60) || defined(_18F97J60) #define PICDEMNET2 #elif defined(__18F67J60) || defined(_18F67J60) #define INTERNET_RADIO #elif defined(__18F8722) || defined(__18F87J10) || defined(_18F8722) || defined(_18F87J10) || defined(__18F87J11) || defined(_18F87J11)|| defined(__18F87J50) || defined(_18F87J50) #define PIC18_EXPLORER //#define HPC_EXPLORER #elif defined(__PIC24FJ64GA004__) #define PIC24FJ64GA004_PIM #elif defined(__PIC24F__) || defined(__PIC24H__) || defined(__dsPIC33F__) || defined(__PIC32MX__) #define EXPLORER_16 #elif defined(__dsPIC30F__) #define DSPICDEM11 #endif #endif // Set configuration fuses (but only once) #if defined(THIS_IS_STACK_APPLICATION) #if defined(__18CXX) #if defined(__EXTENDED18__) #pragma config XINST=ON #elif !defined(HI_TECH_C) #pragma config XINST=OFF #endif #if defined(__18F8722) && !defined(HI_TECH_C) // PICDEM HPC Explorer or PIC18 Explorer board #pragma config OSC=HSPLL, FCMEN=OFF, IESO=OFF, PWRT=OFF, WDT=OFF, LVP=OFF #elif defined(_18F8722) // HI-TECH PICC-18 compiler // PICDEM HPC Explorer or PIC18 Explorer board with HI-TECH PICC-18 compiler __CONFIG(1, HSPLL); __CONFIG(2, WDTDIS); __CONFIG(3, MCLREN); __CONFIG(4, XINSTDIS & LVPDIS); #elif defined(__18F87J10) && !defined(HI_TECH_C) // PICDEM HPC Explorer or PIC18 Explorer board #pragma config WDTEN=OFF, FOSC2=ON, FOSC=HSPLL #elif defined(__18F87J11) && !defined(HI_TECH_C) // PICDEM HPC Explorer or PIC18 Explorer board #pragma config WDTEN=OFF, FOSC=HSPLL #elif defined(__18F87J50) && !defined(HI_TECH_C) // PICDEM HPC Explorer or PIC18 Explorer board #pragma config WDTEN=OFF, FOSC=HSPLL, PLLDIV=3, CPUDIV=OSC1 #elif (defined(__18F97J60) || defined(__18F96J65) || defined(__18F96J60) || defined(__18F87J60) || defined(__18F86J65) || defined(__18F86J60) || defined(__18F67J60) || defined(__18F66J65) || defined(__18F66J60)) && !defined(HI_TECH_C) // PICDEM.net 2 or any other PIC18F97J60 family device #pragma config WDT=OFF, FOSC2=ON, FOSC=HSPLL, ETHLED=ON #elif defined(_18F97J60) || defined(_18F96J65) || defined(_18F96J60) || defined(_18F87J60) || defined(_18F86J65) || defined(_18F86J60) || defined(_18F67J60) || defined(_18F66J65) || defined(_18F66J60) // PICDEM.net 2 board with HI-TECH PICC-18 compiler __CONFIG(1, WDTDIS & XINSTDIS); __CONFIG(2, HSPLL); __CONFIG(3, ETHLEDEN); #elif defined(__18F4620) && !defined(HI_TECH_C) #pragma config OSC=HSPLL, WDT=OFF, MCLRE=ON, PBADEN=OFF, LVP=OFF #endif #elif defined(__PIC24F__) // Explorer 16 board _CONFIG2(FNOSC_PRIPLL & POSCMOD_XT) // Primary XT OSC with 4x PLL _CONFIG1(JTAGEN_OFF & FWDTEN_OFF) // JTAG off, watchdog timer off #elif defined(__dsPIC33F__) || defined(__PIC24H__) // Explorer 16 board _FOSCSEL(FNOSC_PRIPLL) // PLL enabled _FOSC(OSCIOFNC_OFF & POSCMD_XT) // XT Osc _FWDT(FWDTEN_OFF) // Disable Watchdog timer // JTAG should be disabled as well #elif defined(__dsPIC30F__) // dsPICDEM 1.1 board _FOSC(XT_PLL16) // XT Osc + 16X PLL _FWDT(WDT_OFF) // Disable Watchdog timer _FBORPOR(MCLR_EN & PBOR_OFF & PWRT_OFF) #elif defined(__PIC32MX__) #pragma config FPLLODIV = DIV_1, FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FWDTEN = OFF, FPBDIV = DIV_1, POSCMOD = XT, FNOSC = PRIPLL, CP = OFF #endif #endif // Prevent more than one set of config fuse definitions // Clock frequency value. // This value is used to calculate Tick Counter value #if defined(__18CXX) // All PIC18 processors #if defined(PICDEMNET2) || defined(INTERNET_RADIO) || defined(OLIMEX_MAXI) || defined(OLIMEX_MICRO) || defined(OLIMEX_P67J60) || defined(PIC_WEB) #define GetSystemClock() (41666667ul) // Hz #define GetInstructionClock() (GetSystemClock()/4) #define GetPeripheralClock() GetInstructionClock() #elif defined(__18F87J50) || defined(_18F87J50) #define GetSystemClock() (48000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/4) #define GetPeripheralClock() GetInstructionClock() #else #define GetSystemClock() (40000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/4) #define GetPeripheralClock() GetInstructionClock() #endif #elif defined(__PIC24F__) // PIC24F processor #define GetSystemClock() (32000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/2) #define GetPeripheralClock() GetInstructionClock() #elif defined(__PIC24H__) // PIC24H processor #define GetSystemClock() (80000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/2) #define GetPeripheralClock() GetInstructionClock() #elif defined(__dsPIC33F__) // dsPIC33F processor #define GetSystemClock() (80000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/2) #define GetPeripheralClock() GetInstructionClock() #elif defined(__dsPIC30F__) // dsPIC30F processor #define GetSystemClock() (117920000ul) // Hz #define GetInstructionClock() (GetSystemClock()/4) #define GetPeripheralClock() GetInstructionClock() #elif defined(__PIC32MX__) // PIC32MX processor #define GetSystemClock() (80000000ul) // Hz #define GetInstructionClock() (GetSystemClock()/1) #define GetPeripheralClock() (GetInstructionClock()/1) // Set your divider according to your Peripheral Bus Frequency configuration fuse setting #endif // Hardware mappings #if defined(PIC18_EXPLORER) && !defined(HI_TECH_C) // PIC18 Explorer + Fast 100Mbps Ethernet PICtail Plus or Ethernet PICtail // I/O pins #define LED0_TRIS (TRISDbits.TRISD0) #define LED0_IO (LATDbits.LATD0) #define LED1_TRIS (TRISDbits.TRISD1) #define LED1_IO (LATDbits.LATD1) #define LED2_TRIS (TRISDbits.TRISD2) #define LED2_IO (LATDbits.LATD2) #define LED3_TRIS (TRISDbits.TRISD3) #define LED3_IO (LATDbits.LATD3) #define LED4_TRIS (TRISDbits.TRISD4) #define LED4_IO (LATDbits.LATD4) #define LED5_TRIS (TRISDbits.TRISD5) #define LED5_IO (LATDbits.LATD5) #define LED6_TRIS (TRISDbits.TRISD6) #define LED6_IO (LATDbits.LATD6) #define LED7_TRIS (TRISDbits.TRISD7) #define LED7_IO (LATDbits.LATD7) #define LED_GET() (LATD) #define LED_PUT(a) (LATD = (a)) #define BUTTON0_TRIS (TRISAbits.TRISA5) #define BUTTON0_IO (PORTAbits.RA5) #define BUTTON1_TRIS (TRISBbits.TRISB0) #define BUTTON1_IO (PORTBbits.RB0) #define BUTTON2_TRIS (PRODL) // No Button2 on this board #define BUTTON2_IO (1) #define BUTTON3_TRIS (PRODL) // No Button3 on this board #define BUTTON3_IO (1) // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus defines //#define ENC100_INTERFACE_MODE 0 // Uncomment this line to use the ENC424J600/624J600 Ethernet controller (SPI mode) or comment it out to use some other network controller // ENC100_MDIX, ENC100_POR, and ENC100_INT are all optional. Simply leave // them commented out if you don't have such a hardware feature on your // board. #define ENC100_MDIX_TRIS (TRISBbits.TRISB4) #define ENC100_MDIX_IO (LATBbits.LATB4) // #define ENC100_POR_TRIS (TRISBbits.TRISB5) // #define ENC100_POR_IO (LATBbits.LATB5) // #define ENC100_INT_TRIS (TRISBbits.TRISB2) // #define ENC100_INT_IO (PORTBbits.RB2) // ENC424J600/624J600 SPI pinout #define ENC100_CS_TRIS (TRISBbits.TRISB3) #define ENC100_CS_IO (LATBbits.LATB3) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISCbits.TRISC4) // NOTE: SO is ENC624J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (PORTCbits.RC4) #define ENC100_SI_RD_RW_TRIS (TRISCbits.TRISC5) // NOTE: SI is ENC624J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATCbits.LATC5) #define ENC100_SCK_AL_TRIS (TRISCbits.TRISC3) #define ENC100_SCK_AL_IO (PORTCbits.RC3) // NOTE: This must be the PORT, not the LATch like it is for the PSP interface. // ENC424J600/624J600 SPI SFR register selection (controls which SPI // peripheral to use on PICs with multiple SPI peripherals). // #define ENC100_ISR_ENABLE (INTCON3bits.INT2IE) // #define ENC100_ISR_FLAG (INTCON3bits.INT2IF) // #define ENC100_ISR_POLARITY (INTCON2bits.INTEDG2) // #define ENC100_ISR_PRIORITY (INTCON3bits.INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (PIR1bits.SSPIF) #define ENC100_SSPBUF (SSP1BUF) #define ENC100_SPISTAT (SSP1STAT) #define ENC100_SPISTATbits (SSP1STATbits) #define ENC100_SPICON1 (SSP1CON1) #define ENC100_SPICON1bits (SSP1CON1bits) #define ENC100_SPICON2 (SSP1CON2) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISBbits.TRISB5) #define ENC_RST_IO (LATBbits.LATB5) #define ENC_CS_TRIS (TRISBbits.TRISB3) // Uncomment this line to use the ENC28J60 Ethernet controller or comment it out to use some other network controller #define ENC_CS_IO (LATBbits.LATB3) #define ENC_SCK_TRIS (TRISCbits.TRISC3) #define ENC_SDI_TRIS (TRISCbits.TRISC4) #define ENC_SDO_TRIS (TRISCbits.TRISC5) #define ENC_SPI_IF (PIR1bits.SSPIF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISAbits.TRISA3) #define EEPROM_CS_IO (LATAbits.LATA3) #define EEPROM_SCK_TRIS (TRISCbits.TRISC3) #define EEPROM_SDI_TRIS (TRISCbits.TRISC4) #define EEPROM_SDO_TRIS (TRISCbits.TRISC5) #define EEPROM_SPI_IF (PIR1bits.SSPIF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // LCD I/O pins // TODO: Need to add support for LCD behind MCP23S17 I/O expander. This // requires code that isn't in the TCP/IP stack, not just a hardware // profile change. // Serial Flash/SRAM/UART PICtail // #define SPIRAM_CS_TRIS (TRISBbits.TRISB5) // #define SPIRAM_CS_IO (LATBbits.LATB5) // #define SPIRAM_SCK_TRIS (TRISCbits.TRISC3) // #define SPIRAM_SDI_TRIS (TRISCbits.TRISC4) // #define SPIRAM_SDO_TRIS (TRISCbits.TRISC5) // #define SPIRAM_SPI_IF (PIR1bits.SSPIF) // #define SPIRAM_SSPBUF (SSP1BUF) // #define SPIRAM_SPICON1 (SSP1CON1) // #define SPIRAM_SPICON1bits (SSP1CON1bits) // #define SPIRAM_SPICON2 (SSP1CON2) // #define SPIRAM_SPISTAT (SSP1STAT) // #define SPIRAM_SPISTATbits (SSP1STATbits) // // // NOTE: You must also set the SPI_FLASH_SST/SPI_FLASH_SPANSION, // // SPI_FLASH_SECTOR_SIZE, and SPI_FLASH_PAGE_SIZE macros in // // SPIFlash.h to match your particular Flash memory chip!!! // #define SPIFLASH_CS_TRIS (TRISBbits.TRISB4) // #define SPIFLASH_CS_IO (LATBbits.LATB4) // #define SPIFLASH_SCK_TRIS (TRISCbits.TRISC3) // #define SPIFLASH_SDI_TRIS (TRISCbits.TRISC4) // #define SPIFLASH_SDI_IO (PORTCbits.RC4) // #define SPIFLASH_SDO_TRIS (TRISCbits.TRISC5) // #define SPIFLASH_SPI_IF (PIR1bits.SSPIF) // #define SPIFLASH_SSPBUF (SSP1BUF) // #define SPIFLASH_SPICON1 (SSP1CON1) // #define SPIFLASH_SPICON1bits (SSP1CON1bits) // #define SPIFLASH_SPICON2 (SSP1CON2) // #define SPIFLASH_SPISTAT (SSP1STAT) // #define SPIFLASH_SPISTATbits (SSP1STATbits) // Register name fix up for certain processors #define SPBRGH SPBRGH1 #if defined(__18F87J50) || defined(_18F87J50) || defined(__18F87J11) || defined(_18F87J11) #define ADCON2 ADCON1 #endif #elif defined(PIC18_EXPLORER) && defined(HI_TECH_C) // PIC18 Explorer + Fast 100Mbps Ethernet PICtail Plus or Ethernet PICtail + HI-TECH PICC-18 compiler // I/O pins #define LED0_TRIS (TRISD0) #define LED0_IO (LATD0) #define LED1_TRIS (TRISD1) #define LED1_IO (LATD1) #define LED2_TRIS (TRISD2) #define LED2_IO (LATD2) #define LED3_TRIS (TRISD3) #define LED3_IO (LATD3) #define LED4_TRIS (TRISD4) #define LED4_IO (LATD4) #define LED5_TRIS (TRISD5) #define LED5_IO (LATD5) #define LED6_TRIS (TRISD6) #define LED6_IO (LATD6) #define LED7_TRIS (TRISD7) #define LED7_IO (LATD7) #define LED_GET() (LATD) #define LED_PUT(a) (LATD = (a)) #define BUTTON0_TRIS (TRISA5) #define BUTTON0_IO (RA5) #define BUTTON1_TRIS (TRISB0) #define BUTTON1_IO (RB0) #define BUTTON2_TRIS (PRODL) // No Button2 on this board #define BUTTON2_IO (1) #define BUTTON3_TRIS (PRODL) // No Button3 on this board #define BUTTON3_IO (1) // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus defines //#define ENC100_INTERFACE_MODE 0 // Uncomment this line to use the ENC424J600/624J600 Ethernet controller (SPI mode) or comment it out to use some other network controller // ENC100_MDIX, ENC100_POR, and ENC100_INT are all optional. Simply leave // them commented out if you don't have such a hardware feature on your // hardware. #define ENC100_MDIX_TRIS (TRISB4) #define ENC100_MDIX_IO (LATB4) // #define ENC100_POR_TRIS (TRISB5) // #define ENC100_POR_IO (LATB5) // #define ENC100_INT_TRIS (TRISB2) // #define ENC100_INT_IO (RB2) // ENC424J600/624J600 SPI pinout #define ENC100_CS_TRIS (TRISB3) #define ENC100_CS_IO (LATB3) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISC4) // NOTE: SO is ENC624J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (RC4) #define ENC100_SI_RD_RW_TRIS (TRISC5) // NOTE: SI is ENC624J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATC5) #define ENC100_SCK_AL_TRIS (TRISC3) #define ENC100_SCK_AL_IO (RC3) // NOTE: This must be the PORT, not the LATch like it is for the PSP interface. // ENC424J600/624J600 SPI SFR register selection (controls which SPI // peripheral to use on PICs with multiple SPI peripherals). // #define ENC100_ISR_ENABLE (INT2IE) // #define ENC100_ISR_FLAG (INT2IF) // #define ENC100_ISR_POLARITY (INTEDG2) // #define ENC100_ISR_PRIORITY (INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (SSP1IF) #define ENC100_SSPBUF (SSP1BUF) #define ENC100_SPISTAT (SSP1STAT) #define ENC100_SPISTATbits (SSP1STATbits) #define ENC100_SPICON1 (SSP1CON1) #define ENC100_SPICON1bits (SSP1CON1bits) #define ENC100_SPICON2 (SSP1CON2) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISB5) #define ENC_RST_IO (LATB5) #define ENC_CS_TRIS (TRISB3) // Uncomment this line to use the ENC28J60 Ethernet controller or comment it out to use some other network controller #define ENC_CS_IO (LATB3) #define ENC_SCK_TRIS (TRISC3) #define ENC_SDI_TRIS (TRISC4) #define ENC_SDO_TRIS (TRISC5) #define ENC_SPI_IF (SSP1IF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISA3) #define EEPROM_CS_IO (LATA3) #define EEPROM_SCK_TRIS (TRISC3) #define EEPROM_SDI_TRIS (TRISC4) #define EEPROM_SDO_TRIS (TRISC5) #define EEPROM_SPI_IF (SSP1IF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // LCD I/O pins // TODO: Need to add support for LCD behind MCP23S17 I/O expander. This // requires code that isn't in the TCP/IP stack, not just a hardware // profile change. // Register name fix up for certain processors #define SPBRGH SPBRGH1 #define TXSTAbits TXSTA1bits #define RCSTAbits RCSTA1bits #define BAUDCONbits BAUDCON1bits #define GO GODONE #if defined(__18F87J50) || defined(_18F87J50) || defined(__18F87J11) || defined(_18F87J11) #define ADCON2 ADCON1 #endif #elif defined(HPC_EXPLORER) && !defined(HI_TECH_C) // PICDEM HPC Explorer + Fast 100Mbps Ethernet PICtail Plus or Ethernet PICtail // I/O pins #define LED0_TRIS (TRISDbits.TRISD0) #define LED0_IO (LATDbits.LATD0) #define LED1_TRIS (TRISDbits.TRISD1) #define LED1_IO (LATDbits.LATD1) #define LED2_TRIS (TRISDbits.TRISD2) #define LED2_IO (LATDbits.LATD2) #define LED3_TRIS (TRISDbits.TRISD3) #define LED3_IO (LATDbits.LATD3) #define LED4_TRIS (TRISDbits.TRISD4) #define LED4_IO (LATDbits.LATD4) #define LED5_TRIS (TRISDbits.TRISD5) #define LED5_IO (LATDbits.LATD5) #define LED6_TRIS (TRISDbits.TRISD6) #define LED6_IO (LATDbits.LATD6) #define LED7_TRIS (TRISDbits.TRISD7) #define LED7_IO (LATDbits.LATD7) #define LED_GET() (LATD) #define LED_PUT(a) (LATD = (a)) #define BUTTON0_TRIS (TRISBbits.TRISB0) #define BUTTON0_IO (PORTBbits.RB0) #define BUTTON1_TRIS (TRISBbits.TRISB0) // No Button1 on this board, remap to Button0 #define BUTTON1_IO (PORTBbits.RB0) #define BUTTON2_TRIS (TRISBbits.TRISB0) // No Button2 on this board, remap to Button0 #define BUTTON2_IO (PORTBbits.RB0) #define BUTTON3_TRIS (TRISBbits.TRISB0) // No Button3 on this board, remap to Button0 #define BUTTON3_IO (PORTBbits.RB0) // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus defines //#define ENC100_INTERFACE_MODE 0 // Uncomment this line to use the ENC424J600/624J600 Ethernet controller (SPI mode) or comment it out to use some other network controller // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus I/O pins #define ENC100_MDIX_TRIS (TRISBbits.TRISB4) #define ENC100_MDIX_IO (LATBbits.LATB4) #define ENC100_POR_TRIS (TRISBbits.TRISB5) #define ENC100_POR_IO (LATBbits.LATB5) // #define ENC100_INT_TRIS (TRISBbits.TRISB2) // #define ENC100_INT_IO (PORTBbits.RB2) // ENC424J600/624J600 SPI pinout #define ENC100_CS_TRIS (TRISBbits.TRISB3) #define ENC100_CS_IO (LATBbits.LATB3) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISCbits.TRISC4) // NOTE: SO is ENC624J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (PORTCbits.RC4) #define ENC100_SI_RD_RW_TRIS (TRISCbits.TRISC5) // NOTE: SI is ENC624J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATCbits.LATC5) #define ENC100_SCK_AL_TRIS (TRISCbits.TRISC3) #define ENC100_SCK_AL_IO (PORTCbits.RC3) // NOTE: This must be the PORT, not the LATch like it is for the PSP interface. // ENC424J600/624J600 SPI SFR register selection (controls which SPI // peripheral to use on PICs with multiple SPI peripherals). // #define ENC100_ISR_ENABLE (INTCON3bits.INT2IE) // #define ENC100_ISR_FLAG (INTCON3bits.INT2IF) // #define ENC100_ISR_POLARITY (INTCON2bits.INTEDG2) // #define ENC100_ISR_PRIORITY (INTCON3bits.INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (PIR1bits.SSPIF) #define ENC100_SSPBUF (SSP1BUF) #define ENC100_SPISTAT (SSP1STAT) #define ENC100_SPISTATbits (SSP1STATbits) #define ENC100_SPICON1 (SSP1CON1) #define ENC100_SPICON1bits (SSP1CON1bits) #define ENC100_SPICON2 (SSP1CON2) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISBbits.TRISB5) #define ENC_RST_IO (LATBbits.LATB5) #define ENC_CS_TRIS (TRISBbits.TRISB3) // Uncomment this line to use the ENC28J60 Ethernet controller or comment it out to use some other network controller #define ENC_CS_IO (LATBbits.LATB3) #define ENC_SCK_TRIS (TRISCbits.TRISC3) #define ENC_SDI_TRIS (TRISCbits.TRISC4) #define ENC_SDO_TRIS (TRISCbits.TRISC5) #define ENC_SPI_IF (PIR1bits.SSPIF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISBbits.TRISB4) #define EEPROM_CS_IO (LATBbits.LATB4) #define EEPROM_SCK_TRIS (TRISCbits.TRISC3) #define EEPROM_SDI_TRIS (TRISCbits.TRISC4) #define EEPROM_SDO_TRIS (TRISCbits.TRISC5) #define EEPROM_SPI_IF (PIR1bits.SSPIF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // Register name fix up for certain processors #define SPBRGH SPBRGH1 #if defined(__18F87J50) || defined(_18F87J50) || defined(__18F87J11) || defined(_18F87J11) #define ADCON2 ADCON1 #endif #elif defined(HPC_EXPLORER) && defined(HI_TECH_C) // PICDEM HPC Explorer + Ethernet PICtail #define TXSTA TXSTA1 #define RCSTA RCSTA1 #define SPBRG SPBRG1 #define SPBRGH SPBRGH1 #define RCREG RCREG1 #define TXREG TXREG1 // I/O pins #define LED0_TRIS (TRISD0) #define LED0_IO (LATD0) #define LED1_TRIS (TRISD1) #define LED1_IO (LATD1) #define LED2_TRIS (TRISD2) #define LED2_IO (LATD2) #define LED3_TRIS (TRISD3) #define LED3_IO (LATD3) #define LED4_TRIS (TRISD4) #define LED4_IO (LATD4) #define LED5_TRIS (TRISD5) #define LED5_IO (LATD5) #define LED6_TRIS (TRISD6) #define LED6_IO (LATD6) #define LED7_TRIS (TRISD7) #define LED7_IO (LATD7) #define LED_GET() (LATD) #define LED_PUT(a) (LATD = (a)) #define BUTTON0_TRIS (TRISB0) #define BUTTON0_IO (RB0) #define BUTTON1_TRIS (TRISB0) // No Button1 on this board, remap to Button0 #define BUTTON1_IO (RB0) #define BUTTON2_TRIS (TRISB0) // No Button2 on this board, remap to Button0 #define BUTTON2_IO (RB0) #define BUTTON3_TRIS (TRISB0) // No Button3 on this board, remap to Button0 #define BUTTON3_IO (RB0) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISB5) #define ENC_RST_IO (LATB5) #define ENC_CS_TRIS (TRISB3) #define ENC_CS_IO (LATB3) #define ENC_SCK_TRIS (TRISC3) #define ENC_SDI_TRIS (TRISC4) #define ENC_SDO_TRIS (TRISC5) #define ENC_SPI_IF (SSP1IF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISB4) #define EEPROM_CS_IO (LATB4) #define EEPROM_SCK_TRIS (TRISC3) #define EEPROM_SDI_TRIS (TRISC4) #define EEPROM_SDO_TRIS (TRISC5) #define EEPROM_SPI_IF (SSP1IF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) #elif defined(PIC24FJ64GA004_PIM) // Explorer 16 + PIC24FJ64GA004 PIM + Ethernet PICtail Plus // Push Button I/O pins #define BUTTON3_TRIS TRISAbits.TRISA10 // Mutliplexed with LED0 #define BUTTON3_IO PORTAbits.RA10 #define BUTTON2_TRIS TRISAbits.TRISA9 // Multiplexed with LED4 #define BUTTON2_IO PORTAbits.RA9 #define BUTTON1_TRIS TRISCbits.TRISC6 // Multiplexed with LED7 #define BUTTON1_IO PORTCbits.RC6 #define BUTTON0_TRIS TRISAbits.TRISA7 // Multiplexed with LED1 #define BUTTON0_IO PORTAbits.RA7 // LED I/O pins #define LED0_TRIS TRISAbits.TRISA10 // Multiplexed with BUTTON3 #define LED0_IO LATAbits.LATA10 #define LED1_TRIS TRISAbits.TRISA7 // Multiplexed with BUTTON0 #define LED1_IO LATAbits.LATA7 #define LED2_TRIS TRISBbits.TRISB8 // Multiplexed with LCD_DATA4 #define LED2_IO LATBbits.LATB8 #define LED3_TRIS TRISBbits.TRISB9 // Multiplexed with LCD_DATA3 #define LED3_IO LATBbits.LATB9 #define LED4_TRIS TRISAbits.TRISA9 // Multiplexed with BUTTON2 #define LED4_IO LATAbits.LATA9 #define LED5_TRIS TRISAbits.TRISA8 // Multiplexed with EEPROM_CS #define LED5_IO LATAbits.LATA8 #define LED6_TRIS TRISBbits.TRISB12 // Multiplexed with LCD_DATA0 #define LED6_IO LATBbits.LATB12 #define LED7_TRIS TRISCbits.TRISC6 // Multiplexed with BUTTON1 #define LED7_IO LATCbits.LATC6 #define LED_GET() (0) #define LED_PUT(a) // UART I/O Mapping #define UARTTX_TRIS (TRISCbits.TRISC9) #define UARTTX_IO (PORTCbits.RC9) #define UARTRX_TRIS (TRISCbits.TRISC3) #define UARTRX_IO (PORTCbits.RC3) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISCbits.TRISC8) // Not connected by default #define ENC_RST_IO (PORTCbits.RC8) #define ENC_CS_TRIS (TRISBbits.TRISB3) #define ENC_CS_IO (PORTBbits.RB3) // SPI SCK, SDI, SDO pins are automatically controlled by the // PIC24/dsPIC/PIC32 SPI module #define ENC_SPI_IF (IFS0bits.SPI1IF) #define ENC_SSPBUF (SPI1BUF) #define ENC_SPISTAT (SPI1STAT) #define ENC_SPISTATbits (SPI1STATbits) #define ENC_SPICON1 (SPI1CON1) #define ENC_SPICON1bits (SPI1CON1bits) #define ENC_SPICON2 (SPI1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISAbits.TRISA8) #define EEPROM_CS_IO (PORTAbits.RA8) #define EEPROM_SCK_TRIS (TRISCbits.TRISC8) #define EEPROM_SDI_TRIS (TRISCbits.TRISC4) #define EEPROM_SDO_TRIS (TRISCbits.TRISC5) #define EEPROM_SPI_IF (IFS2bits.SPI2IF) #define EEPROM_SSPBUF (SPI2BUF) #define EEPROM_SPICON1 (SPI2CON1) #define EEPROM_SPICON1bits (SPI2CON1bits) #define EEPROM_SPICON2 (SPI2CON2) #define EEPROM_SPISTAT (SPI2STAT) #define EEPROM_SPISTATbits (SPI2STATbits) // LCD Module I/O pins #define LCD_DATA0_TRIS (TRISBbits.TRISB12) // Multiplexed with LED6 #define LCD_DATA0_IO (LATBbits.LATB12) #define LCD_DATA1_TRIS (TRISBbits.TRISB11) #define LCD_DATA1_IO (LATBbits.LATB11) #define LCD_DATA2_TRIS (TRISBbits.TRISB10) #define LCD_DATA2_IO (LATBbits.LATB10) #define LCD_DATA3_TRIS (TRISBbits.TRISB9) // Multiplexed with LED3 #define LCD_DATA3_IO (LATBbits.LATB9) #define LCD_DATA4_TRIS (TRISBbits.TRISB8) // Multiplexed with LED2 #define LCD_DATA4_IO (LATBbits.LATB8) #define LCD_DATA5_TRIS (TRISBbits.TRISB7) #define LCD_DATA5_IO (LATBbits.LATB7) #define LCD_DATA6_TRIS (TRISBbits.TRISB6) #define LCD_DATA6_IO (LATBbits.LATB6) #define LCD_DATA7_TRIS (TRISBbits.TRISB5) #define LCD_DATA7_IO (LATBbits.LATB5) #define LCD_RD_WR_TRIS (TRISBbits.TRISB13) #define LCD_RD_WR_IO (LATBbits.LATB13) #define LCD_RS_TRIS (TRISCbits.TRISC7) #define LCD_RS_IO (LATCbits.LATC7) #define LCD_E_TRIS (TRISBbits.TRISB14) #define LCD_E_IO (LATBbits.LATB14) // Peripheral Pin Select Outputs #define NULL_IO 0 #define C1OUT_IO 1 #define C2OUT_IO 2 #define U1TX_IO 3 #define U1RTS_IO 4 #define U2TX_IO 5 #define U2RTS_IO 6 #define SDO1_IO 7 #define SCK1OUT_IO 8 #define SS1OUT_IO 9 #define SDO2_IO 10 #define SCK2OUT_IO 11 #define SS2OUT_IO 12 #define OC1_IO 18 #define OC2_IO 19 #define OC3_IO 20 #define OC4_IO 21 #define OC5_IO 22 #elif defined(EXPLORER_16) // Explorer 16 + PIC24FJ128GA010/PIC24HJ256GP610/dsPIC33FJ256GP710/ // PIC32MX460F512L/PIC32MX360F512L PIM + // Fast 100Mbps Ethernet PICtail Plus or Ethernet PICtail Plus or ZeroG ZG2100M WiFi PICtail Plus #define LED0_TRIS (TRISAbits.TRISA0) // Ref D3 #define LED0_IO (LATAbits.LATA0) #define LED1_TRIS (TRISAbits.TRISA1) // Ref D4 #define LED1_IO (LATAbits.LATA1) #define LED2_TRIS (TRISAbits.TRISA2) // Ref D5 #define LED2_IO (LATAbits.LATA2) #define LED3_TRIS (TRISAbits.TRISA3) // Ref D6 #define LED3_IO (LATAbits.LATA3) #define LED4_TRIS (TRISAbits.TRISA4) // Ref D7 #define LED4_IO (LATAbits.LATA4) #define LED5_TRIS (TRISAbits.TRISA5) // Ref D8 #define LED5_IO (LATAbits.LATA5) #define LED6_TRIS (TRISAbits.TRISA6) // Ref D9 #define LED6_IO (LATAbits.LATA6) #define LED7_TRIS (TRISAbits.TRISA7) // Ref D10 // Note: This is multiplexed with BUTTON1 #define LED7_IO (LATAbits.LATA7) #define LED_GET() (*((volatile unsigned char*)(&LATA))) #define LED_PUT(a) (*((volatile unsigned char*)(&LATA)) = (a)) #define BUTTON0_TRIS (TRISDbits.TRISD13) // Ref S4 #define BUTTON0_IO (PORTDbits.RD13) #define BUTTON1_TRIS (TRISAbits.TRISA7) // Ref S5 // Note: This is multiplexed with LED7 #define BUTTON1_IO (PORTAbits.RA7) #define BUTTON2_TRIS (TRISDbits.TRISD7) // Ref S6 #define BUTTON2_IO (PORTDbits.RD7) #define BUTTON3_TRIS (TRISDbits.TRISD6) // Ref S3 #define BUTTON3_IO (PORTDbits.RD6) #define UARTTX_TRIS (TRISFbits.TRISF5) #define UARTTX_IO (PORTFbits.RF5) #define UARTRX_TRIS (TRISFbits.TRISF4) #define UARTRX_IO (PORTFbits.RF4) // ENC28J60 I/O pins #define ENC_CS_TRIS (TRISDbits.TRISD14) // Comment this line out if you are using the ENC424J600/624J600, ZeroG ZG2100, or other network controller. #define ENC_CS_IO (PORTDbits.RD14) //#define ENC_RST_TRIS (TRISDbits.TRISD15) // Not connected by default. It is okay to leave this pin completely unconnected, in which case this macro should simply be left undefined. //#define ENC_RST_IO (PORTDbits.RD15) // SPI SCK, SDI, SDO pins are automatically controlled by the // PIC24/dsPIC/PIC32 SPI module #if defined(__C30__) // PIC24F, PIC24H, dsPIC30, dsPIC33 #define ENC_SPI_IF (IFS0bits.SPI1IF) #define ENC_SSPBUF (SPI1BUF) #define ENC_SPISTAT (SPI1STAT) #define ENC_SPISTATbits (SPI1STATbits) #define ENC_SPICON1 (SPI1CON1) #define ENC_SPICON1bits (SPI1CON1bits) #define ENC_SPICON2 (SPI1CON2) #else // PIC32 #define ENC_SPI_IF (IFS0bits.SPI1RXIF) #define ENC_SSPBUF (SPI1BUF) #define ENC_SPISTATbits (SPI1STATbits) #define ENC_SPICON1 (SPI1CON) #define ENC_SPICON1bits (SPI1CONbits) #define ENC_SPIBRG (SPI1BRG) #endif // ENC624J600 Interface Configuration // Comment out ENC100_INTERFACE_MODE if you don't have an ENC624J600 or // ENC424J600. Otherwise, choose the correct setting for the interface you // are using. Legal values are: // - Commented out: No ENC424J600/624J600 present or used. All other // ENC100_* macros are ignored. // - 0: SPI mode using CS, SCK, SI, and SO pins // - 1: 8-bit demultiplexed PSP Mode 1 with RD and WR pins // - 2: *8-bit demultiplexed PSP Mode 2 with R/Wbar and EN pins // - 3: *16-bit demultiplexed PSP Mode 3 with RD, WRL, and WRH pins // - 4: *16-bit demultiplexed PSP Mode 4 with R/Wbar, B0SEL, and B1SEL pins // - 5: 8-bit multiplexed PSP Mode 5 with RD and WR pins // - 6: *8-bit multiplexed PSP Mode 6 with R/Wbar and EN pins // - 9: 16-bit multiplexed PSP Mode 9 with AL, RD, WRL, and WRH pins // - 10: *16-bit multiplexed PSP Mode 10 with AL, R/Wbar, B0SEL, and B1SEL // pins // *IMPORTANT NOTE: DO NOT USE PSP MODE 2, 4, 6, OR 10 ON EXPLORER 16! // Attempting to do so will cause bus contention with the LCD module which // shares the PMP. Also, PSP Mode 3 is risky on the Explorer 16 since it // can randomly cause bus contention with the 25LC256 EEPROM. // #define ENC100_INTERFACE_MODE 0 // If using a parallel interface, direct RAM addressing can be used (if all // addresses wires are connected), or a reduced number of pins can be used // for indirect addressing. If using an SPI interface or PSP Mode 9 or 10 // (multiplexed 16-bit modes), which require all address lines to always be // connected, then this option is ignored. Comment out or uncomment this // macro to match your hardware connections. #define ENC100_PSP_USE_INDIRECT_RAM_ADDRESSING // ENC424J600/624J600 parallel indirect address remapping macro function. // This section translates SFR and RAM addresses presented to the // ReadMemory() and WriteMemory() APIs in ENCX24J600.c to the actual // addresses that must be presented on the parallel interface. This macro // must be modified to match your hardware if you are using an indirect PSP // addressing mode (ENC100_PSP_USE_INDIRECT_RAM_ADDRESSING is defined) and // have some of your address lines tied off to Vdd. If you are using the // SPI interface, then this section can be ignored or deleted. #if (ENC100_INTERFACE_MODE == 1) || (ENC100_INTERFACE_MODE == 2) || (ENC100_INTERFACE_MODE == 5) || (ENC100_INTERFACE_MODE == 6) // 8-bit PSP #define ENC100_TRANSLATE_TO_PIN_ADDR(a) ((((a)&0x0100)<<6) | ((a)&0x00FF)) #elif (ENC100_INTERFACE_MODE == 3) || (ENC100_INTERFACE_MODE == 4) // 16-bit PSP #define ENC100_TRANSLATE_TO_PIN_ADDR(a) (a) #endif // Auto-crossover pins on Fast 100Mbps Ethernet PICtail/PICtail Plus. If // your circuit doesn't have such a feature, delete these two defines. #define ENC100_MDIX_TRIS (TRISBbits.TRISB3) #define ENC100_MDIX_IO (LATBbits.LATB3) // ENC624J600 I/O control and status pins // If a pin is not required for your selected ENC100_INTERFACE_MODE // interface selection (ex: WRH/B1SEL for PSP modes 1, 2, 5, and 6), then // you can ignore, delete, or put anything for the pin definition. Also, // the INT and POR pins are entirely optional. If not connected, comment // them out. #if defined(__dsPIC33FJ256GP710__) #define ENC100_INT_TRIS (TRISAbits.TRISA13) // INT signal is optional and currently unused in the Microchip TCP/IP Stack. Leave this pin disconnected and comment out this pin definition if you don't want it. #define ENC100_INT_IO (PORTAbits.RA13) #else #define ENC100_INT_TRIS (TRISEbits.TRISE9) // INT signal is optional and currently unused in the Microchip TCP/IP Stack. Leave this pin disconnected and comment out this pin definition if you don't want it. #define ENC100_INT_IO (PORTEbits.RE9) #endif #if (ENC100_INTERFACE_MODE >= 1) // Parallel mode // PSP control signal pinout #define ENC100_CS_TRIS (TRISAbits.TRISA5) // CS is optional in PSP mode. If you are not sharing the parallel bus with another device, tie CS to Vdd and comment out this pin definition. #define ENC100_CS_IO (LATAbits.LATA5) #define ENC100_POR_TRIS (TRISCbits.TRISC1) // POR signal is optional. If your application doesn't have a power disconnect feature, comment out this pin definition. #define ENC100_POR_IO (LATCbits.LATC1) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISDbits.TRISD4) #define ENC100_SO_WR_B0SEL_EN_IO (LATDbits.LATD4) #define ENC100_SI_RD_RW_TRIS (TRISDbits.TRISD5) #define ENC100_SI_RD_RW_IO (LATDbits.LATD5) #define ENC100_SCK_AL_TRIS (TRISBbits.TRISB15) #define ENC100_SCK_AL_IO (LATBbits.LATB15) #else // SPI pinout #define ENC100_CS_TRIS (TRISDbits.TRISD14) // CS is mandatory when using the SPI interface #define ENC100_CS_IO (LATDbits.LATD14) #define ENC100_POR_TRIS (TRISDbits.TRISD15) // POR signal is optional. If your application doesn't have a power disconnect feature, comment out this pin definition. #define ENC100_POR_IO (LATDbits.LATD15) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISFbits.TRISF7) // SO is ENCX24J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (PORTFbits.RF7) #define ENC100_SI_RD_RW_TRIS (TRISFbits.TRISF8) // SI is ENCX24J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATFbits.LATF8) #define ENC100_SCK_AL_TRIS (TRISFbits.TRISF6) #endif // ENC624J600 Bit Bang PSP I/O macros and pin configuration for address and // data. If using the SPI interface (ENC100_INTERFACE_MODE is 0) then this // section is not used and can be ignored or deleted. If using the PIC PMP // hardware module (if present), then ENC100_BIT_BANG_PMP must be commented // out and the remaining definitions will be ignored/can be deleted. // Otherwise, if you are using a parallel interface mode, but do not have a // PMP (or want to interface using different pins), define // ENC100_BIT_BANG_PMP and properly configure the applicable macros. //#define ENC100_BIT_BANG_PMP #if defined(ENC100_BIT_BANG_PMP) #if (ENC100_INTERFACE_MODE >= 1) && (ENC100_INTERFACE_MODE <= 4) // Dumultiplexed address/data modes #define ENC100_SET_ADDR_TRIS_OUT do{TRISE &= 0xFF00; TRISG &= 0x8FF0;}while(0) #define ENC100_SET_ADDR_IO(a) do{ \ WORD_VAL _SAIOTemp; _SAIOTemp.Val = a; \ ((BYTE*)&LATE)[0] = _SAIOTemp.v[0]; \ _SAIOTemp.v[0] = _SAIOTemp.v[1] & 0x0F; \ _SAIOTemp.v[1] &= 0x70; \ LATG = (LATG & 0x8FF0) | _SAIOTemp.Val; \ }while(0) #if ENC100_INTERFACE_MODE >= 1 && ENC100_INTERFACE_MODE <= 2 // 8-bit data mode #define ENC100_SET_AD_TRIS_IN do{TRISD |= 0x00FF;}while(0) #define ENC100_SET_AD_TRIS_OUT do{TRISD &= 0xFF00;}while(0) #define ENC100_GET_AD_IO() (((BYTE*)&PORTD)[0]) #define ENC100_SET_AD_IO(data) (((BYTE*)&LATD)[0] = (data)) #else // 16-bit data mode #define ENC100_WRH_B1SEL_TRIS ENC100_SO_WR_B0SEL_EN_TRIS #define ENC100_WRH_B1SEL_IO ENC100_SO_WR_B0SEL_EN_IO #define ENC100_SET_AD_TRIS_IN do{TRISD = 0xFFFF;}while(0) #define ENC100_SET_AD_TRIS_OUT do{TRISD = 0x0000;}while(0) #define ENC100_GET_AD_IO() (((WORD*)&PORTD)[0]) #define ENC100_SET_AD_IO(data) (((WORD*)&LATD)[0] = (data)) #endif #else // Mutliplexed address/data modes #define ENC100_SET_AD_TRIS_IN do{TRISE |= 0x00FF; TRISG |= 0x0003; TRISF |= 0x0003; TRISD |= 0x3040;}while(0) #define ENC100_SET_AD_TRIS_OUT do{TRISE &= 0xFF00; TRISG &= 0xFFFC; TRISF &= 0xFFFC; TRISD &= 0xCFBF;}while(0) #define ENC100_GET_AD_IO() (((BYTE*)&PORTE)[0]) #define ENC100_SET_AD_IO(data) do{WORD _wDataSetMacro = (data); ((BYTE*)&LATE)[0] = ((BYTE*)&_wDataSetMacro)[0]; LATGbits.LATG0 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x1) == 0x1; LATGbits.LATG1 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x2) == 0x2; LATFbits.LATF1 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x4) == 0x4; LATFbits.LATF0 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x8) == 0x8; LATDbits.LATD12 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x10) == 0x10; LATDbits.LATD13 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x20) == 0x20; LATDbits.LATD6 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x40) == 0x40; LATDbits.LATD7 = ((((BYTE*)&_wDataSetMacro)[1]) & 0x80) == 0x80;}while(0) #endif #endif // ENC624J600 SPI SFR register selection (controls which SPI peripheral to // use on PICs with multiple SPI peripherals). If a parallel interface is // used (ENC100_INTERFACE_MODE is >= 1), then the SPI is not used and this // section can be ignored or deleted. #if defined(__C30__) // PIC24F, PIC24H, dsPIC30, dsPIC33 #define ENC100_ISR_ENABLE (IEC1bits.INT2IE) #define ENC100_ISR_FLAG (IFS1bits.INT2IF) #define ENC100_ISR_POLARITY (INTCON2bits.INT2EP) #define ENC100_ISR_PRIORITY (IPC7bits.INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (IFS0bits.SPI1IF) #define ENC100_SSPBUF (SPI1BUF) #define ENC100_SPISTAT (SPI1STAT) #define ENC100_SPISTATbits (SPI1STATbits) #define ENC100_SPICON1 (SPI1CON1) #define ENC100_SPICON1bits (SPI1CON1bits) #define ENC100_SPICON2 (SPI1CON2) #else // PIC32MX #define ENC100_ISR_ENABLE (IEC0bits.INT2IE) #define ENC100_ISR_FLAG (IFS0bits.INT2IF) #define ENC100_ISR_POLARITY (INTCONbits.INT2EP) #define ENC100_ISR_PRIORITY (IPC2bits.INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPICON1bits.ON) #define ENC100_SPI_IF (IFS0bits.SPI1RXIF) #define ENC100_SSPBUF (SPI1BUF) #define ENC100_SPICON1 (SPI1CON) #define ENC100_SPISTATbits (SPI1STATbits) #define ENC100_SPICON1bits (SPI1CONbits) #define ENC100_SPIBRG (SPI1BRG) #endif // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISDbits.TRISD12) #define EEPROM_CS_IO (PORTDbits.RD12) #define EEPROM_SCK_TRIS (TRISGbits.TRISG6) #define EEPROM_SDI_TRIS (TRISGbits.TRISG7) #define EEPROM_SDO_TRIS (TRISGbits.TRISG8) #if defined(__C30__) // PIC24F, PIC24H, dsPIC30, dsPIC33 #define EEPROM_SPI_IF (IFS2bits.SPI2IF) #define EEPROM_SSPBUF (SPI2BUF) #define EEPROM_SPICON1 (SPI2CON1) #define EEPROM_SPICON1bits (SPI2CON1bits) #define EEPROM_SPICON2 (SPI2CON2) #define EEPROM_SPISTAT (SPI2STAT) #define EEPROM_SPISTATbits (SPI2STATbits) #else // PIC32 #define EEPROM_SPI_IF (IFS1bits.SPI2RXIF) #define EEPROM_SSPBUF (SPI2BUF) #define EEPROM_SPICON1 (SPI2CON) #define EEPROM_SPICON1bits (SPI2CONbits) #define EEPROM_SPIBRG (SPI2BRG) #define EEPROM_SPISTAT (SPI2STAT) #define EEPROM_SPISTATbits (SPI2STATbits) #endif // LCD Module I/O pins. NOTE: On the Explorer 16, the LCD is wired to the // same PMP lines required to communicate with an ENCX24J600 in parallel // mode. Since the LCD does not have a chip select wire, if you are using // the ENC424J600/624J600 in parallel mode, the LCD cannot be used. #if !defined(ENC100_INTERFACE_MODE) || (ENC100_INTERFACE_MODE == 0) // SPI only #define LCD_DATA_TRIS (*((volatile BYTE*)&TRISE)) #define LCD_DATA_IO (*((volatile BYTE*)&LATE)) #define LCD_RD_WR_TRIS (TRISDbits.TRISD5) #define LCD_RD_WR_IO (LATDbits.LATD5) #define LCD_RS_TRIS (TRISBbits.TRISB15) #define LCD_RS_IO (LATBbits.LATB15) #define LCD_E_TRIS (TRISDbits.TRISD4) #define LCD_E_IO (LATDbits.LATD4) #endif // // Serial Flash/SRAM/UART PICtail Plus attached to SPI2 (middle pin group) // // This daughter card is not in production, but if you custom attach an SPI // // RAM or SPI Flash chip to your board, then use these definitions as a // // starting point. // #define SPIRAM_CS_TRIS (TRISGbits.TRISG9) // #define SPIRAM_CS_IO (LATGbits.LATG9) // #define SPIRAM_SCK_TRIS (TRISGbits.TRISG6) // #define SPIRAM_SDI_TRIS (TRISGbits.TRISG7) // #define SPIRAM_SDO_TRIS (TRISGbits.TRISG8) // #if defined(__C30__) // PIC24F, PIC24H, dsPIC30, dsPIC33 // #define SPIRAM_SPI_IF (IFS2bits.SPI2IF) // #define SPIRAM_SSPBUF (SPI2BUF) // #define SPIRAM_SPICON1 (SPI2CON1) // #define SPIRAM_SPICON1bits (SPI2CON1bits) // #define SPIRAM_SPICON2 (SPI2CON2) // #define SPIRAM_SPISTAT (SPI2STAT) // #define SPIRAM_SPISTATbits (SPI2STATbits) // #else // PIC32 // #define SPIRAM_SPI_IF (IFS1bits.SPI2RXIF) // #define SPIRAM_SSPBUF (SPI2BUF) // #define SPIRAM_SPICON1 (SPI2CON) // #define SPIRAM_SPICON1bits (SPI2CONbits) // #define SPIRAM_SPIBRG (SPI2BRG) // #endif // // // NOTE: You must also set the SPI_FLASH_SST/SPI_FLASH_SPANSION, // // SPI_FLASH_SECTOR_SIZE, and SPI_FLASH_PAGE_SIZE macros in // // SPIFlash.h to match your particular Flash memory chip!!! // #define SPIFLASH_CS_TRIS (TRISBbits.TRISB8) // #define SPIFLASH_CS_IO (LATBbits.LATB8) // #define SPIFLASH_SCK_TRIS (TRISGbits.TRISG6) // #define SPIFLASH_SDI_TRIS (TRISGbits.TRISG7) // #define SPIFLASH_SDI_IO (PORTGbits.RG7) // #define SPIFLASH_SDO_TRIS (TRISGbits.TRISG8) // #if defined(__C30__) // PIC24F, PIC24H, dsPIC30, dsPIC33 // #define SPIFLASH_SPI_IF (IFS2bits.SPI2IF) // #define SPIFLASH_SSPBUF (SPI2BUF) // #define SPIFLASH_SPICON1 (SPI2CON1) // #define SPIFLASH_SPICON1bits (SPI2CON1bits) // #define SPIFLASH_SPICON2 (SPI2CON2) // #define SPIFLASH_SPISTAT (SPI2STAT) // #define SPIFLASH_SPISTATbits (SPI2STATbits) // #else // PIC32 // #define SPIFLASH_SPI_IF (IFS1bits.SPI2RXIF) // #define SPIFLASH_SSPBUF (SPI2BUF) // #define SPIFLASH_SPICON1 (SPI2CON) // #define SPIFLASH_SPICON1bits (SPI2CONbits) // #define SPIFLASH_SPISTATbits (SPI2STATbits) // #define SPIFLASH_SPIBRG (SPI2BRG) // #endif //---------------------------- // ZeroG ZG2100M WiFi I/O pins //---------------------------- // If you have a ZeroG ZG2100M WiFi PICtail, you must uncomment one of // these two lines to use it. SPI1 is the top-most slot in the Explorer 16 // (closer to the LCD and prototyping area) while SPI2 corresponds to // insertion of the PICtail into the middle of the side edge connector slot. //#define ZG2100_IN_SPI1 //#define ZG2100_IN_SPI2 #if defined( ZG2100_IN_SPI1 ) // ZG2100 in SPI1 slot #define ZG_CS_TRIS (TRISBbits.TRISB2) #define ZG_CS_IO (LATBbits.LATB2) #define ZG_SDI_TRIS (TRISFbits.TRISF7) #define ZG_SCK_TRIS (TRISFbits.TRISF6) #define ZG_SDO_TRIS (TRISFbits.TRISF8) #define ZG_RST_TRIS (TRISFbits.TRISF0) #define ZG_RST_IO (LATFbits.LATF0) #define ZG_EINT_TRIS (TRISEbits.TRISE8) // INT1 #define ZG_EINT_IO (PORTEbits.RE8) #define XCEN33_TRIS (TRISFbits.TRISF1) #define XCEN33_IO (PORTFbits.RF1) #if defined( __C30__ ) #define ZG_EINT_EDGE (INTCON2bits.INT1EP) #define ZG_EINT_IE (IEC1bits.INT1IE) #define ZG_EINT_IF (IFS1bits.INT1IF) #elif defined( __PIC32MX__ ) #define ZG_EINT_EDGE (INTCONbits.INT1EP) #define ZG_EINT_IE (IEC0bits.INT1IE) #define ZG_EINT_IF (IFS0bits.INT1IF) #define ZG_EINT_IE_CLEAR IEC0CLR #define ZG_EINT_IF_CLEAR IFS0CLR #define ZG_EINT_IE_SET IEC0SET #define ZG_EINT_IF_SET IFS0SET #define ZG_EINT_BIT 0x00000080 #define ZG_EINT_IPCSET IPC1SET #define ZG_EINT_IPCCLR IPC1CLR #define ZG_EINT_IPC_MASK 0xFF000000 #define ZG_EINT_IPC_VALUE 0x0C000000 #else #error Determine ZG2100 external interrupt #endif #define ZG_SSPBUF (SPI1BUF) #define ZG_SPISTAT (SPI1STAT) #define ZG_SPISTATbits (SPI1STATbits) #if defined( __C30__ ) #define ZG_SPICON1 (SPI1CON1) #define ZG_SPICON1bits (SPI1CON1bits) #define ZG_SPICON2 (SPI1CON2) #define ZG_SPI_IE (IEC0bits.SPI1IE) // #define ZG_SPI_IP (IPC2bits.SPI1IP) #define ZG_SPI_IF (IFS0bits.SPI1IF) #elif defined( __PIC32MX__ ) #define ZG_SPICON1 (SPI1CON) #define ZG_SPICON1bits (SPI1CONbits) #define ZG_SPI_IE_CLEAR IEC0CLR #define ZG_SPI_IF_CLEAR IFS0CLR #define ZG_SPI_INT_BITS 0x03800000 #define ZG_SPI_BRG (SPI1BRG) #define ZG_MAX_SPI_FREQ (10000000ul) // Hz #else #error Determine ZG2100 SPI information #endif #elif defined( ZG2100_IN_SPI2 ) // ZG2100 in SPI2 slot #define ZG_CS_TRIS (TRISGbits.TRISG9) #define ZG_CS_IO (LATGbits.LATG9) #define ZG_SDI_TRIS (TRISGbits.TRISG7) #define ZG_SCK_TRIS (TRISGbits.TRISG6) #define ZG_SDO_TRIS (TRISGbits.TRISG8) #define ZG_RST_TRIS (TRISGbits.TRISG0) #define ZG_RST_IO (LATGbits.LATG0) #define ZG_EINT_TRIS (TRISAbits.TRISA14) // INT3 #define ZG_EINT_IO (PORTAbits.RA14) #define XCEN33_TRIS (TRISGbits.TRISG1) #define XCEN33_IO (PORTGbits.RG1) #if defined( __C30__ ) #define ZG_EINT_EDGE (INTCON2bits.INT3EP) #define ZG_EINT_IE (IEC3bits.INT3IE) #define ZG_EINT_IF (IFS3bits.INT3IF) #elif defined( __PIC32MX__ ) #define ZG_EINT_EDGE (INTCONbits.INT3EP) #define ZG_EINT_IE (IEC0bits.INT3IE) #define ZG_EINT_IF (IFS0bits.INT3IF) #define ZG_EINT_IE_CLEAR IEC0CLR #define ZG_EINT_IF_CLEAR IFS0CLR #define ZG_EINT_IE_SET IEC0SET #define ZG_EINT_IF_SET IFS0SET #define ZG_EINT_BIT 0x00008000 #define ZG_EINT_IPCSET IPC3SET #define ZG_EINT_IPCCLR IPC3CLR #define ZG_EINT_IPC_MASK 0xFF000000 #define ZG_EINT_IPC_VALUE 0x0C000000 #else #error Determine ZG2100 external interrupt #endif #define ZG_SSPBUF (SPI2BUF) #define ZG_SPISTAT (SPI2STAT) #define ZG_SPISTATbits (SPI2STATbits) #if defined( __C30__ ) #define ZG_SPICON1 (SPI2CON1) #define ZG_SPICON1bits (SPI2CON1bits) #define ZG_SPICON2 (SPI2CON2) #define ZG_SPI_IE (IEC2bits.SPI2IE) // #define ZG_SPI_IP (IPC8bits.SPI2IP) #define ZG_SPI_IF (IFS2bits.SPI2IF) #elif defined( __PIC32MX__ ) #define ZG_SPICON1 (SPI2CON) #define ZG_SPICON1bits (SPI2CONbits) #define ZG_SPI_IE_CLEAR IEC1CLR #define ZG_SPI_IF_CLEAR IFS1CLR #define ZG_SPI_INT_BITS 0x000000e0 #define ZG_SPI_BRG (SPI2BRG) #define ZG_MAX_SPI_FREQ (10000000ul) // Hz #else #error Determine ZG2100 SPI information #endif #endif #elif defined(DSPICDEM11) // dsPICDEM 1.1 Development Board + Ethernet PICtail airwired. There // is no PICtail header on this development board. The following // airwires must be made: // 1. dsPICDEM GND <-> PICtail GND (PICtail pin 27) // 2. dsPICDEM Vdd <- PICtail VPIC (PICtail pin 25) // 3. dsPICDEM RG2 -> PICtail ENC28J60 CS (PICtail pin 22) // 4. dsPICDEM RF6 -> PICtail SCK (PICtail pin 11) // 5. dsPICDEM RF7 <- PICtail SDI (PICtail pin 9) // 6. dsPICDEM RF8 -> PICtail SDO (PICtail pin 7) // 7. dsPICDEM RG3 -> PICtail 25LC256 CS (PICtail pin 20) #define LED0_TRIS (TRISDbits.TRISD3) // Ref LED4 #define LED0_IO (PORTDbits.RD3) #define LED1_TRIS (TRISDbits.TRISD2) // Ref LED3 #define LED1_IO (PORTDbits.RD2) #define LED2_TRIS (TRISDbits.TRISD1) // Ref LED2 #define LED2_IO (PORTDbits.RD1) #define LED3_TRIS (TRISDbits.TRISD0) // Ref LED1 #define LED3_IO (PORTDbits.RD0) #define LED4_TRIS (TRISDbits.TRISD3) // No LED, Remapped to Ref LED4 #define LED4_IO (PORTDbits.RD3) #define LED5_TRIS (TRISDbits.TRISD2) // No LED, Remapped to Ref LED3 #define LED5_IO (PORTDbits.RD2) #define LED6_TRIS (TRISDbits.TRISD1) // No LED, Remapped to Ref LED2 #define LED6_IO (PORTDbits.RD1) #define LED7_TRIS (TRISDbits.TRISD0) // No LED, Remapped to Ref LED1 #define LED7_IO (PORTDbits.RD0) #define LED_GET() ((LED3_IO<<3) | (LED2_IO<<2) | (LED1_IO<<1) | LED0_IO) #define LED_PUT(a) do{BYTE vTemp = (a); LED0_IO = vTemp&0x1; LED1_IO = vTemp&0x2; LED2_IO = vTemp&0x4; LED3_IO = vTemp&0x8;} while(0) #define BUTTON0_TRIS (TRISAbits.TRISA15) // Ref SW4 #define BUTTON0_IO (PORTAbits.RA15) #define BUTTON1_TRIS (TRISAbits.TRISA14) // Ref SW3 #define BUTTON1_IO (PORTAbits.RA14) #define BUTTON2_TRIS (TRISAbits.TRISA13) // Ref SW2 #define BUTTON2_IO (PORTAbits.RA13) #define BUTTON3_TRIS (TRISAbits.TRISA12) // Ref SW1 #define BUTTON3_IO (PORTAbits.RA12) #define UARTTX_TRIS (TRISFbits.TRISF3) #define UARTTX_IO (PORTFbits.RF3) #define UARTRX_TRIS (TRISFbits.TRISF2) #define UARTRX_IO (PORTFbits.RF2) // ENC28J60 I/O pins #define ENC_CS_TRIS (TRISGbits.TRISG2) // User must airwire this #define ENC_CS_IO (PORTGbits.RG2) // SPI SCK, SDI, SDO pins are automatically controlled by the // PIC24/dsPIC/PIC32 SPI module #define ENC_SPI_IF (IFS0bits.SPI1IF) #define ENC_SSPBUF (SPI1BUF) #define ENC_SPICON1 (SPI1CON) #define ENC_SPICON1bits (SPI1CONbits) #define ENC_SPICON2 (SPI1BUF) // SPI1CON2 doesn't exist, remap to unimportant register #define ENC_SPISTAT (SPI1STAT) #define ENC_SPISTATbits (SPI1STATbits) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISGbits.TRISG3) // User must airwire this #define EEPROM_CS_IO (PORTGbits.RG3) #define EEPROM_SCK_TRIS (TRISGbits.TRISG6) #define EEPROM_SDI_TRIS (TRISGbits.TRISG7) #define EEPROM_SDO_TRIS (TRISGbits.TRISG8) #define EEPROM_SPI_IF (IFS0bits.SPI1IF) #define EEPROM_SSPBUF (SPI1BUF) #define EEPROM_SPICON1 (SPI1CON) #define EEPROM_SPICON1bits (SPI1CONbits) #define EEPROM_SPICON2 (SPI1BUF) // SPI1CON2 doesn't exist, remap to unimportant register #define EEPROM_SPISTAT (SPI1STAT) #define EEPROM_SPISTATbits (SPI1STATbits) // SI3000 codec pins #define CODEC_RST_TRIS (TRISFbits.TRISF6) #define CODEC_RST_IO (PORTFbits.RF6) // PIC18F252 LCD Controller #define LCDCTRL_CS_TRIS (TRISGbits.TRISG9) #define LCDCTRL_CS_IO (PORTGbits.RG9) #elif defined(PICDEMNET2) && !defined(HI_TECH_C) // PICDEM.net 2 (PIC18F97J60 + ENC28J60 or ENC624J600) // I/O pins #define LED0_TRIS (TRISJbits.TRISJ0) #define LED0_IO (LATJbits.LATJ0) #define LED1_TRIS (TRISJbits.TRISJ1) #define LED1_IO (LATJbits.LATJ1) #define LED2_TRIS (TRISJbits.TRISJ2) #define LED2_IO (LATJbits.LATJ2) #define LED3_TRIS (TRISJbits.TRISJ3) #define LED3_IO (LATJbits.LATJ3) #define LED4_TRIS (TRISJbits.TRISJ4) #define LED4_IO (LATJbits.LATJ4) #define LED5_TRIS (TRISJbits.TRISJ5) #define LED5_IO (LATJbits.LATJ5) #define LED6_TRIS (TRISJbits.TRISJ6) #define LED6_IO (LATJbits.LATJ6) #define LED7_TRIS (TRISJbits.TRISJ7) #define LED7_IO (LATJbits.LATJ7) #define LED_GET() (LATJ) #define LED_PUT(a) (LATJ = (a)) #define BUTTON0_TRIS (TRISBbits.TRISB3) #define BUTTON0_IO (PORTBbits.RB3) #define BUTTON1_TRIS (TRISBbits.TRISB2) #define BUTTON1_IO (PORTBbits.RB2) #define BUTTON2_TRIS (TRISBbits.TRISB1) #define BUTTON2_IO (PORTBbits.RB1) #define BUTTON3_TRIS (TRISBbits.TRISB0) #define BUTTON3_IO (PORTBbits.RB0) // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus defines //#define ENC100_INTERFACE_MODE 0 // Uncomment this to use the ENC424J600/624J600 Ethernet controller // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus I/O pins #define ENC100_MDIX_TRIS (TRISBbits.TRISB4) #define ENC100_MDIX_IO (LATBbits.LATB4) #define ENC100_POR_TRIS (TRISBbits.TRISB5) #define ENC100_POR_IO (LATBbits.LATB5) #define ENC100_INT_TRIS (TRISBbits.TRISB2) #define ENC100_INT_IO (PORTBbits.RB2) // ENC424J600/624J600 SPI pinout #define ENC100_CS_TRIS (TRISBbits.TRISB3) #define ENC100_CS_IO (LATBbits.LATB3) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISCbits.TRISC4) // NOTE: SO is ENC624J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (PORTCbits.RC4) #define ENC100_SI_RD_RW_TRIS (TRISCbits.TRISC5) // NOTE: SI is ENC624J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATCbits.LATC5) #define ENC100_SCK_AL_TRIS (TRISCbits.TRISC3) #define ENC100_SCK_AL_IO (PORTCbits.RC3) // NOTE: This must be the PORT, not the LATch like it is for the PSP interface. // ENC424J600/624J600 SPI SFR register selection (controls which SPI // peripheral to use on PICs with multiple SPI peripherals). // #define ENC100_ISR_ENABLE (INTCON3bits.INT2IE) // #define ENC100_ISR_FLAG (INTCON3bits.INT2IF) // #define ENC100_ISR_POLARITY (INTCON2bits.INTEDG2) // #define ENC100_ISR_PRIORITY (INTCON3bits.INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (PIR1bits.SSP1IF) #define ENC100_SSPBUF (SSP1BUF) #define ENC100_SPISTAT (SSP1STAT) #define ENC100_SPISTATbits (SSP1STATbits) #define ENC100_SPICON1 (SSP1CON1) #define ENC100_SPICON1bits (SSP1CON1bits) #define ENC100_SPICON2 (SSP1CON2) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISDbits.TRISD2) // Not connected by default #define ENC_RST_IO (LATDbits.LATD2) // #define ENC_CS_TRIS (TRISDbits.TRISD3) // Uncomment this line if you wish to use the ENC28J60 on the PICDEM.net 2 board instead of the internal PIC18F97J60 Ethernet module #define ENC_CS_IO (LATDbits.LATD3) #define ENC_SCK_TRIS (TRISCbits.TRISC3) #define ENC_SDI_TRIS (TRISCbits.TRISC4) #define ENC_SDO_TRIS (TRISCbits.TRISC5) #define ENC_SPI_IF (PIR1bits.SSP1IF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) //---------------- // ZG2100 I/O pins //---------------- // #define ZG_CS_TRIS (TRISCbits.TRISC2) // Uncomment this line if you wish to use the ZG2100 on the PICDEM.net 2 board instead of the internal PIC18F97J60 Ethernet module #define ZG_SDI_TRIS (TRISCbits.TRISC4) #define ZG_SCK_TRIS (TRISCbits.TRISC3) #define ZG_SDO_TRIS (TRISCbits.TRISC5) #define ZG_RST_TRIS (TRISBbits.TRISB1) #define ZG_RST_IO (LATBbits.LATB1) #define ZG_EINT_TRIS (TRISBbits.TRISB0) #define ZG_EINT_IO (PORTBbits.RB0) #define ZG_CS_IO (LATCbits.LATC2) #define XCEN33_TRIS (TRISBbits.TRISB2) #define XCEN33_IO (PORTBbits.RB2) #define ZG_EINT_EDGE (INTCON2bits.INTEDG0) #define ZG_EINT_IE (INTCONbits.INT0IE) #define ZG_EINT_IF (INTCONbits.INT0IF) #define ZG_SPI_IF (PIR1bits.SSPIF) #define ZG_SSPBUF (SSP1BUF) #define ZG_SPISTAT (SSP1STAT) #define ZG_SPISTATbits (SSP1STATbits) #define ZG_SPICON1 (SSP1CON1) #define ZG_SPICON1bits (SSP1CON1bits) #define ZG_SPICON2 (SSP1CON2) #define ZG_SPI_IE (PIE1bits.SSPIE) #define ZG_SPI_IP (IPR1bits.SSPIP) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISDbits.TRISD7) #define EEPROM_CS_IO (LATDbits.LATD7) #define EEPROM_SCK_TRIS (TRISCbits.TRISC3) #define EEPROM_SDI_TRIS (TRISCbits.TRISC4) #define EEPROM_SDO_TRIS (TRISCbits.TRISC5) #define EEPROM_SPI_IF (PIR1bits.SSP1IF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // LCD I/O pins #define LCD_DATA_TRIS (TRISE) #define LCD_DATA_IO (LATE) #define LCD_RD_WR_TRIS (TRISHbits.TRISH1) #define LCD_RD_WR_IO (LATHbits.LATH1) #define LCD_RS_TRIS (TRISHbits.TRISH2) #define LCD_RS_IO (LATHbits.LATH2) #define LCD_E_TRIS (TRISHbits.TRISH0) #define LCD_E_IO (LATHbits.LATH0) // Serial Flash/SRAM/UART PICtail // #define SPIRAM_CS_TRIS (TRISBbits.TRISB5) // #define SPIRAM_CS_IO (LATBbits.LATB5) // #define SPIRAM_SCK_TRIS (TRISCbits.TRISC3) // #define SPIRAM_SDI_TRIS (TRISCbits.TRISC4) // #define SPIRAM_SDO_TRIS (TRISCbits.TRISC5) // #define SPIRAM_SPI_IF (PIR1bits.SSPIF) // #define SPIRAM_SSPBUF (SSP1BUF) // #define SPIRAM_SPICON1 (SSP1CON1) // #define SPIRAM_SPICON1bits (SSP1CON1bits) // #define SPIRAM_SPICON2 (SSP1CON2) // #define SPIRAM_SPISTAT (SSP1STAT) // #define SPIRAM_SPISTATbits (SSP1STATbits) // // // NOTE: You must also set the SPI_FLASH_SST/SPI_FLASH_SPANSION, // // SPI_FLASH_SECTOR_SIZE, and SPI_FLASH_PAGE_SIZE macros in // // SPIFlash.h to match your particular Flash memory chip!!! // #define SPIFLASH_CS_TRIS (TRISBbits.TRISB4) // #define SPIFLASH_CS_IO (LATBbits.LATB4) // #define SPIFLASH_SCK_TRIS (TRISCbits.TRISC3) // #define SPIFLASH_SDI_TRIS (TRISCbits.TRISC4) // #define SPIFLASH_SDI_IO (PORTCbits.RC4) // #define SPIFLASH_SDO_TRIS (TRISCbits.TRISC5) // #define SPIFLASH_SPI_IF (PIR1bits.SSPIF) // #define SPIFLASH_SSPBUF (SSP1BUF) // #define SPIFLASH_SPICON1 (SSP1CON1) // #define SPIFLASH_SPICON1bits (SSP1CON1bits) // #define SPIFLASH_SPICON2 (SSP1CON2) // #define SPIFLASH_SPISTAT (SSP1STAT) // #define SPIFLASH_SPISTATbits (SSP1STATbits) #elif defined(PICDEMNET2) && defined(HI_TECH_C) // PICDEM.net 2 (PIC18F97J60 + ENC28J60) + HI-TECH PICC-18 compiler // Optionally may use Fast 100Mbps Ethernet PICtail Plus (ENC624J600) // I/O pins #define LED0_TRIS (TRISJ0) #define LED0_IO (LATJ0) #define LED1_TRIS (TRISJ1) #define LED1_IO (LATJ1) #define LED2_TRIS (TRISJ2) #define LED2_IO (LATJ2) #define LED3_TRIS (TRISJ3) #define LED3_IO (LATJ3) #define LED4_TRIS (TRISJ4) #define LED4_IO (LATJ4) #define LED5_TRIS (TRISJ5) #define LED5_IO (LATJ5) #define LED6_TRIS (TRISJ6) #define LED6_IO (LATJ6) #define LED7_TRIS (TRISJ7) #define LED7_IO (LATJ7) #define LED_GET() (LATJ) #define LED_PUT(a) (LATJ = (a)) #define BUTTON0_TRIS (TRISB3) #define BUTTON0_IO (RB3) #define BUTTON1_TRIS (TRISB2) #define BUTTON1_IO (RB2) #define BUTTON2_TRIS (TRISB1) #define BUTTON2_IO (RB1) #define BUTTON3_TRIS (TRISB0) #define BUTTON3_IO (RB0) // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISD2) // Not connected by default #define ENC_RST_IO (LATD2) // #define ENC_CS_TRIS (TRISD3) // Uncomment this line if you wish to use the ENC28J60 on the PICDEM.net 2 board instead of the internal PIC18F97J60 Ethernet module #define ENC_CS_IO (LATD3) #define ENC_SCK_TRIS (TRISC3) #define ENC_SDI_TRIS (TRISC4) #define ENC_SDO_TRIS (TRISC5) #define ENC_SPI_IF (SSPIF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus defines //#define ENC100_INTERFACE_MODE 0 // Uncomment this to use the ENC424J600/624J600 Ethernet controller // ENC424J600/624J600 Fast 100Mbps Ethernet PICtail Plus I/O pins #define ENC100_MDIX_TRIS (TRISB4) #define ENC100_MDIX_IO (LATB4) #define ENC100_POR_TRIS (TRISB5) #define ENC100_POR_IO (LATB5) #define ENC100_INT_TRIS (TRISB2) #define ENC100_INT_IO (RB2) // ENC424J600/624J600 SPI pinout #define ENC100_CS_TRIS (TRISB3) #define ENC100_CS_IO (LATB3) #define ENC100_SO_WR_B0SEL_EN_TRIS (TRISC4) // NOTE: SO is ENC624J600 Serial Out, which needs to connect to the PIC SDI pin for SPI mode #define ENC100_SO_WR_B0SEL_EN_IO (RC4) #define ENC100_SI_RD_RW_TRIS (TRISC5) // NOTE: SI is ENC624J600 Serial In, which needs to connect to the PIC SDO pin for SPI mode #define ENC100_SI_RD_RW_IO (LATC5) #define ENC100_SCK_AL_TRIS (TRISC3) #define ENC100_SCK_AL_IO (RC3) // NOTE: This must be the PORT, not the LATch like it is for the PSP interface. // ENC424J600/624J600 SPI SFR register selection (controls which SPI // peripheral to use on PICs with multiple SPI peripherals). // #define ENC100_ISR_ENABLE (INT2IE) // #define ENC100_ISR_FLAG (INT2IF) // #define ENC100_ISR_POLARITY (INTEDG2) // #define ENC100_ISR_PRIORITY (INT2IP) #define ENC100_SPI_ENABLE (ENC100_SPISTATbits.SPIEN) #define ENC100_SPI_IF (PIR1bits.SSP1IF) #define ENC100_SSPBUF (SSP1BUF) #define ENC100_SPISTAT (SSP1STAT) #define ENC100_SPISTATbits (SSP1STATbits) #define ENC100_SPICON1 (SSP1CON1) #define ENC100_SPICON1bits (SSP1CON1bits) #define ENC100_SPICON2 (SSP1CON2) // 25LC256 I/O pins #define EEPROM_CS_TRIS (TRISD7) #define EEPROM_CS_IO (LATD7) #define EEPROM_SCK_TRIS (TRISC3) #define EEPROM_SDI_TRIS (TRISC4) #define EEPROM_SDO_TRIS (TRISC5) #define EEPROM_SPI_IF (SSP1IF) #define EEPROM_SSPBUF (SSP1BUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // LCD I/O pins #define LCD_DATA_TRIS (TRISE) #define LCD_DATA_IO (LATE) #define LCD_RD_WR_TRIS (TRISH1) #define LCD_RD_WR_IO (LATH1) #define LCD_RS_TRIS (TRISH2) #define LCD_RS_IO (LATH2) #define LCD_E_TRIS (TRISH0) #define LCD_E_IO (LATH0) // Serial Flash/SRAM/UART PICtail // #define SPIRAM_CS_TRIS (TRISB5) // #define SPIRAM_CS_IO (LATB5) // #define SPIRAM_SCK_TRIS (TRISC3) // #define SPIRAM_SDI_TRIS (TRISC4) // #define SPIRAM_SDO_TRIS (TRISC5) // #define SPIRAM_SPI_IF (SSPIF) // #define SPIRAM_SSPBUF (SSP1BUF) // #define SPIRAM_SPICON1 (SSP1CON1) // #define SPIRAM_SPICON1bits (SSP1CON1bits) // #define SPIRAM_SPICON2 (SSP1CON2) // #define SPIRAM_SPISTAT (SSP1STAT) // #define SPIRAM_SPISTATbits (SSP1STATbits) // // // NOTE: You must also set the SPI_FLASH_SST/SPI_FLASH_SPANSION, // // SPI_FLASH_SECTOR_SIZE, and SPI_FLASH_PAGE_SIZE macros in // // SPIFlash.h to match your particular Flash memory chip!!! // #define SPIFLASH_CS_TRIS (TRISB4) // #define SPIFLASH_CS_IO (LATB4) // #define SPIFLASH_SCK_TRIS (TRISC3) // #define SPIFLASH_SDI_TRIS (TRISC4) // #define SPIFLASH_SDI_IO (RC4) // #define SPIFLASH_SDO_TRIS (TRISC5) // #define SPIFLASH_SPI_IF (SSPIF) // #define SPIFLASH_SSPBUF (SSP1BUF) // #define SPIFLASH_SPICON1 (SSP1CON1) // #define SPIFLASH_SPICON1bits (SSP1CON1bits) // #define SPIFLASH_SPICON2 (SSP1CON2) // #define SPIFLASH_SPISTAT (SSP1STAT) // #define SPIFLASH_SPISTATbits (SSP1STATbits) // Register name fixup for certain processors #define SPBRGH SPBRGH1 #define TXSTAbits TXSTA1bits #define RCSTAbits RCSTA1bits #define BAUDCONbits BAUDCON1bits #define GO GODONE #elif defined(INTERNET_RADIO) // Internet Radio board // Internet Radio board (05-60142) // I/O pins #define LED0_TRIS (TRISCbits.TRISC2) #define LED0_IO (LATCbits.LATC2) #define LED1_TRIS (PRODL) // No LED1 on this board #define LED1_IO (PRODL) #define LED2_TRIS (PRODL) // No LED2 on this board #define LED2_IO (PRODL) #define LED3_TRIS (PRODL) // No LED3 on this board #define LED3_IO (PRODL) #define LED4_TRIS (PRODL) // No LED4 on this board #define LED4_IO (PRODL) #define LED5_TRIS (PRODL) // No LED5 on this board #define LED5_IO (PRODL) #define LED6_TRIS (PRODL) // No LED6 on this board #define LED6_IO (PRODL) #define LED7_TRIS (PRODL) // No LED7 on this board #define LED7_IO (PRODL) #define LED_GET() (LED0_IO) #define LED_PUT(a) (LED0_IO = (a)) #define BUTTON0_TRIS (TRISBbits.TRISB5) #define BUTTON0_IO (PORTBbits.RB5) #define BUTTON1_TRIS (TRISFbits.TRISF1) #define BUTTON1_IO (PORTFbits.RF1) #define BUTTON2_TRIS (TRISBbits.TRISB4) #define BUTTON2_IO (PORTBbits.RB4) #define BUTTON3_TRIS (PRODL) // No BUTTON3 on this board #define BUTTON3_IO (PRODL) // Serial SRAM #define SPIRAM_CS_TRIS (TRISEbits.TRISE4) #define SPIRAM_CS_IO (LATEbits.LATE4) #define SPIRAM_SCK_TRIS (TRISCbits.TRISC3) #define SPIRAM_SDI_TRIS (TRISCbits.TRISC4) #define SPIRAM_SDO_TRIS (TRISCbits.TRISC5) #define SPIRAM_SPI_IF (PIR1bits.SSPIF) #define SPIRAM_SSPBUF (SSP1BUF) #define SPIRAM_SPICON1 (SSP1CON1) #define SPIRAM_SPICON1bits (SSP1CON1bits) #define SPIRAM_SPICON2 (SSP1CON2) #define SPIRAM_SPISTAT (SSP1STAT) #define SPIRAM_SPISTATbits (SSP1STATbits) #define SPIRAM2_CS_TRIS (TRISEbits.TRISE5) #define SPIRAM2_CS_IO (LATEbits.LATE5) #define SPIRAM2_SCK_TRIS (TRISCbits.TRISC3) #define SPIRAM2_SDI_TRIS (TRISCbits.TRISC4) #define SPIRAM2_SDO_TRIS (TRISCbits.TRISC5) #define SPIRAM2_SPI_IF (PIR1bits.SSPIF) #define SPIRAM2_SSPBUF (SSP1BUF) #define SPIRAM2_SPICON1 (SSP1CON1) #define SPIRAM2_SPICON1bits (SSP1CON1bits) #define SPIRAM2_SPICON2 (SSP1CON2) #define SPIRAM2_SPISTAT (SSP1STAT) #define SPIRAM2_SPISTATbits (SSP1STATbits) // VLSI VS1011/VS1053 audio encoder/decoder and DAC #define MP3_DREQ_TRIS (TRISBbits.TRISB0) // Data Request #define MP3_DREQ_IO (PORTBbits.RB0) #define MP3_XRESET_TRIS (TRISDbits.TRISD0) // Reset, active low #define MP3_XRESET_IO (LATDbits.LATD0) #define MP3_XDCS_TRIS (TRISBbits.TRISB1) // Data Chip Select #define MP3_XDCS_IO (LATBbits.LATB1) #define MP3_XCS_TRIS (TRISBbits.TRISB2) // Control Chip Select #define MP3_XCS_IO (LATBbits.LATB2) #define MP3_SCK_TRIS (TRISCbits.TRISC3) #define MP3_SDI_TRIS (TRISCbits.TRISC4) #define MP3_SDO_TRIS (TRISCbits.TRISC5) #define MP3_SPI_IF (PIR1bits.SSP1IF) #define MP3_SSPBUF (SSP1BUF) #define MP3_SPICON1 (SSP1CON1) #define MP3_SPICON1bits (SSP1CON1bits) #define MP3_SPICON2 (SSP1CON2) #define MP3_SPISTAT (SSP1STAT) #define MP3_SPISTATbits (SSP1STATbits) // OLED Display #define oledWR (PORTAbits.RA3) #define oledWR_TRIS (TRISAbits.TRISA3) #define oledRD (PORTAbits.RA4) #define oledRD_TRIS (TRISAbits.TRISA4) #define oledCS (PORTAbits.RA5) #define oledCS_TRIS (TRISAbits.TRISA5) #define oledRESET (PORTDbits.RD1) #define oledRESET_TRIS (TRISDbits.TRISD1) #define oledD_C (PORTGbits.RG4) #define oledD_C_TRIS (TRISGbits.TRISG4) #elif defined(OLIMEX_P67J60) && defined(HI_TECH_C) #error "HI TECH not supported." #elif defined(OLIMEX_P67J60) && !defined(HI_TECH_C) // PICDEM.net 2 (PIC18F97J60 + ENC28J60) // We have an early revision sillicon for now - do we really need it? #define ETH_18Fx7J60_ERRATA // I/O pins #define LED0_TRIS (PRODL) /* NC */ #define LED0_IO (PRODL) /* NC */ #define LED1_TRIS (TRISBbits.TRISB4) #define LED1_IO (LATBbits.LATB4) /* ignore rest of LEDs */ #define LED2_TRIS (PRODL) #define LED2_IO (PRODL) #define LED3_TRIS (PRODL) #define LED3_IO (PRODL) #define LED4_TRIS (PRODL) #define LED4_IO (PRODL) #define LED5_TRIS (PRODL) #define LED5_IO (PRODL) #define LED6_TRIS (PRODL) #define LED6_IO (PRODL) #define LED7_TRIS (PRODL) #define LED7_IO (PRODL) #define LED_GET() (LED1_IO) #define LED_PUT(a) (LED1_IO = (a)) #define BUTTON0_TRIS (TRISBbits.TRISB3) #define BUTTON0_IO (PORTBbits.RB3) #define BUTTON1_TRIS BUTTON0_TRIS #define BUTTON1_IO 1 #define BUTTON2_TRIS BUTTON0_TRIS #define BUTTON2_IO 1 #define BUTTON3_TRIS BUTTON0_TRIS #define BUTTON3_IO 1 // ENC28J60 I/O pins #define ENC_RST_TRIS (TRISDbits.TRISD2) // Not connected by default #define ENC_RST_IO (LATDbits.LATD2) // #define ENC_CS_TRIS (TRISDbits.TRISD3) // Uncomment this line if you wish to use the ENC28J60 on the PICDEM.net 2 board instead of the internal PIC18F97J60 Ethernet module #define ENC_CS_IO (LATDbits.LATD3) #define ENC_SCK_TRIS (TRISCbits.TRISC3) #define ENC_SDI_TRIS (TRISCbits.TRISC4) #define ENC_SDO_TRIS (TRISCbits.TRISC5) #define ENC_SPI_IF (PIR1bits.SSPIF) #define ENC_SSPBUF (SSP1BUF) #define ENC_SPISTAT (SSP1STAT) #define ENC_SPISTATbits (SSP1STATbits) #define ENC_SPICON1 (SSP1CON1) #define ENC_SPICON1bits (SSP1CON1bits) #define ENC_SPICON2 (SSP1CON2) // spi dataflash #define EEPROM_CS_TRIS (TRISFbits.TRISF7) #define EEPROM_CS_IO (LATFbits.LATF7) #define EEPROM_SCK_TRIS (TRISCbits.TRISC3) #define EEPROM_SDI_TRIS (TRISCbits.TRISC4) #define EEPROM_SDO_TRIS (TRISCbits.TRISC5) #define EEPROM_SPI_IF (PIR1bits.SSPIF) #define EEPROM_SSPBUF (SSPBUF) #define EEPROM_SPICON1 (SSP1CON1) #define EEPROM_SPICON1bits (SSP1CON1bits) #define EEPROM_SPICON2 (SSP1CON2) #define EEPROM_SPISTAT (SSP1STAT) #define EEPROM_SPISTATbits (SSP1STATbits) // Serial Flash/SRAM/UART PICtail // #define SPIRAM_CS_TRIS (TRISBbits.TRISB5) // #define SPIRAM_CS_IO (LATBbits.LATB5) // #define SPIRAM_SCK_TRIS (TRISCbits.TRISC3) // #define SPIRAM_SDI_TRIS (TRISCbits.TRISC4) // #define SPIRAM_SDO_TRIS (TRISCbits.TRISC5) // #define SPIRAM_SPI_IF (PIR1bits.SSPIF) // #define SPIRAM_SSPBUF (SSP1BUF) // #define SPIRAM_SPICON1 (SSP1CON1) // #define SPIRAM_SPICON1bits (SSP1CON1bits) // #define SPIRAM_SPICON2 (SSP1CON2) // #define SPIRAM_SPISTAT (SSP1STAT) // #define SPIRAM_SPISTATbits (SSP1STATbits) // #define SPIFLASH_CS_TRIS (TRISBbits.TRISB4) // #define SPIFLASH_CS_IO (LATBbits.LATB4) // #define SPIFLASH_SCK_TRIS (TRISCbits.TRISC3) // #define SPIFLASH_SDI_TRIS (TRISCbits.TRISC4) // #define SPIFLASH_SDI_IO (PORTCbits.RC4) // #define SPIFLASH_SDO_TRIS (TRISCbits.TRISC5) // #define SPIFLASH_SPI_IF (PIR1bits.SSPIF) // #define SPIFLASH_SSPBUF (SSP1BUF) // #define SPIFLASH_SPICON1 (SSP1CON1) // #define SPIFLASH_SPICON1bits (SSP1CON1bits) // #define SPIFLASH_SPICON2 (SSP1CON2) // #define SPIFLASH_SPISTAT (SSP1STAT) // #define SPIFLASH_SPISTATbits (SSP1STATbits) #elif defined(YOUR_BOARD) // Define your own board hardware profile here #else #error "Hardware profile not defined. See available profiles in HardwareProfile.h and modify or create one." #endif #if defined(__18CXX) // PIC18 // UART mapping functions for consistent API names across 8-bit and 16 or // 32 bit compilers. For simplicity, everything will use "UART" instead // of USART/EUSART/etc. #define BusyUART() BusyUSART() #define CloseUART() CloseUSART() #define ConfigIntUART(a) ConfigIntUSART(a) #define DataRdyUART() DataRdyUSART() #define OpenUART(a,b,c) OpenUSART(a,b,c) #define ReadUART() ReadUSART() #define WriteUART(a) WriteUSART(a) #define getsUART(a,b,c) getsUSART(b,a) #define putsUART(a) putsUSART(a) #define getcUART() ReadUSART() #define putcUART(a) WriteUSART(a) #define putrsUART(a) putrsUSART((far rom char*)a) #else // PIC24F, PIC24H, dsPIC30, dsPIC33, PIC32 // Some A/D converter registers on dsPIC30s are named slightly differently // on other procesors, so we need to rename them. #if defined(__dsPIC30F__) #define ADC1BUF0 ADCBUF0 #define AD1CHS ADCHS #define AD1CON1 ADCON1 #define AD1CON2 ADCON2 #define AD1CON3 ADCON3 #define AD1PCFGbits ADPCFGbits #define AD1CSSL ADCSSL #define AD1IF ADIF #define AD1IE ADIE #define _ADC1Interrupt _ADCInterrupt #endif // Select which UART the STACK_USE_UART and STACK_USE_UART2TCP_BRIDGE // options will use. You can change these to U1BRG, U1MODE, etc. if you // want to use the UART1 module instead of UART2. #define UBRG U2BRG #define UMODE U2MODE #define USTA U2STA #define BusyUART() BusyUART2() #define CloseUART() CloseUART2() #define ConfigIntUART(a) ConfigIntUART2(a) #define DataRdyUART() DataRdyUART2() #define OpenUART(a,b,c) OpenUART2(a,b,c) #define ReadUART() ReadUART2() #define WriteUART(a) WriteUART2(a) #define getsUART(a,b,c) getsUART2(a,b,c) #if defined(__C32__) #define putsUART(a) putsUART2(a) #else #define putsUART(a) putsUART2((unsigned int*)a) #endif #define getcUART() getcUART2() #define putcUART(a) do{while(BusyUART()); WriteUART(a); while(BusyUART()); }while(0) #define putrsUART(a) putrsUART2(a) #endif #endif
