// XXcopter software // ================= // Version XXcontrol_KR_v1.4a // inspired by KKmulticopter // based on assembly code by Rolf R Bakke // Converted by Mike Barton // // Modified by Minsoo Kim // Updated by Jean-Louis Naudin // tested in flight version on QRO v4, V5, V6 // // Optimized for Korean Blue Board ( www.kkmulticopter.kr ) // supports 168 and 328 // // Copter Types*: SINGLE_COPTER, DUAL_COPTER, TRI_COPTER, QUAD_COPTER, QUAD_X_COPTER, HEX_COPTER, Y6_COPTER // // Config Modes (at startup) // ================= // http://www.kkmulticopter.kr/index.html?modea=manual // // // Version History // =============== // // _KR_v1.4a Minor update for the QRO v6 by JL Naudin // _KR_v1.4 Fixed bugs in case of yaw reverse at tricopter // Default Set 3 for GAIN_MULTIPLIER // // _KR_v1.3 DualCopter was added. // Fixed bugs at ReadGainPots // // _KR_v1.2 SingleCopter was added. // // _KR_v1.1 Audible arming sound (Mike's source) // PWM refresh rate 495Hz (Mike's & manuLRK's source) // Default Set 2 for GAIN_MULTIPLIER // Calibrate Gyros when mode changed // // _KR_v1.0 Optimized for Korean Blue Board(www.kkmulticopter.kr) // Servo Noise Filter at Tri // Normal, Acro, UFO mode change by transmitter // Calibrate gyro when Thr: Low, Elevator: Down, Rudder: Left (Normal Mode) // Delay Stick Centering for Receiver Binding // Arming Time 0.5sec and changed to Right-Side Arming // User Delay Procedure // used XXcontrol v1.0i // Config Modes (at startup) // ================= // http://www.kkmulticopter.kr/index.html?modea=manual // // Stick Centering // --------------- // set Pitch Gain pot to zero // set Tx trims to centre // power on // led flashes 3 times // restore gain pot // use as normal // Servo direction reversing for Tri // --------------------------- // set Roll Gain pot to zero // power on // led flashes 3 times // move Rudder stick Left for Normal, Right for reverse // eg: to set Servo Normal, move Tx Rudder stick left, or to reverse it move stick right // ESC throttle calibration // ------------------------ // set Yaw Gain pot to zero // put throttle stick to full // power on // led flashes 3 times // wait for motor signal (double bleep) // throttle to zero // wait for motor confirm signal // power off // restore gain pot // Clear all settings (gyro & stick centering) // ------------------------------------------- // set Roll, Pitch & Yaw Gain pots to zero // power on, wait a few seconds, power off // restore gain pots // /* Single M1 CCW | | | M2 (Servo) | | M5 ---- ----M3 (Servo) | (Servo) | M4 (Servo) Dual M1 CCW | M2 CW | | | M3 ---------- (Servo) | | M4 (Servo) Tri M1 CW M2 CCW \ / \ --- / | | --- | | M3 CCW M4=Tail Servo Quad M1 CW | | | +---+ CCW M2----| |----M3 CCW +---+ | | | M4 CW Quad-X M1CW M2CCW \ / \ --- / | | / --- \ / \ M4 CCW M3 CW Hex M1 CW | M6 | M2 CCW \ | / \ +---+ / -| |- / +---+ \ / | \ M5 | M3 CW | M4 Y6 M1/2 M3/4 M1,4,5 = CW \ / M2,3,6 = CCW \ --- / | | --- | | M5/6 */ /* ----------- Configuration ----------- */ //#define SINGLE_COPTER //#define DUAL_COPTER //#define TWIN_COPTER (In the future) //#define TRI_COPTER #define QUAD_COPTER //#define QUAD_X_COPTER //#define HEX_COPTER //#define Y6_COPTER // defines output rate to ESC/Servo // either define by setting ESC_RATE (Max is approx 495Hz) // uses Timer 1 ticks to control output rate. #define ESC_RATE 300 // in Hz //#define ESC_RATE 400 // in Hz (at SINGLE_COPTER and DUAL_COPTER) //#define ESC_RATE 450 // in Hz //#define ESC_RATE 495 // in Hz #define PWM_LOW_PULSE_INTERVAL (((F_CPU / 8) / ESC_RATE) - 2000)/10 //#define PWM_LOW_PULSE_INTERVAL ((1000000 / ESC_RATE) - 2000)/10 //or define by setting PWM_LOW_PULSE_INTERVAL (minimum is 1) // Adjust these: // down if you have too much gyro assistance // up if you have maxxed your gyro gain #define ROLL_GAIN_MULTIPLIER 3 // 2 #define PITCH_GAIN_MULTIPLIER 3 // 2 #define YAW_GAIN_MULTIPLIER 3 // 2 // Minsoo #define NORMAL_STICK_ROLL_GAIN 50 // Stick %, Normal: 50, Acro: 60~70 #define NORMAL_STICK_PITCH_GAIN 50 // Stick %, Normal: 50, Acro: 60~70 #define NORMAL_STICK_YAW_GAIN 50 // Stick %, Normal: 50, Acro: 60~70 #define ACRO_STICK_ROLL_GAIN 65 // Stick %, Normal: 50, Acro: 60~70 #define ACRO_STICK_PITCH_GAIN 65 // Stick %, Normal: 50, Acro: 60~70 #define ACRO_STICK_YAW_GAIN 65 // Stick %, Normal: 50, Acro: 60~70 #define UFO_STICK_YAW_GAIN 90 // Stick %, Normal: 50, Acro: 60~70, UFO: 80~90 #define ADC_GAIN_DIVIDER 200 // Gyro Value Range (-100~100: 150, -150~150: 225, -250~250: 375) // Stick Arming - enable this line to enable Stick arming #define STICK_ARMING 60 // enable this line if you don't have Yaw gyro connected //#define EXTERNAL_YAW_GYRO // Max Collective // limits the maximum stick collective (range 80->100 100=Off) // this allows gyros to stabilise better when full throttle applied #define MAX_COLLECTIVE 90 // 95 /* ----------- Main Code ----------- */ #include #include #include #include #include #include #include #include "typedefs.h" #include "io_cfg.h" #define EEPROM_DATA_START_POS 0 // allows moving (not really necessary) // Max ADC #define UC_ADC_MAX 1023 // used to invert ADC reading of uC enum GyroDirection { GYRO_NORMAL = 0, GYRO_REVERSED }; enum GyroArrayIndex { ROLL = 0, PITCH, YAW }; // eeProm data structure typedef struct Config_Struct CONFIG_STRUCT; struct Config_Struct { uint8_t setup; // byte to identify if already setup uint8_t RollGyroDirection; uint8_t PitchGyroDirection; uint8_t YawGyroDirection; // allows setting to zero uint16_t RxChannel1ZeroOffset; uint16_t RxChannel2ZeroOffset; uint16_t RxChannel3ZeroOffset; // currently fixed uint16_t RxChannel4ZeroOffset; }; CONFIG_STRUCT Config; // Holds configuration (from eeProm) bool GyroCalibrated; volatile BOOL RxChannelsUpdatingFlag; bool Armed; uint16_t GainInADC[3]; // ADC result uint16_t GainIn[3]; // = GainInADC[3]/10 #ifdef SINGLE_COPTER int16_t LowpassOutServo[3]; // Minsoo #endif #ifdef DUAL_COPTER int16_t LowpassOutServo[2]; // Minsoo #endif #ifdef TRI_COPTER int16_t LowpassOutYaw; // Minsoo #endif #if defined(SINGLE_COPTER) || defined(DUAL_COPTER) || defined(TRI_COPTER) uint16_t ServoPPMRateDivider = 0; #endif volatile uint16_t RxChannel1; // ISR vars volatile uint16_t RxChannel2; volatile uint16_t RxChannel3; volatile uint16_t RxChannel4; uint16_t RxChannel1Start; // ISR vars uint16_t RxChannel2Start; uint16_t RxChannel3Start; uint16_t RxChannel4Start; int16_t RxInRoll; // program vars int16_t RxInPitch; int16_t RxInCollective; int16_t RxInYaw; int16_t gyroADC[3]; // Holds Gyro ADC's int16_t gyroZero[3] = {0,0,0}; // used for calibrating Gyros on ground uint16_t ModeDelayCounter; bool output_motor_high = false; uint16_t PWM_Low_Pulse_Interval = PWM_LOW_PULSE_INTERVAL; // non-const version of PWM_LOW_PULSE_INTERVAL int16_t MotorOut1; int16_t MotorOut2; int16_t MotorOut3; int16_t MotorOut4; #if defined(SINGLE_COPTER) || defined(HEX_COPTER) || defined(Y6_COPTER) int16_t MotorOut5; #endif #if defined(HEX_COPTER) || defined(Y6_COPTER) int16_t MotorOut6; #endif // Minsoo int16_t StickRollGain; int16_t StickPitchGain; int16_t StickYawGain; void setup(void); void loop(void); void Init_ADC(void); void ReadGyros(bool calibrate); void CalibrateGyros(void); void ReadGainPots(void); void RxGetChannels(void); void read_adc(uint8_t channel); void output_motor_ppm(void); void Initial_EEPROM_Config_Load(void); void Save_Config_to_EEPROM(void); void Set_EEPROM_Default_Config(void); void eeprom_write_byte_changed( uint8_t * addr, uint8_t value ); void eeprom_write_block_changes( const uint8_t * src, void * dest, size_t size ); // Minsoo Kim void delay_us(uint8_t time); void delay_ms(uint16_t time); // RX_ROLL ISR(PCINT2_vect) { if ( RX_ROLL ) // rising { RxChannel1Start = TCNT1; } else { // falling RxChannelsUpdatingFlag = 1; RxChannel1 = TCNT1 - RxChannel1Start; RxChannelsUpdatingFlag = 0; } } // RX_PITCH ISR(INT0_vect) { if (RX_PITCH) { RxChannel2Start = TCNT1; } else { // falling RxChannelsUpdatingFlag = 1; RxChannel2 = TCNT1 - RxChannel2Start; RxChannelsUpdatingFlag = 0; } } // RX_COLL ISR(INT1_vect) { if (RX_COLL) { RxChannel3Start = TCNT1; } else { // falling RxChannelsUpdatingFlag = 1; RxChannel3 = TCNT1 - RxChannel3Start; RxChannelsUpdatingFlag = 0; } } // RX_YAW ISR(PCINT0_vect) { if ( RX_YAW ) // rising { RxChannel4Start = TCNT1; } else { // falling RxChannelsUpdatingFlag = 1; RxChannel4 = TCNT1 - RxChannel4Start; RxChannelsUpdatingFlag = 0; } } int main(void) { setup(); while (1) { loop(); } return 1; } void setup(void) { uint16_t i; // nb was uint8_t, must be uint16_t for TRI uint16_t RxChannel1ZeroOffset, RxChannel2ZeroOffset, RxChannel4ZeroOffset; MCUCR |= (1<50); #endif #ifdef SINGLE_COPTER LowpassOutServo[ROLL] = 84; // Center LowpassOutServo[PITCH] = 84; // Center LowpassOutServo[YAW] = 84; // Center #endif #ifdef DUAL_COPTER LowpassOutServo[ROLL] = 84; // Center LowpassOutServo[PITCH] = 84; // Center #endif #ifdef TRI_COPTER LowpassOutYaw = 0; // Minsoo #endif Initial_EEPROM_Config_Load(); // loads config at start-up Init_ADC(); GyroCalibrated = false; Armed = false; RxChannelsUpdatingFlag = 0; RxChannel1 = Config.RxChannel1ZeroOffset; // prime the channels 1520; RxChannel2 = Config.RxChannel2ZeroOffset; // 1520; RxChannel3 = Config.RxChannel3ZeroOffset; // 1120; RxChannel4 = Config.RxChannel4ZeroOffset; // 1520; // flash LED LED = 1; delay_ms(150); LED = 0; sei(); // Global Interrupts // 2 second delay delay_ms(1500); ReadGainPots(); ReadGainPots(); // clear config if (GainInADC[PITCH] < (UC_ADC_MAX*5)/100 && GainInADC[ROLL] < (UC_ADC_MAX*5)/100 && GainInADC[YAW] < (UC_ADC_MAX*5)/100 ) { Set_EEPROM_Default_Config(); while ( 1 ); } // Stick Centering if (GainInADC[PITCH] < (UC_ADC_MAX*5)/100) // less than 5% { // set offsets to zero (otherwise we affect what we want to calibrate !!) Config.RxChannel1ZeroOffset = 0; Config.RxChannel2ZeroOffset = 0; Config.RxChannel4ZeroOffset = 0; // flash LED 3 times for (i=0;i<3;i++) { LED = 1; delay_ms(25); LED = 0; delay_ms(25); } // 5 Seconds Delay, for binding (Minsoo) delay_ms(3750); RxChannel1ZeroOffset = RxChannel2ZeroOffset = RxChannel4ZeroOffset = 0; for (i=0;i<4;i++) { RxGetChannels(); RxChannel1ZeroOffset += RxInRoll; RxChannel2ZeroOffset += RxInPitch; RxChannel4ZeroOffset += RxInYaw; delay_ms(100); } // nb RxGetChannels() divides RxInXXX by 4 so we won't here Config.RxChannel1ZeroOffset = RxChannel1ZeroOffset; Config.RxChannel2ZeroOffset = RxChannel2ZeroOffset; Config.RxChannel3ZeroOffset = 1120; Config.RxChannel4ZeroOffset = RxChannel4ZeroOffset; // Store gyro direction to EEPROM Save_Config_to_EEPROM(); // flash LED, Ending Sign (Minsoo) LED = 1; delay_ms(150); LED = 0; } // Gyro direction reversing if (GainInADC[ROLL] < (UC_ADC_MAX*5)/100) // less than 5% (5/100) * 1023 = 51 { // flash LED 3 times for (i=0;i<3;i++) { LED = 1; delay_ms(25); LED = 0; delay_ms(25); } while(1) { RxGetChannels(); if (RxInRoll < -30) { // normal(left) Config.RollGyroDirection = GYRO_NORMAL; Save_Config_to_EEPROM(); LED = 1; } if (RxInRoll > 30) { // reverse(right) Config.RollGyroDirection = GYRO_REVERSED; Save_Config_to_EEPROM(); LED = 1; } else if (RxInPitch < -30) { // normal(up) Config.PitchGyroDirection = GYRO_NORMAL; Save_Config_to_EEPROM(); LED = 1; } else if (RxInPitch > 30) { // reverse(down) Config.PitchGyroDirection = GYRO_REVERSED; Save_Config_to_EEPROM(); LED = 1; } else if (RxInYaw < -30) { // normal(left) Config.YawGyroDirection = GYRO_NORMAL; Save_Config_to_EEPROM(); LED = 1; } else if (RxInYaw > 30) { // reverse(right) Config.YawGyroDirection = GYRO_REVERSED; Save_Config_to_EEPROM(); LED = 1; } delay_ms(50); LED = 0; } } // ESC throttle calibration if (GainInADC[YAW] < (UC_ADC_MAX*5)/100) // less than 5% { // flash LED 3 times for (i=0;i<3;i++) { LED = 1; delay_ms(25); LED = 0; delay_ms(25); } Armed = true; // override so that output_motor_pwm() won't quit early PWM_Low_Pulse_Interval = ((1000000UL / 50) - 2000)/10; // set to 50Hz #if defined(SINGLE_COPTER) || defined(DUAL_COPTER) || defined(TRI_COPTER) ServoPPMRateDivider = 1; // since we have already set to 50Hz #endif while (1) // loop forever { RxGetChannels(); #ifdef SINGLE_COPTER MotorOut1 = RxInCollective; MotorOut2 = 140; // Center: 140 MotorOut3 = 140; MotorOut4 = 140; MotorOut5 = 140; #elif defined(DUAL_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = 140; // Center: 140 MotorOut4 = 140; #elif defined(TRI_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = 50 + RxInYaw; #elif defined(QUAD_COPTER) || defined(QUAD_X_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = RxInCollective; #elif defined(HEX_COPTER) || defined(Y6_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = RxInCollective; MotorOut5 = RxInCollective; MotorOut6 = RxInCollective; #else #error No Copter configuration defined !!!! #endif output_motor_ppm(); // this regulates rate at which we output signals } } } void loop(void) { static uint8_t i; static uint16_t Change_Arming=0; static uint8_t Arming_TCNT2=0; RxGetChannels(); if (RxInCollective < 0) { // check for stick arming (Timer2 @ 8MHz/1024 = 7812.5KHz) // arm: yaw right (>60), dis-arm: yaw left (<-60) Change_Arming += (uint8_t) (TCNT2 - Arming_TCNT2); Arming_TCNT2 = TCNT2; if (!Armed) { // nb to switch to Right-Side Arming: if (!Armed) { if (RxInYaw 30) Change_Arming = 0; // re-set count } else { if (RxInYaw>-STICK_ARMING || abs(RxInPitch) > 30) Change_Arming = 0; // re-set count, Minsoo } // 3Sec / 0.000128 = 23437 = 0x5B8D or // 2.5Sec / 0.000128 = 19531 = 0x4C4B // 0.5Sec / 0.000128 = 3906 = 0x0F42 // Minsoo if (Change_Arming>0x0F42) { Armed = ! Armed; LED = 0; ModeDelayCounter = 0; if (Armed) { CalibrateGyros(); output_motor_high = false; // re-set 1st time flag LED = 1; // Normal StickRollGain = NORMAL_STICK_ROLL_GAIN; StickPitchGain = NORMAL_STICK_PITCH_GAIN; StickYawGain = NORMAL_STICK_YAW_GAIN; } else if (output_motor_high) { output_motor_ppm(); // turn off } return; } // --- Calibrate gyro when collective below 1% --- //if ( RxInCollective < 1 && Armed && abs(RxInRoll) <20 && abs(RxInPitch) <20) // --- Calibrate gyro when Thr: Low, Elevator: Down, Rudder: Left --- (Minsoo) if (Armed && RxInYaw < -STICK_ARMING && RxInPitch > STICK_ARMING) { if (ModeDelayCounter==0) { //ModeDelayCounter = 0xFB4F; // 0xFFFF-FB4F=0x4B0=1200/400 = 3Seconds ModeDelayCounter = 0xFE6F; // 0xFFFF-FE6F=0x190=400/400 = 1Seconds (Minsoo) CalibrateGyros(); output_motor_high = false; // re-set 1st time flag delay_ms(150); // Normal StickRollGain = NORMAL_STICK_ROLL_GAIN; StickPitchGain = NORMAL_STICK_PITCH_GAIN; StickYawGain = NORMAL_STICK_YAW_GAIN; // flash LED 1 time for (i=0;i<1;i++) { LED = 0; delay_ms(25); LED = 1; delay_ms(25); } } ModeDelayCounter++; } // --- Acro Mode when Thr: Low, Elevator: Up, Rudder: Left --- (Minsoo) if (Armed && RxInYaw < -STICK_ARMING && RxInPitch < -STICK_ARMING) { if (ModeDelayCounter==0) { //ModeDelayCounter = 0xFB4F; // 0xFFFF-FB4F=0x4B0=1200/400 = 3Seconds ModeDelayCounter = 0xFE6F; // 0xFFFF-FE6F=0x190=400/400 = 1Seconds (Minsoo) CalibrateGyros(); output_motor_high = false; // re-set 1st time flag delay_ms(100); // Acro StickRollGain = ACRO_STICK_ROLL_GAIN; StickPitchGain = ACRO_STICK_PITCH_GAIN; StickYawGain = ACRO_STICK_YAW_GAIN; // flash LED 2 times for (i=0;i<2;i++) { LED = 0; delay_ms(25); LED = 1; delay_ms(25); } } ModeDelayCounter++; } // --- UFO Mode when Thr: Low, Elevator: Up, Rudder: Right --- (Minsoo) if (Armed && RxInYaw > STICK_ARMING && RxInPitch < -STICK_ARMING) { if (ModeDelayCounter==0) { //ModeDelayCounter = 0xFB4F; // 0xFFFF-FB4F=0x4B0=1200/400 = 3Seconds ModeDelayCounter = 0xFE6F; // 0xFFFF-FE6F=0x190=400/400 = 1Seconds (Minsoo) CalibrateGyros(); output_motor_high = false; // re-set 1st time flag // Acro StickRollGain = NORMAL_STICK_ROLL_GAIN; StickPitchGain = NORMAL_STICK_PITCH_GAIN; StickYawGain = UFO_STICK_YAW_GAIN; // flash LED 4 times for (i=0;i<4;i++) { LED = 0; delay_ms(25); LED = 1; delay_ms(25); } } ModeDelayCounter++; } } //--- Read gyros --- ReadGyros(false); //--- Start mixing by setting collective to motor input 1,2,3 and 4 --- #ifndef SINGLE_COPTER if (RxInCollective > MAX_COLLECTIVE) RxInCollective = MAX_COLLECTIVE; #endif #ifdef SINGLE_COPTER MotorOut1 = RxInCollective; MotorOut2 = 84; // 84; MotorOut3 = 84; // 84; MotorOut4 = 94; // 84 + 84/8; Ajust LowPassOutValue MotorOut5 = 94; // 84 + 84/8; Ajust LowPassOutValue #elif defined(DUAL_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = 84; MotorOut4 = 84; #elif defined(TRI_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = 50; #elif defined(QUAD_COPTER) || defined(QUAD_X_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = RxInCollective; #elif defined(HEX_COPTER) || defined(Y6_COPTER) MotorOut1 = RxInCollective; MotorOut2 = RxInCollective; MotorOut3 = RxInCollective; MotorOut4 = RxInCollective; MotorOut5 = RxInCollective; MotorOut6 = RxInCollective; #endif //--- Calculate roll gyro output --- // nb IF YOU CHANGE THIS CODE, YOU MUST REMOVE PROPS BEFORE TESTING !!! gyroADC[ROLL] = gyroADC[ROLL] * GainIn[ROLL] * ROLL_GAIN_MULTIPLIER; // Minsoo, 100 * 50 * 3 = 15000 150 * 50 * 3 = 22500 250 * 50 * 3 = 37500 gyroADC[ROLL] /= ADC_GAIN_DIVIDER; // Minsoo, 15000/150 = 100 22500/225 = 100 37500/375 = 100 RxInRoll = (RxInRoll * StickRollGain / 100); // Stick Controll % //--- (Add)Adjust roll gyro output to motors #ifdef SINGLE_COPTER if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { } RxInRoll -= LowpassOutServo[ROLL]; RxInRoll = (RxInRoll >> 3); LowpassOutServo[ROLL] += RxInRoll; MotorOut2 += LowpassOutServo[ROLL]; MotorOut4 -= LowpassOutServo[ROLL]; #elif defined(DUAL_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } RxInRoll -= LowpassOutServo[ROLL]; RxInRoll = (RxInRoll >> 3); LowpassOutServo[ROLL] += RxInRoll; MotorOut4 += LowpassOutServo[ROLL]; #elif defined(TRI_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } RxInRoll = (RxInRoll * 20)/23; //RxInRollSine 60= 0.866 ~ 20/23 or possibly 7/8 MotorOut1 += RxInRoll; MotorOut2 -= RxInRoll; #elif defined(QUAD_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } MotorOut2 += RxInRoll; MotorOut3 -= RxInRoll; #elif defined(QUAD_X_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } RxInRoll = (RxInRoll >> 1); //was:RxInRoll = (RxInRoll * 20)/23; MotorOut1 += RxInRoll; MotorOut2 -= RxInRoll; MotorOut3 -= RxInRoll; MotorOut4 += RxInRoll; #elif defined(HEX_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } RxInRoll = (RxInRoll * 20)/23; //RxInRoll *= 0.866; // Sine 60 MotorOut2 -= RxInRoll; MotorOut3 -= RxInRoll; MotorOut5 += RxInRoll; MotorOut6 += RxInRoll; #elif defined(Y6_COPTER) if (Config.RollGyroDirection == GYRO_NORMAL) { RxInRoll += gyroADC[ROLL]; } else { RxInRoll -= gyroADC[ROLL]; } RxInRoll = (RxInRoll * 20)/23; //RxInRoll *= 0.866; // Sine 60 MotorOut1 += RxInRoll; MotorOut2 += RxInRoll; MotorOut3 -= RxInRoll; MotorOut4 -= RxInRoll; #endif //--- Calculate pitch gyro output --- // nb IF YOU CHANGE THIS CODE, YOU MUST REMOVE PROPS BEFORE TESTING !!! gyroADC[PITCH] = gyroADC[PITCH] * GainIn[PITCH] * PITCH_GAIN_MULTIPLIER; gyroADC[PITCH] /= ADC_GAIN_DIVIDER; RxInPitch = (RxInPitch * StickPitchGain / 100); // Stick Controll % //--- (Add)Adjust pitch gyro output to motors #ifdef SINGLE_COPTER if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } RxInPitch -= LowpassOutServo[PITCH]; RxInPitch = (RxInPitch >> 3); LowpassOutServo[PITCH] += RxInPitch; MotorOut3 += LowpassOutServo[PITCH]; MotorOut5 -= LowpassOutServo[PITCH]; #elif defined(DUAL_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } RxInPitch -= LowpassOutServo[PITCH]; RxInPitch = (RxInPitch >> 3); LowpassOutServo[PITCH] += RxInPitch; MotorOut3 += LowpassOutServo[PITCH]; #elif defined(TRI_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } MotorOut3 -= RxInPitch; RxInPitch = (RxInPitch >> 1); // cosine of 60 MotorOut1 += RxInPitch; MotorOut2 += RxInPitch; #elif defined(QUAD_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } MotorOut1 += RxInPitch; MotorOut4 -= RxInPitch; #elif defined(QUAD_X_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } RxInPitch = (RxInPitch >> 1); //23; //Sine 60 = 0.866 20/23 = 0.869 MotorOut1 += RxInPitch; MotorOut2 += RxInPitch; MotorOut3 -= RxInPitch; MotorOut4 -= RxInPitch; #elif defined(HEX_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } MotorOut1 += RxInPitch; MotorOut4 -= RxInPitch; RxInPitch = (RxInPitch >> 2); MotorOut2 += RxInPitch; MotorOut3 -= RxInPitch; MotorOut5 -= RxInPitch; MotorOut6 += RxInPitch; #elif defined(Y6_COPTER) if (Config.PitchGyroDirection == GYRO_NORMAL) { RxInPitch += gyroADC[PITCH]; } else { RxInPitch -= gyroADC[PITCH]; } MotorOut5 -= RxInPitch; MotorOut6 -= RxInPitch; RxInPitch = (RxInPitch >> 1); // cosine of 60 MotorOut1 += RxInPitch; MotorOut2 += RxInPitch; MotorOut3 += RxInPitch; MotorOut4 += RxInPitch; #endif //--- Calculate yaw gyro output --- gyroADC[YAW] = (gyroADC[YAW] * GainIn[YAW] * YAW_GAIN_MULTIPLIER); gyroADC[YAW] /= ADC_GAIN_DIVIDER; RxInYaw = (RxInYaw * StickYawGain / 100); // Stick Controll % #ifdef SINGLE_COPTER if (Config.YawGyroDirection == GYRO_NORMAL) { // scale gyro output RxInYaw += gyroADC[YAW]; } else { RxInYaw -= gyroADC[YAW]; } RxInYaw -= LowpassOutServo[YAW]; RxInYaw = (RxInYaw >> 3); LowpassOutServo[YAW] += RxInYaw; MotorOut2 += LowpassOutServo[YAW]; MotorOut3 += LowpassOutServo[YAW]; MotorOut4 += LowpassOutServo[YAW]; MotorOut5 += LowpassOutServo[YAW]; #elif defined(TRI_COPTER) if (Config.YawGyroDirection == GYRO_NORMAL) { // scale gyro output RxInYaw += gyroADC[YAW]; } else { RxInYaw -= gyroADC[YAW]; } RxInYaw -= LowpassOutYaw; RxInYaw = (RxInYaw >> 3); LowpassOutYaw += RxInYaw; MotorOut4 += LowpassOutYaw; #else if (Config.YawGyroDirection == GYRO_NORMAL) { // scale gyro output RxInYaw += gyroADC[YAW]; } else { RxInYaw -= gyroADC[YAW]; } //--- (Add)Adjust yaw gyro output to motors #ifdef DUAL_COPTER MotorOut1 -= RxInYaw; MotorOut2 += RxInYaw; #elif defined(QUAD_COPTER) MotorOut1 -= RxInYaw; MotorOut2 += RxInYaw; MotorOut3 += RxInYaw; MotorOut4 -= RxInYaw; #elif defined(QUAD_X_COPTER) MotorOut1 -= RxInYaw; MotorOut2 += RxInYaw; MotorOut3 -= RxInYaw; MotorOut4 += RxInYaw; #elif defined(HEX_COPTER) MotorOut1 -= RxInYaw; MotorOut2 += RxInYaw; MotorOut3 -= RxInYaw; MotorOut4 += RxInYaw; MotorOut5 -= RxInYaw; MotorOut6 += RxInYaw; #elif defined(Y6_COPTER) MotorOut1 -= RxInYaw; MotorOut4 -= RxInYaw; MotorOut5 -= RxInYaw; MotorOut2 += RxInYaw; MotorOut3 += RxInYaw; MotorOut6 += RxInYaw; #endif #endif //--- Limit the lowest value to avoid stopping of motor if motor value is under-saturated --- #ifdef DUAL_COPTER if ( MotorOut1 < 10 ) MotorOut1 = 10; // this is the motor idle level if ( MotorOut2 < 10 ) MotorOut2 = 10; #elif defined(TRI_COPTER) if ( MotorOut1 < 10 ) MotorOut1 = 10; // this is the motor idle level if ( MotorOut2 < 10 ) MotorOut2 = 10; if ( MotorOut3 < 10 ) MotorOut3 = 10; #elif defined(QUAD_COPTER) || defined(QUAD_X_COPTER) if ( MotorOut1 < 10 ) MotorOut1 = 10; // this is the motor idle level if ( MotorOut2 < 10 ) MotorOut2 = 10; if ( MotorOut3 < 10 ) MotorOut3 = 10; if ( MotorOut4 < 10 ) MotorOut4 = 10; #elif defined(HEX_COPTER) || defined(Y6_COPTER) if ( MotorOut1 < 10 ) MotorOut1 = 10; // this is the motor idle level if ( MotorOut2 < 10 ) MotorOut2 = 10; if ( MotorOut3 < 10 ) MotorOut3 = 10; if ( MotorOut4 < 10 ) MotorOut4 = 10; if ( MotorOut5 < 10 ) MotorOut5 = 10; if ( MotorOut6 < 10 ) MotorOut6 = 10; #endif //--- Output to motor ESC's --- if (RxInCollective < 1 || !Armed || !GyroCalibrated) // turn off motors if collective below 1% ??? { // or if gyros not calibrated #ifdef SINGLE_COPTER MotorOut1 = 0; MotorOut2 = 84; MotorOut3 = 84; MotorOut4 = 84; MotorOut5 = 84; #elif defined(DUAL_COPTER) MotorOut1 = 0; MotorOut2 = 0; MotorOut3 = 84; MotorOut4 = 84; #elif defined(TRI_COPTER) MotorOut1 = 0; MotorOut2 = 0; MotorOut3 = 0; MotorOut4 = 50; #elif defined(QUAD_COPTER) || defined(QUAD_X_COPTER) MotorOut1 = 0; MotorOut2 = 0; MotorOut3 = 0; MotorOut4 = 0; #elif defined(HEX_COPTER) || defined(Y6_COPTER) MotorOut1 = 0; MotorOut2 = 0; MotorOut3 = 0; MotorOut4 = 0; MotorOut5 = 0; MotorOut6 = 0; #endif } if (Armed) output_motor_ppm(); // output ESC signal } void Init_ADC(void) { DIDR0 = 0b00111111; // Digital Input Disable Register - ADC5..0 Digital Input Disable ADCSRB = 0b00000000; // ADC Control and Status Register B - ADTS2:0 } void ReadGainPots(void) { read_adc( 3 ); // read roll gain ADC3 GainInADC[ROLL] = ADCL; GainInADC[ROLL] += ((uint16_t) ADCH <<8); GainInADC[ROLL] = 1024 - GainInADC[ROLL]; GainIn[ROLL] = GainInADC[ROLL] / 10; read_adc( 4 ); // read pitch gain ADC4 GainInADC[PITCH] = ADCL; GainInADC[PITCH] += ((uint16_t) ADCH <<8); GainInADC[PITCH] = 1024 - GainInADC[PITCH]; GainIn[PITCH] = GainInADC[PITCH] / 10; read_adc( 5 ); // read yaw gain ADC5 GainInADC[YAW] = ADCL; GainInADC[YAW] += ((uint16_t) ADCH <<8); GainInADC[YAW] = 1024 - GainInADC[YAW]; GainIn[YAW] = GainInADC[YAW] / 10; } void read_adc(uint8_t channel) { ADMUX = channel; // set channel ADCSRA = 0b11000110; // ADEN, ADSC, ADPS1,2 while (ADCSRA & (1 << ADSC)); // wait to complete } void ReadGyros(bool calibrate) { read_adc( 2 ); // read roll gyro ADC2 gyroADC[ROLL] = ADCL; gyroADC[ROLL] += ((uint16_t) ADCH <<8); if (!calibrate) gyroADC[ROLL] -= gyroZero[ROLL]; //remove offset from gyro output read_adc( 1 ); // read pitch gyro ADC1 gyroADC[PITCH] = ADCL; gyroADC[PITCH] += ((uint16_t) ADCH <<8); if (!calibrate) gyroADC[PITCH] -= gyroZero[PITCH]; //remove offset from gyro output #ifdef EXTERNAL_YAW_GYRO gyroADC[YAW] = 0; #else read_adc( 0 ); // read yaw gyro ADC0 gyroADC[YAW] = ADCL; gyroADC[YAW] += ((uint16_t) ADCH <<8); if (!calibrate) gyroADC[YAW] -= gyroZero[YAW]; //remove offset from gyro output #endif } void CalibrateGyros(void) { uint8_t i; ReadGainPots(); // about time we did this ! // get/set gyro zero value (average of 32 readings) gyroZero[ROLL] = 0; gyroZero[PITCH] = 0; gyroZero[YAW] = 0; for (i=0;i<32;i++) { ReadGyros(true); gyroZero[ROLL] += gyroADC[ROLL]; gyroZero[PITCH] += gyroADC[PITCH]; gyroZero[YAW] += gyroADC[YAW]; } gyroZero[ROLL] = (gyroZero[ROLL] >> 5); gyroZero[PITCH] = (gyroZero[PITCH] >> 5); gyroZero[YAW] = (gyroZero[YAW] >> 5); GyroCalibrated = true; } //--- Get and scale RX channel inputs --- void RxGetChannels(void) { static int16_t RxChannel; while ( RxChannelsUpdatingFlag ); RxChannel = RxChannel1; RxChannel -= Config.RxChannel1ZeroOffset; // normalise RxInRoll = (RxChannel >> 2); // " while ( RxChannelsUpdatingFlag ); RxChannel = RxChannel2; RxChannel -= Config.RxChannel2ZeroOffset; // normalise RxInPitch = (RxChannel >> 2); // " while ( RxChannelsUpdatingFlag ); RxChannel = RxChannel3; RxChannel -= Config.RxChannel3ZeroOffset; // scale 0->100 RxInCollective = (RxChannel >> 3); // while ( RxChannelsUpdatingFlag ); RxChannel = RxChannel4; RxChannel -= Config.RxChannel4ZeroOffset; // normalise RxInYaw = (RxChannel >> 2); // " } void output_motor_ppm(void) { static uint8_t i; static uint16_t MotorStartTCNT1, ElapsedTCNT1; static int16_t MotorAdjust; static uint16_t PWM_Low_Count; static int8_t num_of_10uS; #if defined(SINGLE_COPTER) || defined(DUAL_COPTER) || defined(TRI_COPTER) static uint8_t ServoPPMRateCount; #endif // if ESC's are high, we need to turn them off if (output_motor_high) { #ifdef SINGLE_COPTER // set motor limits (0 -> 100) // set servo limits (0 -> 200) if ( MotorOut1 < 0 ) MotorOut1 = 0; else if ( MotorOut1 > 100 ) MotorOut1 = 100; if ( MotorOut2 < 0 ) MotorOut2 = 0; else if ( MotorOut2 > 200 ) MotorOut2 = 200; if ( MotorOut3 < 0 ) MotorOut3 = 0; else if ( MotorOut3 > 200 ) MotorOut3 = 200; if ( MotorOut4 < 0 ) MotorOut4 = 0; else if ( MotorOut4 > 200 ) MotorOut4 = 200; if ( MotorOut5 < 0 ) MotorOut5 = 0; else if ( MotorOut5 > 200 ) MotorOut5 = 200; #elif defined(DUAL_COPTER) // set motor limits (0 -> 100) // set servo limits (0 -> 200) if ( MotorOut1 < 0 ) MotorOut1 = 0; else if ( MotorOut1 > 100 ) MotorOut1 = 100; if ( MotorOut2 < 0 ) MotorOut2 = 0; else if ( MotorOut2 > 100 ) MotorOut2 = 100; if ( MotorOut3 < 0 ) MotorOut3 = 0; else if ( MotorOut3 > 200 ) MotorOut3 = 200; if ( MotorOut4 < 0 ) MotorOut4 = 0; else if ( MotorOut4 > 200 ) MotorOut4 = 200; #else // set motor limits (0 -> 100) if ( MotorOut1 < 0 ) MotorOut1 = 0; else if ( MotorOut1 > 100 ) MotorOut1 = 100; if ( MotorOut2 < 0 ) MotorOut2 = 0; else if ( MotorOut2 > 100 ) MotorOut2 = 100; if ( MotorOut3 < 0 ) MotorOut3 = 0; else if ( MotorOut3 > 100 ) MotorOut3 = 100; if ( MotorOut4 < 0 ) MotorOut4 = 0; else if ( MotorOut4 > 100 ) MotorOut4 = 100; #if defined(HEX_COPTER) || defined(Y6_COPTER) if ( MotorOut5 < 0 ) MotorOut5 = 0; else if ( MotorOut5 > 100 ) MotorOut5 = 100; if ( MotorOut6 < 0 ) MotorOut6 = 0; else if ( MotorOut6 > 100 ) MotorOut6 = 100; #endif #endif // now calculate the time already passed that Motors were HIGH ElapsedTCNT1 = (TCNT1 - MotorStartTCNT1); // start output timer TIFR0 &= ~(1 << TOV0); // clr overflow TCNT0 = 0; // reset counter // convert into 10uS intervals num_of_10uS = (ElapsedTCNT1 / 10) + 1; MotorAdjust = 100 - num_of_10uS; #ifdef SINGLE_COPTER // add adjustment (1mS - time already gone) to 1 channel MotorOut1 += MotorAdjust; #elif defined(DUAL_COPTER) // add adjustment (1mS - time already gone) to all channels MotorOut1 += MotorAdjust; MotorOut2 += MotorAdjust; #else // add adjustment (1mS - time already gone) to all channels MotorOut1 += MotorAdjust; MotorOut2 += MotorAdjust; MotorOut3 += MotorAdjust; MotorOut4 += MotorAdjust; #if defined(HEX_COPTER) || defined(Y6_COPTER) MotorOut5 += MotorAdjust; MotorOut6 += MotorAdjust; #endif #endif // keep signal on for correct time // MotorOutX = 100 -> 200 // Pulse len = 1 -> 2 mS // Servo = 0 - 200 // Pulse len = 0 -> 2.3ms TIFR0 &= ~(1 << TOV0); // clr overflow TCNT0 = 0; // reset counter #ifdef SINGLE_COPTER for (i=0;i<200;i++) { while (TCNT0 < 80); // 10uS @ 8MHz = 80 // 10 @ 1MHz = 10uS TCNT0 -= 80; if (MotorOut1) { MotorOut1--; if (MotorOut1==0) M1 = 0; } if (MotorOut2) { MotorOut2--; if (MotorOut2==0) M2 = 0; } if (MotorOut3) { MotorOut3--; if (MotorOut3==0) M3 = 0; } if (MotorOut4) { MotorOut4--; if (MotorOut4==0) M4 = 0; } if (MotorOut5) { MotorOut5--; if (MotorOut5==0) M5 = 0; } } #elif defined(DUAL_COPTER) for (i=0;i<200;i++) { while (TCNT0 < 80); // 10uS @ 8MHz = 80 // 10 @ 1MHz = 10uS TCNT0 -= 80; if (MotorOut1) { MotorOut1--; if (MotorOut1==0) M1 = 0; } if (MotorOut2) { MotorOut2--; if (MotorOut2==0) M2 = 0; } if (MotorOut3) { MotorOut3--; if (MotorOut3==0) M3 = 0; } if (MotorOut4) { MotorOut4--; if (MotorOut4==0) M4 = 0; } } #else for (i=num_of_10uS;i<200;i++) { while (TCNT0 < 80); // 10uS @ 8MHz = 80 // 10 @ 1MHz = 10uS TCNT0 -= 80; if (MotorOut1) { MotorOut1--; if (MotorOut1==0) M1 = 0; } if (MotorOut2) { MotorOut2--; if (MotorOut2==0) M2 = 0; } if (MotorOut3) { MotorOut3--; if (MotorOut3==0) M3 = 0; } if (MotorOut4) { MotorOut4--; if (MotorOut4==0) M4 = 0; } #if defined(HEX_COPTER) || defined(Y6_COPTER) if (MotorOut5) { MotorOut5--; if (MotorOut5==0) M5 = 0; } if (MotorOut6) { MotorOut6--; if (MotorOut6==0) M6 = 0; } #endif } #endif //Now wait low signal interval PWM_Low_Count = PWM_Low_Pulse_Interval - 1; TIFR0 &= ~(1 << TOV0); // clr overflow TCNT0 = 0; // reset counter while (PWM_Low_Count--) { while (TCNT0 < 80); // 20 @ 2MHz = 10uS TCNT0 -= 80; } } if (! Armed) return; // Log PWM signal HIGH MotorStartTCNT1 = TCNT1; output_motor_high = true; // turn on pins #ifdef SINGLE_COPTER M1 = 1; if(ServoPPMRateCount==ServoPPMRateDivider) { M2 = 1; M3 = 1; M4 = 1; M5 = 1; ServoPPMRateCount = 1; } else { ServoPPMRateCount++; } #elif defined(DUAL_COPTER) M1 = 1; M2 = 1; if(ServoPPMRateCount==ServoPPMRateDivider) { M3 = 1; M4 = 1; ServoPPMRateCount = 1; } else { ServoPPMRateCount++; } #elif defined(TRI_COPTER) M1 = 1; M2 = 1; M3 = 1; if(ServoPPMRateCount==ServoPPMRateDivider) { M4 = 1; ServoPPMRateCount = 1; } else { ServoPPMRateCount++; } #elif defined(QUAD_COPTER) || defined(QUAD_X_COPTER) M1 = 1; M2 = 1; M3 = 1; M4 = 1; #elif defined(HEX_COPTER) || defined(Y6_COPTER) M1 = 1; M2 = 1; M3 = 1; M4 = 1; M5 = 1; M6 = 1; #endif } void eeprom_write_byte_changed( uint8_t * addr, uint8_t value ) { if(eeprom_read_byte(addr) != value) { eeprom_write_byte( addr, value ); } } void eeprom_write_block_changes( const uint8_t * src, void * dest, size_t size ) { size_t len; for(len=0;len
