Version 4 SHEET 1 936 680 WIRE 208 -32 160 -32 WIRE 336 -32 288 -32 WIRE 384 -32 336 -32 WIRE 528 -32 464 -32 WIRE 528 -16 528 -32 WIRE 160 48 160 -32 WIRE 384 48 192 48 WIRE -192 112 -320 112 WIRE -64 112 -112 112 WIRE 48 112 -64 112 WIRE 704 112 496 112 WIRE 848 112 704 112 WIRE -320 128 -320 112 WIRE 192 128 192 48 WIRE 192 128 160 128 WIRE 336 128 336 -32 WIRE 384 128 336 128 WIRE 496 128 496 112 WIRE 848 128 848 112 WIRE 384 176 160 176 WIRE 48 192 -48 192 WIRE 496 224 496 208 WIRE 608 224 496 224 WIRE 848 224 848 208 WIRE 848 224 608 224 WIRE -48 240 -48 192 WIRE 608 240 608 224 WIRE -320 256 -320 208 WIRE 160 288 160 256 WIRE -144 304 -208 304 WIRE 160 304 160 288 WIRE 160 304 -64 304 WIRE -208 336 -208 304 WIRE 384 336 384 256 WIRE -208 464 -208 416 FLAG -48 240 0 FLAG 384 336 0 FLAG 608 240 0 FLAG -208 464 0 FLAG 704 112 rx FLAG 160 288 in FLAG -64 112 tx FLAG -320 256 0 FLAG 528 -16 0 SYMBOL ind2 512 224 R180 WINDOW 0 -33 78 Left 2 WINDOW 3 -35 32 Left 2 SYMATTR InstName L6 SYMATTR Value 1 SYMATTR Type ind SYMBOL ind2 368 160 R0 SYMATTR InstName L5 SYMATTR Value 1 SYMATTR Type ind SYMBOL res 192 -16 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 58 97 VBottom 2 SYMATTR InstName R1 SYMATTR Value 50 SYMBOL voltage -208 320 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V2 SYMATTR Value SINE(0 5 75000) SYMBOL res -160 320 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R3 SYMATTR Value 50 SYMBOL voltage -320 112 R0 WINDOW 123 24 124 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value2 AC 1 SYMATTR InstName V1 SYMATTR Value SINE(0 5 50000) SYMBOL res -96 96 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R2 SYMATTR Value 50 SYMBOL ind2 32 96 R0 WINDOW 0 -40 37 Left 2 WINDOW 3 -33 78 Left 2 SYMATTR InstName L1 SYMATTR Value 1 SYMATTR Type ind SYMBOL ind2 176 144 R180 WINDOW 0 36 80 Left 2 WINDOW 3 36 40 Left 2 SYMATTR InstName L2 SYMATTR Value 1 SYMATTR Type ind SYMBOL ind2 368 32 R0 SYMATTR InstName L3 SYMATTR Value 1 SYMATTR Type ind SYMBOL ind2 176 272 R180 WINDOW 0 36 80 Left 2 WINDOW 3 36 40 Left 2 SYMATTR InstName L4 SYMATTR Value 1 SYMATTR Type ind SYMBOL res 832 112 R0 SYMATTR InstName R5 SYMATTR Value 50 SYMBOL res 368 -16 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R4 SYMATTR Value 1meg TEXT -368 -144 Left 2 !.tran 1m TEXT -368 -104 Left 2 !K1 L1 L2 L4 1 TEXT 40 496 Left 2 ;Twisted Pair Cable 50 Ohm TEXT -24 -272 Left 4 ;Impedance matching with twisted Pair \ncharacteristic Impedance TEXT 624 152 Left 2 ;Receive Path TEXT -368 0 Left 2 ;Transmit Path TEXT 216 416 Left 2 ;75kHz Signal in twisted pair TEXT -368 32 Left 2 ;50KHz Signal in Transmit Path TEXT 184 280 Left 2 ;V1 TEXT 192 0 Left 2 ;V2 TEXT -48 152 Left 2 ;V3 TEXT 560 152 Left 2 ;V4 TEXT -368 -184 Left 2 ;.ac dec 100 1k 100k TEXT -368 -64 Left 2 !K2 L3 L5 L6 1 LINE Normal 96 256 96 48 2 LINE Normal 448 256 448 48 2
