AVRA Ver. 1.3.0 test.asm Fri Aug 9 07:30:00 2013 .include "m8535def.inc" ;***** THIS IS A MACHINE GENERATED FILE - DO NOT EDIT ******************** ;***** Created: 2008-11-07 12:39 ******* Source: ATmega8535.xml ********** ;************************************************************************* ;* A P P L I C A T I O N N O T E F O R T H E A V R F A M I L Y ;* ;* Number : AVR000 ;* File Name : "m8535def.inc" ;* Title : Register/Bit Definitions for the ATmega8535 ;* Date : 2008-11-07 ;* Version : 2.31 ;* Support E-mail : avr@atmel.com ;* Target MCU : ATmega8515 ;* ;* DESCRIPTION ;* When including this file in the assembly program file, all I/O register ;* names and I/O register bit names appearing in the data book can be used. ;* In addition, the six registers forming the three data pointers X, Y and ;* Z have been assigned names XL - ZH. Highest RAM address for Internal ;* SRAM is also defined ;* ;* The Register names are represented by their hexadecimal address. ;* ;* The Register Bit names are represented by their bit number (0-7). ;* ;* Please observe the difference in using the bit names with instructions ;* such as "sbr"/"cbr" (set/clear bit in register) and "sbrs"/"sbrc" ;* (skip if bit in register set/cleared). The following example illustrates ;* this: ;* ;* in r16,PORTB ;read PORTB latch ;* sbr r16,(1<
