# When building a target filesystem, it is desirable to not have to # become root and then run 'mknod' a thousand times. Using a device # table you can create device nodes and directories "on the fly". # # This is a sample device table file for use with genext2fs. You can # do all sorts of interesting things with a device table file. For # example, if you want to adjust the permissions on a particular file # you can just add an entry like: # /sbin/foobar f 2755 0 0 - - - - - # and (assuming the file /sbin/foobar exists) it will be made setuid # root (regardless of what its permissions are on the host filesystem. # Furthermore, you can use a single table entry to create a many device # minors. For example, if I wanted to create /dev/hda and /dev/hda[0-15] # I could just use the following two table entries: # /dev/hda b 640 0 0 3 0 0 0 - # /dev/hda b 640 0 0 3 1 1 1 15 # # Device table entries take the form of: # # where name is the file name, type can be one of: # f A regular file # d Directory # c Character special device file # b Block special device file # p Fifo (named pipe) # uid is the user id for the target file, gid is the group id for the # target file. The rest of the entries (major, minor, etc) apply only # to device special files. # Have fun # -Erik Andersen # # /dev d 755 0 0 - - - - - /dev/pts d 755 0 0 - - - - - /dev/shm d 755 0 0 - - - - - /tmp d 1777 0 0 - - - - - /etc d 755 0 0 - - - - - /home/default d 2755 1000 1000 - - - - - #/var/www/cgi-bin d 755 1000 1000 - - - - - # #/var/www/cgi-bin/led.sh f 755 0 0 - - - - - #/usr/var/cache/rossy l 777 0 0 - - - - - #/usr/var/log/rossy l 777 0 0 - - - - - /bin/busybox f 4755 0 0 - - - - - /etc/shadow f 600 0 0 - - - - - /etc/passwd f 644 0 0 - - - - - /etc/network/if-up.d d 755 0 0 - - - - - /etc/network/if-pre-up.d d 755 0 0 - - - - - /etc/network/if-down.d d 755 0 0 - - - - - /etc/network/if-post-down.d d 755 0 0 - - - - - /usr/share/udhcpc/default.script f 755 0 0 - - - - - # uncomment this to allow starting x as non-root #/usr/X11R6/bin/Xfbdev f 4755 0 0 - - - - - # Normal system devices /dev/mem c 640 0 0 1 1 0 0 - /dev/kmem c 640 0 0 1 2 0 0 - /dev/null c 666 0 0 1 3 0 0 - /dev/zero c 666 0 0 1 5 0 0 - /dev/random c 666 0 0 1 8 0 0 - /dev/urandom c 666 0 0 1 9 0 0 - /dev/ram b 640 0 0 1 1 0 0 - /dev/ram b 640 0 0 1 0 0 1 4 /dev/loop b 640 0 0 7 0 0 1 2 /dev/rtc c 640 0 0 10 135 - - - /dev/rtc c 640 0 0 254 0 0 1 1 /dev/console c 666 0 0 5 1 - - - /dev/tty c 666 0 0 5 0 - - - /dev/tty c 666 0 0 4 0 0 1 8 /dev/ttyp c 666 0 0 3 0 0 1 10 /dev/ptyp c 666 0 0 2 0 0 1 10 /dev/ptmx c 666 0 0 5 2 - - - /dev/ttyP c 666 0 0 57 0 0 1 4 /dev/ttyS c 666 0 0 4 64 0 1 4 /dev/ttyUSB c 666 0 0 188 0 0 1 4 /dev/fb c 640 0 5 29 0 0 32 4 #/dev/ttySA c 666 0 0 204 5 0 1 3 /dev/psaux c 666 0 0 10 1 0 0 - #/dev/ppp c 666 0 0 108 0 - - - /dev/ttygserial c 666 0 0 127 0 - - - # Atmel ttys /dev/ttyUS0 c 666 0 0 4 64 - - - /dev/ttyUS1 c 666 0 0 4 65 - - - /dev/ttyUS2 c 666 0 0 4 66 - - - /dev/ttyUS3 c 666 0 0 4 67 - - - #graphics /dev/lcd c 666 0 0 253 0 - - - /dev/fusion d 755 0 0 - - - - - /dev/fusion/ c 666 0 0 250 0 0 1 8 # Input stuff /dev/input d 755 0 0 - - - - - /dev/input/mice c 640 0 0 13 63 0 0 - /dev/input/mouse c 660 0 0 13 32 0 1 4 /dev/input/event c 660 0 0 13 64 0 1 4 #/dev/input/js c 660 0 0 13 0 0 1 4 # MTD stuff /dev/mtd c 640 0 0 90 0 0 2 6 /dev/mtdblock b 640 0 0 31 0 0 1 6 /dev/ubi_ctrl c 640 0 0 10 63 0 0 - /dev/ubi0 c 640 0 0 253 0 0 0 - # MMC stuff /dev/mmcblk0 b 664 0 0 179 0 - - - /dev/mmcblk0p b 664 0 0 179 1 1 1 4 #Tun/tap driver /dev/net d 755 0 0 - - - - - /dev/net/tun c 660 0 0 10 200 - - - # Audio stuff /dev/audio c 666 0 29 14 4 - - - /dev/audio1 c 666 0 29 14 20 - - - /dev/dsp c 666 0 29 14 3 - - - /dev/dsp1 c 666 0 29 14 19 - - - /dev/sndstat c 666 0 29 14 6 - - - /dev/snd d 777 0 29 - - - - - /dev/snd/controlC0 c 666 0 29 116 0 - - - /dev/snd/seq c 666 0 29 116 1 - - - /dev/snd/pcmC0D0p c 666 0 29 116 16 - - - /dev/snd/pcmC0D0c c 666 0 29 116 24 - - - /dev/snd/timer c 666 0 29 116 33 - - - # User-mode Linux stuff #/dev/ubda b 640 0 0 98 0 0 0 - #/dev/ubda b 640 0 0 98 1 1 1 15 # IDE Devices /dev/hda b 640 0 0 3 0 0 0 - /dev/hda b 640 0 0 3 1 1 1 15 /dev/hdb b 640 0 0 3 64 0 0 - /dev/hdb b 640 0 0 3 65 1 1 15 #/dev/hdc b 640 0 0 22 0 0 0 - #/dev/hdc b 640 0 0 22 1 1 1 15 #/dev/hdd b 640 0 0 22 64 0 0 - #/dev/hdd b 640 0 0 22 65 1 1 15 #/dev/hde b 640 0 0 33 0 0 0 - #/dev/hde b 640 0 0 33 1 1 1 15 #/dev/hdf b 640 0 0 33 64 0 0 - #/dev/hdf b 640 0 0 33 65 1 1 15 #/dev/hdg b 640 0 0 34 0 0 0 - #/dev/hdg b 640 0 0 34 1 1 1 15 #/dev/hdh b 640 0 0 34 64 0 0 - #/dev/hdh b 640 0 0 34 65 1 1 15 # SCSI Devices #/dev/sda b 640 0 0 8 0 0 0 - #/dev/sda b 640 0 0 8 1 1 1 15 #/dev/sdb b 640 0 0 8 16 0 0 - #/dev/sdb b 640 0 0 8 17 1 1 15 #/dev/sdc b 640 0 0 8 32 0 0 - #/dev/sdc b 640 0 0 8 33 1 1 15 #/dev/sdd b 640 0 0 8 48 0 0 - #/dev/sdd b 640 0 0 8 49 1 1 15 #/dev/sde b 640 0 0 8 64 0 0 - #/dev/sde b 640 0 0 8 65 1 1 15 #/dev/sdf b 640 0 0 8 80 0 0 - #/dev/sdf b 640 0 0 8 81 1 1 15 #/dev/sdg b 640 0 0 8 96 0 0 - #/dev/sdg b 640 0 0 8 97 1 1 15 #/dev/sdh b 640 0 0 8 112 0 0 - #/dev/sdh b 640 0 0 8 113 1 1 15 #/dev/sg c 640 0 0 21 0 0 1 15 #/dev/scd b 640 0 0 11 0 0 1 15 #/dev/st c 640 0 0 9 0 0 1 8 #/dev/nst c 640 0 0 9 128 0 1 8 #/dev/st c 640 0 0 9 32 1 1 4 #/dev/st c 640 0 0 9 64 1 1 4 #/dev/st c 640 0 0 9 96 1 1 4 # Floppy disk devices #/dev/fd b 640 0 0 2 0 0 1 2 #/dev/fd0d360 b 640 0 0 2 4 0 0 - #/dev/fd1d360 b 640 0 0 2 5 0 0 - #/dev/fd0h1200 b 640 0 0 2 8 0 0 - #/dev/fd1h1200 b 640 0 0 2 9 0 0 - #/dev/fd0u1440 b 640 0 0 2 28 0 0 - #/dev/fd1u1440 b 640 0 0 2 29 0 0 - #/dev/fd0u2880 b 640 0 0 2 32 0 0 - #/dev/fd1u2880 b 640 0 0 2 33 0 0 - # All the proprietary cdrom devices in the world #/dev/aztcd b 640 0 0 29 0 0 0 - #/dev/bpcd b 640 0 0 41 0 0 0 - #/dev/capi20 c 640 0 0 68 0 0 1 2 #/dev/cdu31a b 640 0 0 15 0 0 0 - #/dev/cdu535 b 640 0 0 24 0 0 0 - #/dev/cm206cd b 640 0 0 32 0 0 0 - #/dev/sjcd b 640 0 0 18 0 0 0 - #/dev/sonycd b 640 0 0 15 0 0 0 - #/dev/gscd b 640 0 0 16 0 0 0 - #/dev/sbpcd b 640 0 0 25 0 0 0 - #/dev/sbpcd b 640 0 0 25 0 0 1 4 #/dev/mcd b 640 0 0 23 0 0 0 - #/dev/optcd b 640 0 0 17 0 0 0 -
