------ Build started: Project: UC3B_Erster_Code_130920, Configuration: Debug AVR ------ Build started. Project "UC3B_Erster_Code_130920.cproj" (default targets): Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!=''). Target "CoreBuild" in file "C:\Programme\Atmel\Atmel Studio 6.1\Vs\Compiler.targets" from project "D:\Eigene Dateien\mc\LS0629\UC3B\UC3B_Erster_Code_130920\UC3B_Erster_Code_130920\UC3B_Erster_Code_130920.cproj" (target "Build" depends on it): Using "RunCompilerTask" task from assembly "C:\Programme\Atmel\Atmel Studio 6.1\Extensions\Application\AvrGCC.dll". Task "RunCompilerTask" C:\Programme\Atmel\Atmel Studio 6.1\shellUtils\make.exe all Building file: ../src/ASF/avr32/boards/evk1101/init.c Invoking: AVR32/GNU C Compiler : "C:\Programme\Atmel\Atmel Studio 6.1\extensions\Atmel\AtmelToolchainProvider\6.1.0.0\avr32-gnu-toolchain\bin\avr32-gcc.exe" -DBOARD=EVK1101 -I"../src" -I"../src/ASF/avr32/boards" -I"../src/ASF/avr32/boards/evk1101" -I"../src/ASF/avr32/drivers/gpio" -I"../src/ASF/avr32/drivers/intc" -I"../src/ASF/avr32/utils" -I"../src/ASF/avr32/utils/preprocessor" -I"../src/ASF/common/boards" -I"../src/ASF/common/utils" -I"../src/config" -O1 -fdata-sections -ffunction-sections -g3 -Wall -mpart=uc3b0256 -c -std=gnu99 -fno-strict-aliasing -Wstrict-prototypes -Wmissing-prototypes -Werror-implicit-function-declaration -Wpointer-arith -mrelax -mno-cond-exec-before-reload -MD -MP -MF "src/ASF/avr32/boards/evk1101/init.d" -MT"src/ASF/avr32/boards/evk1101/init.d" -MT"src/ASF/avr32/boards/evk1101/init.o" -o"src/ASF/avr32/boards/evk1101/init.o" "../src/ASF/avr32/boards/evk1101/init.c" Das System kann den angegebenen Pfad nicht finden. make: *** [src/ASF/avr32/boards/evk1101/init.o] Error 1 Done executing task "RunCompilerTask" -- FAILED. Done building target "CoreBuild" in project "UC3B_Erster_Code_130920.cproj" -- FAILED. Done building project "UC3B_Erster_Code_130920.cproj" -- FAILED. Build FAILED. ========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
