Version 4 SHEET 1 1608 680 WIRE 352 80 80 80 WIRE 496 80 432 80 WIRE 544 80 496 80 WIRE 80 128 80 80 WIRE 496 128 496 80 WIRE 80 256 80 208 WIRE 496 256 496 192 FLAG 496 256 0 FLAG 80 256 0 FLAG 544 80 out IOPIN 544 80 Out SYMBOL res 336 96 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 10k SYMBOL cap 480 128 R0 SYMATTR InstName C1 SYMATTR Value {CF} SYMBOL voltage 80 112 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V1 SYMATTR Value PULSE(0 {VCC} 0 1n 1n 500u 1000u) TEXT -432 96 Left 2 !.tran 0 50m 0 1u TEXT -432 64 Left 2 !.ic V(out)={VCC/2} TEXT -432 24 Left 2 ;.step param CF list 0.01u 0.1u 1u TEXT -432 120 Left 2 !.options plotwinsize=0 TEXT -432 0 Left 2 !.param CF=1u TEXT 664 0 Left 2 ;Approximation:\n--------------\n \nVf_pp_max = 0.25 * Vcc * Tp / Tau\n \nVf_pp_max = 0.25*5*100u/10m = 0.0125V\n \nPrecise formula:\n----------------\n \nh1 = EXP(-Tp / Tau)\nh2 = EXP(Tw / Tau)\nV2 = Vcc * h1 * (h2 - 1) / (1 - h1) low-peak\nV1 = V2 / (h1 * h2) high-peak\nVf_pp = V1 - V2 pp-ripple TEXT 56 392 Left 2 ;V2 TEXT 56 320 Left 2 ;V1 TEXT -440 184 Left 2 !.param Tp=100u Tw=50u Tau=10m Vcc=5\n.param h1=exp(-Tp/Tau)\n.param h2=exp(Tw/Tau)\n.param V2=Vcc*h1*(h2-1)/(1-h1)\n.param V1=V2/(h1*h2)\n.param Vf_pp=V1-V2 TEXT -160 -96 Left 4 ;Calculation Of The Voltage-Ripple When Using A RC-Filter TEXT -440 360 Left 2 !.measure Vpp param Vf_pp\n; Menu: View --> SPICE Error Log LINE Normal 192 320 112 400 LINE Normal 272 400 192 320 LINE Normal 352 320 272 400 LINE Normal 432 400 352 320 LINE Normal 448 320 96 320 2 LINE Normal 448 400 96 400 2
