/* Edited by Johannes Frolich, Modified version from Andrew Payne and original Firefly Firmata Firefly Firmata written by Jason Kelly Johnson and Andrew Payne Copyright 2013 | All Rights Reserved This Firmata allows you to control an Arduino board from Rhino/Grasshopper/Firefly. Updates, Questions, Suggestions visit: http://www.fireflyexperiments.com 1. Plug Arduino boards into your USB port; confirm that your Arduino's green power LED in on 2. Select your specific Arduino Board and Serial Port (Tools > Board; Tools > Serial Port) *Take note of your Serial Port COM # 3. Verify (play button) and Upload (upload button) this program to your Arduino, close the Arduino program 4. then open ... Rhino/Grasshopper/Firefly Note: The Firefly Firmata sets the following pins to perform these functions: NOTE== THIS VERSION ONLY WORKS ON ARDUINO UNO, WITH ULTRASONIC PING SENSOR CONNECTED TO DIGITAL PIN 2!! ON DPIN2 IT SHOWS THE DISTANCE IN CM. */ #include // attach Servo library (http://www.arduino.cc/playground/ComponentLib/Servo) #include // attach arduino pins header file to determine which board type is being used #define BAUDRATE 115200 // Set the Baud Rate to an appropriate speed #define BUFFSIZE 512 // buffer one command at a time, 12 bytes is longer than the max length /*============================================================================== * GLOBAL VARIABLES *============================================================================*/ char buffer[BUFFSIZE]; // declare buffer uint8_t bufferidx = 0; // a type of unsigned integer of length 8 bits char *parseptr; char buffidx; int counter = 0; int numcycles = 1000; int pingPin = 2; //TEST long duration, inches, cm; uint16_t APin0, APin1, APin2, APin3, APin4, APin5, DPin2, DPin4, DPin7; // declare input variables uint16_t DPin3, DPin5, DPin6, DPin8, DPin9, DPin10, DPin11, DPin12, DPin13; // declare output variables Servo Servo3, Servo5, Servo6, Servo8, Servo9, Servo10, Servo11, Servo12, Servo13; // declare Servo objects /*============================================================================== * SETUP() This code runs once *============================================================================*/ void setup() { Init(); //set initial pinmodes Serial.begin(BAUDRATE); // Start Serial communication } /*============================================================================== * LOOP() This code loops *============================================================================*/ void loop() { if(Serial){ ReadSerial(); // read and parse string from serial port and write to pins if (counter >= numcycles){ // Wait every nth loop ReadInputs(); // get input data entfernung(); PrintToPort(); // print data to serial port counter = 0; // reset the counter } counter ++; // increment the writecounter } } /*============================================================================== * FUNCTIONS() *============================================================================*/ void Init(){ // pinMode(2, OUTPUT); pinMode(4, INPUT); pinMode(7, INPUT); } void ReadInputs(){ APin0 = analogRead(0); APin1 = analogRead(1); APin2 = analogRead(2); APin3 = analogRead(3); APin4 = analogRead(4); APin5 = analogRead(5); // DPin2 = digitalRead(2); DPin4 = digitalRead(4); DPin7 = digitalRead(7); } void entfernung(){ pinMode(2, OUTPUT); digitalWrite(2, LOW); delay(2); digitalWrite(2, HIGH); delayMicroseconds(10); digitalWrite(2, LOW); pinMode(2, INPUT); duration = pulseIn(2, HIGH); // delay(10); cm = microsecondsToCentimeters(duration); } long microsecondsToCentimeters(long microseconds) { // speed of sound: 340 m/s or 29 microseconds/cm. // so: half of the distance return microseconds / 29 / 2; } void PrintToPort(){ Serial.print(APin0); Serial.print(","); Serial.print(APin1); Serial.print(","); Serial.print(APin2); Serial.print(","); Serial.print(APin3); Serial.print(","); Serial.print(APin4); Serial.print(","); Serial.print(APin5); Serial.print(","); Serial.print(cm); Serial.print(","); Serial.print(DPin4); Serial.print(","); Serial.print(DPin4); Serial.print(","); Serial.println("eol"); //end of line marker } void ReadSerial(){ char c; // holds one character from the serial port if (Serial.available()) { c = Serial.read(); // read one character buffer[bufferidx] = c; // add to buffer if (c == '\n') { buffer[bufferidx+1] = 0; // terminate it parseptr = buffer; // offload the buffer into temp variable DPin13 = parsedecimal(parseptr); // parse the first number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin12 = parsedecimal(parseptr); // parse the second number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin11 = parsedecimal(parseptr); // parse the third number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin10 = parsedecimal(parseptr); // parse the fourth number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin9 = parsedecimal(parseptr); // parse the fifth number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin8 = parsedecimal(parseptr); // parse the sixth number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin6 = parsedecimal(parseptr); // parse the seventh number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin5 = parsedecimal(parseptr); // parse the eighth number parseptr = strchr(parseptr, ',')+1; // move past the "," DPin3 = parsedecimal(parseptr); // parse the ninth number WriteToPin(13, DPin13, Servo13); //send value out to pin on arduino board WriteToPin(12, DPin12, Servo12); WriteToPin(11, DPin11, Servo11); WriteToPin(10, DPin10, Servo10); WriteToPin(9, DPin9, Servo9); WriteToPin(8, DPin8, Servo8); WriteToPin(6, DPin6, Servo6); WriteToPin(5, DPin5, Servo5); WriteToPin(3, DPin3, Servo3); bufferidx = 0; // reset the buffer for the next read return; // return so that we don't trigger the index increment below } // didn't get newline, need to read more from the buffer bufferidx++; // increment the index for the next character if (bufferidx == BUFFSIZE-1) bufferidx = 0; // if we get to the end of the buffer reset for safety } } void WriteToPin(int _pin, int _value, Servo _servo){ if (_value >= 1000 && _value < 2000) // check if value should be used for Digital Write (HIGH/LOW) { if (_servo.attached()) _servo.detach(); // detach servo is one is attached to pin pinMode(_pin, OUTPUT); // sets the pin for output _value -=1000; // subtract 1000 from the value sent from Firefly if (_value == 1) digitalWrite(_pin, HIGH); // Digital Write to pin else digitalWrite(_pin, LOW); } else if (_value >= 2000 && _value < 3000) // check if value should be used for Analog Write (0-255) { if (_servo.attached()) _servo.detach(); // detach servo is one is attached to pin pinMode(_pin, OUTPUT); // sets the pin for output _value -= 2000; // subtract 2000 from the value sent from Firefly analogWrite(_pin, _value); // Analog Write to pin } else if (_value >= 3000 && _value < 4000) // check if value should be used for Servo Write (0-180) { _value -= 3000; // subtract 3000 from the value sent from Firefly if (!_servo.attached())_servo.attach(_pin); // attaches a Servo to the PWM pin (180 degree standard servos) _servo.write(_value); // Servo Write to the pin } } uint32_t parsedecimal(char *str){ uint32_t d = 0; while (str[0] != 0) { if ((str[0] > '50') || (str[0] < '0')) return d; d *= 10; d += str[0] - '0'; str++; } return d; }
