' * - - * - * * - - - - - - - - - - - - - - - - - - - - - - - - - - - 'Made by Szymon Dyja 'from www.pro-qwerty.com '' * - - * - * * - - - - - - - - - - - - - - - - - - - - - - - - - - $crystal = 8000000 $baud = 19200 Declare Sub Lover_text() Config Pind.2 = Input Config Pind.3 = Input Config Pind.4 = Input Config Pind.6 = Output Portd.2 = 1 Portd.3 = 1 Portd.4 = 1 Portd.6 = 0 Dim A As Integer Dim Secounds As Byte Dim Minutes As Byte Dim Hours As Byte Let Secounds = 0 Let Minutes = 0 Let Hours = 0 Let A = 0 Config Lcd = 16 * 2 Deflcdchar 0 , 32 , 21 , 14 , 4 , 4 , 10 , 17 , 17 ' replace ? with number (0-7) Deflcdchar 1 , 32 , 4 , 14 , 14 , 14 , 4 , 4 , 4 ' replace ? with number (0-7) Config Timer1 = Timer , Prescale = 1024 On Ovf1 Tim1_isr Load Timer1 , 7812 Setclock: Disable Interrupts Let Secounds = 0 Cls Cursor On Blink Lcd "Time: " Lowerline Lcd "Set Clock!" Locate 1 , 9 Lcd ":" Locate 1 , 12 Lcd "." Do If Pind.3 = 0 Then Minutes = Minutes + 1 If Minutes = 60 Then Minutes = 0 Waitms 200 End If If Pind.2 = 0 Then Hours = Hours + 1 If Hours = 24 Then Hours = 0 Waitms 200 End If If Pind.4 = 0 Then Exit Do Locate 1 , 7 Lcd " " Locate 1 , 7 Lcd Hours Locate 1 , 10 Lcd " " Locate 1 , 10 Lcd Minutes Locate 1 , 13 Lcd " " Locate 1 , 13 Lcd Secounds Waitms 50 Loop Enable Timer1 Enable Interrupts Cursor Off Noblink Call Lover_text() Do Toggle Portd.6 Waitms 100 If Pind.4 = 0 Then Waitms 10 While Pind.4 = 0 Nop Wend Goto Setclock End If Loop Tim1_isr: Load Timer1 , 7812 If Secounds = 60 Then Secounds = 0 Minutes = Minutes + 1 If Minutes = 60 Then Minutes = 0 Locate 1 , 10 Lcd " " Hours = Hours + 1 If Hours = 24 Then Hours = 0 Locate 1 , 7 Lcd " " Call Lover_text() nop nop End If End If End If Locate 1 , 7 Lcd Hours Locate 1 , 10 Lcd Minutes Locate 1 , 13 Lcd " " Locate 1 , 13 Lcd Secounds Locate 1 , 16 If A = 0 Then Lcd Chr(0) A = 1 Elseif A = 1 Then Lcd Chr(1) A = 0 End If Secounds = Secounds + 1 Return End Sub Lover_text() Locate 2 , 0 Lcd " Hello! " End Sub
