******************************************************************************** Canon Inkjet Printer Driver Version 3.80 Copyright CANON INC. 2012 All Rights Reserved. ******************************************************************************** 1. About this file This file describes the options available when printing on this printer using the lpr command. 2. Option list This section describes options available for setting up printing with the lpr command. For information about the options that can be used and restrictions on combining options, see the following: Media Type ** Paper Source ** Print Quality ** Color Balance Intensity Contrast Brightness Grayscale Printing Page Size ** Print Size Print Position Automatic Duplex Printing ** Borderless Printing ** Copies Any setting identified with ** has restrictions when combined with other options. For information about restrictions based on print option combinations, see "Restrictions on the combinations of print options." Media Type ** Syntax : -o MediaType=[parameter] Parameter : The following media can be selected. [Default Value=plain] plain Plain Paper glossygold Photo Paper Plus Glossy II proplatinum Photo Paper Pro Platinum luster Photo Paper Pro Luster semigloss Photo Paper Plus Semi-gloss glossypaper Glossy Photo Paper matte Matte Photo Paper envelope Envelope postcardaddress Hagaki A ijpostcard Ink Jet Hagaki glossypost Hagaki K postcard Hagaki highres High Resolution Paper tshirt T-Shirt Transfers otherphoto Other Photo Paper Paper Source ** Syntax : -o InputSlot=[parameter] Parameter : The following Paper Sources can be selected. [Default Value=cassetteauto] cassetteauto Feed from Cassette Print Quality ** Syntax : -o CNQuality=[parameter] Parameter : 1 - 5 [Default Value=differs depending on options] As the value becomes smaller, the print quality improves. As the value becomes larger, the print speed increases. The default value differs depending on other print options. Color Balance Syntax : Cyan -o CNBalanceC=[parameter] Magenta -o CNBalanceM=[parameter] Yellow -o CNBalanceY=[parameter] Parameter : -50 - 50 [Default Value=0] The color tone increases as the number increases. Intensity Syntax : -o CNDensity=[parameter] Parameter : -50 - 50 [Default Value=0] The intensity increases as the number increases. Contrast Syntax : -o CNContrast=[parameter] Parameter : -50 - 50 [Default Value=0] The contrast increases as the number increases. Brightness Syntax : -o CNGamma=[parameter] Parameter : The following parameters can be selected. [Default Value=1.8] 1.4 Light 1.8 Normal 2.2 Dark Grayscale Printing Syntax : -o CNGrayscale Parameter : There is no parameter. Page Size ** Syntax : -o PageSize=[parameter] Parameter : The following Page Sizes can be selected. [Default Value=a4] letter Letter [8.50"x11.00" 215.9x279.4mm] legal Legal [8.50"x14.00" 215.9x355.6mm] a5 A5 [5.83"x8.27" 148.0x210.0mm] a4 A4 [8.27"x11.69" 210.0x297.0mm] b5 B5 [7.17"x10.12" 182.0x257.0mm] 4X6 4"x6" [4.00"x6.00" 101.6x152.4mm] 5X7 5"x7" [5.00"x7.00" 127.0x177.8mm] 8X10 8"x10" [8.00"x10.00" 203.2x254.0mm] l L [3.50"x5.00" 89.0x127.0mm] 2l 2L [5.00"x7.01" 127.0x178.0mm] postcard Hagaki [3.94"x5.83" 100.0x148.0mm] postdbl Hagaki 2 [7.87"x5.83" 200.0x148.0mm] envelop10p Comm. Env. #10 [4.12"x9.50" 104.8x241.3mm] envelopdlp DL Env. [4.33"x8.66" 110.0x220.0mm] envj4p Youkei 4 [4.13"x9.25" 105.0x235.0mm] envj6p Youkei 6 [3.86"x7.48" 98.0x190.0mm] Custom.value1xvalue2mm Custom letter.bl Letter [8.50"x11.00" 215.9x279.4mm] with Borderless Printing a4.bl A4 [8.27"x11.69" 210.0x297.0mm] with Borderless Printing 4X6.bl 4"x6" [4.00"x6.00" 101.6x152.4mm] with Borderless Printing 5X7.bl 5"x7" [5.00"x7.00" 127.0x177.8mm] with Borderless Printing 8X10.bl 8"x10" [8.00"x10.00" 203.2x254.0mm] with Borderless Printing l.bl L [3.50"x5.00" 89.0x127.0mm] with Borderless Printing 2l.bl 2L [5.00"x7.01" 127.0x178.0mm] with Borderless Printing postcard.bl Hagaki [3.94"x5.83" 100.0x148.0mm] with Borderless Printing If you specify Custom for Page Size, specify the size within the following range. You must set both the paper width (value1) and height (value2). Syntax : -o PageSize=Custom.[value1]x[value2]mm Parameter : value1 = 89 mm - 215.9 mm, value2 = 127 mm - 355.6 mm Print Size i) Scaling Specification Specify the size ratio for enlargement or reduction as a % value. With the lpr command, you can use "natural-scaling," which is a standard option, to perform the Scaling Specification. For information about the options that can be set in the lpr command (CUPS), see the homepage for the Common UNIX Printing System (http://www.cups.org/). ii) Fit-to-Page Printing Syntax : -o scaling=100 This function expands or reduces the image to fit the print area, without changing the vertical-horizontal ratio. It scales the image to fit to the print area in either the horizontal or vertical direction. *Scaling Specification and Fit-to-Page Printing cannot be specified at the same time. Print Position With the lpr command, you can use "position," which is a standard option, to perform the Print Position adjustment. For information about the options that can be set in the lpr command (CUPS), see the homepage for the Common UNIX Printing System (http://www.cups.org/). Automatic Duplex Printing ** Syntax : -o Duplex Parameter : There is no parameter. Staple Side Syntax : -o CNStapleSide=[parameter] Parameter : The following Staple Sides can be selected. [Default Value=longside] longside Printing with stapling on the long side. shortside Printing with stapling on the short side. *This option is enabled only when Automatic Duplex Printing is specified. Borderless Printing ** This parameter adjusts the amount that extends outside the paper during Borderless Printing. This parameter is enabled only when Borderless Printing is specified. Syntax : -o CNExtension=[parameter] Parameter : 0 - 3 [Default Value=2] As the number becomes larger, the extension amount increases. Copies Syntax : -o CNCopies=[parameter] Parameter : 1 - 999 [Default Value=1] 3. Restrictions on the combinations of print options The combinations of print option for the lpr command are restricted as shown below. *Automatic Duplex Printing and Media Type/Page Size You can specify the Automatic Duplex Printing if you specified the following Media Type: plain postcardaddress postcard You can specify the Automatic Duplex Printing if you specified the following Page Size: letter a5 a4 b5 postcard *Media Type, Automatic Duplex Printing, Print Quality, and Borderless Printing When combining Media Type, Automatic Duplex Printing, Print Quality, and Borderless Printing, you can specify the following print setting combinations using the lpr command: When Borderless Printing is specified (when specifying a Page Size for Borderless Printing): -o MediaType=plain -o CNQuality=3 -o MediaType=postcard -o CNQuality=2 -o MediaType=postcard -o CNQuality=3 -o MediaType=glossypaper -o CNQuality=2 -o MediaType=glossypaper -o CNQuality=3 -o MediaType=ijpostcard -o CNQuality=2 -o MediaType=ijpostcard -o CNQuality=3 -o MediaType=matte -o CNQuality=2 -o MediaType=matte -o CNQuality=3 -o MediaType=otherphoto -o CNQuality=3 -o MediaType=glossygold -o CNQuality=2 -o MediaType=glossygold -o CNQuality=3 -o MediaType=semigloss -o CNQuality=2 -o MediaType=semigloss -o CNQuality=3 -o MediaType=proplatinum -o CNQuality=1 -o MediaType=proplatinum -o CNQuality=2 -o MediaType=proplatinum -o CNQuality=3 -o MediaType=glossypost -o CNQuality=2 -o MediaType=glossypost -o CNQuality=3 -o MediaType=postcardaddress -o CNQuality=2 -o MediaType=postcardaddress -o CNQuality=3 -o MediaType=luster -o CNQuality=2 -o MediaType=luster -o CNQuality=3 When Borderless Printing is not specified (when not specifying a Page Size for Borderless Printing): -o MediaType=plain -o CNQuality=2 -o MediaType=plain -o Duplex -o CNQuality=2 -o MediaType=plain -o CNQuality=3 -o MediaType=plain -o Duplex -o CNQuality=3 -o MediaType=plain -o CNQuality=4 -o MediaType=plain -o Duplex -o CNQuality=4 -o MediaType=postcard -o CNQuality=2 -o MediaType=postcard -o Duplex -o CNQuality=2 -o MediaType=postcard -o CNQuality=3 -o MediaType=postcard -o Duplex -o CNQuality=3 -o MediaType=envelope -o CNQuality=2 -o MediaType=envelope -o CNQuality=3 -o MediaType=highres -o CNQuality=2 -o MediaType=highres -o CNQuality=3 -o MediaType=tshirt -o CNQuality=2 -o MediaType=glossypaper -o CNQuality=2 -o MediaType=glossypaper -o CNQuality=3 -o MediaType=ijpostcard -o CNQuality=2 -o MediaType=ijpostcard -o CNQuality=3 -o MediaType=matte -o CNQuality=2 -o MediaType=matte -o CNQuality=3 -o MediaType=otherphoto -o CNQuality=3 -o MediaType=glossygold -o CNQuality=2 -o MediaType=glossygold -o CNQuality=3 -o MediaType=semigloss -o CNQuality=2 -o MediaType=semigloss -o CNQuality=3 -o MediaType=proplatinum -o CNQuality=1 -o MediaType=proplatinum -o CNQuality=2 -o MediaType=proplatinum -o CNQuality=3 -o MediaType=glossypost -o CNQuality=2 -o MediaType=glossypost -o CNQuality=3 -o MediaType=postcardaddress -o CNQuality=2 -o MediaType=postcardaddress -o Duplex -o CNQuality=2 -o MediaType=postcardaddress -o CNQuality=3 -o MediaType=postcardaddress -o Duplex -o CNQuality=3 -o MediaType=luster -o CNQuality=2 -o MediaType=luster -o CNQuality=3
