Tristan Van Berkom
for vuc-gl373 0.0.6
Abstract
This document attempts to describe how to use the Glade UI Designer core library to integrate Glade into your application and how to integrate your custom GTK+ derived widgets into the Glade UI Designer.
You can always get the latest version of this document here and you should have received a copy with the glade-3 tarball.
I. Adding your custom widgets
Introducing the Glade Catalog — How to write and install a catalog
Widget Adaptor Definitions — Adding support for custom widgets
Property Class Definitions — How to augment or define a GladePropertyClass
Python Gtk widgets support — How to write and install a catalog for a python widget library
II. Glade Core
GladeApp — The central control point of the Glade core.
GladeProject — The Glade document hub and Load/Save interface.
GladeWidget — An object wrapper for the Glade runtime environment.
GladeFixed — An object wrapper for free-form placement container widgets.
GladeProperty — An interface to properties on the GladeWidget.
GladeWidgetAdaptor — Adaptor base class to add runtime support for each widget class.
GladePropertyClass — Property Class-wide metadata.
GladeWidgetAction — Context menu and toolbar actions.
GladeCommand — An event filter to implement the Undo/Redo stack.
GladeClipboard — A list of GladeWidget objects not in any GladeProject.
GladeBaseEditor — A customisable editor
GladePlaceholder — A GtkWidget to fill empty places.
Xml Utils — An api to read and write xml.
III. Dockable Glade UI Widgets
GladeEditor — A Widget to edit a GladeWidget.
GladeEditorProperty — A generic widget to edit a GladeProperty.
GladePalette — A widget to select a GladeWidgetClass for addition.
GladeClipboardView
GladeInspector — A widget for inspecting objects in a GladeProject.
GladeSignalEditor — An interface to edit signals for a GladeWidget. W
GladeDesignView — A widget to embed the workspace.
IV. Miscellaneous utilities
Glade Parameter — Parameters set in the catalog retrievable from the plugin.
Glade Utils — Welcome to the zoo.
Index
