Glade User Interface Designer Reference Manual | ![]() |
Top | Description | Object Hierarchy | Implemented Interfaces | Properties | Signals |
GladePaletteGladePalette — A widget to select a GladeWidgetClass for addition. |
GladePalette; enum GladeItemAppearance; GtkWidget * glade_palette_new (const GList *catalogs
); void glade_palette_deselect_current_item (GladePalette *palette
,gboolean sticky_aware
); GladeWidgetAdaptor * glade_palette_get_current_item (GladePalette *palette
); GladeItemAppearance glade_palette_get_item_appearance (GladePalette *palette
); void glade_palette_set_item_appearance (GladePalette *palette
,GladeItemAppearance item_appearance
); gboolean glade_palette_get_use_small_item_icons (GladePalette *palette
); void glade_palette_set_use_small_item_icons (GladePalette *palette
,gboolean use_small_item_icons
); void glade_palette_set_show_selector_button (GladePalette *palette
,gboolean show_selector_button
); gboolean glade_palette_get_show_selector_button (GladePalette *palette
GObject +----GInitiallyUnowned +----GtkObject +----GtkWidget +----GtkContainer +----GtkBox +----GtkVBox +----GladePalette
"catalogs" gpointer : Read / Write / Construct Only "current-item" gpointer : Read "item-appearance" GladeItemAppearance : Read / Write "show-selector-button" gboolean : Read / Write "use-small-item-icons" gboolean : Read / Write
GladePalette is responsible for displaying the list of available GladeWidgetClass types and publishing the currently selected class to the Glade core.
typedef enum { GLADE_ITEM_ICON_AND_LABEL, GLADE_ITEM_ICON_ONLY, GLADE_ITEM_LABEL_ONLY } GladeItemAppearance;
Creates a new GladePalette widget
the widget catalogs for the palette. |
Returns : |
a new GladePalette |
Deselects the currently selected item
a GladePalette |
whether to consider sticky selection mode |
Gets the GladeWidgetAdaptor of the currently selected item.
a GladePalette |
Returns : |
the GladeWidgetAdaptor of currently selected item, or NULL if no item is selected. |
a GladePalette |
Returns : |
The appearance of the palette items |
Sets the appearance of the palette items.
a GladePalette |
the item appearance |
a GladePalette |
Returns : |
Whether small item icons are used |
Sets whether to use small item icons.
a GladePalette |
Whether to use small item icons |
Sets whether to show the internal widget selector button
a GladePalette |
whether to show selector button |
a GladePalette |
Returns : |
Whether the selector button is visible |
"catalogs"
property"catalogs" gpointer : Read / Write / Construct Only
The widget catalogs for the palette.
"current-item"
property"current-item" gpointer : Read
The GladeWidgetAdaptor of the currently selected item.
"item-appearance"
property"item-appearance" GladeItemAppearance : Read / Write
The appearance of the palette items.
Default value: GLADE_ITEM_ICON_ONLY
property"show-selector-button" gboolean : Read / Write
Whether to show the internal selector button.
Default value: TRUE
property"use-small-item-icons" gboolean : Read / Write
Whether to use small icons to represent items.
Default value: FALSE
