Partlist Exported from tester.sch at 14.12.2013 17:07:34 EAGLE Version 6.4.0 Copyright (c) 1988-2013 CadSoft Assembly variant: Part Value Device Package Library Sheet C1 1n C-EUC0805 C0805 rcl 1 C2 10n C-EUC0805 C0805 rcl 1 C3 100n C-EUC0805 C0805 rcl 1 C4 100n C-EUC0805 C0805 rcl 1 C5 47u CPOL-EU153CLV-0505 153CLV-0505 rcl 1 C6 1u C-EUC0805 C0805 rcl 1 C7 1u C-EUC0805 C0805 rcl 1 C8 1u C-EUC0805 C0805 rcl 1 C9 100n C-EUC0805 C0805 rcl 1 C10 100n C-EUC0805 C0805 rcl 1 C11 22p C-EUC0805 C0805 rcl 1 C12 22p C-EUC0805 C0805 rcl 1 C13 1u C-EUC0805 C0805 rcl 1 C14 1u C-EUC0805 C0805 rcl 1 C15 47u CPOL-EU153CLV-0505 153CLV-0505 rcl 1 C16 10n C-EUC0805 C0805 rcl 1 D1 BAV 103 DIODE-SOD80C SOD80C diode 1 D2 SB130 SCHOTTKY-DIODE_RAD3-5-A DIODE-3-5A-V markus 1 DC1 5V/+-15V NMA NMA dc-dc-converter 1 DIS1 EA-DOG-M162 EA-DOG-M_LCD EA_DOGM ea 1 G1 AB9V AB9V AB9V battery 1 IC1 ATmega8/88/168 MEGA8-PU DIL28-3 avr-7 1 JP1 ISP ML6 ML6 con-ml 1 JP2 TEST FE05-1 FE05-1 con-lsta 1 JP3 TESTZENER FE04-1 FE04-1 con-lsta 1 JP4 TESTEXT PINHD-2X5 2X05 pinhead 1 JP7 TEST2 FE02-1 FE02-1 con-lsta 1 K1 NA 05W K NA NA relay 1 L1 33u SM-NE29 SM-NE29 inductor-neosid 1 LED1 POWER LED5MMEXT LED5MM led 1 P1 250 TRIM_EU-CA6H CA6H pot 1 P2 10k lin TRIM_EU-CA9V CA9V pot 1 Q1 BC847CSMD BC847CSMD SOT23 transistor-npn 1 Q2 BC847CSMD BC847CSMD SOT23 transistor-npn 1 Q3 BC807-40SMD BC807-40SMD SOT23-BEC transistor-pnp 1 Q4 8,000 MHz CRYSTALHC49S HC49/S crystal 1 Q5 BC847CSMD BC847CSMD SOT23 transistor-npn 1 Q6 IRLML6402 IRLML6402 MICRO3 mosfet 1 R1 680 R-EU_R0805 R0805 resistor 1 R2 470k R-EU_R0805 R0805 resistor 1 R3 680 R-EU_R0805 R0805 resistor 1 R4 470k R-EU_R0805 R0805 resistor 1 R5 680 R-EU_R0805 R0805 resistor 1 R6 470k R-EU_R0805 R0805 resistor 1 R7 3k3 R-EU_R0805 R0805 resistor 1 R8 27k R-EU_R0805 R0805 resistor 1 R9 100k R-EU_R0805 R0805 resistor 1 R10 33k R-EU_R0805 R0805 resistor 1 R11 10k R-EU_R0805 R0805 resistor 1 R12 3k3 R-EU_R0805 R0805 resistor 1 R13 10k R-EU_R0805 R0805 resistor 1 R14 27k R-EU_R0805 R0805 resistor 1 R15 4k7 R-EU_R0805 R0805 resistor 1 R16 2k2 R-EU_R0805 R0805 resistor 1 R17 10k R-EU_R0805 R0805 resistor 1 R18 3k3 R-EU_R0805 R0805 resistor 1 R19 10k R-EU_R0805 R0805 resistor 1 R20 100k R-EU_R0805 R0805 resistor 1 R21 10k R-EU_R0805 R0805 resistor 1 R22 12k R-EU_R0805 R0805 resistor 1 R23 10k R-EU_R0805 R0805 resistor 1 R24 180k R-EU_R0805 R0805 resistor 1 R25 20k R-EU_R0805 R0805 resistor 1 S1 DTS-6 DTS-6 DTS-6 switch-tact 1 U1 LT1004CZ-2.5 LM329DZ TO92 reference 1 U2 MCP1702-5002 MCP1702-5002 TO92-LOWDROP asko 1 U3 MCP1702-5002 MCP1702-5002 TO92-LOWDROP asko 1 U4 LM339D LM339D SO14 linear 1 U5 BCR421U BCR421UHAND SC74_INFINEON c-infineon_v2 1 X1 NEB21R NEB21R NEB21R con-lumberg 1
