// // By Kyle McDonald // From the instructables project at: // http://www.instructables.com/id/DIY-3D-Controller/ #define resolution 8 #define mains 50 // 60: north america, japan; 50: most other places #define refresh 2 * 1000000 / mains void setup() { Serial.begin(115200); // unused pins are fairly insignificant, // but pulled low to reduce unknown variables for(int i = 2; i < 14; i++) { pinMode(i, OUTPUT); digitalWrite(i, LOW); } for(int i = 8; i < 11; i++) pinMode(i, INPUT); startTimer(); } void loop() { Serial.print(time(8, B00000001), DEC); Serial.print(" "); Serial.print(time(9, B00000010), DEC); Serial.print(" "); Serial.println(time(10, B00000100), DEC); } long time(int pin, byte mask) { unsigned long count = 0, total = 0; while(checkTimer() < refresh) { // pinMode is about 6 times slower than assigning // DDRB directly, but that pause is important pinMode(pin, OUTPUT); PORTB = 0; pinMode(pin, INPUT); while((PINB & mask) == 0) count++; total++; } startTimer(); return (count << resolution) / total; } extern volatile unsigned long timer0_overflow_count; void startTimer() { timer0_overflow_count = 0; TCNT0 = 0; } unsigned long checkTimer() { return ((timer0_overflow_count << 8) + TCNT0) << 2; }
