$regfile = "m8def.dat" $crystal = 1000000 $baud = 4800 Print "VacControl 1.0" Print "19.08.2014 A.Hermann" Print "Slavesystem" 'Referenz und Umrechnung Druck Dim Ref As Single Dim Fak As Single Ref = 53.00 Fak = 18.44 'Allgemeine Variablen Dim Druck_volt As Integer Dim Druck_bar As Single Dim Druck_bar_ As String * 10 'ADC Konfigurieren Config Adc = Single , Prescaler = Auto , Reference = Avcc Start Adc 'Interrupt RS232 Empfang Declare Sub Serial0charmatch Config Serialin = Buffered , Size = 20 , Bytematch = 13 Enable Interrupts 'Link LED Link Alias Portd.6 Config Link = Output 'Run LED Run Alias Portd.5 Config Run = Output Test Alias Portb.0 Config Test = Output Gosub Init 'Hauptprogramm Main: Do Wait 2 Druck_volt = Getadc(0) Waitms 50 'Print "Druck ADC= " ; Druck_volt Wait 2 Loop End Dim I As Byte Sub Serial0charmatch() 'Datenempfang Signalisieren Local Incomming_data As String * 10 'lesen Input Incomming_data Noecho If Incomming_data = "132" Then Toggle Test Toggle Link Waitms 100 Toggle Link Waitms 100 Toggle Link Waitms 100 Toggle Link Wait 1 Toggle Test Gosub Senden Else !NOP End If End Sub Init: Run = 1 Link = 1 Return Senden: 'Print "Sensor 1: " ; Druck_volt ; "Volt" Waitms 100 Druck_bar = Druck_volt - 36 'Referenz abziehen 'Print "Druck nach abzug" ; Druck_bar Druck_bar = Druck_bar / 18.44 'umrechen in bar Druck_bar = Druck_bar / 100 Druck_bar_ = Str(druck_bar) Druck_bar_ = Fusing(druck_bar , "#.##") Print Druck_bar_ ; "bar" Toggle Link Waitms 100 Toggle Test Toggle Link Waitms 100 Toggle Test Toggle Link Waitms 100 Toggle Test Toggle Link Waitms 100 Toggle Test Return
