// FIRMWARE REPLACEMENT FOR CHATPAD's pic16f883 // see attached documents to learn more // release 0.3.1 from jean : giancarlotodone at yahoo dot it // for the Open Keyboard Project // thanks alot to Gidi (who owns an half of my chatpad, call him "sponsor") // and my sweethart piceta; they helped me handling // cable knots while reversing and testing. // Thanks as well to all people who demonstrated interest in this project! #define CONFIG_BAUDRATE 1 #define CONFIG_SENDMODE 2 #define CONFIG_LIGHTMODE 3 #define CONFIG_LIGHTSTRENGTH 4 #define CONFIG_LIGHTFADEOFFTIME 5 #define CONFIG_REPEAT 6 // not used yet #define CONFIG_ACCEPTCOMMANDS 7 // not used yet #define CONFIG_MACROS 8 // not used yet #define SENDMODE_SERIAL 0 #define SENDMODE_SCAN 1 #define SENDMODE_PS2 2 // not used yet #define LIGHTMODE_ALWAYSOFF 0 #define LIGHTMODE_ALWAYSON 1 #define LIGHTMODE_FADE 2 #define LIGHTMODE_LASTMODE 2 #define BAUDRATE_300 1 #define BAUDRATE_1200 2 #define BAUDRATE_2400 3 #define BAUDRATE_4800 4 #define BAUDRATE_9600 5 #define BAUDRATE_19200 6 #define BAUDRATE_38400 7 #define BAUDRATE_57600 8 #define BAUDRATE_115200 9 const char scanMap[50] = { // i could output directly idx, 8, 9, 10, 40, 20, 30, 47, // but maybe a translation map 41, 42, 43, 39, 44, 38, 45, // can prove useful in future. 31, 32, 33, 35, 34, 36, 37, // starts from 1...think 0 21, 22, 23, 25, 24, 26, 27, // should be reserved for 11, 12, 13, 15, 14, 16, 17, // future use 1, 2, 3, 5, 4, 6, 7, 28, 18, 19, 0, 0, 29, 46 }; const char serialMap[4][49] = { // CHARACTER MAPPING MATRIX for "pure serial mode" // normal char press {56, 57, 48, 13, 112, 44, 0, 0, 0, 0, 46, 32, 109, 0, 0, 121, 120, 118, 99, 98, 110, 97, 115, 100, 103, 102, 104, 106, 113, 119, 101, 116, 114, 122, 117, 49, 50, 51, 53, 52, 54, 55, 107, 105, 111, 0, 0, 108, 8}, // shifted {56, 57, 48, 13, 80, 44, 0, 0, 0, 0, 46, 32, 77, 0, 0, 89, 88, 86, 67, 66, 78, 65, 83, 68, 71, 70, 72, 74, 81, 87, 69, 84, 82, 90, 85, 49, 50, 51, 53, 52, 54, 55, 75, 73, 79, 0, 0, 76, 8}, // green alt {56, 57, 48, 13, 61, 39, 0, 0, 0, 0, 63, 32, 58, 0, 0, 60, 62, 45, 126, 42, 59, 0, 0, 0, 0, 0, 123, 125, 33, 34, 128, 37, 36, 38, 47, 49, 50, 51, 53, 52, 54, 55, 91, 40, 41, 0, 0, 93, 8}, // red alt {56, 57, 48, 13, 92, 35, 0, 0, 0, 0, 0, 32, 0, 0, 0, 0, 124, 95, 0, 43, 0, 0, 0, 0, 0, 0, 96, 0, 64, 0, 0, 0, 0, 94, 0, 49, 50, 51, 53, 52, 54, 55, 0, 0, 0, 0, 0, 0, 8} }; ////////// END OF MAPPING MATRIX unsigned char data[7] = {0,0,0,0,0,0,0}; unsigned char oldData[7] = {0,0,0,0,0,0,0}; unsigned char justPressed[7] = {0,0,0,0,0,0,0}; unsigned char newlyPressd = 0; unsigned char AMask = 0; unsigned char BMask = 0; unsigned char somethingChanged = 0; unsigned long int timer = 0xFFFF; unsigned long int lightFadeOffTime = 0x8000; // alternates (shift,green,red) mapping to translation map // 0 1 2 3 4 5 6 7 unsigned char alts [] = {0, 1, 2, 2, 3, 3, 3, 3}; unsigned char alt; void (*send)() = 0; void (*lightHandler)() = 0; unsigned char baudrate = 0; unsigned char sendMode = 0; unsigned char lightMode = 0; unsigned char lightStrenght = 0; unsigned char pwmRunning = 0; void enterPowerSave(){ PORTA = 0; INTCON.RBIE = 1; // enables PORTB on-change interrupt asm{ sleep; } } void exitPowerSave(){ INTCON.RBIE = 0; // disables PORTB on-change interrupt } void setupUsart(unsigned char br){ switch(br){ // done so, because you can't call USART_Init(variable); but only USART_Init(literal); case BAUDRATE_300: USART_Init(300); break; case BAUDRATE_1200: USART_Init(1200); break; case BAUDRATE_2400: USART_Init(2400); break; case BAUDRATE_4800: USART_Init(4800); break; case BAUDRATE_9600: USART_Init(9600); break; case BAUDRATE_19200: USART_Init(19200); break; case BAUDRATE_38400: USART_Init(38400); break; case BAUDRATE_57600: USART_Init(57600); break; case BAUDRATE_115200: USART_Init(115200); break; default: EEprom_write(CONFIG_BAUDRATE, BAUDRATE_4800); // if no config found, set a default 4800 br = BAUDRATE_4800; USART_Init(4800); } baudrate = br; } void turnBacklightOn(){ timer = lightFadeOffTime; if (!pwmRunning) { PWM1_Start(); PWM2_Start(); pwmRunning = 1; } PWM1_Change_Duty(lightStrenght); PWM2_Change_Duty(lightStrenght); } void nop(){ } void lightFade(){ unsigned char s; if (newlyPressd) { turnBacklightOn(); return; } if (timer>0) timer --; else { PWM1_Stop; PWM2_Stop; PORTC = 255; pwmRunning = 0; enterPowerSave(); } if (timer<(~lightStrenght)){ PWM1_Change_Duty(~((unsigned char)timer)); PWM2_Change_Duty(~((unsigned char)timer)); } } void setupLightMode(unsigned char lm){ if (pwmRunning){ PWM1_Stop(); PWM2_Stop(); } switch (lm){ case LIGHTMODE_ALWAYSOFF: lightHandler = &nop; lightStrenght = 0xFF; lightMode = LIGHTMODE_ALWAYSOFF; break; case LIGHTMODE_ALWAYSON: lightHandler = &nop; turnBacklightOn(); lightMode = LIGHTMODE_ALWAYSON; break; case LIGHTMODE_FADE: lightHandler = &lightFade; turnBacklightOn(); lightStrenght = 0x80; // restore middle luminosity lightMode = LIGHTMODE_FADE; break; default : EEprom_write(CONFIG_LIGHTMODE, LIGHTMODE_ALWAYSOFF); lightMode = LIGHTMODE_ALWAYSOFF; lightHandler = &nop; lightStrenght = 0xFF; } PORTC = 255; // PWM init if (lightMode != LIGHTMODE_ALWAYSOFF) { PWM1_Init(40000); PWM1_Change_Duty(lightStrenght); PWM1_Start(); PWM2_Init(40000); PWM2_Change_Duty(lightStrenght); PWM2_Start(); pwmRunning = 1; } } void doScan(){ unsigned char sc = 0; newlyPressd = 0; for (AMask=1; AMask<128; AMask<<=1){ oldData[sc] = data[sc]; // save old data PORTA = ~AMask; // put a 0 on the line we want to inspect data[sc] = PORTB; // read PORTB (pulled up)...if a line goes to 0, bingo! data[sc] = data[sc] | PORTB; // antibounce data[sc] = data[sc] | PORTB; // antibounce data[sc] = ~data[sc]; // return to positive logic justPressed[sc] = data[sc]&(~oldData[sc]); newlyPressd = newlyPressd | justPressed[sc]; sc++; } } void serialSend(){ unsigned char idx = 0; unsigned char sc = 0; for (AMask=1; AMask<128; AMask<<=1){ for (BMask=1; BMask<128; BMask<<=1){ if (justPressed[sc] & BMask) USART_Write(serialMap[alt][idx]); idx++; } sc++; } alt = alts[data[2]&1|((data[1]&1)<<1)|((data[0]&64)>>4)]; // next scan can use alt retrieved here } void scanSend(){ unsigned char idx = 0; unsigned char sc = 0; unsigned char bs = 0; for (AMask=1; AMask<128; AMask<<=1){ somethingChanged = data[sc] ^ oldData[sc]; bs = 0; for (BMask=1; BMask<128; BMask<<=1){ if (someThingChanged & BMask) USART_Write(scanMap[idx] | (((data[sc]&BMask)>>bs)<<6)); // | 64 if pressed bs++; idx++; } sc++; } } void ps2Send(){ // not implemented yet } void setupSendMode(unsigned char sm){ switch (sm){ case SENDMODE_SCAN : send = &scanSend; sendMode = SENDMODE_SCAN; break; case SENDMODE_SERIAL: send = &serialSend; sendMode = SENDMODE_SERIAL; break; // case SENDMODE_PS2: send = &ps2send; // sendMode = SENDMODE_PS2; // break; default : send = &serialSend; EEprom_write(CONFIG_SENDMODE, SENDMODE_SERIAL); sendMode = SENDMODE_SERIAL; } } void config(){ timer = lightFadeOffTime; if ((data[1]&4)&&(lightStrenght<0xff)) { // < lightStrenght++; PWM1_Change_Duty(lightStrenght); PWM2_Change_Duty(lightStrenght); if (lightMode==LIGHTMODE_ALWAYSOFF) lightMode = LIGHTMODE_FADE; } // decrease light strenght if ((data[1]&64)&&(lightStrenght>0)) { // > lightStrenght--; PWM1_Change_Duty(lightStrenght); PWM2_Change_Duty(lightStrenght); if (lightMode==LIGHTMODE_ALWAYSOFF) lightMode = LIGHTMODE_FADE; } // increase light strenght if (justPressed[5]&1){ // 1 // if (data[1]&1) // this buttion combination just doesn't work...think that's because of the buttons staying on the same matrix line. // setupUsart(BAUDRATE_4800); // else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 2<<8; // } } if (justPressed[5]&2){ // 2 if (data[1]&1) ;//setupUsart(BAUDRATE_300); //all setupUsart commented out are to save code words space...otherwise i'm running into demo limit else { //consider donating some money to me to purchase a full version of mikroC and continue development setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 4<<8; // more or less 5 sec } } if (justPressed[5]&4){ // 3 if (data[1]&1) ;//setupUsart(BAUDRATE_1200); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 8<<8; } } if (justPressed[5]&16){ // 4 if (data[1]&1) ;//setupUsart(BAUDRATE_2400); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 16<<8; } } if (justPressed[5]&8){ // 5 if (data[1]&1) setupUsart(BAUDRATE_4800); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 32<<8; } } if (justPressed[5]&32){ // 6 if (data[1]&1) setupUsart(BAUDRATE_9600); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 64<<8; } } if (justPressed[5]&64){ // 7 if (data[1]&1) ;//setupUsart(BAUDRATE_19200); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 128<<8; } } if (justPressed[0]&1){ // 8 if (data[1]&1) ;//setupUsart(BAUDRATE_38400); else { setupLightMode(LIGHTMODE_FADE); lightFadeOffTime = 255<<8; } } if (justPressed[0]&2){ // 9 if (data[1]&1) ;//setupUsart(BAUDRATE_57600); else setupLightMode(LIGHTMODE_ALWAYSON); } if (justPressed[0]&4){ // 0 if (data[1]&1) ;//setupUsart(BAUDRATE_115200); else setupLightMode(LIGHTMODE_ALWAYSOFF); } if (justPressed[3]&1){ // A setupSendMode(SENDMODE_SCAN); } if (justPressed[3]&2){ // S setupSendMode(SENDMODE_SERIAL); } Delay_5ms(); } void saveConfig(){ EEprom_write(CONFIG_BAUDRATE, baudrate); EEprom_write(CONFIG_SENDMODE, sendMode); EEprom_write(CONFIG_LIGHTMODE, lightMode); EEprom_write(CONFIG_LIGHTSTRENGTH, lightStrenght); EEprom_write(CONFIG_LIGHTFADEOFFTIME, lightFadeOffTime>>8); } void interrupt() { if (INTCON.RBIF) { // SOMETHING CHANGED ON PORTB... exitPowerSave(); // just wakeup and so some scanning... INTCON.RBIF = 0; // clear intr flag } // if (PIR1.RCIF) { // USART RECEIVE BUFFER () FULL... // // } } void main() { OSCCON = 0x67; // 01100111 - 0110 stands for 4Mhz internal clock ANSEL = 0; // Configure AN pins as digital I/O ANSELH = 0; PORTA = 0; // init port A TRISA = 0; // 1 = input PORTB = 0; // initialize PORTB TRISB = 255; // designate PORTB as all input PORTC = 0; // initialize PORTC TRISC = 0; // designate PORTB 0-7 as output OPTION_REG = 0; // pull-ups enabled on PORTB....no external pull-downs // present, so we have to run negative logic... //WPUB = 127; // weak pull-ups enabled on PORTB 0-6 // AAARGH!! this caused random Light-On INTCON.RBIE = 0; // disables PORTB on-change interrupt INTCON.RBIF = 0; // clear PORTB mismatch values IOCB = 127; // pin 0-6 of PORTB configured to raise interrupt when changed PIE1 = 32; // RCIE = 1; enables EUSART on-receive interrupt INTCON.GIE = 1; // Global Interrupt Enable/disable // SEND MODE ------------------ Delay_ms(20); // required for eeprom_read to work correctly sendMode = EEprom_read(CONFIG_SENDMODE); setupSendMode(sendMode); // TODO: if in PS2 mode don't initialize usart // USART --------------- Delay_ms(20); // required for eeprom_read to work correctly baudrate = EEprom_read(CONFIG_BAUDRATE); setupUsart(baudrate); // Initalize USART (xxxx baud rate, 1 stop bit, no parity...) // LIGHTS ---------------- Delay_ms(20); // required for eeprom_read to work correctly lightFadeOffTime = EEprom_read(CONFIG_LIGHTFADEOFFTIME) << 8; lightStrenght = EEprom_read(CONFIG_LIGHTSTRENGTH); Delay_ms(20); // required for eeprom_read to work correctly lightMode = EEprom_read(CONFIG_LIGHTMODE); setUpLightMode(lightMode); do { doScan(); if (data[1]&2) { config(); // people button pressed -> config mode }else{ if (oldData[1]&2) saveConfig(); // ppl btn just released... save config send(); } lightHandler(); Delay_80us(); // without this delay, pic hangs on sleep... } while (1); // endless loop }
