Version 4 SHEET 1 1352 680 WIRE 0 -48 -96 -48 WIRE 240 -48 128 -48 WIRE 384 -48 240 -48 WIRE 464 -48 384 -48 WIRE 544 -48 464 -48 WIRE 672 -48 624 -48 WIRE 720 -48 672 -48 WIRE 816 -48 720 -48 WIRE -96 16 -96 -48 WIRE 816 16 816 -48 WIRE 464 32 464 -48 WIRE 672 32 672 -48 WIRE 96 48 96 32 WIRE 128 48 96 48 WIRE 240 48 240 -48 WIRE 240 48 208 48 WIRE -96 160 -96 96 WIRE 464 160 464 96 WIRE 464 160 -96 160 WIRE 672 160 672 96 WIRE 672 160 464 160 WIRE 816 160 816 96 WIRE 816 160 672 160 WIRE -96 176 -96 160 WIRE 0 288 -112 288 WIRE 224 288 96 288 WIRE 400 288 224 288 WIRE 448 288 400 288 WIRE 528 288 448 288 WIRE 672 288 608 288 WIRE 768 288 672 288 WIRE 816 288 768 288 WIRE -112 352 -112 288 WIRE 448 352 448 288 WIRE 816 352 816 288 WIRE 672 368 672 288 WIRE 80 384 80 336 WIRE 112 384 80 384 WIRE 224 384 224 288 WIRE 224 384 192 384 WIRE -112 496 -112 432 WIRE 448 496 448 416 WIRE 448 496 -112 496 WIRE 672 496 672 432 WIRE 672 496 448 496 WIRE 816 496 816 432 WIRE 816 496 672 496 WIRE -112 512 -112 496 FLAG -96 176 0 FLAG 720 -48 out FLAG -112 512 0 FLAG 768 288 out2 FLAG 384 -48 l1 FLAG 400 288 l2 SYMBOL ind 528 -32 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 WINDOW 39 -51 50 VTop 2 SYMATTR InstName L1 SYMATTR Value 2µ SYMATTR SpiceLine Rser=10m SYMBOL voltage 112 48 R270 WINDOW 0 40 1 VRight 2 WINDOW 3 -55 -85 VRight 2 WINDOW 123 0 0 Left 2 WINDOW 39 -83 -85 VRight 2 SYMATTR InstName V1 SYMATTR Value PULSE(0 6 0 20n 20n 0.3u 1u) SYMATTR SpiceLine Rser=5 SYMBOL res 800 0 R0 SYMATTR InstName R1 SYMATTR Value 1 SYMBOL cap 656 32 R0 WINDOW 39 24 84 Left 2 SYMATTR InstName C1 SYMATTR Value 10µ SYMATTR SpiceLine Rser=5m SYMBOL schottky 448 96 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D1 SYMATTR Value MBRS340 SYMATTR Description Diode SYMATTR Type diode SYMBOL voltage -96 0 R0 SYMATTR InstName V2 SYMATTR Value 5 SYMBOL ind 512 304 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 WINDOW 39 -23 56 VBottom 2 SYMATTR InstName L2 SYMATTR Value 2µ SYMATTR SpiceLine Rser=10m SYMBOL voltage 96 384 R270 WINDOW 0 40 1 VRight 2 WINDOW 3 -55 -85 VRight 2 WINDOW 123 0 0 Left 2 WINDOW 39 -83 -85 VRight 2 SYMATTR InstName V3 SYMATTR Value PULSE(0 6 0 20n 20n 0.3u 1u) SYMATTR SpiceLine Rser=5 SYMBOL res 800 336 R0 SYMATTR InstName R2 SYMATTR Value 1 SYMBOL cap 656 368 R0 WINDOW 39 24 84 Left 2 SYMATTR InstName C2 SYMATTR Value 10µ SYMATTR SpiceLine Rser=5m SYMBOL schottky 432 416 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D2 SYMATTR Value MBRS340 SYMATTR Description Diode SYMATTR Type diode SYMBOL voltage -112 336 R0 SYMATTR InstName V4 SYMATTR Value 5 SYMBOL nmos 0 336 R270 WINDOW 0 76 12 VRight 2 WINDOW 3 107 13 VRight 2 SYMATTR InstName M1 SYMATTR Value FDS6961A SYMBOL EPCGaN 96 32 R270 WINDOW 0 115 -100 VRight 2 WINDOW 3 149 -101 VRight 2 SYMATTR InstName U2 SYMATTR Value EPC8007 TEXT -128 -272 Left 2 !.tran 100u startup TEXT -128 -232 Left 2 !.options gmin=1e-10 abstol=1e-10 TEXT -120 -384 Left 2 ;http://epc-co.com/epc/DesignSupport/DeviceModels.aspx\nhttp://epc-co.com/epc/documents/spice-files/LTSPICE/EPCGaNLibrary.zip TEXT -120 -496 Left 2 ;Choose the LSPICE models from this link below. Unzip the zip-file and copy the symbol file and the \nmodel file into the folder of your schematic.This model file EPCGaNLibrary.lib contains all GaN-Fets. \nThe symbol EPCGaN.asy already contains the name of the model file. Thus no ".inc" is required.
