atmega8: low fuse byte: clock-source external xtal: CHKSEL = 0 -> default: 0xe1 new: 0b11100000 = 0xe0 high fuse byte: 512 words bootloader size: BOOTSZ0 = 1 BOOTSZ1 = 0 reset vector, jump to bootloader on reset: BOOTRST = 0 no eeprom erase on chip erase: EESAVE = 0 -> default: 0b11011001 = 0xd9 new: 0b11010010 = 0xd2 lock byte: SPM is not allowed to write to the Boot Loader section BLB12 = 1 BLB11 = 0 -> default: 0b111111 = 0x3f new: 0b101111 = 0x2f atmega88/168: low fuse byte: clock-source external xtal: CHKSEL = 0 disable system clock divide by 8: CKDIV8 = 1 -> default: 0b01100010 = 0x62 new: 0b11100000 = 0xe0 high fuse byte: no eeprom erase on chip erase: EESAVE = 0 -> default: 0b11011111 = 0xdf new: 0b11010111 = 0xd7 extended fuse byte: 512 words bootloader size: BOOTSZ0 = 1 BOOTSZ1 = 0 OR: 1024 words bootloader size: BOOTSZ0 = 0 BOOTSZ1 = 0 reset vector, jump to bootloader on reset: BOOTRST = 0 -> default: 0b001 = 0x01 new: 0b010 = 0x02 OR 0x00 lock byte: SPM is not allowed to write to the Boot Loader section BLB12 = 1 BLB11 = 0 -> default: 0b111111 = 0x3f new: 0b101111 = 0x2f atmega32: high fuse byte - enable jtag unprogram: JTAGEN = 1 - bootloader size 512 words: BOOTSZ1 = 1 BOOTSZ0 = 0 - jump to bootloader: BOORST = 0 -> default: 0b10011001 = 0x99 neu: 0b11011100 = 0xdc low fuse byte: - external crystal clock, fast rising power: CKSEL = 1111 -> default: 0b11100001 = 0xe1 neu: 0b11101111 = 0xef lock byte: SPM is not allowed to write to the Boot Loader section BLB12 = 1 BLB11 = 0 -> default: 0b111111 = 0x3f new: 0b101111 = 0x2f atmega644: high fuse byte - enable jtag unprogram: JTAGEN = 1 - bootloader size 1024 words: BOOTSZ1 = 1 BOOTSZ0 = 0 - jump to bootloader: BOORST = 0 -> default: 0b10011001 = 0x99 neu: 0b11011100 = 0xdc low fuse byte: - external crystal clock, fast rising power: CKSEL3..0 = 0111 SUT1..0 = 10 - (unprogram) CKDIV8 = 1 -> default: 0b01100010 = 0x62 neu: 0b11100111 = 0xe7 lock byte: SPM is not allowed to write to the Boot Loader section BLB12 = 1 BLB11 = 0 -> default: 0b111111 = 0x3f new: 0b101111 = 0x2f
