Der Sketch verwendet 2.580 Bytes (31%) des Programmspeicherplatzes. Das Maximum sind 8.192 Bytes. Globale Variablen verwenden 158 Bytes des dynamischen Speichers. D:\Programme\Arduino\hardware\tools\avr/bin/avrdude -CD:\Programme\Arduino\hardware\tools\avr/etc/avrdude.conf -v -pattiny84 -cstk500v1 -PCOM18 -b19200 -Uflash:w:C:\Windows\TEMP\build29be726e8adfdce07fcfa56b8772cd26.tmp/Test_Software_Serial_ATtiny84.ino.hex:i avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "D:\Programme\Arduino\hardware\tools\avr/etc/avrdude.conf" Using Port : COM18 Using Programmer : stk500v1 Overriding Baud Rate : 19200 AVR Part : ATtiny84 Chip Erase delay : 4500 us PAGEL : P00 BS2 : P00 RESET disposition : possible i/o RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 6 4 0 no 512 4 0 4000 4500 0xff 0xff flash 65 6 32 0 yes 8192 64 128 4500 4500 0xff 0xff signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Programmer Type : STK500 Description : Atmel STK500 Version 1.x firmware Hardware Version: 2 Firmware Version: 1.18 Topcard : Unknown Vtarget : 0.0 V Varef : 0.0 V Oscillator : Off SCK period : 0.1 us avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.02s avrdude: Device signature = 0x1e930c avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "C:\Windows\TEMP\build29be726e8adfdce07fcfa56b8772cd26.tmp/Test_Software_Serial_ATtiny84.ino.hex" avrdude: writing flash (2580 bytes): Writing | ################################################## | 100% 4.00s avrdude: 2580 bytes of flash written avrdude: verifying flash memory against C:\Windows\TEMP\build29be726e8adfdce07fcfa56b8772cd26.tmp/Test_Software_Serial_ATtiny84.ino.hex: avrdude: load data flash data from input file C:\Windows\TEMP\build29be726e8adfdce07fcfa56b8772cd26.tmp/Test_Software_Serial_ATtiny84.ino.hex: avrdude: input file C:\Windows\TEMP\build29be726e8adfdce07fcfa56b8772cd26.tmp/Test_Software_Serial_ATtiny84.ino.hex contains 2580 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 2.03s avrdude: verifying ... avrdude: 2580 bytes of flash verified avrdude done. Thank you.
