**** Build of configuration Release for project MagicQuartz **** make all Building file: ../lcd_drv.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"lcd_drv.d" -MT"lcd_drv.d" -c -o "lcd_drv.o" "../lcd_drv.c" Finished building: ../lcd_drv.c Building file: ../main.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c" ../main.c: In function 'ADC_Init': ../main.c:788:15: warning: variable 'result' set but not used [-Wunused-but-set-variable] unsigned int result; ^ ../main.c: In function 'liveQuartzMenu': ../main.c:2842:16: warning: variable 'currentSelection' set but not used [-Wunused-but-set-variable] unsigned char currentSelection = 0; ^ Finished building: ../main.c Building target: MagicQuartz.elf Invoking: AVR C++ Linker avr-g++ -lc -lm -Wl,-Map,MagicQuartz.map,--cref -L"/Users/sebmate/workspace-avr/MagicQuartz" -mmcu=atmega328p -o"MagicQuartz.elf" ./lcd_drv.o ./main.o -lc Finished building target: MagicQuartz.elf Invoking: AVR Create Extended Listing avr-objdump -h -S MagicQuartz.elf >"MagicQuartz.lss" Finished building: MagicQuartz.lss Create Flash image (ihex format) avr-objcopy -R .eeprom -O ihex MagicQuartz.elf "MagicQuartz.hex" Finished building: MagicQuartz.hex Create eeprom image (ihex format) avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex MagicQuartz.elf "MagicQuartz.eep" Finished building: MagicQuartz.eep Invoking: Print Size avr-size --format=avr --mcu=atmega328p MagicQuartz.elf AVR Memory Usage ---------------- Device: atmega328p Program: 31168 bytes (95.1% Full) (.text + .data + .bootloader) Data: 1872 bytes (91.4% Full) (.data + .bss + .noinit) Finished building: sizedummy **** Build Finished **** **** Build of configuration Release for project MagicQuartz **** make all Building file: ../lcd_drv.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"lcd_drv.d" -MT"lcd_drv.d" -c -o "lcd_drv.o" "../lcd_drv.c" Finished building: ../lcd_drv.c Building file: ../main.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c" ../main.c: In function 'ADC_Init': ../main.c:788:15: warning: variable 'result' set but not used [-Wunused-but-set-variable] unsigned int result; ^ ../main.c: In function 'liveQuartzMenu': ../main.c:2842:16: warning: variable 'currentSelection' set but not used [-Wunused-but-set-variable] unsigned char currentSelection = 0; ^ Finished building: ../main.c Building target: MagicQuartz.elf Invoking: AVR C++ Linker avr-g++ -lc -lm -Wl,-Map,MagicQuartz.map,--cref -L"/Users/sebmate/workspace-avr/MagicQuartz" -mmcu=atmega328p -o"MagicQuartz.elf" ./lcd_drv.o ./main.o -lc Finished building target: MagicQuartz.elf Invoking: AVR Create Extended Listing avr-objdump -h -S MagicQuartz.elf >"MagicQuartz.lss" Finished building: MagicQuartz.lss Create Flash image (ihex format) avr-objcopy -R .eeprom -O ihex MagicQuartz.elf "MagicQuartz.hex" Finished building: MagicQuartz.hex Create eeprom image (ihex format) avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex MagicQuartz.elf "MagicQuartz.eep" Finished building: MagicQuartz.eep Invoking: Print Size avr-size --format=avr --mcu=atmega328p MagicQuartz.elf AVR Memory Usage ---------------- Device: atmega328p Program: 31168 bytes (95.1% Full) (.text + .data + .bootloader) Data: 1872 bytes (91.4% Full) (.data + .bss + .noinit) Finished building: sizedummy **** Build Finished ****
