**** Build of configuration Release for project MagicQuartz **** make all Building file: ../lcd_drv.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"lcd_drv.d" -MT"lcd_drv.d" -c -o "lcd_drv.o" "../lcd_drv.c" Finished building: ../lcd_drv.c Building file: ../main.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c" Finished building: ../main.c Building target: MagicQuartz.elf Invoking: AVR C++ Linker avr-g++ -lc -lm -Wl,-Map,MagicQuartz.map,--cref -mrelax -Wl,--gc-sections -L"/Users/sebmate/workspace-avr/MagicQuartz" -mmcu=atmega328p -o"MagicQuartz.elf" ./lcd_drv.o ./main.o -lc Finished building target: MagicQuartz.elf Invoking: AVR Create Extended Listing avr-objdump -h -S MagicQuartz.elf >"MagicQuartz.lss" Finished building: MagicQuartz.lss Create Flash image (ihex format) avr-objcopy -R .eeprom -R .fuse -R .lock -R .signature -O ihex MagicQuartz.elf "MagicQuartz.hex" Finished building: MagicQuartz.hex Create eeprom image (ihex format) avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex MagicQuartz.elf "MagicQuartz.eep" Finished building: MagicQuartz.eep Invoking: Print Size avr-size --format=avr --mcu=atmega328p MagicQuartz.elf AVR Memory Usage ---------------- Device: atmega328p Program: 31300 bytes (95.5% Full) (.text + .data + .bootloader) Data: 1841 bytes (89.9% Full) (.data + .bss + .noinit) Finished building: sizedummy **** Build Finished **** **** Build of configuration Release for project MagicQuartz **** make all Building file: ../lcd_drv.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -v -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"lcd_drv.d" -MT"lcd_drv.d" -c -o "lcd_drv.o" "../lcd_drv.c" Using built-in specs. COLLECT_GCC=avr-gcc COLLECT_LTO_WRAPPER=/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/lto-wrapper Target: avr Configured with: ../configure --prefix=/usr/local/CrossPack-AVR-20120217 --disable-dependency-tracking --disable-nls --disable-werror --target=avr --enable-languages=c,c++ --disable-libssp --with-dwarf2 --with-gmp=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math --with-mpfr=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math --with-mpc=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math Thread model: single gcc version 4.5.1 (GCC) COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFlcd_drv.d' '-MTlcd_drv.d' '-c' '-o' 'lcd_drv.o' /usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/cc1 -quiet -v -imultilib avr5 -MMD lcd_drv.d -MFlcd_drv.d -MP -MTlcd_drv.d -MQ lcd_drv.o -dD -DF_CPU=16000000UL ../lcd_drv.c -quiet -dumpbase lcd_drv.c -mmcu=atmega328p -auxbase-strip lcd_drv.o -g3 -gstabs -Os -Wall -std=gnu99 -version -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -funsigned-char -funsigned-bitfields -o /var/folders/cy/yvgv3jcd7_586vts17nj45700000gn/T//ccnOir1G.s GNU C (GCC) version 4.5.1 (avr) compiled by GNU C version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00), GMP version 4.3.2, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/sys-include" #include "..." search starts here: #include <...> search starts here: /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/include /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/include-fixed /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/include End of search list. GNU C (GCC) version 4.5.1 (avr) compiled by GNU C version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00), GMP version 4.3.2, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: e419f279c3c0557e2b9395d49257cc00 COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFlcd_drv.d' '-MTlcd_drv.d' '-c' '-o' 'lcd_drv.o' Finished building: ../lcd_drv.c Building file: ../main.c Invoking: AVR Compiler avr-gcc -Wall -g3 -gstabs -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -v -mmcu=atmega328p -DF_CPU=16000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c" /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/bin/as -mmcu=atmega328p -o lcd_drv.o /var/folders/cy/yvgv3jcd7_586vts17nj45700000gn/T//ccnOir1G.s COMPILER_PATH=/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/bin/ LIBRARY_PATH=/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/avr5/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/lib/avr5/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFlcd_drv.d' '-MTlcd_drv.d' '-c' '-o' 'lcd_drv.o' Using built-in specs. COLLECT_GCC=avr-gcc COLLECT_LTO_WRAPPER=/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/lto-wrapper Target: avr Configured with: ../configure --prefix=/usr/local/CrossPack-AVR-20120217 --disable-dependency-tracking --disable-nls --disable-werror --target=avr --enable-languages=c,c++ --disable-libssp --with-dwarf2 --with-gmp=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math --with-mpfr=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math --with-mpc=/Users/cs/Developer/Repos/Microcontroller/CrossPack-AVR/math Thread model: single gcc version 4.5.1 (GCC) COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFmain.d' '-MTmain.d' '-c' '-o' 'main.o' /usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/cc1 -quiet -v -imultilib avr5 -MMD main.d -MFmain.d -MP -MTmain.d -MQ main.o -dD -DF_CPU=16000000UL ../main.c -quiet -dumpbase main.c -mmcu=atmega328p -auxbase-strip main.o -g3 -gstabs -Os -Wall -std=gnu99 -version -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -funsigned-char -funsigned-bitfields -o /var/folders/cy/yvgv3jcd7_586vts17nj45700000gn/T//ccN5m6Dh.s GNU C (GCC) version 4.5.1 (avr) compiled by GNU C version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00), GMP version 4.3.2, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/sys-include" #include "..." search starts here: #include <...> search starts here: /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/include /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/include-fixed /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/include End of search list. GNU C (GCC) version 4.5.1 (avr) compiled by GNU C version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.1.00), GMP version 4.3.2, MPFR version 3.1.0, MPC version 0.9 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: e419f279c3c0557e2b9395d49257cc00 COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFmain.d' '-MTmain.d' '-c' '-o' 'main.o' /usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/bin/as -mmcu=atmega328p -o main.o /var/folders/cy/yvgv3jcd7_586vts17nj45700000gn/T//ccN5m6Dh.s Finished building: ../main.c Building target: MagicQuartz.elf Invoking: AVR C++ Linker avr-g++ -lc -lm -Wl,-Map,MagicQuartz.map,--cref -mrelax -Wl,--gc-sections -L"/Users/sebmate/workspace-avr/MagicQuartz" -mmcu=atmega328p -o"MagicQuartz.elf" ./lcd_drv.o ./main.o -lc COMPILER_PATH=/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/libexec/gcc/avr/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/bin/ Finished building target: MagicQuartz.elf Invoking: AVR Create Extended Listing avr-objdump -h -S MagicQuartz.elf >"MagicQuartz.lss" LIBRARY_PATH=/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/avr5/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/lib/avr5/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/:/usr/local/CrossPack-AVR-20120217/lib/gcc/avr/4.5.1/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-Wall' '-g3' '-gstabs' '-Os' '-fpack-struct' '-fshort-enums' '-ffunction-sections' '-fdata-sections' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-v' '-mmcu=atmega328p' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFmain.d' '-MTmain.d' '-c' '-o' 'main.o' Finished building: MagicQuartz.lss Create Flash image (ihex format) avr-objcopy -R .eeprom -R .fuse -R .lock -R .signature -O ihex MagicQuartz.elf "MagicQuartz.hex" Finished building: MagicQuartz.hex Create eeprom image (ihex format) avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex MagicQuartz.elf "MagicQuartz.eep" Finished building: MagicQuartz.eep Invoking: Print Size avr-size --format=avr --mcu=atmega328p MagicQuartz.elf AVR Memory Usage ---------------- Device: atmega328p Program: 31300 bytes (95.5% Full) (.text + .data + .bootloader) Data: 1841 bytes (89.9% Full) (.data + .bss + .noinit) Finished building: sizedummy **** Build Finished ****
