Version 4 SHEET 1 1860 680 WIRE 1312 -608 848 -608 WIRE -384 -560 -464 -560 WIRE -80 -560 -304 -560 WIRE 240 -560 240 -576 WIRE 240 -560 128 -560 WIRE 512 -560 240 -560 WIRE 736 -528 656 -528 WIRE 800 -528 736 -528 WIRE 848 -528 848 -608 WIRE 848 -528 800 -528 WIRE 1056 -528 1024 -528 WIRE 1312 -528 1312 -608 WIRE 1312 -528 1280 -528 WIRE 1344 -528 1312 -528 WIRE 1776 -528 1568 -528 WIRE -80 -496 -80 -560 WIRE 128 -496 128 -560 WIRE 128 -496 -80 -496 WIRE 240 -496 240 -560 WIRE 368 -496 336 -496 WIRE 512 -496 448 -496 WIRE 1776 -496 1776 -528 WIRE -464 -480 -464 -560 WIRE 848 -464 848 -528 WIRE 1056 -464 1056 -528 WIRE 1120 -464 1056 -464 WIRE 1280 -464 1280 -528 WIRE 1280 -464 1200 -464 WIRE 1344 -464 1344 -528 WIRE 1568 -464 1568 -528 WIRE 1568 -464 1344 -464 WIRE 128 -416 -80 -416 WIRE 240 -400 240 -416 WIRE 1568 -384 944 -384 WIRE 1776 -384 1776 -432 WIRE 944 -368 944 -384 WIRE -464 -336 -464 -400 WIRE -80 -336 -80 -416 WIRE -80 -336 -464 -336 WIRE 128 -336 128 -416 WIRE 240 -336 128 -336 WIRE 336 -272 336 -496 WIRE 736 -272 736 -528 WIRE 736 -272 336 -272 WIRE 848 -272 848 -384 WIRE 1568 -272 1568 -384 WIRE 1776 -272 1776 -304 WIRE 1776 -272 1568 -272 WIRE -784 -240 -784 -272 WIRE -624 -240 -624 -272 WIRE -784 -112 -784 -160 WIRE -624 -112 -624 -160 FLAG -624 -112 0 FLAG -784 -112 0 FLAG -624 -272 -15V FLAG -784 -272 +15V FLAG 544 -608 -15V FLAG 544 -448 +15V FLAG 800 -528 out FLAG 240 -576 in1 FLAG 240 -400 0 FLAG 240 -336 0 FLAG 1024 -528 0 FLAG 944 -368 0 FLAG 848 -272 0 SYMBOL Opamps\\LT1210 544 -528 M180 SYMATTR InstName U1 SYMBOL voltage -784 -256 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V1 SYMATTR Value 15 SYMBOL voltage -624 -144 R180 WINDOW 0 24 96 Left 2 WINDOW 3 24 16 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V2 SYMATTR Value 15 SYMBOL res 832 -480 R0 SYMATTR InstName R4 SYMATTR Value 100 SYMBOL res 1760 -400 R0 SYMATTR InstName R6 SYMATTR Value 50 SYMBOL res 224 -512 R0 SYMATTR InstName R1 SYMATTR Value 50 SYMBOL res 464 -512 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R3 SYMATTR Value {Rx} SYMBOL diode 1760 -496 R0 SYMATTR InstName D1 SYMBOL res -288 -576 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R_50 SYMATTR Value 50 SYMBOL voltage -464 -496 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V3 SYMATTR Value PULSE(0 -2 0 2.5n 2.5n 50n) SYMBOL res 1104 -448 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R2 SYMATTR Value 50 TEXT 1624 -576 Left 2 ;Extern (Meßgrät) TEXT -504 -648 Left 2 ;Signalgenerator TEXT -816 -56 Left 2 !.tran 250n TEXT -816 -440 Left 4 ;LTspiceXVII TEXT 376 -320 Left 2 !.step param Rx 300 1k 100 TEXT -32 -544 Left 2 ;Koaxleitung\n50 Ohm TEXT 1408 -512 Left 2 ;Koaxleitung\n50 Ohm TEXT 1104 -528 Left 2 ;Abschluss TEXT 1272 -424 Left 2 ;T-Stück TEXT 200 -400 VLeft 2 ;Abschluss TEXT 456 -712 Left 2 ;Verstärkerstufe / Buffer LINE Normal 1584 -240 1584 -560 2 LINE Normal 1856 -240 1584 -240 2 LINE Normal 1856 -560 1856 -240 2 LINE Normal 1584 -560 1856 -560 2 LINE Normal 1584 -560 1584 -560 2 RECTANGLE Normal -128 -304 -528 -624 2 RECTANGLE Normal 112 -304 -64 -624 2 RECTANGLE Normal 1248 -416 992 -560 2 RECTANGLE Normal 1552 -240 1376 -560 2 RECTANGLE Normal 1264 -240 1360 -560 2 RECTANGLE Normal 976 -208 160 -688 2
