#include #include #include "app/factory.h" using namespace QP; void delay(int counter); void delay(int counter) { uint16_t del = 0; for(del = 0; del < counter ; del ++) { for(uint16_t del_counter = 0 ; del_counter < 1680 ; del_counter ++){/*NOP*/} } } int main() { //===================================================================================================== // Initialisation //===================================================================================================== BSP_init(); // Initialize board specific stuff QF::init(); // Initialize execution framework factory.build(); // Construct, initialize application //===================================================================================================== //Definition of the Variables //===================================================================================================== uint16_t buttonsState; int VarSenkrecht = 0; int VarWaagrecht = 0; int keyLock = 0; int var_tast9 = 0; int var_tast8 = 0; int var_tast7 = 0; int var_tast6 = 0; int var_tast5 = 0; int var_tast4 = 0; int var_tast3 = 0; int var_tast2 = 0; int var_tast1 = 0; int var_taste = 0; //===================================================================================================== // keyboard request //===================================================================================================== while (true) { do { switch(VarWaagrecht) { case 0: factory.buttonController().Taster4(true); factory.buttonController().Taster1(false); break; case 1: factory.buttonController().Taster1(true); factory.buttonController().Taster2(false); break; case 2: factory.buttonController().Taster2(true); factory.buttonController().Taster3(false); break; case 3: factory.buttonController().Taster3(true); factory.buttonController().Taster4(false); break; } delay(100); buttonsState = factory.buttonController().readButtonsValue(); VarSenkrecht = (buttonsState & 0xF0); //===================================================================================================== // which Button is pressed? //===================================================================================================== if(keyLock == 0) { switch(VarWaagrecht) { case 0: switch(VarSenkrecht) { case 16: keyLock = 1; factory.ledController().myLed7(true); var_taste = 13; break; case 32: keyLock = 1; factory.ledController().myLed7(false); var_taste = 14; break; case 64: keyLock = 1; factory.ledController().myLed7(true); var_taste = 15; break; case 128: keyLock = 1; factory.ledController().myLed7(false); var_taste = 16; break; } break; case 1: switch(VarSenkrecht) { case 16: keyLock = 1; factory.ledController().myLed7(true); var_taste = 9; break; case 32: keyLock = 1; factory.ledController().myLed7(false); var_taste = 10; break; case 64: keyLock = 1; factory.ledController().myLed7(true); var_taste = 11; break; case 128: keyLock = 1; factory.ledController().myLed7(false); var_taste = 12; break; } break; case 2: switch(VarSenkrecht) { case 16: keyLock = 1; factory.ledController().myLed7(true); var_taste = 1; break; case 32: keyLock = 1; factory.ledController().myLed7(false); var_taste = 2; break; case 64: keyLock = 1; factory.ledController().myLed7(true); var_taste = 3; break; case 128: keyLock = 1; factory.ledController().myLed7(false); var_taste = 4; break; } break; case 3: switch(VarSenkrecht) { case 16: keyLock = 1; factory.ledController().myLed7(true); var_taste = 5; break; case 32: keyLock = 1; factory.ledController().myLed7(false); var_taste = 6; break; case 64: keyLock = 1; factory.ledController().myLed7(true); var_taste = 7; break; case 128: keyLock = 1; factory.ledController().myLed7(false); var_taste = 8; break; } break; } } delay(100); if((keyLock == 1) && ((buttonsState & 0xF0)==0)) { keyLock = 0; } VarWaagrecht++; if(VarWaagrecht == 0x04) { VarWaagrecht = 0; } //===================================================================================================== // PIN correct? //===================================================================================================== if(var_taste > 0) { var_tast9 = var_tast8; var_tast8 = var_tast7; var_tast7 = var_tast6; var_tast6 = var_tast5; var_tast5 = var_tast4; var_tast4 = var_tast3; var_tast3 = var_tast2; var_tast2 = var_tast1; var_tast1 = var_taste; var_taste = 0; } // überprüfen des ersten Codes //if((var_tast1 == 9) && (var_tast2 == 8) && (var_tast3 == 7) &&(var_tast4 == 6) && (var_tast5 == 5) &&(var_tast6 == 4) &&(var_tast7 == 3) && (var_tast8 == 2)&& (var_tast9 == 1)) if((var_tast1 == 3) && (var_tast2 == 2)) {// zurücksetzten aller Eingaben var_tast9 = 0; var_tast8 = 0; var_tast7 = 0; var_tast6 = 0; var_tast5 = 0; var_tast4 = 0; var_tast3 = 0; var_tast2 = 0; var_tast1 = 0; factory.ledController().myLed6(false); } //=========================================================================================== } while(1); } QF::run(); // Run execution framework return 0; }
