CPU-Z TXT Report ------------------------------------------------------------------------- Binaries ------------------------------------------------------------------------- CPU-Z version 1.73.0.x64 Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 4 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 -- Core 2 -- Thread 0 2 -- Core 3 -- Thread 0 3 Timers ------------------------------------------------------------------------- ACPI timer 3.580 MHz HPET timer 14.318 MHz Perf timer 3.412 MHz Sys timer 1.000 KHz Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 4 (max 4) Number of threads 4 (max 4) Name AMD A8-6500 Codename Richland Specification AMD A8-6500 APU with Radeon(tm) HD Graphics CPU ************* Package Socket FM2 (904) CPUID F.3.1 Extended CPUID 15.13 Core Stepping RL-A1 Technology 32 nm TDP Limit 65.3 Watts Core Speed 3892.1 MHz Multiplier x Bus Speed 39.0 x 99.8 MHz Stock frequency 3500 MHz Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4 L1 Data cache 4 x 16 KBytes, 4-way set associative, 64-byte line size L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size L2 cache 2 x 2048 KBytes, 16-way set associative, 64-byte line size FID/VID Control yes Min FID 8.5x # of P-States 8 P-State FID 0x19 - VID 0x1A - IDD 17 (20.50x - 1.387 V) P-State FID 0x17 - VID 0x1E - IDD 19 (19.50x - 1.362 V) P-State FID 0x15 - VID 0x2E - IDD 16 (18.50x - 1.262 V) P-State FID 0x13 - VID 0x38 - IDD 12 (17.50x - 1.200 V) P-State FID 0x10 - VID 0x42 - IDD 10 (16.00x - 1.137 V) P-State FID 0xB - VID 0x4C - IDD 8 (13.50x - 1.075 V) P-State FID 0x6 - VID 0x5E - IDD 6 (11.00x - 0.962 V) P-State FID 0x1 - VID 0x70 - IDD 4 (8.50x - 0.850 V) PStateReg 0x800001A6-0x00003419 PStateReg 0x800001BF-0x00003C17 PStateReg 0x8000019D-0x00005C15 PStateReg 0x80000176-0x00007013 PStateReg 0x80000164-0x00008410 PStateReg 0x8000014F-0x0000980B PStateReg 0x80000137-0x0000BC06 PStateReg 0x80000123-0x0040E001 Package Type 0x2 Model 00 String 1 0x0 String 2 0x0 Page 0x0 Base TDP 0 Watts Boosted P-States 3 Max non-turbo ratio 35.00x Max turbo ratio 41.00x TSC 3493.6 MHz APERF 3878.0 MHz MPERF 3493.3 MHz Attached device PCI device at bus 0, device 24, function 0 100 00000000 00000000 00000000 00000000 110 0000000C 00000000 00000000 00000000 120 00000000 00000000 00000000 00000000 130 00000000 00000000 00000000 00000000 140 00000000 00000000 00000000 00000000 150 00000000 00000000 00000000 00000000 160 00000000 00000000 00000800 0074003A 170 00000001 00000000 00000000 00000000 180 00000000 00000000 00000000 00000000 190 00000000 00000000 00000000 00000000 1A0 80000003 00000000 00000000 00000000 1B0 00000000 00000000 00000000 00000000 1C0 00000000 00000000 00000000 00000000 1D0 00000000 00000000 00000000 0000000E 1E0 00000000 00000000 00000000 00000000 1F0 00000000 00000000 00000000 00000000 Attached device PCI device at bus 0, device 24, function 1 100 00000000 00000000 00000000 00000000 110 00000000 00000000 00000000 00000000 120 00000000 00000043 00000000 00000000 130 00000000 00000000 00000000 00000000 140 00000000 00000000 00000000 00000000 150 00000000 00000000 00000000 00000000 160 00000000 00000000 00000000 00000000 170 00000000 00000000 00000000 00000000 180 00000000 00000000 00000000 00000000 190 00000000 00000000 00000000 00000000 1A0 00000000 00000000 00000000 00000000 1B0 00000000 00000000 00000000 00000000 1C0 00000000 00000000 00000000 00000000 1D0 00000000 00000000 00000000 00000000 1E0 00000000 00000000 00000000 00000000 1F0 00000000 00000000 00000000 00000000 Attached device PCI device at bus 0, device 24, function 2 100 00000000 00000000 00000000 00000000 110 00000100 00000000 0C4CA424 0CE00F31 120 00FB2FF7 00000000 00000000 00000000 130 FED37ED3 FB376667 7F8D55DB 997F1D2C 140 00000001 00000000 00000000 00000000 150 00000000 00000000 00000000 00000000 160 01F8FFE0 00000000 00000000 00000000 170 00000000 00000000 00020000 18080058 180 0000000B 00800005 3D000000 00020000 190 03010000 9F490892 8D0F812F 000000A1 1A0 031D0380 00000000 80320000 00000000 1B0 0FC39801 4C0F7D26 00000000 00000000 1C0 00000000 00000000 00000000 00000000 1D0 00000000 00000000 00000000 00000000 1E0 00000000 00000000 00000000 00000000 1F0 00000000 00000000 00000000 00000000 Attached device PCI device at bus 0, device 24, function 3 100 00000000 00000000 00000000 00000000 110 00000000 00000000 00000000 00000000 120 00000000 00000000 00000000 00000000 130 00000000 00000000 00000000 00000000 140 00A11555 00000077 0000052A 00000000 150 00000000 00000000 00000000 00000000 160 C00A0FFF 00000000 C00A0FFF 00000000 170 00000000 00000000 00000000 00000004 180 017003E0 00000000 08000010 00000000 190 00000000 00000000 04000000 00000000 1A0 00034182 00000000 00000000 00000000 1B0 00000000 00000000 00000000 00000000 1C0 00000000 00000000 00000000 00000100 1D0 00000000 00000000 00000000 00000000 1E0 00000000 80001385 00000000 00000000 1F0 00080000 00000000 00000000 090E074F Attached device PCI device at bus 0, device 24, function 4 100 00000000 00000000 00000000 00FE0045 110 000C2002 00000000 1907190B 00000000 120 00000000 00000000 801C0280 00000000 130 00000000 00000000 00000000 00000001 140 156E1A6D 000321CE 1F96AC77 0003E317 150 38380838 22222222 000000FE 8000008D 160 00610F01 00000000 00000000 00000276 170 00000000 00000000 00000000 00000000 180 00000000 00000000 00000000 00000000 190 00000000 00000000 00000000 00000000 1A0 00000000 00000000 00000000 00000000 1B0 00000000 00000000 000000CD 00000000 1C0 00000000 00000000 00000000 00000000 1D0 00000000 00000000 00000000 00000000 1E0 0B4C3419 0B7E3C17 0B3A5C15 0AEC7013 1F0 0AC88410 0A9E980B 0A6EBC06 0A47E001 Attached device PCI device at bus 0, device 24, function 5 100 00000000 00000000 00000000 00000000 110 00000000 00000000 00000000 00000000 120 00000011 00000000 0060DF38 0000002E 130 00000000 00000000 00000000 00000000 140 00000000 00000000 00000000 00000000 150 00000000 00000000 01240047 0139002C 160 2900F819 29010017 22010815 97457099 170 0000049B 011AC262 00060C04 AE02E016 180 00000000 00000000 0000004D 00000000 190 00000000 0000000B 00202020 00000000 1A0 00000000 00000000 00000000 00000000 1B0 00000000 00000000 00000000 00000000 1C0 00000000 00000000 00000000 00000000 1D0 00000000 00000000 00000000 00000000 1E0 00000000 00000000 00000000 00000000 1F0 00000000 00000000 00000000 00000000 Temperature 1 90°C (193°F) [0x59] (Package) Power 0 55.85 W (Cores) Power 1 17.89 W (Uncore) Power 2 73.75 W (Package) Voltage 0 1.32 Volts (Cores) Voltage 1 1.22 Volts (Uncore) Current 0 42.35 Amps (Cores) Current 1 14.68 Amps (Uncore) Thread dumps ------------------------------------------------------------------------- CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 0204000Ah Max CPUID level 0000000Dh Max CPUID ext. level 8000001Eh Cache descriptor Level 1, D, 16 KB, 1 thread(s) Cache descriptor Level 1, I, 64 KB, 2 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID 0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00610F31 0x00040800 0x3E98320B 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x00000007 0x00000000 0x00000008 0x00000000 0x00000000 0x00000008 0x00000000 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000 0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00610F31 0x20000000 0x01EBBFFF 0x2FD3FBFF 0x80000002 0x20444D41 0x362D3841 0x20303035 0x20555041 0x80000003 0x68746977 0x64615220 0x286E6F65 0x20296D74 0x80000004 0x47204448 0x68706172 0x20736369 0x00202020 0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140 0x80000006 0x64006400 0x64004200 0x08008140 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9 0x80000008 0x00003030 0x00000000 0x00004003 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000 0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F 0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000 0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000 0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001 0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00900 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000040 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000000 MSR 0xC0010064 0x800001A6 0x00003419 MSR 0xC0010065 0x800001BF 0x00003C17 MSR 0xC0010066 0x8000019D 0x00005C15 MSR 0xC0010067 0x80000176 0x00007013 MSR 0xC0010068 0x80000164 0x00008410 MSR 0xC0010058 0x00000000 0xF0000019 MSR 0xC0010015 0x00000000 0x09001011 MSR 0xC001001F 0x00404000 0x00810000 MSR 0xC0010071 0x81520006 0x2C413C17 MSR 0xC0010070 0x00000000 0x44013C17 CPU Thread 1 APIC ID 1 Topology Processor ID 0, Core ID 1, Thread ID 0 Type 0204000Ah Max CPUID level 0000000Dh Max CPUID ext. level 8000001Eh Cache descriptor Level 1, D, 16 KB, 1 thread(s) Cache descriptor Level 1, I, 64 KB, 2 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID 0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00610F31 0x01040800 0x3E98320B 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x00000007 0x00000000 0x00000008 0x00000000 0x00000000 0x00000008 0x00000000 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000 0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00610F31 0x20000000 0x01EBBFFF 0x2FD3FBFF 0x80000002 0x20444D41 0x362D3841 0x20303035 0x20555041 0x80000003 0x68746977 0x64615220 0x286E6F65 0x20296D74 0x80000004 0x47204448 0x68706172 0x20736369 0x00202020 0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140 0x80000006 0x64006400 0x64004200 0x08008140 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9 0x80000008 0x00003030 0x00000000 0x00004003 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000 0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F 0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000 0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000 0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001 0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000040 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000000 MSR 0xC0010064 0x800001A6 0x00003419 MSR 0xC0010065 0x800001BF 0x00003C17 MSR 0xC0010066 0x8000019D 0x00005C15 MSR 0xC0010067 0x80000176 0x00007013 MSR 0xC0010068 0x80000164 0x00008410 MSR 0xC0010058 0x00000000 0xF0000019 MSR 0xC0010015 0x00000000 0x09001011 MSR 0xC001001F 0x00404000 0x00810000 MSR 0xC0010071 0x81520006 0x2C413C17 MSR 0xC0010070 0x00000000 0x44013C17 CPU Thread 2 APIC ID 2 Topology Processor ID 0, Core ID 2, Thread ID 0 Type 0204000Ah Max CPUID level 0000000Dh Max CPUID ext. level 8000001Eh Cache descriptor Level 1, D, 16 KB, 1 thread(s) Cache descriptor Level 1, I, 64 KB, 2 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID 0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00610F31 0x02040800 0x3E98320B 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x00000007 0x00000000 0x00000008 0x00000000 0x00000000 0x00000008 0x00000000 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000 0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00610F31 0x20000000 0x01EBBFFF 0x2FD3FBFF 0x80000002 0x20444D41 0x362D3841 0x20303035 0x20555041 0x80000003 0x68746977 0x64615220 0x286E6F65 0x20296D74 0x80000004 0x47204448 0x68706172 0x20736369 0x00202020 0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140 0x80000006 0x64006400 0x64004200 0x08008140 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9 0x80000008 0x00003030 0x00000000 0x00004003 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000 0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F 0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000 0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000 0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001 0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000040 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000000 MSR 0xC0010064 0x800001A6 0x00003419 MSR 0xC0010065 0x800001BF 0x00003C17 MSR 0xC0010066 0x8000019D 0x00005C15 MSR 0xC0010067 0x80000176 0x00007013 MSR 0xC0010068 0x80000164 0x00008410 MSR 0xC0010058 0x00000000 0xF0000019 MSR 0xC0010015 0x00000000 0x09001011 MSR 0xC001001F 0x00404000 0x00810000 MSR 0xC0010071 0x81520006 0x2C413C17 MSR 0xC0010070 0x00000000 0x44013C17 CPU Thread 3 APIC ID 3 Topology Processor ID 0, Core ID 3, Thread ID 0 Type 0204000Ah Max CPUID level 0000000Dh Max CPUID ext. level 8000001Eh Cache descriptor Level 1, D, 16 KB, 1 thread(s) Cache descriptor Level 1, I, 64 KB, 2 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID 0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65 0x00000001 0x00610F31 0x03040800 0x3E98320B 0x178BFBFF 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00000000 0x00000000 0x00000000 0x00000000 0x00000005 0x00000040 0x00000040 0x00000003 0x00000000 0x00000006 0x00000000 0x00000000 0x00000001 0x00000000 0x00000007 0x00000000 0x00000008 0x00000000 0x00000000 0x00000008 0x00000000 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000 0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65 0x80000001 0x00610F31 0x20000000 0x01EBBFFF 0x2FD3FBFF 0x80000002 0x20444D41 0x362D3841 0x20303035 0x20555041 0x80000003 0x68746977 0x64615220 0x286E6F65 0x20296D74 0x80000004 0x47204448 0x68706172 0x20736369 0x00202020 0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140 0x80000006 0x64006400 0x64004200 0x08008140 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9 0x80000008 0x00003030 0x00000000 0x00004003 0x00000000 0x80000009 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF 0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000 0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000 0x80000010 0x00000000 0x00000000 0x00000000 0x00000000 0x80000011 0x00000000 0x00000000 0x00000000 0x00000000 0x80000012 0x00000000 0x00000000 0x00000000 0x00000000 0x80000013 0x00000000 0x00000000 0x00000000 0x00000000 0x80000014 0x00000000 0x00000000 0x00000000 0x00000000 0x80000015 0x00000000 0x00000000 0x00000000 0x00000000 0x80000016 0x00000000 0x00000000 0x00000000 0x00000000 0x80000017 0x00000000 0x00000000 0x00000000 0x00000000 0x80000018 0x00000000 0x00000000 0x00000000 0x00000000 0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000 0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000 0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000 0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F 0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000 0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000 0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001 0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000 MSR 0x0000001B 0x00000000 0xFEE00800 MSR 0xC0010114 0x00000000 0x00000008 MSR 0xC0010061 0x00000000 0x00000040 MSR 0xC0010062 0x00000000 0x00000000 MSR 0xC0010063 0x00000000 0x00000000 MSR 0xC0010064 0x800001A6 0x00003419 MSR 0xC0010065 0x800001BF 0x00003C17 MSR 0xC0010066 0x8000019D 0x00005C15 MSR 0xC0010067 0x80000176 0x00007013 MSR 0xC0010068 0x80000164 0x00008410 MSR 0xC0010058 0x00000000 0xF0000019 MSR 0xC0010015 0x00000000 0x09001011 MSR 0xC001001F 0x00404000 0x00810000 MSR 0xC0010071 0x81520006 0x2C413C17 MSR 0xC0010070 0x00000000 0x44013C17 Chipset ------------------------------------------------------------------------- Northbridge AMD K15 IMC rev. 00 Southbridge AMD AMD 08 FCH rev. 2.4 Graphic Interface PCI-Express PCI-E Link Width x0 PCI-E Max Link Width x0 Memory Type DDR3 Memory Size 8 GBytes Channels Single Memory Frequency 798.4 MHz (1:8) CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 28 Bank Cycle Time (tRC) 39 Uncore Frequency 798.4 MHz Memory SPD ------------------------------------------------------------------------- DIMM # 1 SMBus address 0x50 Memory type DDR3 Module format UDIMM Manufacturer (ID) (00000000000000000000) Size 8192 MBytes Max bandwidth PC3-12800 (800 MHz) Part number Manufacturing date Week 44/Year 16 Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-16-22 @ 457 MHz JEDEC #2 7.0-7-7-19-26 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-24-33 @ 685 MHz JEDEC #5 10.0-10-10-27-37 @ 761 MHz JEDEC #6 11.0-11-11-28-39 @ 800 MHz DIMM # 1 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 11 0B 02 05 22 00 01 03 11 01 08 0A 00 FC 00 10 69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 83 81 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 07 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 16 44 00 00 00 00 A2 06 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 01 16 59 5A 54 Monitoring ------------------------------------------------------------------------- Mainboard Model A68MD PRO (0x00000251 - 0x0276E64C) LPCIO ------------------------------------------------------------------------- LPCIO Vendor ITE LPCIO Model IT8772 LPCIO Vendor ID 0x90 LPCIO Chip ID 0x8772 LPCIO Revision ID 0x1 Config Mode I/O address 0x2E Config Mode LDN 0x4 Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 87 72 01 00 00 00 0C 00 01 00 00 48 02 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 0A 30 0A 20 00 00 00 00 00 00 00 00 00 00 00 00 70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00 Register space LPC, base address = 0x0A30 Hardware Monitors ------------------------------------------------------------------------- Hardware monitor ITE IT8772 Voltage 0 1.34 Volts [0x70] (CPU VCORE) Voltage 1 1.51 Volts [0x7E] (VIN1) Voltage 2 2.00 Volts [0xA7] (+3.3V) Voltage 3 3.45 Volts [0xAB] (+5V) Voltage 4 4.46 Volts [0x5D] (+12V) Voltage 5 -4.46 Volts [0x5D] (-12V) Voltage 6 -8.88 Volts [0xB9] (-5V) Voltage 7 2.76 Volts [0x89] (+5V VCCH) Voltage 8 1.66 Volts [0x8A] (VBAT) Temperature 0 47°C (116°F) [0x2F] (TMPIN0) Temperature 1 31°C (87°F) [0x1F] (TMPIN1) Temperature 2 40°C (104°F) [0x28] (TMPIN2) Fan 1 1527 RPM [0x1BA] (FANIN1) Fan PWM 0 0 pc [0x0] (FANPWM0) Fan PWM 1 0 pc [0x0] (FANPWM1) Fan PWM 2 0 pc [0x0] (FANPWM2) Register space LPC, base address = 0x0A30 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 13 15 00 00 FF FF FE FF FF FF 48 0F 08 FF BA FF 10 EF 7F 2B 77 C7 00 00 82 FF 01 FF 5F 38 E6 E6 E6 20 70 7E A6 AC 5D 5D B9 89 8A 2F 1F 28 80 0C FF FF 30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 40 5A 55 7F 7F 7F 7F 5F 40 AD 6A D4 00 FF FF FF FF 50 FF 1C 7F 7F 7F 40 00 00 90 00 00 12 60 00 00 00 60 7F 7F 7F FF 00 00 0F FF 7F 7F 7F FF 00 02 00 FF 70 0A 14 46 32 1E 02 00 FF FF FF FF FF FF FF FF FF 80 00 00 00 00 00 00 00 00 00 00 00 00 00 1E C0 0B 90 FF 00 00 00 FF 00 00 00 42 99 00 00 01 95 72 28 A0 A6 EB EB EB EB EB EB FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Hardware monitor AMD ADL Voltage 0 1.27 Volts [0x4FA] (VIN0) Temperature 0 27°C (80°F) [0x1B] (TMPIN0) Clock Speed 0 800.00 MHz [0x320] (Graphics) Clock Speed 1 800.00 MHz [0x320] (Memory) PCI Devices ------------------------------------------------------------------------- Register space PCI Express, base address = 0x0F0000000 Description Host Bridge Location bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x1410 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x1022 Subsystem ID 0x1410 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 10 14 06 00 20 02 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 22 10 10 14 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 02 20 00 00 50 22 10 10 14 00 00 00 00 00 00 00 00 00 00 00 00 60 9D 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 18 00 00 03 00 00 00 00 31 20 00 00 90 00 00 00 E0 4A 01 00 00 00 81 3F 40 00 00 00 00 A0 01 80 30 01 EF BE AD DE 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 80 01 C0 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 46 00 33 01 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00 Description VGA Controller Location bus 0 (0x00), device 1 (0x01), function 0 (0x00) Common header Vendor ID 0x1002 Model ID 0x990E Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x03 Cache Line 0x10 Latency 0x00 Header 0x80 PCI header Address 0 (memory) 0xE0000000 Address 1 (port) 0x0000F000 Address 2 (memory) 0xFEB00000 Subvendor ID 0x1565 Subsystem ID 0x1708 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Complex Integrated Endpoint Device Port 0 Version 2.0 Link width 0x (max 0x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 0E 99 07 04 10 00 00 00 00 03 10 00 80 00 10 08 00 00 E0 01 F0 00 00 00 00 B0 FE 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 08 17 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 65 15 08 17 50 01 58 03 06 00 00 00 00 10 A0 92 00 A0 8F 00 00 60 10 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 00 81 00 0C F0 E0 FE 00 00 00 00 91 49 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Multimedia device Location bus 0 (0x00), device 1 (0x01), function 1 (0x01) Common header Vendor ID 0x1002 Model ID 0x9902 Revision ID 0x00 PI 0x00 SubClass 0x03 BaseClass 0x04 Cache Line 0x10 Latency 0x00 Header 0x80 PCI header Address 0 (memory) 0xFEB44000 Subvendor ID 0x1002 Subsystem ID 0x9902 Int. Line 0x12 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Complex Integrated Endpoint Device Port 0 Version 2.0 Link width 0x (max 0x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 02 99 06 00 10 00 00 00 03 04 10 00 80 00 10 00 40 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 02 99 30 00 00 00 00 50 00 00 00 00 00 00 00 12 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 02 10 02 99 50 01 58 03 06 00 00 00 00 10 A0 92 00 A0 8F 00 00 60 10 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description PCI to PCI Bridge Location bus 0 (0x00), device 4 (0x04), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x1414 Revision ID 0x00 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x10 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x01 Int. Line 0x05 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class PCI Express Caps offset 0x58 Device type Root Port of PCI-E Root Complex Port 1 Version 2.0 Physical slot #0 Presence detect yes Link width 1x (max 1x) PCI capability Caps class Message Signalled Interrupts Caps offset 0xA0 PCI capability Caps class Subsystem Vendor Caps offset 0xB0 SubVendor ID 0x1022 SubSystem ID 0x1234 PCI capability Caps class HyperTransport Caps offset 0xB8 Interface type MSI Mapping Extended capabilities Caps class Vendor Specific Caps offset 0x100 Vendor ID 1 Size 16 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 14 14 07 04 10 00 00 00 04 06 10 00 01 00 10 00 00 00 00 00 00 00 00 00 01 01 00 E1 E1 00 00 20 A0 FE A0 FE 01 E8 01 E8 00 00 00 00 00 00 00 00 30 00 00 00 00 50 00 00 00 00 00 00 00 05 01 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 03 C8 00 00 00 00 10 A0 42 01 21 80 00 00 60 00 28 00 00 12 0C 70 01 40 00 11 70 00 00 04 00 70 00 00 40 00 00 00 01 00 00 00 00 00 1F 00 00 00 80 06 00 00 00 06 00 00 00 02 00 01 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 05 B0 80 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 0D B8 00 00 22 10 34 12 08 00 03 A8 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00 110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller Location bus 0 (0x00), device 16 (0x10), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x7812 Revision ID 0x03 PI 0x30 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x00 Header 0x80 PCI header Address 0 (memory) 0xFEB4A000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class Message Signalled Interrupts Caps offset 0x70 PCI capability Caps class MSI-X Caps offset 0x90 PCI capability Caps class PCI Express Caps offset 0xA0 Device type Root Complex Integrated Endpoint Device Port 0 Version 2.0 Link width 0x (max 0x) Extended capabilities Caps class 0x18 Caps offset 0x100 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 12 78 06 04 10 00 03 30 03 0C 10 00 80 00 10 04 A0 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00 40 00 00 00 00 00 00 00 00 04 00 00 00 11 01 FF 00 50 01 70 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00 A0 10 00 92 00 C0 8F 00 00 00 28 10 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 08 17 80 00 00 00 00 00 00 00 00 00 00 00 00 00 100 18 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller Location bus 0 (0x00), device 16 (0x10), function 1 (0x01) Common header Vendor ID 0x1022 Model ID 0x7812 Revision ID 0x03 PI 0x30 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFEB48000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x00 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.2 PCI capability Caps class Message Signalled Interrupts Caps offset 0x70 PCI capability Caps class MSI-X Caps offset 0x90 PCI capability Caps class PCI Express Caps offset 0xA0 Device type Root Complex Integrated Endpoint Device Port 0 Version 2.0 Link width 0x (max 0x) PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 12 78 06 04 10 00 03 30 03 0C 10 00 00 00 10 04 80 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 50 00 00 00 00 00 00 00 00 02 00 00 40 00 00 00 00 00 00 00 00 04 00 00 00 11 01 FF 00 50 01 70 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00 A0 10 00 92 00 C0 8F 00 00 00 28 10 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 08 17 80 00 00 00 00 00 00 00 00 00 00 00 00 00 100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Serial ATA Controller Location bus 0 (0x00), device 17 (0x11), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x7801 Revision ID 0x40 PI 0x01 SubClass 0x06 BaseClass 0x01 Cache Line 0x00 Latency 0x20 Header 0x00 PCI header Address 0 (port) 0x0000F140 Address 1 (port) 0x0000F130 Address 2 (port) 0x0000F120 Address 3 (port) 0x0000F110 Address 4 (port) 0x0000F100 Address 5 (memory) 0xFEB51000 Subvendor ID 0x1565 Subsystem ID 0x550B Int. Line 0x13 Int. Pin 0x01 PCI capability Caps class Message Signalled Interrupts Caps offset 0x50 PCI capability Caps class 0x12 Caps offset 0x70 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 01 78 07 00 30 02 40 01 06 01 00 20 00 00 10 41 F1 00 00 31 F1 00 00 21 F1 00 00 11 F1 00 00 20 01 F1 00 00 00 10 B5 FE 00 00 00 00 65 15 0B 55 30 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00 40 10 00 C0 00 01 00 20 00 40 08 00 C0 00 00 34 FC 50 05 70 86 00 00 00 00 00 00 00 00 00 00 00 00 00 60 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00 70 12 00 10 00 0F 00 00 00 18 01 00 00 17 68 00 04 80 10 00 00 00 06 00 14 00 AB 01 08 00 F0 00 00 00 90 27 60 74 C7 07 00 FF 01 01 41 17 00 20 01 00 00 A0 3D 58 01 08 0C 00 00 00 0D 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 10 00 00 FF 00 00 00 00 D0 13 00 06 03 00 00 64 00 00 00 00 00 00 00 00 00 E0 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller (OHCI) Location bus 0 (0x00), device 18 (0x12), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x7807 Revision ID 0x11 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x20 Header 0x80 PCI header Address 0 (memory) 0xFEB50000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x12 Int. Pin 0x01 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 07 78 06 00 A0 02 11 10 03 0C 10 20 80 00 10 00 00 B5 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 03 D8 F0 00 00 00 00 FF FF FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 BB 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 18 (0x12), function 2 (0x02) Common header Vendor ID 0x1022 Model ID 0x7808 Revision ID 0x11 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xFEB4F000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x11 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0xC0 Caps version 1.1 PCI capability Caps class Debug Port Caps offset 0xE4 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 08 78 06 00 B0 02 11 20 03 0C 10 20 00 00 10 00 F0 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 40 11 2A A6 7B AA 0F 00 00 00 00 00 00 00 00 00 60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 A0 01 00 00 01 00 20 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller (OHCI) Location bus 0 (0x00), device 19 (0x13), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x7807 Revision ID 0x11 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x20 Header 0x80 PCI header Address 0 (memory) 0xFEB4E000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x12 Int. Pin 0x01 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 07 78 06 00 A0 02 11 10 03 0C 10 20 80 00 10 00 E0 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 03 D8 F0 00 00 00 00 FF FF FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 BB 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 19 (0x13), function 2 (0x02) Common header Vendor ID 0x1022 Model ID 0x7808 Revision ID 0x11 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xFEB4D000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x11 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0xC0 Caps version 1.1 PCI capability Caps class Debug Port Caps offset 0xE4 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 08 78 06 00 B0 02 11 20 03 0C 10 20 00 00 10 00 D0 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 40 11 2A A6 7B AA 0F 00 00 00 00 00 00 00 00 00 60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 A0 01 00 00 01 00 20 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description SMBus Controller Location bus 0 (0x00), device 20 (0x14), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x780B Revision ID 0x14 PI 0x00 SubClass 0x05 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 0B 78 03 04 20 02 14 00 05 0C 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Multimedia device Location bus 0 (0x00), device 20 (0x14), function 2 (0x02) Common header Vendor ID 0x1022 Model ID 0x780D Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x04 Cache Line 0x10 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xFEB40000 Subvendor ID 0x1565 Subsystem ID 0x821E Int. Line 0x10 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.1 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 0D 78 06 00 10 04 01 00 03 04 10 20 00 00 10 04 00 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 1E 82 30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00 40 00 00 40 00 01 00 00 00 00 00 00 00 01 00 00 00 50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description PCI to ISA Bridge Location bus 0 (0x00), device 20 (0x14), function 3 (0x03) Common header Vendor ID 0x1022 Model ID 0x780E Revision ID 0x11 PI 0x00 SubClass 0x01 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 0E 78 0F 00 20 02 11 00 01 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 04 00 00 00 D5 FF 03 FF 07 FF 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 0A 00 00 00 00 0F 00 00 FF FF FF 70 67 45 23 00 00 00 00 00 9C 00 00 00 00 0B 00 00 80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 02 00 C1 FE 2E 01 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 E9 45 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 27 00 82 FF D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description PCI to PCI Bridge Location bus 0 (0x00), device 20 (0x14), function 4 (0x04) Common header Vendor ID 0x1022 Model ID 0x780F Revision ID 0x40 PI 0x01 SubClass 0x04 BaseClass 0x06 Cache Line 0x00 Latency 0x40 Header 0x81 PCI header Primary bus 0x00 Secondary bus 0x02 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 0F 78 27 04 A0 02 40 01 04 06 00 40 81 00 10 00 00 00 00 00 00 00 00 00 02 02 40 F0 00 80 22 20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 26 00 3C FF 00 00 00 00 0C 0F 3F D1 00 00 00 00 50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF 60 CA 0E 17 00 BA 98 10 02 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06 E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description USB Controller (OHCI) Location bus 0 (0x00), device 20 (0x14), function 5 (0x05) Common header Vendor ID 0x1022 Model ID 0x7809 Revision ID 0x11 PI 0x10 SubClass 0x03 BaseClass 0x0C Cache Line 0x10 Latency 0x20 Header 0x00 PCI header Address 0 (memory) 0xFEB4C000 Subvendor ID 0x1565 Subsystem ID 0x3709 Int. Line 0x12 Int. Pin 0x03 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 09 78 06 00 A0 02 11 10 03 0C 10 20 00 00 10 00 C0 B4 FE 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 65 15 09 37 30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00 40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 50 40 03 D8 F0 00 00 00 00 FF FF FF FF 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 80 BB 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x1400 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 00 14 00 00 10 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 01 02 04 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 03 00 E0 00 00 00 00 80 2E 00 00 0E 00 58 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 20 10 11 77 00 00 00 00 13 00 00 00 90 A8 02 05 80 00 00 01 02 27 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 1 (0x01) Common header Vendor ID 0x1022 Model ID 0x1401 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 01 14 00 00 00 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 03 00 00 00 00 00 1E 02 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 03 00 E0 00 00 BF FE 00 03 C0 FE 00 80 FF FF 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 13 E0 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 03 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 F0 03 20 00 E0 01 00 00 00 00 00 00 00 00 00 00 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 2 (0x02) Common header Vendor ID 0x1022 Model ID 0x1402 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 02 14 00 00 00 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 E0 FF F8 01 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 02 00 58 00 08 18 80 0B 00 00 00 05 00 80 00 00 00 00 3D 00 00 02 00 90 00 00 01 03 92 08 49 9F 2F 81 0F 8D A1 00 00 00 A0 80 03 1D 03 00 00 00 00 00 00 32 80 00 00 00 00 B0 BE 74 E9 B6 50 00 00 00 EB C9 AF 09 75 37 44 8D C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 CA E5 AF 1D A7 DC 6A E7 DE 7F B2 DD 0E F7 E6 EC E0 FF 67 7E F4 FE 7F FE FF F4 FE FF 9F 4E 15 AC D9 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 3 (0x03) Common header Vendor ID 0x1022 Model ID 0x1403 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI capability Caps class Secure Device Caps offset 0xF0 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 03 14 00 00 10 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 40 FF FF FF FF 40 00 B0 48 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 05 00 24 72 00 00 00 70 52 00 01 10 70 57 11 17 10 01 01 18 01 14 0C 20 00 18 0E 05 04 80 00 00 00 00 E2 00 00 00 00 00 81 00 00 40 40 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 48 09 A0 EF 0F A0 28 00 00 00 F0 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 23 0F 80 C8 50 7F 00 00 38 57 A7 00 E0 00 00 00 00 20 00 00 00 06 4F F0 01 00 00 00 00 F0 0F 00 10 00 00 00 00 00 00 00 00 00 31 0F 61 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 4 (0x04) Common header Vendor ID 0x1022 Model ID 0x1404 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 04 14 00 00 00 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 5 (0x05) Common header Vendor ID 0x1022 Model ID 0x1405 Revision ID 0x00 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 22 10 05 14 00 00 00 00 00 00 00 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 03 00 03 00 03 30 16 16 04 10 02 01 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 B0 00 00 00 00 00 00 00 00 12 06 00 00 12 06 00 00 C0 00 00 00 00 B0 17 00 25 51 19 00 25 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 E2 CF FF 03 00 00 00 00 46 01 45 00 71 00 02 00 F0 00 00 00 00 11 00 80 1C 00 00 00 00 00 00 00 00 Description Ethernet Controller Location bus 1 (0x01), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x10EC Model ID 0x8168 Revision ID 0x0C PI 0x00 SubClass 0x00 BaseClass 0x02 Cache Line 0x10 Latency 0x00 Header 0x00 PCI header Address 0 (port) 0x0000E000 Address 2 (memory) 0xFEA00000 Address 4 (memory) 0xE8000000 Subvendor ID 0x1565 Subsystem ID 0x2400 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x40 Caps version 1.2 PCI capability Caps class Message Signalled Interrupts Caps offset 0x50 PCI capability Caps class PCI Express Caps offset 0x70 Device type PCI-E Endpoint Device Port 0 Version 2.0 Link width 1x (max 1x) PCI capability Caps class MSI-X Caps offset 0xB0 PCI capability Caps class Virtual Product Data Caps offset 0xD0 Extended capabilities Caps class Advanced Error Reporting Caps offset 0x100 Caps class Virtual Channel Caps offset 0x140 Caps class Device Serial Number Caps offset 0x160 Caps class 0x18 Caps offset 0x170 PCI registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 EC 10 68 81 07 04 10 00 0C 00 00 02 10 00 00 00 10 01 E0 00 00 00 00 00 00 04 00 A0 FE 00 00 00 00 20 0C 00 00 E8 00 00 00 00 00 00 00 00 65 15 00 24 30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00 40 01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00 50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 10 B0 02 02 C0 8C 00 00 00 50 10 00 11 7C 47 00 80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 1F 08 0C 00 10 00 00 00 02 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 100 01 00 01 14 00 00 10 00 00 00 40 00 30 20 46 00 110 C0 20 00 00 00 60 00 00 B4 00 00 00 02 00 00 40 120 FF 00 90 00 20 46 A6 FE 00 00 00 00 00 00 00 00 130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DMI ------------------------------------------------------------------------- DMI BIOS BIOS ********* vendor American Megatrends Inc. version 4.6.5 date 12/15/2015 ROM size 1024 KB DMI System Information manufacturer BIOSTAR Group product A68MD PRO version unknown serial None UUID {03000200-0400-0500-0006-000700080009} SKU None family None DMI Baseboard vendor BIOSTAR Group model A68MD PRO revision unknown serial None DMI System Enclosure manufacturer BIOSTAR Group chassis type Desktop chassis serial None DMI Extension Slot designation J6B2 type A5 populated yes DMI Extension Slot designation J6B1 type A5 populated yes DMI Extension Slot designation J6D1 type A5 populated yes DMI Extension Slot designation J7B1 type A5 populated yes DMI Physical Memory Array location Motherboard usage System Memory correction None max capacity 8192 MBytes max# of devices 4 DMI Memory Device designation DIMM 0 format DIMM type unknown total width 64 bits data width 64 bits size 8192 MBytes DMI Memory Device designation DIMM 0 format DIMM type unknown total width 64 bits data width 64 bits DMI Processor manufacturer AuthenticAMD model AMD A8-6500 APU with Radeon(tm) HD Graphics clock speed 3500.0 MHz FSB speed 100.0 MHz multiplier 35.0x Storage ------------------------------------------------------------------------- Drive 0 Device Path \\?\scsi#disk&ven_hitachi&prod_hds721010cla630#4&bbefc9&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} Type Fixed Name Hitachi HDS721010CLA630 Capacity 931.5 GB SMART Support Yes Drive 1 Device Path \\?\usbstor#disk&ven_brother&prod_dcp-165c&rev_1.00#7&11a2ceac&0&broh9f159883&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} Type Removable Name Brother DCP-165C SMART Support Yes USB Devices ------------------------------------------------------------------------- USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x04F9, product=0x0204 USB Device USB-Verbundgerät, class=0x00, subclass=0x00, vendor=0x0C45, product=0x7603 USB Device USB-Eingabegerät, class=0x00, subclass=0x00, vendor=0x1BCF, product=0x0053 Graphics ------------------------------------------------------------------------- Number of adapters 1 Graphic APIs ------------------------------------------------------------------------- API ATI I/O API ADL SDK Display Adapters ------------------------------------------------------------------------- Display adapter 0 Name AMD Radeon HD 8570D Board Manufacturer 0x1565 (0x1708) Memory size 128 MB PCI device bus 0 (0x0), device 1 (0x1), function 0 (0x0) Vendor ID 0x1002 (0x1565) Model ID 0x990E (0x1708) Performance Level 0 Core clock 304.0 MHz Memory clock 800.0 MHz Performance Level 1 Core clock 800.0 MHz Memory clock 800.0 MHz Win32_VideoController AdapterRAM = 0x8000000 (134217728) Win32_VideoController DriverVersion = 15.200.1065.0 Win32_VideoController DriverDate = 07/21/2015 Monitor 0 Model HL225DBB () ID HSD0000 Serial 1234567890123 Manufacturing Date Week 28, Year 2016 Size 21.7 inches Max Resolution 1920 x 1080 @ 60 Hz Horizontal Freq. Range 30-83 kHz Vertical Freq. Range 56-75 Hz Max Pixel Clock 180 MHz Gamma Factor 2.2 Software ------------------------------------------------------------------------- Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 14393) DirectX Version 12.0 Register Spaces ------------------------------------------------------------------------- Register space PCI Register space PCI #2 Register space PCI Express, base address = 0x0F0000000 Register space class = 0x12 Register space SMBus, base address = 0x0B00 Register space LPC, base address = 0x0A30 Register space LPC, base address = 0x02E
