/*************************************************************************************** Name : LED CUBE 8x8x8 74HC595 By : ****************************************************************************************/ #include #include #include //NEU #define AXIS_X 1 #define AXIS_Y 2 #define AXIS_Z 3 //--- Pin connected to ST_CP of 74HC595 //--- Gelbe Leitung RCK int latchPin = 10; //--- Pin connected to SH_CP of 74HC595 //--- Schwarze Leitung SCK int clockPin = 13; //--- Pin connected to DS of 74HC595 //--- Lila Leitung SI int dataPin = 11; //--- Used for faster latching int latchPinPORTB = latchPin - 8; //holds value for all the pins, [x][y][z] byte cube[8][8]; //Counts through the layers int current_layer = 0; /* //NEU Anfang * an extension to the interrupt support for arduino. * add pin change interrupts to the external interrupts, giving a way * for users to have interrupts drive off of any pin. * Refer to avr-gcc header files, arduino source and atmega datasheet. */ /* * Theory: all IO pins on Atmega168 are covered by Pin Change Interrupts. * The PCINT corresponding to the pin must be enabled and masked, and * an ISR routine provided. Since PCINTs are per port, not per pin, the ISR * must use some logic to actually implement a per-pin interrupt service. */ /* Pin to interrupt map: * D0-D7 = PCINT 16-23 = PCIR2 = PD = PCIE2 = pcmsk2 * D8-D13 = PCINT 0-5 = PCIR0 = PB = PCIE0 = pcmsk0 * A0-A5 (D14-D19) = PCINT 8-13 = PCIR1 = PC = PCIE1 = pcmsk1 */ volatile uint8_t *port_to_pcmask[] = { &PCMSK0, &PCMSK1, &PCMSK2 }; static int PCintMode[24]; typedef void (*voidFuncPtr)(void); volatile static voidFuncPtr PCintFunc[24] = { NULL }; volatile static uint8_t PCintLast[3]; /* * attach an interrupt to a specific pin using pin change interrupts. */ void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode) { uint8_t bit = digitalPinToBitMask(pin); uint8_t port = digitalPinToPort(pin); uint8_t slot; volatile uint8_t *pcmask; // map pin to PCIR register if (port == NOT_A_PORT) { return; } else { port -= 2; pcmask = port_to_pcmask[port]; } // -- Fix by Baziki. In the original sources it was a little bug, which cause analog ports to work incorrectly. if (port == 1) { slot = port * 8 + (pin - 14); } else { slot = port * 8 + (pin % 8); } // --Fix end PCintMode[slot] = mode; PCintFunc[slot] = userFunc; // set the mask *pcmask |= bit; // enable the interrupt PCICR |= 0x01 << port; } void PCdetachInterrupt(uint8_t pin) { uint8_t bit = digitalPinToBitMask(pin); uint8_t port = digitalPinToPort(pin); volatile uint8_t *pcmask; // map pin to PCIR register if (port == NOT_A_PORT) { return; } else { port -= 2; pcmask = port_to_pcmask[port]; } // disable the mask. *pcmask &= ~bit; // if that's the last one, disable the interrupt. if (*pcmask == 0) { PCICR &= ~(0x01 << port); } } // common code for isr handler. "port" is the PCINT number. // there isn't really a good way to back-map ports and masks to pins. static void PCint(uint8_t port) { uint8_t bit; uint8_t curr; uint8_t mask; uint8_t pin; // get the pin states for the indicated port. curr = *portInputRegister(port+2); mask = curr ^ PCintLast[port]; PCintLast[port] = curr; // mask is pins that have changed. screen out non pcint pins. if ((mask &= *port_to_pcmask[port]) == 0) { return; } // mask is pcint pins that have changed. for (uint8_t i=0; i < 8; i++) { bit = 0x01 << i; if (bit & mask) { pin = port * 8 + i; // Trigger interrupt if mode is CHANGE, or if mode is RISING and // the bit is currently high, or if mode is FALLING and bit is low. if ((PCintMode[pin] == CHANGE || ((PCintMode[pin] == RISING) && (curr & bit)) || ((PCintMode[pin] == FALLING) && !(curr & bit))) && (PCintFunc[pin] != NULL)) { PCintFunc[pin](); } } } } SIGNAL(PCINT0_vect) { PCint(0); } SIGNAL(PCINT1_vect) { PCint(1); } SIGNAL(PCINT2_vect) { PCint(2); } //Neu Ende //--- This process is run by the timer and does the PWM control void iProcess() { //last layer store int oldLayerBit = current_layer + 2; //increment layer count current_layer++; if (current_layer >= 8) { current_layer = 0; } //--- Run through all the shift register values and send them (last one first) // latching in the process latchOff(); for (int i = 0 ; i < 8 ; i++) { spi_transfer(cube[current_layer][i]); } //Hide the old layer digitalWrite(oldLayerBit, LOW); //New data on the pins latchOn(); //new layer high digitalWrite(current_layer + 2, HIGH); } //--- Direct port access latching void latchOn() { bitSet(PORTB, latchPinPORTB); } void latchOff() { bitClear(PORTB, latchPinPORTB); } //--- Used to setup SPI based on current pin setup // this is called in the setup routine; void setupSPI() { byte clr; SPCR |= ( (1 << SPE) | (1 << MSTR) ); // enable SPI as master SPCR &= ~( (1 << SPR1) | (1 << SPR0) ); // clear prescaler bits clr = SPSR; // clear SPI status reg clr = SPDR; // clear SPI data reg SPSR |= (1 << SPI2X); // set prescaler bits delay(10); } //--- The really fast SPI version of shiftOut byte spi_transfer(byte data) { SPDR = data; // Start the transmission loop_until_bit_is_set(SPSR, SPIF); return SPDR; // return the received byte, we don't need that } volatile uint8_t effect = 0; //NEU Anfang #define MAXEFFECTS 17 void tick(void) { effect++; if (effect > MAXEFFECTS) { effect = 0; } } //NEU Ende void setup() { Serial.begin(9600); //layer pins for (int i = 2; i < 10; i++) { pinMode(i, OUTPUT); } pinMode(latchPin, OUTPUT); pinMode(clockPin, OUTPUT); pinMode(dataPin, OUTPUT); pinMode(14, INPUT_PULLUP); //Neu digitalWrite(latchPin, LOW); digitalWrite(dataPin, LOW); digitalWrite(clockPin, LOW); PCattachInterrupt(14, tick, FALLING); //Neu //--- Setup to run SPI setupSPI(); //--- Activate the PWM timer Timer1.initialize(100); // Timer for updating pwm pins Timer1.attachInterrupt(iProcess); } void loop() { int i, x, y, z; while (true) {switch( effect ) //NEU Anfang { case : 0 effect_wormsqueeze (2, AXIS_Z, -1, 100, 1000); break; case : 1 effect_rand_patharound(200, 500); break; case : 2 effect_intro(); break; case : 3 sinelines(4000, 10); break; case : 4 effect_random_sparkle(); break; case : 5 side_ripples (300, 500); break; case : 6 mirror_ripples(600, 400); break; case : 7 quad_ripples (600, 300); break; case : 8 linespin(1500, 10); break; case : 9 fireworks(10, 30, 500); break; case : 10 effect_box_wamp(1000); break; case : 11 effect_rain(100); break; case : 12 effect_planboing(AXIS_Z, 700); effect_planboing(AXIS_Y, 700); effect_planboing(AXIS_X, 700); break; case : 13 effect_blinky2(); break; case : 14 effect_random_filler(75, 1); effect_random_filler(75, 0); break; case : 15 effect_boxside_randsend_parallel (AXIS_X, 0, 200, 1); effect_boxside_randsend_parallel (AXIS_X, 1, 200, 1); effect_boxside_randsend_parallel (AXIS_Y, 0, 300, 1); effect_boxside_randsend_parallel (AXIS_Y, 1, 300, 1); effect_boxside_randsend_parallel (AXIS_Z, 0, 600, 1); effect_boxside_randsend_parallel (AXIS_Z, 1, 600, 1); break; case : 16 effect_axis_updown_randsuspend(AXIS_Z, 550, 5000, 0); effect_axis_updown_randsuspend(AXIS_Z, 550, 5000, 1); effect_axis_updown_randsuspend(AXIS_Z, 550, 5000, 0); effect_axis_updown_randsuspend(AXIS_Z, 550, 5000, 1); effect_axis_updown_randsuspend(AXIS_X, 550, 5000, 0); effect_axis_updown_randsuspend(AXIS_X, 550, 5000, 1); effect_axis_updown_randsuspend(AXIS_Y, 550, 5000, 0); effect_axis_updown_randsuspend(AXIS_Y, 550, 5000, 1); break; case : 17 effect_text(1000); break; //Neu Ende } } // ========================================================================================== // TEXT Functions // ========================================================================================== char font_data[128][8] = { { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // 0 : // | | // | | // | | // | | // | | // | | // | | // | | { 0x00, 0x3E, 0x41, 0x55, 0x41, 0x55, 0x49, 0x3E }, // 1 :  // | | // | ***** | // | * * | // | * * * * | // | * * | // | * * * * | // | * * * | // | ***** | { 0x00, 0x3E, 0x7F, 0x6B, 0x7F, 0x6B, 0x77, 0x3E }, // 2 :  // | | // | ***** | // | ******* | // | ** * ** | // | ******* | // | ** * ** | // | *** *** | // | ***** | { 0x00, 0x22, 0x77, 0x7F, 0x7F, 0x3E, 0x1C, 0x08 }, // 3 :  // | | // | * * | // | *** *** | // | ******* | // | ******* | // | ***** | // | *** | // | * | { 0x00, 0x08, 0x1C, 0x3E, 0x7F, 0x3E, 0x1C, 0x08 }, // 4 :  // | | // | * | // | *** | // | ***** | // | ******* | // | ***** | // | *** | // | * | { 0x00, 0x08, 0x1C, 0x2A, 0x7F, 0x2A, 0x08, 0x1C }, // 5 :  // | | // | * | // | *** | // | * * * | // | ******* | // | * * * | // | * | // | *** | { 0x00, 0x08, 0x1C, 0x3E, 0x7F, 0x3E, 0x08, 0x1C }, // 6 :  // | | // | * | // | *** | // | ***** | // | ******* | // | ***** | // | * | // | *** | { 0x00, 0x00, 0x1C, 0x3E, 0x3E, 0x3E, 0x1C, 0x00 }, // 7 :  // | | // | | // | *** | // | ***** | // | ***** | // | ***** | // | *** | // | | { 0xFF, 0xFF, 0xE3, 0xC1, 0xC1, 0xC1, 0xE3, 0xFF }, // 8 :  // | ******** | // | ******** | // | *** ** | // | ** * | // | ** * | // | ** * | // | *** ** | // | ******** | { 0x00, 0x00, 0x1C, 0x22, 0x22, 0x22, 0x1C, 0x00 }, // 9 : // | | // | | // | *** | // | * * | // | * * | // | * * | // | *** | // | | { 0xFF, 0xFF, 0xE3, 0xDD, 0xDD, 0xDD, 0xE3, 0xFF }, // 10 : // | ******** | // | ******** | // | *** ** | // | ** *** * | // | ** *** * | // | ** *** * | // | *** ** | // | ******** | { 0x00, 0x0F, 0x03, 0x05, 0x39, 0x48, 0x48, 0x30 }, // 11 : // | | // | **** | // | ** | // | * * | // | *** * | // | * * | // | * * | // | ** | { 0x00, 0x08, 0x3E, 0x08, 0x1C, 0x22, 0x22, 0x1C }, // 12 : // | | // | * | // | ***** | // | * | // | *** | // | * * | // | * * | // | *** | { 0x00, 0x18, 0x14, 0x10, 0x10, 0x30, 0x70, 0x60 }, // 13 : // | | // | ** | // | * * | // | * | // | * | // | ** | // | *** | // | ** | { 0x00, 0x0F, 0x19, 0x11, 0x13, 0x37, 0x76, 0x60 }, // 14 :  // | | // | **** | // | ** * | // | * * | // | * ** | // | ** *** | // | *** ** | // | ** | { 0x00, 0x08, 0x2A, 0x1C, 0x77, 0x1C, 0x2A, 0x08 }, // 15 :  // | | // | * | // | * * * | // | *** | // | *** *** | // | *** | // | * * * | // | * | { 0x00, 0x60, 0x78, 0x7E, 0x7F, 0x7E, 0x78, 0x60 }, // 16 :  // | | // | ** | // | **** | // | ****** | // | ******* | // | ****** | // | **** | // | ** | { 0x00, 0x03, 0x0F, 0x3F, 0x7F, 0x3F, 0x0F, 0x03 }, // 17 :  // | | // | ** | // | **** | // | ****** | // | ******* | // | ****** | // | **** | // | ** | { 0x00, 0x08, 0x1C, 0x2A, 0x08, 0x2A, 0x1C, 0x08 }, // 18 :  // | | // | * | // | *** | // | * * * | // | * | // | * * * | // | *** | // | * | { 0x00, 0x66, 0x66, 0x66, 0x66, 0x00, 0x66, 0x66 }, // 19 :  // | | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | | // | ** ** | // | ** ** | { 0x00, 0x3F, 0x65, 0x65, 0x3D, 0x05, 0x05, 0x05 }, // 20 :  // | | // | ****** | // | ** * * | // | ** * * | // | **** * | // | * * | // | * * | // | * * | { 0x00, 0x0C, 0x32, 0x48, 0x24, 0x12, 0x4C, 0x30 }, // 21 :  // | | // | ** | // | ** * | // | * * | // | * * | // | * * | // | * ** | // | ** | { 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x7F, 0x7F }, // 22 :  // | | // | | // | | // | | // | | // | ******* | // | ******* | // | ******* | { 0x00, 0x08, 0x1C, 0x2A, 0x08, 0x2A, 0x1C, 0x3E }, // 23 :  // | | // | * | // | *** | // | * * * | // | * | // | * * * | // | *** | // | ***** | { 0x00, 0x08, 0x1C, 0x3E, 0x7F, 0x1C, 0x1C, 0x1C }, // 24 :  // | | // | * | // | *** | // | ***** | // | ******* | // | *** | // | *** | // | *** | { 0x00, 0x1C, 0x1C, 0x1C, 0x7F, 0x3E, 0x1C, 0x08 }, // 25 :  // | | // | *** | // | *** | // | *** | // | ******* | // | ***** | // | *** | // | * | { 0x00, 0x08, 0x0C, 0x7E, 0x7F, 0x7E, 0x0C, 0x08 }, // 26 :  // | | // | * | // | ** | // | ****** | // | ******* | // | ****** | // | ** | // | * | { 0x00, 0x08, 0x18, 0x3F, 0x7F, 0x3F, 0x18, 0x08 }, // 27 :  // | | // | * | // | ** | // | ****** | // | ******* | // | ****** | // | ** | // | * | { 0x00, 0x00, 0x00, 0x70, 0x70, 0x70, 0x7F, 0x7F }, // 28 :  // | | // | | // | | // | *** | // | *** | // | *** | // | ******* | // | ******* | { 0x00, 0x00, 0x14, 0x22, 0x7F, 0x22, 0x14, 0x00 }, // 29 :  // | | // | | // | * * | // | * * | // | ******* | // | * * | // | * * | // | | { 0x00, 0x08, 0x1C, 0x1C, 0x3E, 0x3E, 0x7F, 0x7F }, // 30 :  // | | // | * | // | *** | // | *** | // | ***** | // | ***** | // | ******* | // | ******* | { 0x00, 0x7F, 0x7F, 0x3E, 0x3E, 0x1C, 0x1C, 0x08 }, // 31 :  // | | // | ******* | // | ******* | // | ***** | // | ***** | // | *** | // | *** | // | * | { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // 32 : // | | // | | // | | // | | // | | // | | // | | // | | { 0x00, 0x18, 0x18, 0x18, 0x18, 0x18, 0x00, 0x18 }, // 33 : ! // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | | // | ** | { 0x00, 0x36, 0x36, 0x14, 0x00, 0x00, 0x00, 0x00 }, // 34 : " // | | // | ** ** | // | ** ** | // | * * | // | | // | | // | | // | | { 0x00, 0x36, 0x36, 0x7F, 0x36, 0x7F, 0x36, 0x36 }, // 35 : # // | | // | ** ** | // | ** ** | // | ******* | // | ** ** | // | ******* | // | ** ** | // | ** ** | { 0x00, 0x08, 0x1E, 0x20, 0x1C, 0x02, 0x3C, 0x08 }, // 36 : $ // | | // | * | // | **** | // | * | // | *** | // | * | // | **** | // | * | { 0x00, 0x60, 0x66, 0x0C, 0x18, 0x30, 0x66, 0x06 }, // 37 : % // | | // | ** | // | ** ** | // | ** | // | ** | // | ** | // | ** ** | // | ** | { 0x00, 0x3C, 0x66, 0x3C, 0x28, 0x65, 0x66, 0x3F }, // 38 : & // | | // | **** | // | ** ** | // | **** | // | * * | // | ** * * | // | ** ** | // | ****** | { 0x00, 0x18, 0x18, 0x18, 0x30, 0x00, 0x00, 0x00 }, // 39 : ' // | | // | ** | // | ** | // | ** | // | ** | // | | // | | // | | { 0x00, 0x60, 0x30, 0x18, 0x18, 0x18, 0x30, 0x60 }, // 40 : ( // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x06, 0x0C, 0x18, 0x18, 0x18, 0x0C, 0x06 }, // 41 : ) // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x00, 0x36, 0x1C, 0x7F, 0x1C, 0x36, 0x00 }, // 42 : * // | | // | | // | ** ** | // | *** | // | ******* | // | *** | // | ** ** | // | | { 0x00, 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00 }, // 43 : + // | | // | | // | * | // | * | // | ***** | // | * | // | * | // | | { 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x30, 0x60 }, // 44 : , // | | // | | // | | // | | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00 }, // 45 : - // | | // | | // | | // | | // | **** | // | | // | | // | | { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x60 }, // 46 : . // | | // | | // | | // | | // | | // | | // | ** | // | ** | { 0x00, 0x00, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x00 }, // 47 : / // | | // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | | { 0x00, 0x3C, 0x66, 0x6E, 0x76, 0x66, 0x66, 0x3C }, // 48 : 0 // | | // | **** | // | ** ** | // | ** *** | // | *** ** | // | ** ** | // | ** ** | // | **** | { 0x00, 0x18, 0x18, 0x38, 0x18, 0x18, 0x18, 0x7E }, // 49 : 1 // | | // | ** | // | ** | // | *** | // | ** | // | ** | // | ** | // | ****** | { 0x00, 0x3C, 0x66, 0x06, 0x0C, 0x30, 0x60, 0x7E }, // 50 : 2 // | | // | **** | // | ** ** | // | ** | // | ** | // | ** | // | ** | // | ****** | { 0x00, 0x3C, 0x66, 0x06, 0x1C, 0x06, 0x66, 0x3C }, // 51 : 3 // | | // | **** | // | ** ** | // | ** | // | *** | // | ** | // | ** ** | // | **** | { 0x00, 0x0C, 0x1C, 0x2C, 0x4C, 0x7E, 0x0C, 0x0C }, // 52 : 4 // | | // | ** | // | *** | // | * ** | // | * ** | // | ****** | // | ** | // | ** | { 0x00, 0x7E, 0x60, 0x7C, 0x06, 0x06, 0x66, 0x3C }, // 53 : 5 // | | // | ****** | // | ** | // | ***** | // | ** | // | ** | // | ** ** | // | **** | { 0x00, 0x3C, 0x66, 0x60, 0x7C, 0x66, 0x66, 0x3C }, // 54 : 6 // | | // | **** | // | ** ** | // | ** | // | ***** | // | ** ** | // | ** ** | // | **** | { 0x00, 0x7E, 0x66, 0x0C, 0x0C, 0x18, 0x18, 0x18 }, // 55 : 7 // | | // | ****** | // | ** ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x3C, 0x66, 0x66, 0x3C, 0x66, 0x66, 0x3C }, // 56 : 8 // | | // | **** | // | ** ** | // | ** ** | // | **** | // | ** ** | // | ** ** | // | **** | { 0x00, 0x3C, 0x66, 0x66, 0x3E, 0x06, 0x66, 0x3C }, // 57 : 9 // | | // | **** | // | ** ** | // | ** ** | // | ***** | // | ** | // | ** ** | // | **** | { 0x00, 0x00, 0x18, 0x18, 0x00, 0x18, 0x18, 0x00 }, // 58 : : // | | // | | // | ** | // | ** | // | | // | ** | // | ** | // | | { 0x00, 0x00, 0x18, 0x18, 0x00, 0x18, 0x18, 0x30 }, // 59 : ; // | | // | | // | ** | // | ** | // | | // | ** | // | ** | // | ** | { 0x00, 0x06, 0x0C, 0x18, 0x30, 0x18, 0x0C, 0x06 }, // 60 : < // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x00, 0x00, 0x3C, 0x00, 0x3C, 0x00, 0x00 }, // 61 : = // | | // | | // | | // | **** | // | | // | **** | // | | // | | { 0x00, 0x60, 0x30, 0x18, 0x0C, 0x18, 0x30, 0x60 }, // 62 : > // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x3C, 0x66, 0x06, 0x1C, 0x18, 0x00, 0x18 }, // 63 : ? // | | // | **** | // | ** ** | // | ** | // | *** | // | ** | // | | // | ** | { 0x00, 0x38, 0x44, 0x5C, 0x58, 0x42, 0x3C, 0x00 }, // 64 : @ // | | // | *** | // | * * | // | * *** | // | * ** | // | * * | // | **** | // | | { 0x00, 0x3C, 0x66, 0x66, 0x7E, 0x66, 0x66, 0x66 }, // 65 : A // | | // | **** | // | ** ** | // | ** ** | // | ****** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x7C, 0x66, 0x66, 0x7C, 0x66, 0x66, 0x7C }, // 66 : B // | | // | ***** | // | ** ** | // | ** ** | // | ***** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x3C, 0x66, 0x60, 0x60, 0x60, 0x66, 0x3C }, // 67 : C // | | // | **** | // | ** ** | // | ** | // | ** | // | ** | // | ** ** | // | **** | { 0x00, 0x7C, 0x66, 0x66, 0x66, 0x66, 0x66, 0x7C }, // 68 : D // | | // | ***** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x7E, 0x60, 0x60, 0x7C, 0x60, 0x60, 0x7E }, // 69 : E // | | // | ****** | // | ** | // | ** | // | ***** | // | ** | // | ** | // | ****** | { 0x00, 0x7E, 0x60, 0x60, 0x7C, 0x60, 0x60, 0x60 }, // 70 : F // | | // | ****** | // | ** | // | ** | // | ***** | // | ** | // | ** | // | ** | { 0x00, 0x3C, 0x66, 0x60, 0x60, 0x6E, 0x66, 0x3C }, // 71 : G // | | // | **** | // | ** ** | // | ** | // | ** | // | ** *** | // | ** ** | // | **** | { 0x00, 0x66, 0x66, 0x66, 0x7E, 0x66, 0x66, 0x66 }, // 72 : H // | | // | ** ** | // | ** ** | // | ** ** | // | ****** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x3C, 0x18, 0x18, 0x18, 0x18, 0x18, 0x3C }, // 73 : I // | | // | **** | // | ** | // | ** | // | ** | // | ** | // | ** | // | **** | { 0x00, 0x1E, 0x0C, 0x0C, 0x0C, 0x6C, 0x6C, 0x38 }, // 74 : J // | | // | **** | // | ** | // | ** | // | ** | // | ** ** | // | ** ** | // | *** | { 0x00, 0x66, 0x6C, 0x78, 0x70, 0x78, 0x6C, 0x66 }, // 75 : K // | | // | ** ** | // | ** ** | // | **** | // | *** | // | **** | // | ** ** | // | ** ** | { 0x00, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x7E }, // 76 : L // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ****** | { 0x00, 0x63, 0x77, 0x7F, 0x6B, 0x63, 0x63, 0x63 }, // 77 : M // | | // | ** ** | // | *** *** | // | ******* | // | ** * ** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x63, 0x73, 0x7B, 0x6F, 0x67, 0x63, 0x63 }, // 78 : N // | | // | ** ** | // | *** ** | // | **** ** | // | ** **** | // | ** *** | // | ** ** | // | ** ** | { 0x00, 0x3C, 0x66, 0x66, 0x66, 0x66, 0x66, 0x3C }, // 79 : O // | | // | **** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | **** | { 0x00, 0x7C, 0x66, 0x66, 0x66, 0x7C, 0x60, 0x60 }, // 80 : P // | | // | ***** | // | ** ** | // | ** ** | // | ** ** | // | ***** | // | ** | // | ** | { 0x00, 0x3C, 0x66, 0x66, 0x66, 0x6E, 0x3C, 0x06 }, // 81 : Q // | | // | **** | // | ** ** | // | ** ** | // | ** ** | // | ** *** | // | **** | // | ** | { 0x00, 0x7C, 0x66, 0x66, 0x7C, 0x78, 0x6C, 0x66 }, // 82 : R // | | // | ***** | // | ** ** | // | ** ** | // | ***** | // | **** | // | ** ** | // | ** ** | { 0x00, 0x3C, 0x66, 0x60, 0x3C, 0x06, 0x66, 0x3C }, // 83 : S // | | // | **** | // | ** ** | // | ** | // | **** | // | ** | // | ** ** | // | **** | { 0x00, 0x7E, 0x5A, 0x18, 0x18, 0x18, 0x18, 0x18 }, // 84 : T // | | // | ****** | // | * ** * | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x66, 0x66, 0x66, 0x66, 0x66, 0x66, 0x3E }, // 85 : U // | | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x66, 0x66, 0x66, 0x66, 0x66, 0x3C, 0x18 }, // 86 : V // | | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | **** | // | ** | { 0x00, 0x63, 0x63, 0x63, 0x6B, 0x7F, 0x77, 0x63 }, // 87 : W // | | // | ** ** | // | ** ** | // | ** ** | // | ** * ** | // | ******* | // | *** *** | // | ** ** | { 0x00, 0x63, 0x63, 0x36, 0x1C, 0x36, 0x63, 0x63 }, // 88 : X // | | // | ** ** | // | ** ** | // | ** ** | // | *** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x66, 0x66, 0x66, 0x3C, 0x18, 0x18, 0x18 }, // 89 : Y // | | // | ** ** | // | ** ** | // | ** ** | // | **** | // | ** | // | ** | // | ** | { 0x00, 0x7E, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x7E }, // 90 : Z // | | // | ****** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ****** | { 0x00, 0x1E, 0x18, 0x18, 0x18, 0x18, 0x18, 0x1E }, // 91 : [ // | | // | **** | // | ** | // | ** | // | ** | // | ** | // | ** | // | **** | { 0x00, 0x00, 0x60, 0x30, 0x18, 0x0C, 0x06, 0x00 }, // 92 : \ // | | // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | | { 0x00, 0x78, 0x18, 0x18, 0x18, 0x18, 0x18, 0x78 }, // 93 : ] // | | // | **** | // | ** | // | ** | // | ** | // | ** | // | ** | // | **** | { 0x00, 0x08, 0x14, 0x22, 0x41, 0x00, 0x00, 0x00 }, // 94 : ^ // | | // | * | // | * * | // | * * | // | * * | // | | // | | // | | { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F }, // 95 : _ // | | // | | // | | // | | // | | // | | // | | // | ******* | { 0x00, 0x0C, 0x0C, 0x06, 0x00, 0x00, 0x00, 0x00 }, // 96 : ` // | | // | ** | // | ** | // | ** | // | | // | | // | | // | | { 0x00, 0x00, 0x00, 0x3C, 0x06, 0x3E, 0x66, 0x3E }, // 97 : a // | | // | | // | | // | **** | // | ** | // | ***** | // | ** ** | // | ***** | { 0x00, 0x60, 0x60, 0x60, 0x7C, 0x66, 0x66, 0x7C }, // 98 : b // | | // | ** | // | ** | // | ** | // | ***** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x00, 0x00, 0x3C, 0x66, 0x60, 0x66, 0x3C }, // 99 : c // | | // | | // | | // | **** | // | ** ** | // | ** | // | ** ** | // | **** | { 0x00, 0x06, 0x06, 0x06, 0x3E, 0x66, 0x66, 0x3E }, // 100 : d // | | // | ** | // | ** | // | ** | // | ***** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x00, 0x00, 0x3C, 0x66, 0x7E, 0x60, 0x3C }, // 101 : e // | | // | | // | | // | **** | // | ** ** | // | ****** | // | ** | // | **** | { 0x00, 0x1C, 0x36, 0x30, 0x30, 0x7C, 0x30, 0x30 }, // 102 : f // | | // | *** | // | ** ** | // | ** | // | ** | // | ***** | // | ** | // | ** | { 0x00, 0x00, 0x3E, 0x66, 0x66, 0x3E, 0x06, 0x3C }, // 103 : g // | | // | | // | ***** | // | ** ** | // | ** ** | // | ***** | // | ** | // | **** | { 0x00, 0x60, 0x60, 0x60, 0x7C, 0x66, 0x66, 0x66 }, // 104 : h // | | // | ** | // | ** | // | ** | // | ***** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x00, 0x18, 0x00, 0x18, 0x18, 0x18, 0x3C }, // 105 : i // | | // | | // | ** | // | | // | ** | // | ** | // | ** | // | **** | { 0x00, 0x0C, 0x00, 0x0C, 0x0C, 0x6C, 0x6C, 0x38 }, // 106 : j // | | // | ** | // | | // | ** | // | ** | // | ** ** | // | ** ** | // | *** | { 0x00, 0x60, 0x60, 0x66, 0x6C, 0x78, 0x6C, 0x66 }, // 107 : k // | | // | ** | // | ** | // | ** ** | // | ** ** | // | **** | // | ** ** | // | ** ** | { 0x00, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18 }, // 108 : l // | | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | // | ** | { 0x00, 0x00, 0x00, 0x63, 0x77, 0x7F, 0x6B, 0x6B }, // 109 : m // | | // | | // | | // | ** ** | // | *** *** | // | ******* | // | ** * ** | // | ** * ** | { 0x00, 0x00, 0x00, 0x7C, 0x7E, 0x66, 0x66, 0x66 }, // 110 : n // | | // | | // | | // | ***** | // | ****** | // | ** ** | // | ** ** | // | ** ** | { 0x00, 0x00, 0x00, 0x3C, 0x66, 0x66, 0x66, 0x3C }, // 111 : o // | | // | | // | | // | **** | // | ** ** | // | ** ** | // | ** ** | // | **** | { 0x00, 0x00, 0x7C, 0x66, 0x66, 0x7C, 0x60, 0x60 }, // 112 : p // | | // | | // | ***** | // | ** ** | // | ** ** | // | ***** | // | ** | // | ** | { 0x00, 0x00, 0x3C, 0x6C, 0x6C, 0x3C, 0x0D, 0x0F }, // 113 : q // | | // | | // | **** | // | ** ** | // | ** ** | // | **** | // | ** * | // | **** | { 0x00, 0x00, 0x00, 0x7C, 0x66, 0x66, 0x60, 0x60 }, // 114 : r // | | // | | // | | // | ***** | // | ** ** | // | ** ** | // | ** | // | ** | { 0x00, 0x00, 0x00, 0x3E, 0x40, 0x3C, 0x02, 0x7C }, // 115 : s // | | // | | // | | // | ***** | // | * | // | **** | // | * | // | ***** | { 0x00, 0x00, 0x18, 0x18, 0x7E, 0x18, 0x18, 0x18 }, // 116 : t // | | // | | // | ** | // | ** | // | ****** | // | ** | // | ** | // | ** | { 0x00, 0x00, 0x00, 0x66, 0x66, 0x66, 0x66, 0x3E }, // 117 : u // | | // | | // | | // | ** ** | // | ** ** | // | ** ** | // | ** ** | // | ***** | { 0x00, 0x00, 0x00, 0x00, 0x66, 0x66, 0x3C, 0x18 }, // 118 : v // | | // | | // | | // | | // | ** ** | // | ** ** | // | **** | // | ** | { 0x00, 0x00, 0x00, 0x63, 0x6B, 0x6B, 0x6B, 0x3E }, // 119 : w // | | // | | // | | // | ** ** | // | ** * ** | // | ** * ** | // | ** * ** | // | ***** | { 0x00, 0x00, 0x00, 0x66, 0x3C, 0x18, 0x3C, 0x66 }, // 120 : x // | | // | | // | | // | ** ** | // | **** | // | ** | // | **** | // | ** ** | { 0x00, 0x00, 0x00, 0x66, 0x66, 0x3E, 0x06, 0x3C }, // 121 : y // | | // | | // | | // | ** ** | // | ** ** | // | ***** | // | ** | // | **** | { 0x00, 0x00, 0x00, 0x3C, 0x0C, 0x18, 0x30, 0x3C }, // 122 : z // | | // | | // | | // | **** | // | ** | // | ** | // | ** | // | **** | { 0x00, 0x0E, 0x18, 0x18, 0x30, 0x18, 0x18, 0x0E }, // 123 : { // | | // | *** | // | ** | // | ** | // | ** | // | ** | // | ** | // | *** | { 0x00, 0x18, 0x18, 0x18, 0x00, 0x18, 0x18, 0x18 }, // 124 : | // | | // | ** | // | ** | // | ** | // | | // | ** | // | ** | // | ** | { 0x00, 0x70, 0x18, 0x18, 0x0C, 0x18, 0x18, 0x70 }, // 125 : } // | | // | *** | // | ** | // | ** | // | ** | // | ** | // | ** | // | *** | { 0x00, 0x00, 0x00, 0x3A, 0x6C, 0x00, 0x00, 0x00 }, // 126 : ~ // | | // | | // | | // | *** * | // | ** ** | // | | // | | // | | { 0x00, 0x08, 0x1C, 0x36, 0x63, 0x41, 0x41, 0x7F } // 127 :  // | | // | * | // | *** | // | ** ** | // | ** ** | // | * * | // | * * | // | ******* | }; // Define display string here const int charNum = 20; char string[charNum] = {'H', 'A', 'L', 'L', 'O', '-', 'M', 'A', 'D', 'E', '-', 'B', 'Y', '-', 'T', 'O', 'B', 'I', 'A', 'S',}; void effect_text(int delayt) { fill(0x00); for (int ltr = 0; ltr < charNum; ltr++) { // For each letter in string array for (int dist = 0; dist < 8; dist++) { //bring letter forward fill(0x00);//blank last row int rev = 0; for (int rw = 7; rw >= 0; rw--) {//copy rows cube[rev][dist] = bitswap(font_data[string[ltr]][rw]); rev++; } delay_ms(delayt); } } } unsigned char bitswap (unsigned char x)//Reverses a byte (so letters aren't backwards); { byte result; asm("mov __tmp_reg__, %[in] \n\t" "lsl __tmp_reg__ \n\t" /* shift out high bit to carry */ "ror %[out] \n\t" /* rotate carry __tmp_reg__to low bit (eventually) */ "lsl __tmp_reg__ \n\t" /* 2 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 3 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 4 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 5 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 6 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 7 */ "ror %[out] \n\t" "lsl __tmp_reg__ \n\t" /* 8 */ "ror %[out] \n\t" : [out] "=r" (result) : [in] "r" (x)); return (result); } // ========================================================================================== // Effect functions // ========================================================================================== void effect_wormsqueeze (int size, int axis, int direction, int iterations, int delay) { int x, y, i, j, k, dx, dy; int cube_size; int origin = 0; if (direction == -1) origin = 7; cube_size = 8 - (size - 1); x = rand() % cube_size; y = rand() % cube_size; for (i = 0; i < iterations; i++) { dx = ((rand() % 3) - 1); dy = ((rand() % 3) - 1); if ((x + dx) > 0 && (x + dx) < cube_size) x += dx; if ((y + dy) > 0 && (y + dy) < cube_size) y += dy; shift(axis, direction); for (j = 0; j < size; j++) { for (k = 0; k < size; k++) { if (axis == AXIS_Z) setvoxel(x + j, y + k, origin); if (axis == AXIS_Y) setvoxel(x + j, origin, y + k); if (axis == AXIS_X) setvoxel(origin, y + j, x + k); } } delay_ms(delay); } } volatile const unsigned char font[910] [5] = { //volatile const unsigned char font[455] EEMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f, 0x5f, 0x00, 0x00, // ! 0x00, 0x03, 0x00, 0x03, 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14, // "# 0x24, 0x2a, 0x7f, 0x2a, 0x12, 0x23, 0x13, 0x08, 0x64, 0x62, // $% 0x36, 0x49, 0x55, 0x22, 0x50, 0x00, 0x05, 0x03, 0x00, 0x00, // &' 0x00, 0x1c, 0x22, 0x41, 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00, // () 0x14, 0x08, 0x3e, 0x08, 0x14, 0x08, 0x08, 0x3e, 0x08, 0x08, // *+ 0x00, 0x50, 0x30, 0x00, 0x00, 0x08, 0x08, 0x08, 0x08, 0x08, // ,- 0x00, 0x60, 0x60, 0x00, 0x00, 0x20, 0x10, 0x08, 0x04, 0x02, // ./ 0x3e, 0x51, 0x49, 0x45, 0x3e, 0x00, 0x42, 0x7f, 0x40, 0x00, // 01 0x42, 0x61, 0x51, 0x49, 0x46, 0x21, 0x41, 0x45, 0x4b, 0x31, // 23 0x18, 0x14, 0x12, 0x7f, 0x10, 0x27, 0x45, 0x45, 0x45, 0x39, // 45 0x3c, 0x4a, 0x49, 0x49, 0x30, 0x01, 0x71, 0x09, 0x05, 0x03, // 67 0x36, 0x49, 0x49, 0x49, 0x36, 0x06, 0x49, 0x49, 0x29, 0x1e, // 89 0x00, 0x36, 0x36, 0x00, 0x00, 0x00, 0x56, 0x36, 0x00, 0x00, // :; 0x08, 0x14, 0x22, 0x41, 0x00, 0x14, 0x14, 0x14, 0x14, 0x14, // <= 0x00, 0x41, 0x22, 0x14, 0x08, 0x02, 0x01, 0x51, 0x09, 0x06, // >? 0x32, 0x49, 0x79, 0x41, 0x3e, 0x7e, 0x11, 0x11, 0x11, 0x7e, // @A 0x7f, 0x49, 0x49, 0x49, 0x36, 0x3e, 0x41, 0x41, 0x41, 0x22, // BC 0x7f, 0x41, 0x41, 0x22, 0x1c, 0x7f, 0x49, 0x49, 0x49, 0x41, // DE 0x7f, 0x09, 0x09, 0x09, 0x01, 0x3e, 0x41, 0x49, 0x49, 0x7a, // FG 0x7f, 0x08, 0x08, 0x08, 0x7f, 0x00, 0x41, 0x7f, 0x41, 0x00, // HI 0x20, 0x40, 0x41, 0x3f, 0x01, 0x7f, 0x08, 0x14, 0x22, 0x41, // JK 0x7f, 0x40, 0x40, 0x40, 0x40, 0x7f, 0x02, 0x0c, 0x02, 0x7f, // LM 0x7f, 0x04, 0x08, 0x10, 0x7f, 0x3e, 0x41, 0x41, 0x41, 0x3e, // NO 0x7f, 0x09, 0x09, 0x09, 0x06, 0x3e, 0x41, 0x51, 0x21, 0x5e, // PQ 0x7f, 0x09, 0x19, 0x29, 0x46, 0x46, 0x49, 0x49, 0x49, 0x31, // RS 0x01, 0x01, 0x7f, 0x01, 0x01, 0x3f, 0x40, 0x40, 0x40, 0x3f, // TU 0x1f, 0x20, 0x40, 0x20, 0x1f, 0x3f, 0x40, 0x38, 0x40, 0x3f, // VW 0x63, 0x14, 0x08, 0x14, 0x63, 0x07, 0x08, 0x70, 0x08, 0x07, // XY 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, 0x7f, 0x41, 0x41, 0x00, // Z[ 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x41, 0x41, 0x7f, 0x00, // \] 0x04, 0x02, 0x01, 0x02, 0x04, 0x40, 0x40, 0x40, 0x40, 0x40, // ^_ 0x00, 0x01, 0x02, 0x04, 0x00, 0x20, 0x54, 0x54, 0x54, 0x78, // `a 0x7f, 0x48, 0x44, 0x44, 0x38, 0x38, 0x44, 0x44, 0x44, 0x20, // bc 0x38, 0x44, 0x44, 0x48, 0x7f, 0x38, 0x54, 0x54, 0x54, 0x18, // de 0x08, 0x7e, 0x09, 0x01, 0x02, 0x0c, 0x52, 0x52, 0x52, 0x3e, // fg 0x7f, 0x08, 0x04, 0x04, 0x78, 0x00, 0x44, 0x7d, 0x40, 0x00, // hi 0x20, 0x40, 0x44, 0x3d, 0x00, 0x7f, 0x10, 0x28, 0x44, 0x00, // jk 0x00, 0x41, 0x7f, 0x40, 0x00, 0x7c, 0x04, 0x18, 0x04, 0x78, // lm 0x7c, 0x08, 0x04, 0x04, 0x78, 0x38, 0x44, 0x44, 0x44, 0x38, // no 0x7c, 0x14, 0x14, 0x14, 0x08, 0x08, 0x14, 0x14, 0x18, 0x7c, // pq 0x7c, 0x08, 0x04, 0x04, 0x08, 0x48, 0x54, 0x54, 0x54, 0x20, // rs 0x04, 0x3f, 0x44, 0x40, 0x20, 0x3c, 0x40, 0x40, 0x20, 0x7c, // tu 0x1c, 0x20, 0x40, 0x20, 0x1c, 0x3c, 0x40, 0x30, 0x40, 0x3c, // vw 0x44, 0x28, 0x10, 0x28, 0x44, 0x0c, 0x50, 0x50, 0x50, 0x3c, // xy 0x44, 0x64, 0x54, 0x4c, 0x44 // z }; volatile const unsigned char bitmaps[13][8] = { // volatile const unsigned char bitmaps[13][8] EEMEM = { {0xc3, 0xc3, 0x00, 0x18, 0x18, 0x81, 0xff, 0x7e}, // smiley 3 small {0x3c, 0x42, 0x81, 0x81, 0xc3, 0x24, 0xa5, 0xe7}, // Omega {0x00, 0x04, 0x06, 0xff, 0xff, 0x06, 0x04, 0x00}, // Arrow {0x81, 0x42, 0x24, 0x18, 0x18, 0x24, 0x42, 0x81}, // X {0xBD, 0xA1, 0xA1, 0xB9, 0xA1, 0xA1, 0xA1, 0x00}, // ifi {0xEF, 0x48, 0x4B, 0x49, 0x4F, 0x00, 0x00, 0x00}, // TG {0x38, 0x7f, 0xE6, 0xC0, 0xE6, 0x7f, 0x38, 0x00}, // Commodore symbol {0x00, 0x22, 0x77, 0x7f, 0x3e, 0x3e, 0x1c, 0x08}, // Heart {0x1C, 0x22, 0x55, 0x49, 0x5d, 0x22, 0x1c, 0x00}, // face {0x37, 0x42, 0x22, 0x12, 0x62, 0x00, 0x7f, 0x00}, // ST {0x89, 0x4A, 0x2c, 0xF8, 0x1F, 0x34, 0x52, 0x91}, // STAR {0x18, 0x3c, 0x7e, 0xdb, 0xff, 0x24, 0x5a, 0xa5}, // Space Invader {0x00, 0x9c, 0xa2, 0xc5, 0xc1, 0xa2, 0x9c, 0x00} // Fish }; const unsigned char paths[44] PROGMEM = {0x07, 0x06, 0x05, 0x04, 0x03, 0x02, 0x01, 0x00, 0x10, 0x20, 0x30, 0x40, 0x50, 0x60, 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77, 0x67, 0x57, 0x47, 0x37, 0x27, 0x17, 0x04, 0x03, 0x12, 0x21, 0x30, 0x40, 0x51, 0x62, 0x73, 0x74, 0x65, 0x56, 0x47, 0x37, 0x26, 0x15 }; // circle, len 16, offset 28 void font_getpath (unsigned char path, unsigned char *destination, int length) { int i; int offset = 0; if (path == 1) offset = 28; for (i = 0; i < length; i++) destination[i] = pgm_read_byte(&paths[i + offset]); } void effect_pathmove (unsigned char *path, int length) { int i, z; unsigned char state; for (i = (length - 1); i >= 1; i--) { for (z = 0; z < 8; z++) { state = getvoxel(((path[(i - 1)] >> 4) & 0x0f), (path[(i - 1)] & 0x0f), z); altervoxel(((path[i] >> 4) & 0x0f), (path[i] & 0x0f), z, state); } } for (i = 0; i < 8; i++) clrvoxel(((path[0] >> 4) & 0x0f), (path[0] & 0x0f), i); } void effect_rand_patharound (int iterations, int delay) { int z, dz, i; z = 4; unsigned char path[28]; font_getpath(0, path, 28); for (i = 0; i < iterations; i++) { dz = ((rand() % 3) - 1); z += dz; if (z > 7) z = 7; if (z < 0) z = 0; effect_pathmove(path, 28); setvoxel(0, 7, z); delay_ms(delay); } } void effect_intro() { int cnt, cnt_2, time; //Bottom To Top for (cnt = 0; cnt <= 7; cnt++) { box_wireframe(0, 0, 0, 7, 7, cnt); delay_ms(2000); } for (cnt = 0; cnt < 7; cnt++) { clrplane_z(cnt); delay_ms(2000); } //Shift Things Right //1 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 6); } delay_ms(2000); //2 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 5); } setvoxel(0, 0, 6); setvoxel(7, 0, 6); delay_ms(2000); //3 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 4); } setvoxel(0, 0, 5); setvoxel(7, 0, 5); setvoxel(0, 0, 6); setvoxel(7, 0, 6); delay_ms(2000); //4 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 3); } setvoxel(0, 0, 4); setvoxel(7, 0, 4); setvoxel(0, 0, 5); setvoxel(7, 0, 5); setvoxel(0, 0, 6); setvoxel(7, 0, 6); delay_ms(2000); //5 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 2); } setvoxel(0, 0, 3); setvoxel(7, 0, 3); setvoxel(0, 0, 4); setvoxel(7, 0, 4); setvoxel(0, 0, 5); setvoxel(7, 0, 5); setvoxel(0, 0, 6); setvoxel(7, 0, 6); delay_ms(2000); //6 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 1); } setvoxel(0, 0, 2); setvoxel(7, 0, 2); setvoxel(0, 0, 3); setvoxel(7, 0, 3); setvoxel(0, 0, 4); setvoxel(7, 0, 4); setvoxel(0, 0, 5); setvoxel(7, 0, 5); delay_ms(2000); //7 shift(AXIS_Y, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, 0, 0); } setvoxel(0, 0, 1); setvoxel(7, 0, 1); setvoxel(0, 0, 2); setvoxel(7, 0, 2); setvoxel(0, 0, 3); setvoxel(7, 0, 3); setvoxel(0, 0, 4); setvoxel(7, 0, 4); setvoxel(0, 0, 5); setvoxel(7, 0, 5); delay_ms(2000); //Right To Left for (cnt = 0; cnt <= 7; cnt++) { box_wireframe(0, 0, 0, 7, cnt, 7); delay_ms(2000); } for (cnt = 0; cnt < 7; cnt++) { clrplane_y(cnt); delay_ms(2000); } //Shift to the bottom for (cnt_2 = 6; cnt_2 >= 0; cnt_2--) { shift(AXIS_Z, -1); for (cnt = 0; cnt <= 7; cnt++) { setvoxel(cnt, cnt_2, 0); } for (cnt = 6; cnt > cnt_2; cnt--) { setvoxel(0, cnt, 0); setvoxel(7, cnt, 0); } delay_ms(2000); } //Make All Wall Box for (cnt = 0; cnt <= 6; cnt++) { fill(0x00); box_walls(0, 0, 0, 7, 7, cnt); delay_ms(2000); } time = 2000; for (cnt_2 = 0; cnt_2 < 5; cnt_2++) { time = time - 300; //Make Box Smaller for (cnt = 0; cnt <= 3; cnt++) { fill(0x00); box_walls(cnt, cnt, cnt, 7 - cnt, 7 - cnt, 7 - cnt); delay_ms(time); } //Make Box Bigger for (cnt = 0; cnt <= 3; cnt++) { fill(0x00); box_walls(3 - cnt, 3 - cnt, 3 - cnt, 4 + cnt, 4 + cnt, 4 + cnt); delay_ms(time); } } for (cnt_2 = 0; cnt_2 < 5; cnt_2++) { time = time + 300; //Make Box Smaller for (cnt = 0; cnt <= 3; cnt++) { fill(0x00); box_walls(cnt, cnt, cnt, 7 - cnt, 7 - cnt, 7 - cnt); delay_ms(time); } //Make Box Bigger for (cnt = 0; cnt <= 3; cnt++) { fill(0x00); box_walls(3 - cnt, 3 - cnt, 3 - cnt, 4 + cnt, 4 + cnt, 4 + cnt); delay_ms(time); } } delay_ms(2000); } void sinelines (int iterations, int delay) { int i, x; float left, right, sine_base, x_dividor, ripple_height; for (i = 0; i < iterations; i++) { for (x = 0; x < 8 ; x++) { x_dividor = 2 + sin((float)i / 100) + 1; ripple_height = 3 + (sin((float)i / 200) + 1) * 6; sine_base = (float) i / 40 + (float) x / x_dividor; left = 4 + sin(sine_base) * ripple_height; right = 4 + cos(sine_base) * ripple_height; right = 7 - left; //printf("%i %i \n", (int) left, (int) right); line_3d(0 - 3, x, (int) left, 7 + 3, x, (int) right); //line_3d((int) right, 7, x); } // delay_ms(delay); fill(0x00); } } void effect_random_sparkle_flash (int iterations, int voxels, int delay) { int i; int v; for (i = 0; i < iterations; i++) { for (v = 0; v <= voxels; v++) setvoxel(rand() % 8, rand() % 8, rand() % 8); delay_ms(delay); fill(0x00); } } void draw_positions_axis (char axis, unsigned char positions[64], int invert) { int x, y, p; fill(0x00); for (x = 0; x < 8; x++) { for (y = 0; y < 8; y++) { if (invert) { p = (7 - positions[(x * 8) + y]); } else { p = positions[(x * 8) + y]; } if (axis == AXIS_Z) setvoxel(x, y, p); if (axis == AXIS_Y) setvoxel(x, p, y); if (axis == AXIS_X) setvoxel(p, y, x); } } } void effect_random_sparkle (void) { int i; for (i = 1; i < 20; i++) { effect_random_sparkle_flash(5, i, 200); } for (i = 20; i >= 1; i--) { effect_random_sparkle_flash(5, i, 200); } } void side_ripples(int iterations, int delay) { // 16 values for square root of a^2+b^2. index a*4+b = 10*sqrt // This gives the distance to 3.5,3.5 from the point unsigned char sqrt_LUT[] = {49, 43, 38, 35, 43, 35, 29, 26, 38, 29, 21, 16, 35, 25, 16, 7}; //LUT_START // Macro from new tottymath. Commented and replaced with full code unsigned char LUT[65]; init_LUT(LUT); int i; unsigned char x, y, height, distance; for (i = 0; i < iterations * 4; i += 4) { fill(0x00); for (x = 0; x < 4; x++) for (y = 0; y < 4; y++) { // x+y*4 gives no. from 0-15 for sqrt_LUT distance = sqrt_LUT[x + y * 4]; // distance is 0-50 roughly // height is sin of distance + iteration*4 //height=4+totty_sin(LUT,distance+i)/52; height = (196 + totty_sin(LUT, distance + i)) / 49; // Use 4-way mirroring to save on calculations setvoxel(x, height, y); setvoxel(7 - x, height, y); setvoxel(x, height, 7 - y); setvoxel(7 - x, height, 7 - y); setvoxel(x, 7 - height, y); setvoxel(7 - x, 7 - height, y); setvoxel(x, 7 - height, 7 - y); setvoxel(7 - x, 7 - height, 7 - y); } delay_ms(delay); } } void mirror_ripples(int iterations, int delay) { // 16 values for square root of a^2+b^2. index a*4+b = 10*sqrt // This gives the distance to 3.5,3.5 from the point unsigned char sqrt_LUT[] = {49, 43, 38, 35, 43, 35, 29, 26, 38, 29, 21, 16, 35, 25, 16, 7}; //LUT_START // Macro from new tottymath. Commented and replaced with full code unsigned char LUT[65]; init_LUT(LUT); int i; unsigned char x, y, height, distance; for (i = 0; i < iterations * 4; i += 4) { fill(0x00); for (x = 0; x < 4; x++) for (y = 0; y < 4; y++) { // x+y*4 gives no. from 0-15 for sqrt_LUT distance = sqrt_LUT[x + y * 4]; // distance is 0-50 roughly // height is sin of distance + iteration*4 //height=4+totty_sin(LUT,distance+i)/52; height = (196 + totty_sin(LUT, distance + i)) / 49; // Use 4-way mirroring to save on calculations setvoxel(x, y, height); setvoxel(7 - x, y, height); setvoxel(x, 7 - y, height); setvoxel(7 - x, 7 - y, height); setvoxel(x, y, 7 - height); setvoxel(7 - x, y, 7 - height); setvoxel(x, 7 - y, 7 - height); setvoxel(7 - x, 7 - y, 7 - height); } delay_ms(delay); } } void quad_ripples(int iterations, int delay) { // 16 values for square root of a^2+b^2. index a*4+b = 10*sqrt // This gives the distance to 3.5,3.5 from the point unsigned char sqrt_LUT[] = {49, 43, 38, 35, 43, 35, 29, 26, 38, 29, 21, 16, 35, 25, 16, 7}; //LUT_START // Macro from new tottymath. Commented and replaced with full code unsigned char LUT[65]; init_LUT(LUT); int i; unsigned char x, y, height, distance; for (i = 0; i < iterations * 4; i += 4) { fill(0x00); for (x = 0; x < 4; x++) for (y = 0; y < 4; y++) { // x+y*4 gives no. from 0-15 for sqrt_LUT distance = sqrt_LUT[x + y * 4]; // distance is 0-50 roughly // height is sin of distance + iteration*4 //height=4+totty_sin(LUT,distance+i)/52; height = (196 + totty_sin(LUT, distance + i)) / 49; // Use 4-way mirroring to save on calculations setvoxel(x, y, height); setvoxel(7 - x, y, height); setvoxel(x, 7 - y, height); setvoxel(7 - x, 7 - y, height); setvoxel(x, y, 7 - height); setvoxel(7 - x, y, 7 - height); setvoxel(x, 7 - y, 7 - height); setvoxel(7 - x, 7 - y, 7 - height); setvoxel(x, height, y); setvoxel(7 - x, height, y); setvoxel(x, height, 7 - y); setvoxel(7 - x, height, 7 - y); setvoxel(x, 7 - height, y); setvoxel(7 - x, 7 - height, y); setvoxel(x, 7 - height, 7 - y); setvoxel(7 - x, 7 - height, 7 - y); } delay_ms(delay); } } void init_LUT(unsigned char LUT[65]) { unsigned char i; float sin_of, sine; for (i = 0; i < 65; i++) { sin_of = i * PI / 64; // Just need half a sin wave sine = sin(sin_of); // Use 181.0 as this squared is <32767, so we can multiply two sin or cos without overflowing an int. LUT[i] = sine * 181.0; } } void effect_axis_updown_randsuspend (char axis, int delay, int sleep, int invert) { unsigned char positions[64]; unsigned char destinations[64]; int i, px; // Set 64 random positions for (i = 0; i < 64; i++) { positions[i] = 0; // Set all starting positions to 0 destinations[i] = rand() % 8; } // Loop 8 times to allow destination 7 to reach all the way for (i = 0; i < 8; i++) { // For every iteration, move all position one step closer to their destination for (px = 0; px < 64; px++) { if (positions[px] < destinations[px]) { positions[px]++; } } // Draw the positions and take a nap draw_positions_axis (axis, positions, invert); delay_ms(delay); } // Set all destinations to 7 (opposite from the side they started out) for (i = 0; i < 64; i++) { destinations[i] = 7; } // Suspend the positions in mid-air for a while delay_ms(sleep); // Then do the same thing one more time for (i = 0; i < 8; i++) { for (px = 0; px < 64; px++) { if (positions[px] < destinations[px]) { positions[px]++; } if (positions[px] > destinations[px]) { positions[px]--; } } draw_positions_axis (axis, positions, invert); delay_ms(delay); } } void linespin (int iterations, int delay) { float top_x, top_y, top_z, bot_x, bot_y, bot_z, sin_base; float center_x, center_y; center_x = 4; center_y = 4; int i, z; for (i = 0; i < iterations; i++) { //printf("Sin base %f \n",sin_base); for (z = 0; z < 8; z++) { sin_base = (float)i / 50 + (float)z / (10 + (7 * sin((float)i / 200))); top_x = center_x + sin(sin_base) * 5; top_y = center_x + cos(sin_base) * 5; //top_z = center_x + cos(sin_base/100)*2.5; bot_x = center_x + sin(sin_base + 3.14) * 10; bot_y = center_x + cos(sin_base + 3.14) * 10; //bot_z = 7-top_z; bot_z = z; top_z = z; // setvoxel((int) top_x, (int) top_y, 7); // setvoxel((int) bot_x, (int) bot_y, 0); //printf("P1: %i %i %i P2: %i %i %i \n", (int) top_x, (int) top_y, 7, (int) bot_x, (int) bot_y, 0); //line_3d((int) top_x, (int) top_y, (int) top_z, (int) bot_x, (int) bot_y, (int) bot_z); line_3d((int) top_z, (int) top_x, (int) top_y, (int) bot_z, (int) bot_x, (int) bot_y); } // delay_ms(delay); fill(0x00); } } void line_3d (int x1, int y1, int z1, int x2, int y2, int z2) { int i, dx, dy, dz, l, m, n, x_inc, y_inc, z_inc, err_1, err_2, dx2, dy2, dz2; int pixel[3]; pixel[0] = x1; pixel[1] = y1; pixel[2] = z1; dx = x2 - x1; dy = y2 - y1; dz = z2 - z1; x_inc = (dx < 0) ? -1 : 1; l = abs(dx); y_inc = (dy < 0) ? -1 : 1; m = abs(dy); z_inc = (dz < 0) ? -1 : 1; n = abs(dz); dx2 = l << 1; dy2 = m << 1; dz2 = n << 1; if ((l >= m) && (l >= n)) { err_1 = dy2 - l; err_2 = dz2 - l; for (i = 0; i < l; i++) { //PUT_PIXEL(pixel); setvoxel(pixel[0], pixel[1], pixel[2]); //printf("Setting %i %i %i \n", pixel[0],pixel[1],pixel[2]); if (err_1 > 0) { pixel[1] += y_inc; err_1 -= dx2; } if (err_2 > 0) { pixel[2] += z_inc; err_2 -= dx2; } err_1 += dy2; err_2 += dz2; pixel[0] += x_inc; } } else if ((m >= l) && (m >= n)) { err_1 = dx2 - m; err_2 = dz2 - m; for (i = 0; i < m; i++) { //PUT_PIXEL(pixel); setvoxel(pixel[0], pixel[1], pixel[2]); //printf("Setting %i %i %i \n", pixel[0],pixel[1],pixel[2]); if (err_1 > 0) { pixel[0] += x_inc; err_1 -= dy2; } if (err_2 > 0) { pixel[2] += z_inc; err_2 -= dy2; } err_1 += dx2; err_2 += dz2; pixel[1] += y_inc; } } else { err_1 = dy2 - n; err_2 = dx2 - n; for (i = 0; i < n; i++) { setvoxel(pixel[0], pixel[1], pixel[2]); //printf("Setting %i %i %i \n", pixel[0],pixel[1],pixel[2]); //PUT_PIXEL(pixel); if (err_1 > 0) { pixel[1] += y_inc; err_1 -= dz2; } if (err_2 > 0) { pixel[0] += x_inc; err_2 -= dz2; } err_1 += dy2; err_2 += dx2; pixel[2] += z_inc; } } setvoxel(pixel[0], pixel[1], pixel[2]); //printf("Setting %i %i %i \n", pixel[0],pixel[1],pixel[2]); //PUT_PIXEL(pixel); } // ****************************************** int totty_sin(unsigned char LUT[65], int sin_of) { unsigned char inv = 0; if (sin_of < 0) { sin_of = -sin_of; inv = 1; } sin_of &= 0x7f; //127 if (sin_of > 64) { sin_of -= 64; inv = 1 - inv; } if (inv) return -LUT[sin_of]; else return LUT[sin_of]; } void fireworks (int iterations, int n, int delay) { fill(0x00); int i, f, e; float origin_x = 3; float origin_y = 3; float origin_z = 3; int rand_y, rand_x, rand_z; float slowrate, gravity; // Particles and their position, x,y,z and their movement, dx, dy, dz float particles[n][6]; for (i = 0; i < iterations; i++) { origin_x = rand() % 4; origin_y = rand() % 4; origin_z = rand() % 2; origin_z += 5; origin_x += 2; origin_y += 2; // shoot a particle up in the air for (e = 0; e < origin_z; e++) { setvoxel(origin_x, origin_y, e); delay_ms(600 + 500 * e); fill(0x00); } // Fill particle array for (f = 0; f < n; f++) { // Position particles[f][0] = origin_x; particles[f][1] = origin_y; particles[f][2] = origin_z; rand_x = rand() % 200; rand_y = rand() % 200; rand_z = rand() % 200; // Movement particles[f][3] = 1 - (float)rand_x / 100; // dx particles[f][4] = 1 - (float)rand_y / 100; // dy particles[f][5] = 1 - (float)rand_z / 100; // dz } // explode for (e = 0; e < 25; e++) { slowrate = 1 + tan((e + 0.1) / 20) * 10; gravity = tan((e + 0.1) / 20) / 2; for (f = 0; f < n; f++) { particles[f][0] += particles[f][3] / slowrate; particles[f][1] += particles[f][4] / slowrate; particles[f][2] += particles[f][5] / slowrate; particles[f][2] -= gravity; setvoxel(particles[f][0], particles[f][1], particles[f][2]); } delay_ms(delay); fill(0x00); } } } void effect_box_wamp(int delayt) { for (int k = 0; k < 3; k++) { for (int i = 0; i < 4; i++) { fill(0x00); box_filled(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } for (int i = 3; i >= 0; i--) { fill(0x00); box_filled(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } } for (int k = 0; k < 3; k++) { for (int i = 0; i < 4; i++) { fill(0x00); box_walls(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } for (int i = 3; i >= 0; i--) { fill(0x00); box_walls(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } } for (int k = 0; k < 3; k++) { for (int i = 0; i < 4; i++) { fill(0x00); box_wireframe(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } for (int i = 3; i >= 0; i--) { fill(0x00); box_wireframe(3 - i, 3 - i, 3 - i, 4 + i, 4 + i, 4 + i); delay_ms(delayt); } } } void effect_boxside_randsend_parallel (char axis, int origin, int delayt, int mode) { int i; int done; unsigned char cubepos[64]; unsigned char pos[64]; int notdone = 1; int notdone2 = 1; int sent = 0; for (i = 0; i < 64; i++) { pos[i] = 0; } while (notdone) { if (mode == 1) { notdone2 = 1; while (notdone2 && sent < 64) { i = rand() % 64; if (pos[i] == 0) { sent++; pos[i] += 1; notdone2 = 0; } } } else if (mode == 2) { if (sent < 64) { pos[sent] += 1; sent++; } } done = 0; for (i = 0; i < 64; i++) { if (pos[i] > 0 && pos[i] < 7) { pos[i] += 1; } if (pos[i] == 7) done++; } if (done == 64) notdone = 0; for (i = 0; i < 64; i++) { if (origin == 0) { cubepos[i] = pos[i]; } else { cubepos[i] = (7 - pos[i]); } } delay_ms(delayt); draw_positions_axis(axis, cubepos, 0); } } void effect_rain (int iterations) { int i, ii; int rnd_x; int rnd_y; int rnd_num; for (ii = 0; ii < iterations; ii++) { rnd_num = rand() % 4; for (i = 0; i < rnd_num; i++) { rnd_x = rand() % 8; rnd_y = rand() % 8; setvoxel(rnd_x, rnd_y, 7); } delay_ms(1000); shift(AXIS_Z, -1); } } // Set or clear exactly 512 voxels in a random order. void effect_random_filler (int delayt, int state) { int x, y, z; int loop = 0; if (state == 1) { fill(0x00); } else { fill(0xff); } while (loop < 511) { x = rand() % 8; y = rand() % 8; z = rand() % 8; if ((state == 0 && getvoxel(x, y, z) == 0x01) || (state == 1 && getvoxel(x, y, z) == 0x00)) { altervoxel(x, y, z, state); delay_ms(delayt); loop++; } } } void effect_blinky2() { int i, r; fill(0x00); for (r = 0; r < 2; r++) { i = 750; while (i > 0) { fill(0x00); delay_ms(i); fill(0xff); delay_ms(100); i = i - (15 + (1000 / (i / 10))); } delay_ms(1000); i = 750; while (i > 0) { fill(0x00); delay_ms(751 - i); fill(0xff); delay_ms(100); i = i - (15 + (1000 / (i / 10))); } } } // Draw a plane on one axis and send it back and forth once. void effect_planboing (int plane, int speedd) { int i; for (i = 0; i < 8; i++) { fill(0x00); setplane(plane, i); delay_ms(speedd); } for (i = 7; i >= 0; i--) { fill(0x00); setplane(plane, i); delay_ms(speedd); } } // ========================================================================================== // Draw functions // ========================================================================================== // Set a single voxel to ON void setvoxel(int x, int y, int z) { if (inrange(x, y, z)) cube[z][y] |= (1 << x); } // Set a single voxel to ON void clrvoxel(int x, int y, int z) { if (inrange(x, y, z)) cube[z][y] &= ~(1 << x); } // This function validates that we are drawing inside the cube. unsigned char inrange(int x, int y, int z) { if (x >= 0 && x < 8 && y >= 0 && y < 8 && z >= 0 && z < 8) { return 0x01; } else { // One of the coordinates was outside the cube. return 0x00; } } // Get the current status of a voxel unsigned char getvoxel(int x, int y, int z) { if (inrange(x, y, z)) { if (cube[z][y] & (1 << x)) { return 0x01; } else { return 0x00; } } else { return 0x00; } } // In some effect we want to just take bool and write it to a voxel // this function calls the apropriate voxel manipulation function. void altervoxel(int x, int y, int z, int state) { if (state == 1) { setvoxel(x, y, z); } else { clrvoxel(x, y, z); } } // Flip the state of a voxel. // If the voxel is 1, its turned into a 0, and vice versa. void flpvoxel(int x, int y, int z) { if (inrange(x, y, z)) cube[z][y] ^= (1 << x); } // Makes sure x1 is alwas smaller than x2 // This is usefull for functions that uses for loops, // to avoid infinite loops void argorder(int ix1, int ix2, int *ox1, int *ox2) { if (ix1 > ix2) { int tmp; tmp = ix1; ix1 = ix2; ix2 = tmp; } *ox1 = ix1; *ox2 = ix2; } // Sets all voxels along a X/Y plane at a given point // on axis Z void setplane_z (int z) { int i; if (z >= 0 && z < 8) { for (i = 0; i < 8; i++) cube[z][i] = 0xff; } } // Clears voxels in the same manner as above void clrplane_z (int z) { int i; if (z >= 0 && z < 8) { for (i = 0; i < 8; i++) cube[z][i] = 0x00; } } void setplane_x (int x) { int z; int y; if (x >= 0 && x < 8) { for (z = 0; z < 8; z++) { for (y = 0; y < 8; y++) { cube[z][y] |= (1 << x); } } } } void clrplane_x (int x) { int z; int y; if (x >= 0 && x < 8) { for (z = 0; z < 8; z++) { for (y = 0; y < 8; y++) { cube[z][y] &= ~(1 << x); } } } } void setplane_y (int y) { int z; if (y >= 0 && y < 8) { for (z = 0; z < 8; z++) cube[z][y] = 0xff; } } void clrplane_y (int y) { int z; if (y >= 0 && y < 8) { for (z = 0; z < 8; z++) cube[z][y] = 0x00; } } void setplane (char axis, unsigned char i) { switch (axis) { case AXIS_X: setplane_x(i); break; case AXIS_Y: setplane_y(i); break; case AXIS_Z: setplane_z(i); break; } } void clrplane (char axis, unsigned char i) { switch (axis) { case AXIS_X: clrplane_x(i); break; case AXIS_Y: clrplane_y(i); break; case AXIS_Z: clrplane_z(i); break; } } // Fill a value into all 64 byts of the cube buffer // Mostly used for clearing. fill(0x00) // or setting all on. fill(0xff) void fill (unsigned char pattern) { int z; int y; for (z = 0; z < 8; z++) { for (y = 0; y < 8; y++) { cube[z][y] = pattern; } } } // Draw a box with all walls drawn and all voxels inside set void box_filled(int x1, int y1, int z1, int x2, int y2, int z2) { int iy; int iz; argorder(x1, x2, &x1, &x2); argorder(y1, y2, &y1, &y2); argorder(z1, z2, &z1, &z2); for (iz = z1; iz <= z2; iz++) { for (iy = y1; iy <= y2; iy++) { cube[iz][iy] |= byteline(x1, x2); } } } // Darw a hollow box with side walls. void box_walls(int x1, int y1, int z1, int x2, int y2, int z2) { int iy; int iz; argorder(x1, x2, &x1, &x2); argorder(y1, y2, &y1, &y2); argorder(z1, z2, &z1, &z2); for (iz = z1; iz <= z2; iz++) { for (iy = y1; iy <= y2; iy++) { if (iy == y1 || iy == y2 || iz == z1 || iz == z2) { cube[iz][iy] = byteline(x1, x2); } else { cube[iz][iy] |= ((0x01 << x1) | (0x01 << x2)); } } } } // Draw a wireframe box. This only draws the corners and edges, // no walls. void box_wireframe(int x1, int y1, int z1, int x2, int y2, int z2) { int iy; int iz; argorder(x1, x2, &x1, &x2); argorder(y1, y2, &y1, &y2); argorder(z1, z2, &z1, &z2); // Lines along X axis cube[z1][y1] = byteline(x1, x2); cube[z1][y2] = byteline(x1, x2); cube[z2][y1] = byteline(x1, x2); cube[z2][y2] = byteline(x1, x2); // Lines along Y axis for (iy = y1; iy <= y2; iy++) { setvoxel(x1, iy, z1); setvoxel(x1, iy, z2); setvoxel(x2, iy, z1); setvoxel(x2, iy, z2); } // Lines along Z axis for (iz = z1; iz <= z2; iz++) { setvoxel(x1, y1, iz); setvoxel(x1, y2, iz); setvoxel(x2, y1, iz); setvoxel(x2, y2, iz); } } // Returns a byte with a row of 1's drawn in it. // byteline(2,5) gives 0b00111100 char byteline (int start, int end) { return ((0xff << start) & ~(0xff << (end + 1))); } // Flips a byte 180 degrees. // MSB becomes LSB, LSB becomes MSB. char flipbyte (char byte) { char flop = 0x00; flop = (flop & 0b11111110) | (0b00000001 & (byte >> 7)); flop = (flop & 0b11111101) | (0b00000010 & (byte >> 5)); flop = (flop & 0b11111011) | (0b00000100 & (byte >> 3)); flop = (flop & 0b11110111) | (0b00001000 & (byte >> 1)); flop = (flop & 0b11101111) | (0b00010000 & (byte << 1)); flop = (flop & 0b11011111) | (0b00100000 & (byte << 3)); flop = (flop & 0b10111111) | (0b01000000 & (byte << 5)); flop = (flop & 0b01111111) | (0b10000000 & (byte << 7)); return flop; } // Draw a line between any coordinates in 3d space. // Uses integer values for input, so dont expect smooth animations. void line(int x1, int y1, int z1, int x2, int y2, int z2) { float xy; // how many voxels do we move on the y axis for each step on the x axis float xz; // how many voxels do we move on the y axis for each step on the x axis unsigned char x, y, z; unsigned char lasty, lastz; // We always want to draw the line from x=0 to x=7. // If x1 is bigget than x2, we need to flip all the values. if (x1 > x2) { int tmp; tmp = x2; x2 = x1; x1 = tmp; tmp = y2; y2 = y1; y1 = tmp; tmp = z2; z2 = z1; z1 = tmp; } if (y1 > y2) { xy = (float)(y1 - y2) / (float)(x2 - x1); lasty = y2; } else { xy = (float)(y2 - y1) / (float)(x2 - x1); lasty = y1; } if (z1 > z2) { xz = (float)(z1 - z2) / (float)(x2 - x1); lastz = z2; } else { xz = (float)(z2 - z1) / (float)(x2 - x1); lastz = z1; } // For each step of x, y increments by: for (x = x1; x <= x2; x++) { y = (xy * (x - x1)) + y1; z = (xz * (x - x1)) + z1; setvoxel(x, y, z); } } // Delay loop. // This is not calibrated to milliseconds, // but we had allready made to many effects using this // calibration when we figured it might be a good idea // to calibrate it. void delay_ms(uint16_t x) { uint8_t y, z; for ( ; x > 0 ; x--) { for ( y = 0 ; y < 90 ; y++) { for ( z = 0 ; z < 6 ; z++) { asm volatile ("nop"); } } } } // Shift the entire contents of the cube along an axis // This is great for effects where you want to draw something // on one side of the cube and have it flow towards the other // side. Like rain flowing down the Z axiz. void shift (char axis, int direction) { int i, x , y; int ii, iii; int state; for (i = 0; i < 8; i++) { if (direction == -1) { ii = i; } else { ii = (7 - i); } for (x = 0; x < 8; x++) { for (y = 0; y < 8; y++) { if (direction == -1) { iii = ii + 1; } else { iii = ii - 1; } if (axis == AXIS_Z) { state = getvoxel(x, y, iii); altervoxel(x, y, ii, state); } if (axis == AXIS_Y) { state = getvoxel(x, iii, y); altervoxel(x, ii, y, state); } if (axis == AXIS_X) { state = getvoxel(iii, y, x); altervoxel(ii, y, x, state); } } } } if (direction == -1) { i = 7; } else { i = 0; } for (x = 0; x < 8; x++) { for (y = 0; y < 8; y++) { if (axis == AXIS_Z) clrvoxel(x, y, i); if (axis == AXIS_Y) clrvoxel(x, i, y); if (axis == AXIS_X) clrvoxel(i, y, x); } } }
