/********************************************************************************** * Home Automation with Alexa and NodeMCU * WeMos smart devices emulation using FAUXMOESP Library * * Code based on the great open source lib & example code at: * http://tinkerman.cat/emulate-wemo-device-esp8266/ * which is based off of the Python example code by: * https://github.com/makermusings/fauxmo * * Also, thanks to Sid for Sid's E Classroom * https://www.youtube.com/c/SidsEClassroom * * fauxmoESP is a library for ESP8266-based devices that emulates a Belkin WeMo device * and thus allows you to control them using this protocol, in particular from * Alexa-powered devices like the Amazon Echo or the Dot. * * 7 devices to be discovered: * * 4 Simple WeMo devices * ==> Light1 ==> Relay 1 ==> NodeMCU D5 * ==> Light2 ==> Relay 3 ==> NodeMCU D7 * ==> Outlet1 ==> Relay 2 ==> NodeMCU D6 * ==> Outlet2 ==> Relay 4 ==> NodeMCU D8 * * 3 Groups of devices * ==> All Devices * ==> Living Room (Light1 and Outlet1) * ==> Bed Room (Light2 and Outlet2) * * To discovery devices for the first time, use voice commnad: * "Computer (or Alexa), discovery devices" * * To activate a device or a gropu of devices, you should use voice commands, like: * "Computer (or Alexa), turn on Light1" or "..., turn off Light1" * "Computer (or Alexa), turn on Living Room" or "..., turn off Living Room" * "Computer (or Alexa), turn on All Devices" or "..., turn off All Devices" * * Developed by Marcelo Rovai on 19Aug17 * Visit my blog: https://MJRoBot.org *********************************************************************************/ #include #include #include "fauxmoESP.h" /* Network credentials */ #define WIFI_SSID "§§§§§" #define WIFI_PASS "§§§§§" #define SERIAL_BAUDRATE 115200 /* Belkin WeMo emulation */ fauxmoESP fauxmo; /* Set Relay Pins */ #define RELAY_1 D5 #define RELAY_2 D6 #define RELAY_3 D7 #define RELAY_4 D8 void setup() { Serial.begin(SERIAL_BAUDRATE); //setup and wifi connection wifiSetup(); //Set relay pins to outputs pinMode(RELAY_1, OUTPUT); pinMode(RELAY_2, OUTPUT); pinMode(RELAY_3, OUTPUT); pinMode(RELAY_4, OUTPUT); //Set each relay pin to HIGH ====== NOTE THAT THE RELAYS USE INVERSE LOGIC ===== digitalWrite(RELAY_1, HIGH); delay(500); digitalWrite(RELAY_2, HIGH); delay(500); digitalWrite(RELAY_3, HIGH); delay(500); digitalWrite(RELAY_4, HIGH); delay(500); // Device Names for Simulated Wemo switches fauxmo.addDevice("Light One"); fauxmo.addDevice("Light Two"); fauxmo.addDevice("Outlet One"); fauxmo.addDevice("Outlet Two"); fauxmo.onMessage(callback); } void loop() { fauxmo.handle(); } /* --------------------------------------------------------------------------- Device Callback ----------------------------------------------------------------------------*/ void callback(uint8_t device_id, const char * device_name, bool state) { Serial.print("Device "); Serial.print(device_name); Serial.print(" state: "); if (state) { Serial.println("ON"); } else { Serial.println("OFF"); } //Switching action on detection of device name if ( (strcmp(device_name, "Light One") == 0) ) { if (!state) { digitalWrite(RELAY_1, HIGH); } else { digitalWrite(RELAY_1, LOW); } } if ( (strcmp(device_name, "Light Two") == 0) ) { if (!state) { digitalWrite(RELAY_3, HIGH); } else { digitalWrite(RELAY_3, LOW); } } if ( (strcmp(device_name, "Outlet One") == 0) ) { if (!state) { digitalWrite(RELAY_2, HIGH); } else { digitalWrite(RELAY_2, LOW); } } if ( (strcmp(device_name, "Outlet Two") == 0) ) { if (!state) { digitalWrite(RELAY_4, HIGH); } else { digitalWrite(RELAY_4, LOW); } } } /* ----------------------------------------------------------------------------- Wifi Setup -----------------------------------------------------------------------------*/ void wifiSetup() { // Set WIFI module to STA mode WiFi.mode(WIFI_STA); // Connect Serial.println (); Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID); Serial.println(); WiFi.begin(WIFI_SSID, WIFI_PASS); // Wait while (WiFi.status() != WL_CONNECTED) { Serial.print("."); delay(100); } Serial.print(" ==> CONNECTED!" ); Serial.println(); // Connected! Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str()); Serial.println(); }
