'************************************************************************ 'GLIPICT.BAS Graphic application for use with a T6963C (or compatible) 'graphic LCD controller connected to a Microchip(TM) PIC 16F877 'Written in MELabs PicBasicPro(TM) Ver 3.32 'Beta version 0.8.0 'SHARP LCD used: 240x64 graphic LCD (EL backlight) '================== NOT FOR COMMERICIAL USE ============================= ' ' Author: Ranjit Diol - COMPSys, May 2001 ' (c) Copyright Ranjit Diol, 2001 ' ' DISCLAIMER: This file is being released as non-commericial ' freeware. It is being provided "AS IS", neither the author, ' nor COMPSys shall be held liable for any damages direct or indirect ' caused by its use. ' ' LICENSE: This application may be used in its entirety or ' in parts within some other non-commercial application as long ' as the author is given credit for those parts used. ' ' Contact: rsdiol@compsys1.com for more information ' ' Many thanks to Steve Lawther for his documentation on the T6963 ' and his sample assembly code which made this project possible ' '************************************************************************** device = 16F877 DEFINE ONINT_USED 1 'If using ISP DEFINE OSC 4 'Adjust to suit your design 'ADCON1 = 7 'Adjust ADC for your needs SPBRG=0 '************ NOTE *********** ALL_DIGITAL = True 'Variables used ' *** MODIFY AS REQUIRED FOR OTHER PINS AND PORTS ***** ' glcd_tris var TRISD 'Data bus direction glcd_dat var PORTD 'LCD 8 bit data bus glcd_wr var PORTc.2 'Write control bit glcd_rd var PORTe.0 'Read control bit glcd_ce var PORTe.1 'Chip enable control bit glcd_cd var PORTe.2 'Command and Data toggle bit glcd_rst var PORTa.5 'Reset control bit 'glcd_fs var PORTC.5 'Font select control bit 'glcd_bl var PORTA.5 'Back light control bit glcd_bsy var PORTD.7 'In case there is a need, not really used glcd_btn var PORTB.0 'A button for debugging purposes glcd_sta0 var PORTD.0 'Status Bit 0 glcd_sta1 var PORTD.1 'Status Bit 1 glcd_sta2 var PORTD.2 'Status Bit 2 glcd_sta3 var PORTD.3 'Status Bit 3 'General use variables used glcd_msb var BYTE 'Data 1 variable glcd_lsb var BYTE 'Data 2 variable glcd_cmd var BYTE 'Command variable gl_tmp var BYTE 'Temp var gl_old var BYTE 'Previous byte var gl_x var WORD '16 bit var for address loop gl_y var WORD '16 bit var for address loop gl_i var BYTE gl_j var BYTE gl_k var BYTE gl_l var BYTE num_1 var BYTE num_2 var BYTE gl_stp var BYTE 'Step var in FOR..NEXT gl_ad1 var BYTE 'Addr var gl_ad2 var BYTE 'Addr var graph_home var WORD 'LCD graphic start addr graph_area var WORD 'LCD graphic bytes per line text_home var WORD 'LCD text start addr text_area var WORD 'LCD text chars per line 'Initialize variables gl_tmp = 0 gl_i = 0 gl_stp = 1 '************************ ' LCD Module constants * '************************ ' 'Register set commands: CURSOR_PTR_SET con $21 'Cursor Pointer Set OFFSET_REG_SET con $22 'Offset Register Set ADDR_PTR_SET con $24 'Address Pointer Set 'Control Word Set commands: TEXT_HOME_SET con $40 'Text Home Address Set TEXT_AREA_SET con $41 'Text Area Set GRAPH_HOME_SET con $42 'Graphics Home address Set GRAPH_AREA_SET con $43 'Graphics Area Set 'Mode Set commands (OR with CG rom commands): OR_MODE con $80 'OR mode XOR_MODE con $81 'XOR mode AND_MODE con $83 'AND mode TEXT_ATTR_MODE con $84 'Text Attribute mode INT_CG_MODE con $80 'Internal CG ROM mode EXT_CG_MODE con $88 'External CG ROM mode 'Display Mode commands (OR together required bits): DISPLAY_OFF con $90 'display off BLINK_ON con $91 CURSOR_ON con $92 TEXT_ON con $94 GRAPHIC_ON con $98 TEXT_AND_GRAPH_ON con $9C 'Cursor Pattern Select CURSOR_1LINE con $A0 CURSOR_2LINE con $A1 CURSOR_3LINE con $A2 CURSOR_4LINE con $A3 CURSOR_5LINE con $A4 CURSOR_6LINE con $A5 CURSOR_7LINE con $A6 CURSOR_8LINE con $A7 'Data Auto Read/Write DATA_AUTO_WR con $B0 DATA_AUTO_RD con $B1 AUTO_DATA_RESET con $B2 'Data Read/Write DATA_WR_INC con $C0 'Data write and increment addr DATA_RD_INC con $C1 'Data read and increment addr DATA_WR_DEC con $C2 'Data write and decrement addr DATA_RD_DEC con $C3 'Data read and decrement addr DATA_WR con $C4 'Data write - no addr change DATA_RD con $C5 'Data read - no addr change 'Screen Peek SCREEN_PEEK con $E0 'Screen Copy SCREEN_COPY con $E8 'Bit Set/Reset (OR with bit number 0-7) BIT_RESET con $F0 BIT_SET con $F8 '************************ ' STATUS bits * '************************ STA0 con 0 'command excution status STA1 con 1 'data read/write status STA2 con 2 'auto data read status STA3 con 3 'auto data write status STA5 con 5 'controller status STA6 con 6 'peek/copy error flag STA7 con 7 'blink? or blank? status ASCII_OFFSET con $20 'ASCII offset for conversion GL_PAUSE con 2 'Initialize LCD VRAM area variables graph_home = $1000 'Decimal 4096 graph_area = $0028 '40 bytes per line text_home = $0000 text_area = $0028 '40 6x8 chars per line 'Set appropriate port/bit dir TRISB.0 = 0 TRISB.1 = 0 TRISB.2 = 0 TRISD = 0 TRISC = 0 TRISC.0 = 0 TRISC.2 = 0 TRISC.5 = 0 TRISA.4 = 0 TRISA.5 = 0 trise = 0 'Initial settings of port and bits glcd_dat = 0 'Clear PORTD glcd_wr = 1 'Write high glcd_rd = 1 'Read high glcd_ce = 1 'Chip enable high (active low) glcd_cd = 1 'Command high 'glcd_fs = 1 'Set Font size (1=6x8 and 0=8x8 font) glcd_rst = 1 'RESET always high (low will reset the LCD controller) 'glcd_bl = 0 'Backlight 0=off 1=on glcd_btn = 0 'debug led pause 500 'Let things stabilize glcd_rst = 0 ' Reset after power-on pause 1 glcd_rst = 1 portc.0 = 0 goto init '****** jump past the routines below ****** '*********** PBP Subroutines used in this program ******* send_2: gosub busy_chk glcd_dat = glcd_lsb glcd_cd = 0 glcd_rd = 1 glcd_ce = 0 glcd_wr = 0 pauseus GL_PAUSE glcd_wr = 1 glcd_ce = 1 send_1: gosub busy_chk glcd_dat = glcd_msb glcd_cd = 0 glcd_rd = 1 glcd_ce = 0 glcd_wr = 0 pauseus GL_PAUSE glcd_wr = 1 glcd_ce = 1 send_cmd: gosub busy_chk glcd_dat = glcd_cmd glcd_rd = 1 glcd_ce = 0 glcd_wr = 0 pauseus GL_PAUSE glcd_wr = 1 glcd_ce = 1 return busy_chk: glcd_ce = 1 glcd_tris= %11111111 glcd_cd = 1 glcd_wr = 1 glcd_ce = 0 glcd_rd = 0 pauseus GL_PAUSE if glcd_sta0 <> 1 AND glcd_sta1 <> 1 then busy_chk glcd_rd = 1 glcd_ce = 1 glcd_tris = %00000000 return ln1: ' Set Addr Ptr glcd_msb = gl_ad1 glcd_lsb = gl_ad2 glcd_cmd = ADDR_PTR_SET 'call SEND2 gosub send_2 for gl_x = num_1 to num_2 step gl_stp glcd_msb = gl_k glcd_cmd = DATA_WR_INC gosub send_1 next return setadr: ' Set Addr Ptr glcd_msb = gl_ad1 glcd_lsb = gl_ad2 glcd_cmd = ADDR_PTR_SET gosub send_2 return write1: glcd_msb = gl_k glcd_cmd = DATA_WR_INC gosub send_1 return design1: gl_j =$00 for gl_i = $00 to $07 for gl_y=($1820+gl_j) to ($1847+gl_j) step 2 gl_ad1= gl_y.BYTE1 gl_ad2= gl_y.BYTE0 gosub setadr gosub write1 next gl_j=gl_j+$28 next return '********** End of PBP subroutines ********************* '======================================================== '************End of all subroutines ********************* '******************************************************** '************* BEGIN MAIN PROGRAM *********************** '******************************************************** '***Initialize and setup display headings,titles etc **** init: 'Initialization 'See data sheets for more info for the commands and parameters ' Set Graphic Home Addr glcd_msb = graph_home.BYTE1 glcd_lsb = graph_home.BYTE0 glcd_cmd = GRAPH_HOME_SET gosub send_2 ' Set Graphic Area glcd_msb = graph_area.BYTE1 glcd_lsb = graph_area.BYTE0 glcd_cmd = GRAPH_AREA_SET gosub send_2 ' Set Text Home Addr glcd_msb = text_home.BYTE1 glcd_lsb = text_home.BYTE0 glcd_cmd = TEXT_HOME_SET gosub send_2 ' Set Text Area glcd_msb = text_area.BYTE1 glcd_lsb = text_area.BYTE0 glcd_cmd = TEXT_AREA_SET gosub send_2 ' Set OR mode glcd_cmd = OR_MODE gosub send_cmd ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $00 glcd_cmd = ADDR_PTR_SET gosub send_2 ' Set Graphic mode on glcd_cmd = GRAPHIC_ON gosub send_cmd for gl_i = 1 to 240 ' Clear Graphic Screen for gl_j = 1 to 64 glcd_msb = $00 'Clear byte glcd_cmd = DATA_WR_INC 'Command gosub send_1 'Send glcd_msb followed by glcd_cmd next next 'Do it 240x64 times ' Set Addr Ptr glcd_msb = $10 glcd_lsb = $00 glcd_cmd = ADDR_PTR_SET gosub send_2 for gl_y= $1000 to $14d8 step $28 'Left Vert Line gl_ad1= gl_y.BYTE1 gl_ad2= gl_y.BYTE0 gl_k=%11100000 num_1 =1 num_2 =1 gosub ln1 next for gl_y= $1027 to $1528 step $28 'Right Vert Line gl_ad1= gl_y.BYTE1 gl_ad2= gl_y.BYTE0 gl_k= %11000001 num_1 =1 num_2 =1 gosub ln1 next gl_k = $ff num_1 = 1 num_2 = 40 gl_stp = 1 gl_ad1 = $10 gl_ad2 = $00 gosub ln1 ' Graphic Line Top gl_ad1 = $15 gl_ad2 = $00 gosub ln1 ' Graphic Line Middle gl_ad1 = $19 gl_ad2 = $d8 gosub ln1 ' Graphic Line Bottom ' Set Graphic & Text mode on glcd_cmd = TEXT_ON gosub send_cmd ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $29 glcd_cmd = ADDR_PTR_SET gosub send_2 for gl_i = 0 to 35 lookup gl_i,["TOSHIBA T6963 "] ,glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $54 glcd_cmd = ADDR_PTR_SET gosub send_2 for gl_i = 0 to 7 lookup gl_i,["Counter"],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $65 glcd_cmd = ADDR_PTR_SET gosub send_2 for gl_i = 0 to 6 lookup gl_i,["Button"],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $ca glcd_cmd = ADDR_PTR_SET gosub send_2 for gl_i = 0 to 33 lookup gl_i,["By Ranjit Diol using PIC Basic Pro"],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next ' Set Graphic & Text mode on glcd_cmd = TEXT_AND_GRAPH_ON gosub send_cmd gl_tmp = 0 gl_old = 0 '************* MAIN LOOP ****************** '********** Continuous Cycle ************** '****************************************** looper: 'if glcd_btn =1 then 'Debugging code to check if main loop works 'glcd_btn = 0 'pause 200 'else 'glcd_btn = 1 'pause 200 'endif for gl_l = $f8 to $ff gl_k = gl_l gosub design1 ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $6d glcd_cmd = ADDR_PTR_SET gosub send_2 if glcd_btn = 1 then for gl_i = 0 to 2 lookup gl_i,["OFF"],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next else for gl_i = 0 to 2 lookup gl_i,["ON "],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 next endif pause 200 next if gl_tmp > 9 then gl_tmp = 0 endif ' Set Addr Ptr glcd_msb = $00 glcd_lsb = $5d glcd_cmd = ADDR_PTR_SET gosub send_2 lookup gl_tmp,["0123456789"],glcd_msb glcd_msb = glcd_msb - ASCII_OFFSET glcd_cmd = DATA_WR_INC gosub send_1 gl_tmp = gl_tmp + 1 if gl_old =0 then jmp gl_ad1=$14 gl_ad2=gl_old gosub setadr gl_k = $00 gosub write1 jmp: gl_ad1=$14 gl_ad2=$3b+gl_tmp gl_old =gl_ad2 gosub setadr gl_k = %11111111 gosub write1 goto looper '*********** Keeping on looping forever **** end '******** END OF MAIN PROGRAM **************
