Version 4 SHEET 1 1824 1724 WIRE 944 160 944 144 WIRE 848 256 848 160 WIRE 944 256 944 160 WIRE 944 336 848 336 WIRE 944 368 944 336 WIRE 1152 496 1152 464 WIRE 1152 496 976 496 WIRE 1152 544 1152 496 WIRE -96 608 -96 560 WIRE 32 608 32 560 WIRE 32 608 -96 608 WIRE 208 608 32 608 WIRE 336 608 208 608 WIRE 416 608 336 608 WIRE 496 608 416 608 WIRE 576 608 496 608 WIRE 976 640 976 496 WIRE 208 656 208 608 WIRE 336 656 336 608 WIRE 416 656 416 608 WIRE 656 656 560 656 WIRE 560 688 560 656 WIRE 1152 688 1152 624 WIRE 496 704 496 608 WIRE 512 704 496 704 WIRE 336 752 336 720 WIRE 416 752 416 720 WIRE 976 752 976 720 WIRE 336 768 336 752 WIRE 416 768 416 752 WIRE 512 784 512 752 WIRE 560 784 560 768 WIRE 560 784 512 784 WIRE 512 800 512 784 WIRE 976 880 976 832 WIRE 1152 880 1152 768 WIRE 1152 880 976 880 WIRE 1152 960 1152 880 FLAG -96 480 0 FLAG 32 480 0 FLAG 208 720 0 FLAG 336 848 0 FLAG 416 848 0 FLAG 576 608 x IOPIN 576 608 Out FLAG 1152 464 Vp IOPIN 1152 464 BiDir FLAG 1152 960 Vn IOPIN 1152 960 BiDir FLAG 512 800 0 FLAG 656 656 s IOPIN 656 656 Out FLAG 944 368 0 FLAG 944 160 f_off FLAG 848 160 f_on FLAG 336 752 V_x_off FLAG 416 752 V_x_on FLAG 0 0 V_x_on SYMBOL bi -96 480 R0 WINDOW 3 -97 153 Left 2 SYMATTR Value I=G_on(I(Vc))*f_on(V(x)) SYMATTR InstName B1 SYMBOL bi 32 480 R0 SYMATTR InstName B2 SYMATTR Value I=G_off(I(Vc))*f_off(V(x)) SYMBOL cap 192 656 R0 SYMATTR InstName C1 SYMATTR Value 1 SYMBOL diode 320 656 R0 SYMATTR InstName D1 SYMBOL diode 432 720 R180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D2 SYMBOL voltage 336 752 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 WINDOW 3 -147 72 Left 2 SYMATTR Value {x_off} SYMATTR InstName V1 SYMBOL voltage 416 752 R0 WINDOW 3 24 94 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value {x_on} SYMATTR InstName V2 SYMBOL voltage 1152 672 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName Vc SYMATTR Value 0 SYMBOL bv 1152 528 R0 SYMATTR InstName B4 SYMATTR Value V=cs(I(Vc),V(x)) SYMBOL e 560 672 R0 WINDOW 3 37 48 Left 2 SYMATTR Value {1/x_off} SYMATTR InstName E1 SYMBOL bv 944 240 R0 WINDOW 3 90 60 Left 2 SYMATTR Value V=f_off(V(x)) SYMATTR InstName B5 SYMBOL bv 848 240 R0 WINDOW 3 -187 66 Left 2 SYMATTR Value V=f_on(V(x)) SYMATTR InstName B6 SYMBOL voltage 976 624 R0 WINDOW 3 24 96 Invisible 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V3 SYMATTR Value PULSE(0 1 100n 1f 1f 1u 10u) SYMBOL res 960 736 R0 SYMATTR InstName R1 SYMATTR Value 1 TEXT 24 -32 Left 2 !.param k_off=0.05 i_off=7u alpha_off=3 R_off=100k TEXT 24 0 Left 2 !.param k_on=-0.05 i_on=-7u alpha_on=3 R_on=1k TEXT 24 32 Left 2 !.param w_c=100p a_off=2.8n a_on=0.2n TEXT 24 64 Left 2 !.param x_on=0n x_off=3n TEXT 16 208 Left 2 !.func f_off(w) {exp(-exp( (w-a_off)/w_c))} TEXT 16 240 Left 2 !.func f_on(w) {exp(-exp( -(w-a_on)/w_c))} TEXT 16 280 Left 2 !.func G_off(i) {k_off*(i/i_off-1)**alpha_off*u(i-i_off)} TEXT 16 312 Left 2 !.func G_on(i) {k_on*(i/i_on-1)**alpha_on*u(i_on-i)} TEXT 0 -72 Left 2 ;Use fitting parameter of figure 10 and 12 TEXT 24 96 Left 2 !.param lambda=ln(R_off/R_on) TEXT 16 424 Left 2 !.ic V(x)={x_init} TEXT 24 128 Left 2 !.param x_init=3n TEXT 8 952 Left 2 !.model idealD D(Ron=1f Roff=100G Vfwd=1f) TEXT 416 1016 Left 2 !.tran 0 2u 0 1n TEXT 16 384 Left 2 !.func cs1(i,x) {i*R_on*exp(lambda*(x_off-x)/(x_off-x_on))} TEXT 16 352 Left 2 !.func cs(i,w) {i* ( R_on + (R_off-R_on)*(x_off-w)/(x_off-x_on) ) }
