#include const char* ssid = "FRITZ!Box Fon WLAN 7270"; const char* password = "12345678"; WiFiServer server(80); const unsigned long intervall15 = 900000; //15min unsigned long currentMillis15 = 0; // speicher für 15 min boolean minutena = false; boolean minutenb = false; int tasterPinOn = 4; int tasterPinOff = 12; void setup() { Serial.begin(115200); pinMode(5, OUTPUT); // set the LED pin mode pinMode(tasterPinOn,INPUT); pinMode(tasterPinOff,INPUT); delay(10); digitalWrite(5, HIGH); delay(10); // We start by connecting to a WiFi network Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected."); Serial.println("IP address: "); Serial.println(WiFi.localIP()); server.begin(); } int value = 0; void loop() { WiFiClient client = server.available(); // listen for incoming clients if (client) { // if you get a client, Serial.println("New Client."); // print a message out the serial port String currentLine = ""; // make a String to hold incoming data from the client while (client.connected()) { // loop while the client's connected if (client.available()) { // if there's bytes to read from the client, char c = client.read(); // read a byte, then Serial.write(c); // print it out the serial monitor if (c == '\n') { // if the byte is a newline character // if the current line is blank, you got two newline characters in a row. // that's the end of the client HTTP request, so send a response: if (currentLine.length() == 0) { // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK) // and a content-type so the client knows what's coming, then a blank line: client.println("HTTP/1.1 200 OK"); client.println("Content-type:text/html"); client.println("Connection: close"); client.println(); client.println(""); client.println(""); client.println(""); // lässt alle 5 //sekunden die Seite neu laden client.println(); // the content of the HTTP response follows the header: client.print("
Zirkulation
"); // überschrift fett,unterstrichen und groß client.print(" Zirkulation für 15 min an machen.
"); //link in dem Punkt client.print("
"); // absatz bzw eine zeile frei client.print(" Zirkulation für 10 min an machen.
"); // absatz bzw eine zeile frei client.print(" Zirkulation sofort ausschalten.
"); client.print("
"); if (digitalRead(5)==1) // gibt an im browser ob die Pumpe gerade an oder aus ist {client.print(" Pumpe ist AUS
");} else if (digitalRead(5)==0) {client.print(" Pumpe ist AN
");} client.print("
"); client.print("
"); if (minutena = true){ client.print((millis() - currentMillis15)/1000); // einheit in Sekunden client.print(" von 900 (Pumpe schaltet bei 900 ab.)
");} else if (minutenb = true){ client.print((millis() - currentMillis15)/1000); client.print(" von 600 (Pumpe schaltet bei 600 ab.)
");} // The HTTP response ends with another blank line: client.println(); // break out of the while loop: break; } else { // if you got a newline, then clear currentLine: currentLine = ""; } } else if (c != '\r') { // if you got anything else but a carriage return character, currentLine += c; // add it to the end of the currentLine } // Check to see if the client request was "GET /H" or "GET /L": if (currentLine.endsWith("GET /H")) { digitalWrite(5, LOW); // bei Low schaltet das Relais durch currentMillis15 = millis(); // Zeit gespeichert 15 min minutena = true; } if (currentLine.endsWith("GET /T")) { digitalWrite(5, LOW); // bei Low schaltet das Relais durch currentMillis15 = millis()-300000; // Zeit gespeichert 10 min minutenb = true; } if (currentLine.endsWith("GET /L")) { digitalWrite(5, HIGH); // GET /L turns the LED off currentMillis15 = millis()- intervall15 -1; minutena = false; minutenb = false; } } } // close the connection: client.stop(); Serial.println("Client Disconnected."); } if (digitalRead(tasterPinOn)==HIGH){ // gibt analoge eingabe wieder über den taster digitalWrite(5, LOW); currentMillis15 = millis()-300000; minutenb = true;} if (digitalRead(tasterPinOff)==HIGH){ // gibt analoge eingabe wieder über den taster digitalWrite(5, HIGH); currentMillis15 = millis()- intervall15 -1; minutena = false; minutenb = false; } if (millis() - currentMillis15 > intervall15){ // 15 min warten // turn LED on: digitalWrite(5, HIGH); minutena = false; minutenb = false; } }
